Home » Archived » Visual Editor (VE) » VE properties tab is empty
VE properties tab is empty [message #96529] Thu, 07 July 2005 10:05 Go to next message
Originally posted by: ath.steinheim.com
When I click on a Shell-Object in the VE-view or the JavaBeans-Tab, the
properties-tab is empty. Instead I get the following errors in the
error-log:
!ENTRY org.eclipse.ui 4 4 2005-07-07 10:45:08.241
!MESSAGE Unhandled event loop exception
!ENTRY org.eclipse.ui 4 0 2005-07-07 10:45:08.241
!MESSAGE Failed to execute runnable (java.lang.ClassCastException:
org.eclipse.emf.ecore.impl.EClassImpl)
!STACK 0
org.eclipse.swt.SWTException: Failed to execute runnable
(java.lang.ClassCastException: org.eclipse.emf.ecore.impl.EClassImpl)
at org.eclipse.swt.SWT.error(SWT.java:2942)
at org.eclipse.swt.SWT.error(SWT.java:2865)
at
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:126)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3057)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2716)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Caused by: java.lang.ClassCastException:
at
org.eclipse.ve.internal.java.core.BeanProxyAdapter.getBeanPr opertyValue(BeanProxyAdapter.java:1373)
at
org.eclipse.ve.internal.java.core.BeanPropertySourceAdapter. getPropertyValue(BeanPropertySourceAdapter.java:93)
at
org.eclipse.ve.internal.swt.WidgetPropertySourceAdapter.getP ropertyValue(WidgetPropertySourceAdapter.java:365)
at
org.eclipse.ve.internal.propertysheet.command.CommandStackPr opertySheetEntry.primGetValues(CommandStackPropertySheetEntr y.java:173)
at
org.eclipse.ve.internal.propertysheet.AbstractPropertySheetE ntry.refreshValues(AbstractPropertySheetEntry.java:892)
at
org.eclipse.ve.internal.propertysheet.AbstractPropertySheetE ntry.refreshChildEntries(AbstractPropertySheetEntry.java:823 )
at
org.eclipse.ve.internal.propertysheet.AbstractPropertySheetE ntry.setValues(AbstractPropertySheetEntry.java:1028)
at
org.eclipse.ui.views.properties.PropertySheetViewer.setInput (PropertySheetViewer.java:875)
at
org.eclipse.ui.views.properties.PropertySheetPage.selectionC hanged(PropertySheetPage.java:392)
at
org.eclipse.ve.internal.propertysheet.EToolsPropertySheetPag e.superSelectionChanged(EToolsPropertySheetPage.java:250)
at
org.eclipse.ve.internal.propertysheet.EToolsPropertySheetPag e.access$2(EToolsPropertySheetPage.java:243)
at
org.eclipse.ve.internal.propertysheet.EToolsPropertySheetPag e$1.run(EToolsPropertySheetPage.java:236)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
... 18 more
Am I doing something wrong, or is it a problem with VE?
Andreas
Re: VE properties tab is empty [message #96545 is a reply to message #96529] Thu, 07 July 2005 10:09 Go to previous messageGo to next message
Sorry, I forgot to post some further informations:
Eclipse Platform
Version: 3.1.0
Build id: I20050627-1435
Eclipse Graphical Editing Framework
Version: 3.1
Build id: 200506300200
Visual Editor
Version: 1.1.0
Build id: 200506301538
Re: VE properties tab is empty [message #96558 is a reply to message #96545] Thu, 07 July 2005 11:08 Go to previous messageGo to next message
We've never seen that and it shouldn't occur. What EMF are you using?
Also try
1) Bring up a VE editor
2) Close the editor
3) Do a Projects->Clean...->Clean all projects
4) Reopen the editor
I'm thinking they may be some old stuff laying around.
> Eclipse Platform
> Version: 3.1.0
> Version: 3.1
> Visual Editor
> Version: 1.1.0
Rich Kulp
Re: VE properties tab is empty [message #96585 is a reply to message #96558] Thu, 07 July 2005 12:08 Go to previous messageGo to next message
Thanks for the quick answer. Project cleanup did not help.
BTW it's a new installation. Just Eclipse and VE.
