Home » Archived » Test and Performance Tools Platform (TPTP) » Agent Controller is unavailable under port 10002
Agent Controller is unavailable under port 10002 [message #97019] Wed, 25 April 2007 15:28 Go to next message
I get the Agent Controller is unavailable (...) error. I am using Eclipse
3.3m6, installed tptp a few days ago so it should be quite new.
I'm running Vista Business /w all patches.
Here is a screenshot of the error message:
http://warberg.net/files/tptp_error.jpg
I hope you can help me...
Andreas
Re: Agent Controller is unavailable under port 10002 [message #97039 is a reply to message #97019] Wed, 25 April 2007 22:02 Go to previous messageGo to next message
Hi Andreas,
I would suggest trying the work-around for running the Agent Controller
on Vista:
http://www.eclipse.org/tptp/home/downloads/releasenotes/rele asenotes4_3_0.html#3_AC_20
Paul
"Andreas Warberg" <andreas@warberg.net> wrote in message
news:8e1962421a852c46aedccd15d1340000$1@www.eclipse.org...
> Hi
> Regards
> Andreas
Re: Agent Controller is unavailable under port 10002 [message #97087 is a reply to message #97039] Thu, 26 April 2007 03:40 Go to previous messageGo to next message
All right I found out that you have to install an auxiliary program, the
Agent Controller, by itself.
(Btw why don't you provide a simple, step-by-step, howto setup the system?
This seems to be a general shortcoming for all the eclipse projects I've
seen so far! Weird...)
So I did this but having installed the controller I still get errors, this
time it is:
Error occurred during initialization of VM
Could not find agent library on the library path or in the local
directory: JPIBootLoader
What is the next step?
Thank you.
Andreas
Re: Agent Controller is unavailable under port 10002 [message #97128 is a reply to message #97087] Thu, 26 April 2007 06:39 Go to previous messageGo to next message
Hi Andreas,
TPTP provides all of the necessary support, installation and release
information in the Documentation section at the bottom of each build page.
I would suggest consulting the Installation Guide and Release Notes.
Have you followed the install steps in the Agent Controller's
getting_started.html
( http://dev.eclipse.org/viewcvs/index.cgi/platform/org.eclips e.tptp.platform.agentcontroller/src-native-new/packaging_md/ windows/getting_started.html?root=TPTP_Project&revision= 1.6)?
Paul
news:c37a250d908ab06ac3539c79035a6269$1@www.eclipse.org...
> time it is:
> Thank you.
> Regards
> Andreas
Re: Agent Controller is unavailable under port 10002 [message #97142 is a reply to message #97087] Thu, 26 April 2007 07:03 Go to previous messageGo to next message
Andreas,
I have opened https://bugs.eclipse.org/bugs/show_bug.cgi?id=184203 to
address the usability of our download documentation.
Paul
> time it is:
> Thank you.
> Regards
> Andreas
Re: Agent Controller is unavailable under port 10002 [message #97155 is a reply to message #97128] Thu, 26 April 2007 07:36 Go to previous messageGo to next message
Well actually I just installed the system from Eclipse using the Callisto
discovery site.
In response to the "Are you sure that you need to read this guide? There
is a default for typical users..." found at the release instructions - yes
I do consider myself a typical user ;)
My Eclipse is plain vanilla from Eclipse.org. OEM operating system,
default everything.
I wasn't aware of a need to install an additional "Agent Controller" until
you mentioned it in the last post.
It seems there is quite some configuring to do with the Agent Controller.
I will give it a try when I have some more time.
Thanks for your help.
Andreas
Re: Agent Controller is unavailable under port 10002 [message #97359 is a reply to message #97155] Mon, 30 April 2007 09:00 Go to previous messageGo to next message
Hi Andreas,
All of the supported uses cases in TPTP are supported by the Integrated
Agent Controller which is packaged with TPTP. The user has the choice to
installed and configure the stand-alone Agent Controller.
IF the user opts to install TPTP via the Update Manager, all of the
dependencies are enforced by the TPTP features. However, the user still
needs to consult the product or release documentation of the project they
are installing.
Paul
news:1526a33bbe4a37c924f0e84094c51296$1@www.eclipse.org...
> discovery site.
> default everything.
> Regards
> Andreas
Re: Agent Controller is unavailable under port 10002 [message #97819 is a reply to message #97087] Sun, 06 May 2007 00:19 Go to previous messageGo to next message
Originally posted by: flounder.microsoft.com
I agree with andreas that the feature is confusing, from what I understand
most developers don't need an agent as shouldn't the "integrated agent", or
the "direct connection" be all thats needed for profiling a runtime
instance?
> time it is:
> Thank you.
> Regards
> Andreas
Re: Agent Controller is unavailable under port 10002 [message #97988 is a reply to message #97819] Mon, 07 May 2007 07:14 Go to previous message
Hi John,
Yes, the Integrated Agent Controller is sufficient for all local use
cases (e.g. logging, profiling, test execution, etc.). This is covered in
our product documentation:
http://help.eclipse.org/help32/topic/org.eclipse.tptp.platfo rm.agentcontroller.doc.user/concepts/ac/c_ac_ovr.html
Specific to this problem on Vista, I was under the impression that
Andreas was using the Agent Controller. However, I would suggest following
the analogous work-around for the Integrated Agent Controller:
http://www.eclipse.org/tptp/home/downloads/releasenotes/rele asenotes4_3_0.html#3_AC_19
Also, whenever there is an issue with the Integrated Agent Controller,
we like to verify the symptoms by running the same scenario using the Agent
Controller.
Paul
"John Smith" <flounder@microsoft.com> wrote in message
news:f1jkvv$kgk$1@build.eclipse.org...
>instance?
>> system? This seems to be a general shortcoming for all the eclipse
>> projects I've seen so far! Weird...)
>> this time it is:
>> Thank you.
>> Regards
>> Andreas
Previous Topic:Access controller and integrated access controller woes and some feedback to the owners of this feat
Next Topic:Reading from console view
Current Time: Sat Jul 19 08:45:26 EDT 2025
Powered by FUDForum. Page generated in 0.25543 seconds
