Can't make TPTP work on my eclipse [message #97486] |
Tue, 01 May 2007 12:05  |
Originally posted by: Guillaume.Bertrand.sd-partners.com
Hi!
I can't get the Profiler to run on my eclipse platform, even when I follow
the tutorial:
- I create a profiling configuration
- I add a set of classes to include in the profiling
- I run the profiler
- I can see the status bar being updated with events counts and bytes
processed...
and there, nothing appears in the log view or the graphs or anywhere else.
I can't even seem to find the view described in "select your monitor,
right-click and select Open With > Execution Flow"
am I doing something wrong here?
Thanks for your help!
Guillaume.
Re: Can't make TPTP work on my eclipse [message #97849 is a reply to message #97486] |
Sun, 06 May 2007 03:29   |
Guillaume Bertrand wrote:
> Hi!
> follow the tutorial:
> processed...
> else. I can't even seem to find the view described in "select your
> monitor, right-click and select Open With > Execution Flow"
Is the Profiling and Logging perspective available (can be selected from
the menu: Window > Open Perspective > Other...)?
If so, switch to this perspective and open the Profiling Monitor view
(Window > Show View > Other... Profiling and Logging > Profiling Monitor).
If this view is available, you should see a node describing the
application you profile, and you can use it to open any of the relevant
analysis views as described in the documentation.
Probably not :) If the views are not available, you may have a
configuration problem. One common reason is that you didn't install the
EMF plugin. Please make sure that all prerequisites (as described in the
TPTP download page) are properly installed.
HTH,
Asaf
Asaf Yaffe
Eclipse TPTP Committer, JVMTI Profiler
Re: Can't make TPTP work on my eclipse [message #98253 is a reply to message #97849] |
Tue, 08 May 2007 09:14  |
Hi Asaf!
Unfortunately, all the views are present, but they stay empty whatever I
do (oh and EMF is present too)... however, I successfully ran TPTP on
another machine with a brand new installation of Eclipse!
I don't know what is happening with my current version of Eclipse, but I
can see what I need to do next: reinstall everything from scratch!
Thanks anyway!
Guillaume.
FUDForum. Page generated in 0.30502 seconds
