Home » Eclipse Projects » Eclipse Platform » Juno 3.8 - Invalid property category path: ValidationPropertiesPage
Juno 3.8 - Invalid property category path: ValidationPropertiesPage [message #957663] Thu, 25 October 2012 07:52 Go to next message
Since I installed Juno 3.8 I started getting xml-validation errors.
In particular I got the "No grammar constraints (DTD or XML Schema)
referenced in the document." in the eclipse-generated plugin.xml.
I silenced it turning off specific warning generation.
This doesn't look right, but can live with it.
I also have the following error:
Invalid property category path: ValidationPropertiesPage (bundle:
org.eclipse.wst.xml.ui, propertyPage:
org.eclipse.wst.xml.ui.propertyPage.project.validation)
eclipse.buildId=M20120914-1540
java.version=1.7.0_09
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=it_IT
Command-line arguments: -os win32 -ws win32 -arch x86_64
Which seems correct since in my Window->Preferences->General->
Editors->Structured Text Editors page I can see:
[x] Report problems as you type
ValidationPreferencePage not found
[x] Inform when unsupported content type is in editor
All this seems to point to some mistake in my setup.
Can someone help me solve this?
TiA
Mauro
Re: Juno 3.8 - Invalid property category path: ValidationPropertiesPage [message #976619 is a reply to message #957663] Thu, 08 November 2012 13:19 Go to previous messageGo to next message
Looks like your org.eclipse.wst.validation.ui plug-in is either missing
or not being considered. The category path mentioned is added there.
Nitin Dahyabhai
Eclipse WTP Source Editing and JSDT
IBM Rational
Re: Juno 3.8 - Invalid property category path: ValidationPropertiesPage [message #982033 is a reply to message #957663] Mon, 12 November 2012 17:21 Go to previous messageGo to next message
I have opened a bug. It seems that one of the XML bundles is not capturing dependency on validation.ui bundle.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=394142
Re: Juno 3.8 - Invalid property category path: ValidationPropertiesPage [message #984487 is a reply to message #957663] Wed, 14 November 2012 13:47 Go to previous message
Can you share some information on how you assembled your setup? Juno packages are all based on 4.2, so you would have had to put this together yourself to be on 3.8.
Previous Topic:Question about Java intra-project build order
Next Topic:Eclipse 3.7.5 crash [log file attached]
Current Time: Sat Jul 19 22:04:34 EDT 2025
Powered by FUDForum. Page generated in 0.05127 seconds
