Home » Modeling » TMF (Xtext) » How to speed up serialization
How to speed up serialization [message #972711] Mon, 05 November 2012 16:10 Go to next message
I've working on a graphical editor on top of an Xtext/Xbase-based DSL.
As recommended, the diagram is in XMI-file that is linked to data
objects are in an XtextResource, the latter serialized as text. During
debugging I've only created small models that are serialized fairly
quickly. Now I've implemented creating diagrams for existing DSL files,
and it seems to take forever, even for relatively small files. I've read
that Xtext uses a backtracking serialization algorithm, so I assume
there something about my grammar that results in a lot of trying and
failing. I have a some questions relating to this:
- How can I find out which grammar rules are causing problems?
- Is there a way to customize the Serializer so it makes better choices
concerning which paths to follow?
Hallvard
Re: How to speed up serialization [message #972727 is a reply to message #972711] Mon, 05 November 2012 16:20 Go to previous messageGo to next message
Hi Hallvard,
which serializer do you use? Is it based on the ParseTreeConstructor or
on the Sequencer approach (when in doubt, you may browse the mwe2 file
that generates your language).
Sebastian
Looking for professional support for Xtext, Xtend or Eclipse Modeling?
Am 05.11.12 22:12, schrieb Hallvard Trætteberg:
> Hallvard
Re: How to speed up serialization [message #972772 is a reply to message #972727] Mon, 05 November 2012 17:10 Go to previous messageGo to next message
It seems I'm using the ParseTreeConstructor variant.
Hallvard
Re: How to speed up serialization [message #972782 is a reply to message #972727] Mon, 05 November 2012 17:20 Go to previous messageGo to next message
> Hi Hallvard,
I switched to fragment = serializer.SerializerFragment {} and now it
runs faster! Should have thought of that in the first place.
Hallvard
Re: How to speed up serialization [message #972807 is a reply to message #972782] Mon, 05 November 2012 17:43 Go to previous messageGo to next message
Am 05.11.12 23:20, schrieb Hallvard Trætteberg:
>> Hi Hallvard,
> Hallvard
Thanks for the feedback.
Sebastian
Re: How to speed up serialization [message #972813 is a reply to message #972807] Mon, 05 November 2012 17:50 Go to previous messageGo to next message
>>> Hi Hallvard,
>> Hallvard
Hm. Although it is quicker, it still takes around 15 seconds for a file
that's "small". Still a bit too much, so I still could need some hints for
- how to find out which grammar rules are causing problems?
- a way to customize the Serializer so it makes better choices?
Hallvard
Re: How to speed up serialization [message #973399 is a reply to message #972813] Tue, 06 November 2012 04:47 Go to previous message
Hi Hallvard,
did you try a profiler to see where the time is spent?
Customizing is done via the *Sequencers. Have a look at the
XbaseSemanticSequencer to see how things can be implemented.
Sebastian
Am 05.11.12 23:52, schrieb Hallvard Trætteberg:
>>>> Hi Hallvard,
>>> Hallvard
> Hallvard
Previous Topic:Newline removed when model gets updated
Next Topic:imports 'out of the box'
Current Time: Sat Jul 19 06:28:15 EDT 2025
Powered by FUDForum. Page generated in 0.04969 seconds
