Home » Modeling » OCL » OCL Interpreter in Java (Helios)
OCL Interpreter in Java (Helios) [message #973434] |
Tue, 06 November 2012 05:26  |
I'm trying to run OCL in Java and have been following the OCL Interpreter tutorial provided with Helios. When I try to evaluate my expressions it seems that the context is not being picked up and if I try to navigate through my model eg self.lowerLevel, it does not seem to work either. The code is below and the result of the print is:
Evaluation: org.eclipse.emf.ecore.xmi.impl.XMIResourceImpl@1c10945d uri='file:/Users/Ger/sep12-group6/east-adl-validator/src/process/Timing.xmi'
I had expected it to print the model element associated with the context I set.
Am I missing some steps from my code?
Thanks very much,
Ger
public void doOcl(XMIResource model) {
boolean valid;
OCLExpression<EClassifier> query = null;
try {
// create an OCL instance for Ecore
OCL<?, EClassifier, ?, ?, ?, ?, ?, ?, ?, Constraint, EClass, EObject> ocl;
ResourceSet resourceSet = new ResourceSetImpl();
resourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap().put(Resource.Factory.Registry.DEFAULT_EXTENSION, new XMIResourceFactoryImpl());
resourceSet.getPackageRegistry().put(ElementsPackage.eNS_URI, ElementsPackage.eINSTANCE);
Resource res = resourceSet.createResource(
URI.createFileURI(new File("/Users/Ger/sep12-group6/east-adl-validator/src/process/Timing.xmi").toString()));
try {
res.load(null);
} catch (IOException e) {
e.printStackTrace();
ocl = OCL.newInstance(EcoreEnvironmentFactory.INSTANCE, res);
// create an OCL helper object
OCLHelper<EClassifier, ?, ?, Constraint> helper = ocl
.createOCLHelper();
// set the OCL context classifier
helper.setContext(TimingPackage.Literals.TIMING_CONSTRAINT);
query = helper.createQuery("self");
System.out.println("Evaluation: " + ocl.evaluate(res, query));
// record success
valid = true;
} catch (Exception e) {
// record failure to parse
valid = false;
System.err.println("OCL Error: " + e.getLocalizedMessage());
Re: OCL Interpreter in Java (Helios) [message #973709 is a reply to message #973434] |
Tue, 06 November 2012 10:01   |
You have passed an XMIResource as the context to OCL.evaluate, and in
your example this is what has been returned as self. This usage is
ill-formed compared to the TimingPackage.Literals.TIMING_CONSTRAINT
defined as the type of self. A stronger well-formedness check could have
rejected the bad self, but the behaviour is not wrong.
Ed Willink
On 06/11/2012 13:43, Ger Garrigan wrote:
> Hello,
> Evaluation:
> mailto:org.eclipse.emf.ecore.xmi.impl.XMIResourceImpl@1c10945d
> context I set.
> Thanks very much,
> Ger
> boolean valid;
> try {
> try {
> res.load(null);
> .createOCLHelper();
> query));
> // record success
> valid = true;
> valid = false;
Re: OCL Interpreter in Java (Helios) [message #979209 is a reply to message #977915] |
Sat, 10 November 2012 13:29   |
Hi Ed,
Thanks for the clarification about the printing.
