Home » Newcomers » Newcomers » problem with file being "unlocatable "
problem with file being "unlocatable " [message #962992] Mon, 29 October 2012 09:40 Go to next message
I am using Xilinx's SDK to debug a microblaze processor on an FPGA. The software is eclipse underneath and has started giving me lots of issues (occasionally will work, most of the time it barfs though). On the last time it ran, I looked at the log and there was actually a lot of eclipse related error messages (all the same). It boils down that it says that it cannot locate a file that it has no problem opening in the editor. Is something else screwed up?
Here is the beginning snippet of the log:
!SESSION 2012-10-29 08:57:27.112 -----------------------------------------------
eclipse.buildId=Release 14.2 Build SDK_P.28xd
java.version=1.6.0_21
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Command-line arguments:  -os win32 -ws win32 -arch x86_64
!ENTRY org.eclipse.cdt.dsf.ui 2 0 2012-10-29 09:30:49.226
!MESSAGE Unable to locate file: C:/CMU/src/fpga/SCM/ublaze_workspace/peripheral_tests_0/src/testperiph.c
!ENTRY org.eclipse.cdt.dsf.ui 2 0 2012-10-29 09:30:49.233
!ENTRY org.eclipse.cdt.dsf.ui 2 0 2012-10-29 09:30:49.236
!ENTRY org.eclipse.cdt.dsf.ui 2 0 2012-10-29 09:30:49.238
About 20 more of that same message sequence continues after the snippet.
I am running this on a Win7 x64 machine and I downloaded the shared project via a GIT repo (mentioning in case this is something that happens with shared projects since the other person is using Linux). Any help would be greatly appreciated!
Re: problem with file being "unlocatable " [message #967148 is a reply to message #962992] Thu, 01 November 2012 10:30 Go to previous messageGo to next message
Eclipse Webmaster is currently offline Eclipse WebmasterFriend
Do you really think the Eclipse "newcomers" forum will be of any help to
you? :)
You could perhaps try the CDT forum, but I would have guessed the Xilinx
support area would be the best place.
Denis
> The
Re: problem with file being "unlocatable " [message #967419 is a reply to message #967148] Thu, 01 November 2012 14:55 Go to previous messageGo to next message
Denis,
Since I was a newcomer, and it appeared to be an eclipse issue at heart (and I got no help on the Xilinx forums), I figured I would try my luck here. Thanks though.
~Jason
Re: problem with file being "unlocatable " [message #967438 is a reply to message #967419] Thu, 01 November 2012 15:13 Go to previous messageGo to next message
On 11/1/2012 12:55 PM, Jason Matusiak wrote:
> Denis,
> ~Jason
If you tag it carefully on stackoverflow.com, you'll likely get a hit there.
Re: problem with file being "unlocatable " [message #972344 is a reply to message #967438] Mon, 05 November 2012 09:55 Go to previous message
I had forgotten about stackoverflow. I will give that a shot, thanks!
Previous Topic:How to change eclipse typing editor to notepad style?
Next Topic:Setting up CVS Host
Current Time: Sat Jul 19 08:47:49 EDT 2025
Powered by FUDForum. Page generated in 0.07646 seconds
