Duplicate entries / namespace problems [message #870248] |
Mon, 07 May 2012 08:47  |
Hi guys,
i have this grammar:
grammar org.xtext.example.mydsl.MyDsl with org.eclipse.xtext.common.Terminals
generate myDsl "http ://www.xtext.org/example/mydsl/MyDsl"
Model:
(jobfunction += JobFunction)*
JobFunction: name='executeJob'
(statements+=Statement)*
Statement :
TryStatement |
CatchStatement |
DeclarationStatement
enum CatchEnums: NegativeResponseException | NoResponseException
TryStatement : keyword='try' '{'(tryStatements+=Statement)+ '}' ;
CatchStatement : keyword='catch' ((exception=CatchEnums | userException=StringDeclaration) '{'(catchStatements+=Statement)+ '}') ;
DeclarationStatement : Declaration ';'
Declaration : StringNumberBoolDeclaration |
ButtonDeclaration;
StringNumberBoolDeclaration : StringDeclaration | IntDeclaration | FloatDeclaration | BoolDeclaration;
StringDeclaration : type='string' name=ID ('=' exp=Expression)?;
IntDeclaration : type='int' name=ID ('=' exp=Expression)?;
FloatDeclaration : type='float' name=ID ('=' exp=Expression)?;
BoolDeclaration: type='bool' name=ID ('=' exp=Expression)?;
ButtonDeclaration : type='button' name=ID;
Expression : expSingle+=SingleExpression (op+=Operator expSingle+=SingleExpression)*
enum Operator : PLUS='+' |
MINUS='-' |
EQUAL='==' |
NOT='!'
SingleExpression :
( litInt = INT ) |
( litBool = ('true' | 'false') ) |
( invert='!'? var = [Declaration] )
with this simple file:
executeJob ()
try
int bla;
try
int bla;
The error Xtext gives me is : Duplicate Statement bla.
The same text worked with Xtext 1.0. The expected behaviour would be for
Xtext to recognize the try block as a seperate scope. If the variable had been declared
in a higher level than the blocks I would have understood that, but not like that.
Now I already tried to hack together a "workaround" like this:
public Class<? extends INamesAreUniqueValidationHelper> bindINamesAreUniqueValidationHelper() {
return NAUVH.class;
public class NAUVH extends NamesAreUniqueValidationHelper {
private String getLastSeg(URI u) {
return u.segment(u.segmentCount() - 1);
private boolean isInScope(IEObjectDescription descr, IEObjectDescription decl) {
int diff = descr.getEObjectURI().fragment().length()
- decl.getEObjectURI().fragment().length();
String f1 = descr.getEObjectURI().fragment();
String f2 = decl.getEObjectURI().fragment();
int slash1 = f1.lastIndexOf("@");
int slash2 = f2.lastIndexOf("@");
String sub1 = f1.substring(0, Math.max(0, slash1));
String sub2 = f2.substring(0, Math.max(0, slash2));
return sub1.startsWith(sub2);
public void checkUniqueNames(Iterable<IEObjectDescription> descriptions,
ValidationMessageAcceptor acceptor) {
Iterator<IEObjectDescription> iter = descriptions.iterator();
if (!iter.hasNext())
return;
List<IEObjectDescription> decls = new ArrayList<IEObjectDescription>();
while (iter.hasNext()) {
IEObjectDescription descr = iter.next();
for (IEObjectDescription decl : decls) {
// if in scope and name value is identical, print an error!
if (isInScope(descr, decl)
&& descr.getQualifiedName().getLastSegment()
.equals(decl.getQualifiedName().getLastSegment())) {
acceptor.acceptError("Duplicate variable "
+ descr.getQualifiedName().getLastSegment() + " ("
+ descr.getEObjectURI().fragment() + ")",
descr.getEObjectOrProxy(), null, -1, null, "");
decls.add(descr);
CancelIndicator cancelIndicator, ValidationMessageAcceptor acceptor) {
this.checkUniqueNames(descriptions, acceptor);
[Updated on: Mon, 07 May 2012 08:49] by Moderator
Re: Duplicate entries / namespace problems [message #974003 is a reply to message #870248] |
Tue, 06 November 2012 14:51  |
late reply: a simple fix i found for this, perhaps it will be useful for someone :
public class MyNameProvider extends DefaultDeclarativeQualifiedNameProvider {
protected QualifiedName qualifiedName(Statement ele)
if (ele.eContainer() instanceof TryStatement)
if (EcoreUtil2.isAssignableFrom(MyDslPackage.Literals.STRING_NUMBER_BOOL_DECLARATION, ele.eClass()))
StringNumberBoolDeclaration decl = (StringNumberBoolDeclaration) ele;
return QualifiedName.create("try", String.valueOf(NodeModelUtils.findActualNodeFor(ele.eContainer()).getOffset()), decl.getName());
return null;
the only remaining problem: now only duplicates in try-blocks are recognized, so i've got to find another solution to providing a qualifiedname.
[Updated on: Tue, 06 November 2012 14:54] by Moderator
FUDForum. Page generated in 0.04251 seconds
