Home » Eclipse Projects » Equinox » Redirect std out inside console
Redirect std out inside console [message #965698] Wed, 31 October 2012 08:48 Go to next message
When executing a command inside the osgi console, I would like std out to be redirected to a file.
Is that supported somehow?
For instance
osgi> ss
will list the state of all bundles.
I would like to redirect its output to a file inside the console itself (output of ss was just an example, I think of more complex third-parties commands).
Re: Redirect std out inside console [message #966695 is a reply to message #965698] Thu, 01 November 2012 02:36 Go to previous messageGo to next message
If you are using Equinox 3.8/Eclipse 4.2, you could try piping to the tac command:
osgi> ss | tac <filename>
You can get a description of this command with "tac -?" or "tac --help".
HTH
Lazar
Re: Redirect std out inside console [message #966716 is a reply to message #966695] Thu, 01 November 2012 03:00 Go to previous message
Great, thanks, that works!
I had to provide a valid/full URI (e.g. file:///d:/tmp/out.txt), but it is ok.
I guess, stdin/stderr are supported in a similar way?
Lazar Kirchev wrote on Thu, 01 November 2012 02:36
HTH
Lazar
Previous Topic:Equinox and Declarative Services Annotations
Next Topic:Log4j in eclipse 4 application
Current Time: Sat Jul 19 15:30:19 EDT 2025
Powered by FUDForum. Page generated in 0.02975 seconds
