Home » Eclipse Projects » Remote Application Platform (RAP) » Menu&MenuItem
Menu&MenuItem [message #965444] Wed, 31 October 2012 04:33 Go to next message
Hello all,
I have the following code. When a button is pressed a menu with a menuitem is created. When selecting the menuitem an action should be performed.
In rap 1.5.0 & 1.5.1 the action is not performed.
In rap 1.4.0 the code works perfectly.
Should I change this code in some different way for rap 1.5 ?
Thank you.
        final Button menuButton = new Button(parent, SWT.None);
        menuButton.setText("Menu button...");
        menuButton.addSelectionListener(new SelectionAdapter()
            public void widgetSelected(SelectionEvent e)
                final Menu menu = new Menu(addButton.getShell(), SWT.POP_UP);
                addButton.setMenu(menu);
                MenuItem item = new MenuItem(menu, SWT.NONE);
                item.setText("Select all");
                item.addSelectionListener(new SelectionListener()
                        System.out.println("Select all");
                    public void widgetDefaultSelected(SelectionEvent e)
                menu.addMenuListener(new MenuListener()
                    public void menuShown(MenuEvent e)
                    public void menuHidden(MenuEvent e)
                        menu.dispose();
                menu.setLocation(addButton.getShell().getDisplay().map(addButton, null, 0, 0));
                menu.setVisible(true);
Re: Menu&MenuItem [message #965841 is a reply to message #965444] Wed, 31 October 2012 10:48 Go to previous messageGo to next message
I'm not sure what may have changed between 1.4 and 1.5, but you might try creating the menu once instead of creating and disposing each time. It could be that your menuHidden listener fires before the MenuItem selection listener, and so the selection listener never gets called. That is just a guess. Try something like this instead. I tested on 1.5 and it works for me.
		final Menu menu = new Menu(menuButton.getShell(), SWT.POP_UP);
		menuButton.setMenu(menu);
				menu.setLocation(menuButton.getShell().getDisplay().map(menuButton, null, 0, 0));
Hope that helps,
Cole
Re: Menu&MenuItem [message #968517 is a reply to message #965444] Fri, 02 November 2012 10:20 Go to previous messageGo to next message
in RAP 1.5 we changed the event processing order [1] to be as close as
possible to SWT. We changed the order of Hide and Selection events. In
RAP 1.4 the Selection event was fired before the Hide event, in RAP 1.5
is the opposite. As you dispose the menu in the Hide event, Selection
event is not fired, because the MenuItem is disposed too. I've checked
your snippet in SWT and it behaves exactly the same like in RAP - no
Selection event.
[1] 325756: Check RAP events processing order against SWT
https://bugs.eclipse.org/bugs/show_bug.cgi?id=325756
HTH,
Ivan
On 10/31/2012 10:33 AM, bogdan toma wrote:
> Hello all,
> performed.
> Thank you.
> @Override
> SWT.POP_UP);
> menu.dispose();
> null, 0, 0));
Ivan Furnadjiev
Twitter: @EclipseRAP
Re: Menu&MenuItem [message #971155 is a reply to message #968517] Sun, 04 November 2012 11:46 Go to previous message
Thank you. So it was my mistake.
it works like Cole Markham exampled.
Thank you again.
Previous Topic:Deploy problem
Next Topic:Compression of communication in Rap 2.0
Current Time: Sat Jul 19 19:58:27 EDT 2025
Powered by FUDForum. Page generated in 0.05148 seconds
