Home » Modeling » OCL » Operation Body Expression
Operation Body Expression [message #972270] Mon, 05 November 2012 08:48 Go to next message
I am trying to use Operation Body Expression as they are defined in the OCL specification at section 7.4.6
I created an example ocl file like this
import '[url]http://www.eclipse.org/uml2/4.0.0/UML[/url]'
package UML
context Operation
	def: class:Class=self.oclAsType(ocl::OclElement)->closure(oclContainer())->select(oclIsTypeOf(Class))->any(true).oclAsType(Class)
	inv testName('this is a test warning'):
		class.name='Test'
endpackage
And validated a simple UML model against it. It works properly.
If I modify the ocl in this way
import 'http://www.eclipse.org/uml2/4.0.0/UML'
package UML
context Operation
		class.name='Test'
context Operation::getContainerClass() : Class
	body: self.oclAsType(ocl::OclElement)->closure(oclContainer())->select(oclIsTypeOf(Class))->any(true).oclAsType(Class)
endpackage
I get an error depicted on the getContainerClass() Operation Declaration saying
Unresolved 'unknown-type' 'getContainerClass'
What am I doing wrong?
[Updated on: Mon, 05 November 2012 08:48] by Moderator
Re: Operation Body Expression [message #972770 is a reply to message #972270] Mon, 05 November 2012 17:08 Go to previous messageGo to next message
Comments below
Not sure which OCL specification.
7.4.6 is nothing to do with Operation Body Expression.
> Quote:
>> package UML
>> context Operation
>> def:
>> class.name='Test'
>> endpackage
No idea why you're going to so much trouble to create an ambiguous
definition of the pre-existing UML property.
You might find selectByType() helpful.
> package UML
> context Operation
> def:
> class.name='Test'
> body:
> endpackage
> Declaration saying Unresolved 'unknown-type' 'getContainerClass'
You are defining a body for a pre-existing operation that is not
pre-existing. Use def to define rather than complement.
Ed Willink
Re: Operation Body Expression [message #972808 is a reply to message #972270] Mon, 05 November 2012 17:45 Go to previous messageGo to next message
Ed there is something I still don't understand
The example in the specification is
context Person::getCurrentSpouse() : Person
pre: self.isMarried = true
body: self.mariages->select( m | m.ended = false ).spouse
and an OCL expression is said may be used to indicate the result of a query operation.
Although I may use a define I'd like to understand why it does not work with an operation. I guess I am not getting what does it mean the operation is pre-existing. My aim was actually to define an operation which did not exist.
[Updated on: Mon, 05 November 2012 17:46] by Moderator
Re: Operation Body Expression [message #973429 is a reply to message #972808] Tue, 06 November 2012 05:19 Go to previous messageGo to next message
A Complete OCL document complements a pre-existing meta-model which may
contain classes, operations and properties. (body:, pre:, post:)
(context anOperation) Incomplete operations may be complemented by
defining a body, pre-conditions and post conditions. (init:, derive:)
(context aProperty) Incomplete properties may be complemented by
defining an initial value, or imposing a derived constraint.
(context aType) types may be complemented/extended by defining
additional operations and properties (def:...)
You are confusing the two syntaxes for operation.
Ed Willink
> query operation. Although I may use a define I'd like to understand
> why it does not work with an operation. I guess I am not getting the
Re: Operation Body Expression [message #973953 is a reply to message #972270] Tue, 06 November 2012 14:02 Go to previous messageGo to next message
yes I misunderstood it.
I thought it was a means to define queries (like queries in MOFM2T). Is there any way to do that?
As far as I understand a def is accessible in the context where it is defined.
I would like instead to define a query accessible from different contexts.
Thank you Ed
Re: Operation Body Expression [message #974072 is a reply to message #973953] Tue, 06 November 2012 15:59 Go to previous messageGo to next message
The additional features should be accessible wherever the Complete OCL
document is loaded.
Ed Willink
On 06/11/2012 19:02, Andrea Sindico wrote:
> yes I misunderstood it. I thought it was a means to define queries
> (like queries in MOFM2T). Is there any way to do that? As far as I
> understand a def is accessible in the context where it is defined. I
> Thank you Ed
Re: Operation Body Expression [message #980059 is a reply to message #972270] Sun, 11 November 2012 05:08 Go to previous message
indeed they are. Thanks Ed now I have got it
Previous Topic:OCL Interpreter in Java (Helios)
Next Topic:OCL Iterator index
Current Time: Sat Jul 19 21:52:32 EDT 2025
Powered by FUDForum. Page generated in 0.04437 seconds