Now this is the context of the tree iterator:
TI DomainModel.EAST_ADL.Timing.impl.TimingImpl@55e552 (shortName: testTiming) (category: <unset>, uuid: <unset>) (name: tim)
TI DomainModel.EAST_ADL.Timing.impl.ExecutionTimeConstraintImpl@123ef32 (shortName: testExecTimeConstraint) (category: <unset>, uuid: <unset>) (name: exec)
TI DomainModel.EAST_ADL.Timing.impl.TimeDurationImpl@2cc04e (shortName: testLowerTimeDuration) (category: <unset>, uuid: <unset>) (name: testLowerTimeDuration) (cseCode: 2, cseCodeFactor: 3, value: 2.0)
TI DomainModel.EAST_ADL.Timing.impl.TimeDurationImpl@54c41 (shortName: testUpperTimeDuration) (category: <unset>, uuid: <unset>) (name: testUpperTimeDuration) (cseCode: 2, cseCodeFactor: 3, value: 1.0)
TI DomainModel.EAST_ADL.Timing.impl.TimeDurationImpl@1d16a7f (shortName: testVariationTimeDuration) (category: <unset>, uuid: <unset>) (name: testVariationTimeDuration) (cseCode: 2, cseCodeFactor: 3, value: 10.0)
What troubles me is that for a query like this "self.lower.value" I get :
TI DomainModel.EAST_ADL.Timing.impl.TimingImpl@1ac44c2 (shortName: testTiming) (category: <unset>, uuid: <unset>) (name: tim)
Evaluation: true
TI DomainModel.EAST_ADL.Timing.impl.ExecutionTimeConstraintImpl@f1468c (shortName: testExecTimeConstraint) (category: <unset>, uuid: <unset>) (name: exec)
Evaluation: false
TI DomainModel.EAST_ADL.Timing.impl.TimeDurationImpl@154bd83 (shortName: testLowerTimeDuration) (category: <unset>, uuid: <unset>) (name: testLowerTimeDuration) (cseCode: 2, cseCodeFactor: 3, value: 2.0)
Evaluation: true
TI DomainModel.EAST_ADL.Timing.impl.TimeDurationImpl@65ea4b(shortName: testUpperTimeDuration) (category: <unset>, uuid: <unset>) (name: testUpperTimeDuration) (cseCode: 2, cseCodeFactor: 3, value: 1.0)
Evaluation: true
TI DomainModel.EAST_ADL.Timing.impl.TimeDurationImpl@f8fdd3 (shortName: testVariationTimeDuration) (category: <unset>, uuid: <unset>) (name: testVariationTimeDuration) (cseCode: 2, cseCodeFactor: 3, value: 10.0)
Evaluation: true
which is correct cause the xmi has Timing as the root,ExecutionTimingConstraint as its child and the three TimingDurations(upper,lower and variation) are children of ExecutionTimingConstraint. So the query validates only for the ExecutionTimingConstraint.
Now if I change the query to "self.lower.value > 0" I get the same result even thought it is clear that in the lower Object the value is 2.0 so it should not validate. That is why I wrongly assumed that it was an issue of the printed formula.
Is there something wrong with my query?How can I get the correct validation?
Thanks in advance.
Paschalis.
[Updated on: Sat, 10 November 2012 13:30] by Moderator
Re: OCL Interpreter in Java (Helios) [message #979966 is a reply to message #979209] |
Sun, 11 November 2012 03:11  |
What you produce is no where near reproducible, so I can only make some
observations.
It's always good to check validation with some bad cases, otherwise you
might not be executing the validation code at all; it's easy for the
registrations to malfunction.
Your query "self.lower.value" seems to return 5 objects which suggests a
collection, so I would hope to see a syntax error from "self.lower.value
> 0". The actual value of the threshold should not affect validation at
all.
Ed Willink
On 10/11/2012 18:29, Paschalis Tsolakidis wrote:
> Hi Ed,
> TI mailto:DomainModel.EAST_ADL.Timing.impl.TimingImpl@55e552
> TI
> mailto:DomainModel.EAST_ADL.Timing.impl.ExecutionTimeConstraintImpl@123ef32
> (name: exec)
> TI mailto:DomainModel.EAST_ADL.Timing.impl.TimeDurationImpl@2cc04e
> TI mailto:DomainModel.EAST_ADL.Timing.impl.TimeDurationImpl@54c41
> TI mailto:DomainModel.EAST_ADL.Timing.impl.TimeDurationImpl@1d16a7f
> 3, value: 10.0)
> TI mailto:DomainModel.EAST_ADL.Timing.impl.TimingImpl@1ac44c2
> Evaluation: true
> TI
> mailto:DomainModel.EAST_ADL.Timing.impl.ExecutionTimeConstraintImpl@f1468c
> (name: exec)
> Evaluation: false
> TI mailto:DomainModel.EAST_ADL.Timing.impl.TimeDurationImpl@154bd83
> Evaluation: true
> TI mailto:DomainModel.EAST_ADL.Timing.impl.TimeDurationImpl@65ea4b
> Evaluation: true
> TI mailto:DomainModel.EAST_ADL.Timing.impl.TimeDurationImpl@f8fdd3
> 3, value: 10.0)
> Evaluation: true
> validation?
> Thanks in advance.
> Paschalis.
Current Time: Sat Jul 19 19:17:03 EDT 2025
Powered by FUDForum. Page generated in 0.04963 seconds