Eclipse Modeling Framework (EMF)
Version: 2.1.0.I200506230200
When I simply open my project (a simple Shell, currently nothing more), VE
shows up but I get the following message in the error log:
Error 2005-07-07 13:06:05.691 Exception thrown.
at
org.eclipse.emf.ecore.impl.EStructuralFeatureImpl.getSetting Delegate(EStructuralFeatureImpl.java:790)
at
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eSettingDelegate (BasicEObjectImpl.java:822)
at
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eDynamicIsSet(Ba sicEObjectImpl.java:609)
at
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eIsSet(BasicEObj ectImpl.java:600)
at
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveFeatures(XMLS aveImpl.java:951)
at
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveElementID(XML SaveImpl.java:2272)
at
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveElement(XMLSa veImpl.java:889)
at
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveContainedMany (XMLSaveImpl.java:2001)
at
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveFeatures(XMLS aveImpl.java:1221)
at
at
org.eclipse.emf.ecore.xmi.impl.XMISaveImpl.writeTopObjects(X MISaveImpl.java:78)
at
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.traverse(XMLSaveI mpl.java:478)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.save(XMLSaveImpl. java:206)
at
org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doSave(XMLRes ourceImpl.java:193)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(Resour ceImpl.java:893)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(Resour ceImpl.java:813)
at
org.eclipse.ve.internal.java.codegen.util.VEModelCacheUtilit y.doSaveCache(VEModelCacheUtility.java:158)
at
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.doSave(JavaSourceTranslator.java:1349)
at
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or$2.doRun(JavaSourceTranslator.java:917)
at
org.eclipse.ve.internal.java.codegen.util.ReverseParserJob.r un(ReverseParserJob.java:56)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:76)
eclipse.buildId=I20050627-1435
java.version=1.5.0_04
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
Command-line arguments: -os win32 -ws win32 -arch x86
Andreas
Found a fix ... [message #96599 is a reply to message #96585] Thu, 07 July 2005 13:36 Go to previous messageGo to next message
I simply changed the JDK compliance to 1.4 and pointed the active JDK to
1.4.2 instead of 1.5.
Greetings,
Andreas
Re: Found a fix ... [message #96614 is a reply to message #96599] Thu, 07 July 2005 13:40 Go to previous messageGo to next message
Thanks for the info. We are trying to figure how to at least tolerate
1.5 (i.e. ignore the things we don't understand like generics, enums,
and annotations) rather than crashing.
By the way, could you please append the class that was causing the
problem? That way we can test it out on our changes for 1.5 to make sure
it will work.
> Greetings,
> Andreas
Rich Kulp
Re: Found a fix ... [message #96705 is a reply to message #96614] Thu, 07 July 2005 14:48 Go to previous messageGo to next message
Sorry, but I have worked on and can't reproduce the error - even with a
new class. It seems like magic, but I can now switch between JDK 1.4.2 and
1.5...
> it will work.
Re: Found a fix ... [message #97016 is a reply to message #96705] Fri, 08 July 2005 09:47 Go to previous message
> and 1.5...
>> sure it will work.
Did you file defined 1.5 annotation class? see https://bugs.eclipse.org/bugs/show_bug.cgi?id=76944
Re: VE properties tab is empty [message #608986 is a reply to message #96529] Thu, 07 July 2005 10:09 Go to previous message
Eclipse Platform
Version: 3.1.0
Version: 3.1
Visual Editor
Version: 1.1.0
Re: VE properties tab is empty [message #608987 is a reply to message #96545] Thu, 07 July 2005 11:08 Go to previous message
Also try
2) Close the editor
> Eclipse Platform
> Version: 3.1.0
> Version: 3.1
> Visual Editor
> Version: 1.1.0
Rich Kulp
Re: VE properties tab is empty [message #608989 is a reply to message #96558] Thu, 07 July 2005 12:08 Go to previous message
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Andreas
Found a fix ... [message #608990 is a reply to message #96585] Thu, 07 July 2005 13:36 Go to previous message
Greetings,
Andreas
Re: Found a fix ... [message #608991 is a reply to message #96599] Thu, 07 July 2005 13:40 Go to previous message
it will work.
> Greetings,
> Andreas
Rich Kulp
Re: Found a fix ... [message #608997 is a reply to message #96614] Thu, 07 July 2005 14:48 Go to previous message
1.5...
> it will work.
Re: Found a fix ... [message #609012 is a reply to message #96705] Fri, 08 July 2005 09:47 Go to previous message
> and 1.5...
>> sure it will work.
Previous Topic:serializing to XML form
Next Topic:Cannot open visual editor
Current Time: Sat Jul 19 07:05:53 EDT 2025
Powered by FUDForum. Page generated in 0.12085 seconds
