Home » Archived » Test and Performance Tools Platform (TPTP) » Agent Controller exception on CentOS 4.1
Agent Controller exception on CentOS 4.1 [message #97010] Wed, 25 April 2007 13:27 Go to next message
Originally posted by: davidbbs.stanford.edu
When I start the ACServer I get:
Starting Agent Controller.
Exception in thread "Thread-0" java.lang.NoClassDefFoundError:
org/eclipse/hyades/internal/execution/file/FileServer
ACServer started successfully.
The provided "SampleClient" executable doesn't work.
I tried installing the 3.3M6 build of Eclipse and the latest 4.4 build
of TPTP. (The one with the included ACServer in the Eclipse plugin
directory.)
If I manually run the TimeCollector after starting the ACServer it works.
Any ideas as to why this isn't working? I'm running on a cluster of AMD
64-bit opterons with Java HotSpot(TM) 64-Bit Server VM (build
1.5.0_05-b05, mixed mode).
-David
Re: Agent Controller exception on CentOS 4.1 [message #97048 is a reply to message #97010] Wed, 25 April 2007 22:06 Go to previous messageGo to next message
Hi David,
This appears to be a packaging issue with the Agent Controller. A
couple of questions:
1) Which 4.4 build are you using? I would suggest using the
http://www.eclipse.org/tptp/home/downloads/?buildId=TPTP-4.4 .0-200703270100D
build.
2) Does your install have the <Agent Controller installation
directory> \plugins\org.eclipse.hyades.execution_4.3.0.v200702211436\he xl.jar
JAR?
Paul
"David" <davidbbs@stanford.edu> wrote in message
news:davidbbs-0834A6.10275225042007@news.eclipse.org...
> directory.)
> -David
Re: Agent Controller exception on CentOS 4.1 [message #97114 is a reply to message #97010] Thu, 26 April 2007 06:23 Go to previous messageGo to next message
Hi David,
I opened the bugzilla https://bugs.eclipse.org/bugs/show_bug.cgi?id=184192
to track the deffect with finding of preconfigured agents.
Igor
Re: Agent Controller exception on CentOS 4.1 [message #97201 is a reply to message #97048] Fri, 27 April 2007 12:43 Go to previous messageGo to next message
Paul,
I was using build:
tptp.platform.runtime-TPTP-4.4.0-200704180100
tptp.trace.runtime-TPTP-4.4.0-200704180100
on
eclipse-SDK-3.3M6-linux-gtk-x86_64
I'm not sure this is a packaging issue as I had the same exact
problem when I downloaded the standalone Agent Controller
agntctrl.linux_em64t-TPTP-4.3.1. There was a previous message from
Pranab Dhar earlier in the newsgroup about this issue as well.
The standalone install has:
-rwxr-xr-x 1 davidbbs davidbbs 473830 Feb 22 11:15 hexl.jar
In the plugins directory, but exhibits identical behavior.
The install that I got from the integrated eclipse install (plugin:
org.eclipse.tptp.platform.ac.linux_em64t_4.4.0.v200704180100 ) does not
have hexl.jar in it, but it doesn't have a plugins directory either. I
did not find hexl.jar anywhere in the eclipse plugins directory.
If I try the 200703270100D build as you suggest, does it have the
agent controller packaged as a plugin or do I need to use the standalone
install. I donwnloaded the 200704180100 build because the readme notes
said it had them included and I couldn't get the stand alone agent
controller to work.
-David
In article <f0p1fk$pkg$1@build.eclipse.org>,
"Paul Slauenwhite" <paules@ca.ibm.com> wrote:
> Hi David,
> build.
> JAR?
> Paul
> > directory.)
> > -David
Re: Agent Controller exception on CentOS 4.1 [message #97344 is a reply to message #97201] Mon, 30 April 2007 08:51 Go to previous message
Hi David,
The Integrated Agent Controller uses binaries in the plug-ins packaged
with Eclipse so there would be no plugins directory.
It appears as if the packaging is fine for your stand-alone Agent
Controller. Have you followed the install and configuration instructions in
the Agent Controller's getting_started.html?
Try installing the stand-alone Agent Controller for the 200703270100D
build (separate download).
Paul
news:davidbbs-7067D1.09433727042007@news.eclipse.org...
> Paul,
> I was using build:
> on
> controller to work.
> -David
>> Hi David,
>> build.
>> JAR?
>> Paul
>> > directory.)
>> > works.
>> > -David
Previous Topic:Installing new Agent
Next Topic:who can tell me how to monitor the HPUX machine, thanks!
Current Time: Sat Jul 19 22:31:30 EDT 2025
Powered by FUDForum. Page generated in 0.05048 seconds
