Home » Modeling » OCL » OCL in XText Editor
OCL in XText Editor [message #969881] Sat, 03 November 2012 12:53 Go to next message
I admit I am new to the Complete OCL.
I'd like to use it as a validation means instead of the XText default validation as described in this very nice presentation http://www.slideshare.net/EdWillink/enrich-your-models-with-ocl.
In this way I could exploit the same OCL to perform validation before further QVT/MOFM2T(ACCELEO) transformations.
To this end I have started with an empty .ocl file and I am trying to define the first import.
The problem is that it depicts this error:
Unresolved import 'http:/...' : White spaces are required between publicId and systemId.
What am I doing wrong?
[Updated on: Sat, 03 November 2012 13:07] by Moderator
Re: Eclipse in XText Editor [message #969899 is a reply to message #969881] Sat, 03 November 2012 13:07 Go to previous messageGo to next message
You don;'t provide much to go on...
An import of http:/... is an import of a registered package using its
nsURI. It would appear that this p[ackage is not registered.
If instead you use a platform:/... import then you can reference your
*.ecore or *.uml file.
Have you tried following the Complete OCL tutorial or examining the
Royal and Loyal example?
Ed Willink
On 03/11/2012 16:53, Andrea Sindico wrote:
> I admit I am new to Complete OCL. I'd like to use it as a validation
> define the first import. The problem is that it depicts this error:
Re: Eclipse in XText Editor [message #969914 is a reply to message #969899] Sat, 03 November 2012 13:27 Go to previous messageGo to next message
Hi Ed,
thank for your kind answer.
I have tried the platform:/resource/.. notation importing the Ecore as you suggested and it works.
However I guess I have to import the registered package in order to use it in a secondary Eclipse Application (which also executes the XText editor for the language to validate).
am I right?
Re: Eclipse in XText Editor [message #969974 is a reply to message #969914] Sat, 03 November 2012 14:25 Go to previous messageGo to next message
It is certainly important to use consistent references to ensure that
project/plugin usages are respected.
Unfortunately this is not easy in standalone applications, and a variety
of modeling applications have a variety of inconsistently helpful
workarounds.
You may find org.eclipse.ocl.examples.domain.utilities.ProjectMap helpful.
A couple of recent EMF changes suggest that these difficulties may be
much reduced in Kepler.
Ed Willink
On 03/11/2012 17:27, Andrea Sindico wrote:
> Hi Ed,
> thank for your kind answer. I have tried the platform:/resource/..
> notation importing the Ecore as you suggested and it works. However I
> am I right?
Re: Eclipse in XText Editor [message #970195 is a reply to message #969974] Sat, 03 November 2012 18:51 Go to previous messageGo to next message
Ed, the last line of slide 66 is hidden by a red box.
what is the code to pass the EValidator to the registar?
Thank you
Re: Eclipse in XText Editor [message #970200 is a reply to message #970195] Sat, 03 November 2012 18:58 Go to previous messageGo to next message
OK I guess it was
registrar.register(ePackage, new CompleteOCLEObjectValidator(ePackage,oclUri));
but it says it is deprecated Sad
Re: Eclipse in XText Editor [message #970250 is a reply to message #970200] Sat, 03 November 2012 19:55 Go to previous messageGo to next message
Although deprecated it works fine. The only thing I don't like is that the whole context, in the wrong dsl, is highlighted as error, not just the wrong token. Is there any way to just highlight it?
Re: Eclipse in XText Editor [message #971024 is a reply to message #970200] Sun, 04 November 2012 09:13 Go to previous messageGo to next message
On 03/11/2012 22:58, Andrea Sindico wrote:
> OK I guess it was
> but it says it is deprecated :(
If you look at the deprecated implementation, it is
@Deprecated
public CompleteOCLEObjectValidator(@NonNull EPackage ePackage,
@NonNull URI oclURI) {
this(ePackage, oclURI, null);
so just add a null to make the message go away. Ideally pass a
pre-existing metaModelManager to avoid loading all your meta-models
redundantly to create another metaModelManager.
Ed Willink
Re: Eclipse in XText Editor [message #971033 is a reply to message #970195] Sun, 04 November 2012 09:23 Go to previous messageGo to next message
Seems to be an ODP loading issue. The original is fine at
http://www.eclipse.org/modeling/mdt/ocl/docs/publications/EclipseCon2011Tutorial/EnrichingWithOCL.odp.
Ed Willink
> Thank you
> Regards
Re: Eclipse in XText Editor [message #971038 is a reply to message #970250] Sun, 04 November 2012 09:30 Go to previous message
It's only software; I'm sure it's possible....
Realistically, the API for detecting an error needs to be better. It's
probably possible to get Xtext to show a narrower context. However this
won't happen until I have got all the UML and OCL OCL constraints code
generated and being used live.
I don't understand the "wrong dsl" comment. Perhaps you need to share
some screenshots.
Ed Willink
Previous Topic:Ecore derived attribute's derivation specialization
Next Topic:OCL editor
Current Time: Sat Jul 19 06:41:26 EDT 2025
Powered by FUDForum. Page generated in 0.06182 seconds
