Home » Archived » Visual Editor (VE) » Problems using SWT
Problems using SWT [message #97506] Tue, 12 July 2005 23:26 Go to next message
I've installed the versions of GEF and EMF that are attached to the
current VE build and they seem to be working correctly. My problem is
that whenever I try running one of the SWT smoke test samples, I get the
following stacktrace...
I've made sure to include the SWT library variable (even with JFace
support) on my build path. Not the jars, but the actual library. I am
using Java 1.5, but have set my compile settings to 1.4 for the project.
org.eclipse.swt.SWTException: Unable to load graphics library [GDI+ is
required] (java.lang.NoClassDefFoundError)
at org.eclipse.swt.SWT.error(SWT.java:2942)
at org.eclipse.swt.graphics.Device.checkGDIP(Device.java:175)
at org.eclipse.swt.graphics.GC.initGdip(GC.java:3193)
at org.eclipse.swt.graphics.GC.setAlpha(GC.java:3442)
at org.eclipse.draw2d.SWTGraphics.setAlpha(SWTGraphics.java:912 )
at
org.eclipse.ve.internal.cde.core.OutlineBorder.paint(Outline Border.java:68)
at org.eclipse.draw2d.Figure.paintBorder(Figure.java:1070)
at org.eclipse.draw2d.Figure.paint(Figure.java:1056)
at org.eclipse.draw2d.Figure.paintChildren(Figure.java:1091)
at org.eclipse.draw2d.Figure.paintClientArea(Figure.java:1123)
at org.eclipse.draw2d.Figure.paint(Figure.java:1055)
at
org.eclipse.ve.internal.cde.core.ImageFigure.paintClientArea (ImageFigure.java:112)
at
org.eclipse.draw2d.ScalableFreeformLayeredPane.paintClientAr ea(ScalableFreeformLayeredPane.java:61)
at org.eclipse.draw2d.Figure.paintClientArea(Figure.java:1118)
at org.eclipse.draw2d.Viewport.paintClientArea(Viewport.java:15 6)
at
org.eclipse.draw2d.DeferredUpdateManager.repairDamage(Deferr edUpdateManager.java:225)
at
org.eclipse.draw2d.DeferredUpdateManager.performUpdate(Defer redUpdateManager.java:145)
at
org.eclipse.draw2d.DeferredUpdateManager$UpdateRequest.run(D eferredUpdateManager.java:40)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3057)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2716)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Re: Problems using SWT [message #97520 is a reply to message #97506] Wed, 13 July 2005 00:23 Go to previous messageGo to next message
So I installed all the same plugins for the test pass on my thinkpad which
has JRE 1.5 installed, instead of my home Win2k SP4 machine running JDK
1.5. Everything now works without issue.
One thing I neglected to mention earlier, was that I could run the smoke
test shells as java beans just fine. The problem was that I couldn't look
at them in the VE.
On my win2k box I've also noticed the following trace, which I may have
missed the first time...
!STACK 0
required] (java.lang.UnsatisfiedLinkError:
C:\Download\eclipse\configuration\org.eclipse.osgi\bundles\1 17\1\.cp\swt-gdip-win32-3138.dll:
Can't find dependent libraries)
Re: Problems using SWT [message #97599 is a reply to message #97520] Wed, 13 July 2005 08:08 Go to previous message
After talking with Gili it would seem this is due to alpha blending being
enabled. I'm going to pick up a newer build than the I20050708 and try
again.
Re: Problems using SWT [message #609046 is a reply to message #97506] Wed, 13 July 2005 00:23 Go to previous message
at them in the VE.
!STACK 0
Re: Problems using SWT [message #609051 is a reply to message #97520] Wed, 13 July 2005 08:08 Go to previous message
again.
Previous Topic:SWT menus
Next Topic:Final Test Pass for 1.1
Current Time: Sat Jul 19 20:41:51 EDT 2025
Powered by FUDForum. Page generated in 0.05006 seconds
