Home » Eclipse Projects » Equinox » equinox.security.sample: NoClassDefFoundError: org/eclipse/equinox/security/auth/SecurePlatform
equinox.security.sample: NoClassDefFoundError: org/eclipse/equinox/security/auth/SecurePlatform [message #96247] Thu, 30 August 2007 06:04 Go to next message
Originally posted by: ado.bsiag.com
Hi all
I'm trying to run the sample application from
http://wiki.eclipse.org/index.php?title=Security:_JCA/JAAS_f ramework_contribution#Running_the_sample_application
and I'm running always into a NoClassDefFoundError:
org/eclipse/equinox/security/auth/SecurePlatform exception. I've tried
playing with the classpath and the dependencies with no luck so far. My
attempts aren't helped by the fact that I'm an OSGi and JAAS newbie.
In eclipse I've imported cvsroot/eclipse/equinox-incubator/security/
org.eclipse.equinox.security.boot
org.eclipse.equinox.security.provider
org.eclipse.equinox.security.auth
org.eclipse.equinox.security.ui.default
and
org.eclipse.equinox.security.sample
from CVS. Then I've put the boot.jar into the lib/ folder of the sample
project and put the VM option -Xbootclasspath/a:lib/boot.jar into its
run dialog.
Eclipse doesn't show any errors until you try to run the sample. Then it
says:
java.lang.NoClassDefFoundError:
at
org.eclipse.equinox.security.sample.AuthApplication.run(Auth Application.java:47)
at
at
at java.lang.reflect.Method.invoke(Method.java:585)
at
org.eclipse.equinox.internal.app.EclipseAppContainer.callMet hod(EclipseAppContainer.java:533)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:155)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:363)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:176)
at
at
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 504)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:443)
at org.eclipse.equinox.launcher.Main.run(Main.java:1169)
at org.eclipse.equinox.launcher.Main.main(Main.java:1144)
Any help is very much appreciated.
Yours, Arthur
Re: equinox.security.sample: NoClassDefFoundError: org/eclipse/equinox/security/auth/SecurePlatform [message #96263 is a reply to message #96247] Thu, 30 August 2007 07:12 Go to previous messageGo to next message
Hi, Arthur
I think that the relative path to the boot.jar isn't sufficient because
it is relative to your Eclipse install folder (mine is C:\eclipse_3.3).
You can try to enter the full path to boot.jar to see whether this makes
any difference.
Danail
Arthur wrote:
> Hi all
> and
> run dialog.
> says:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Yours, Arthur
Re: equinox.security.sample: NoClassDefFoundError: org/eclipse/equinox/security/auth/SecurePlatform [message #96276 is a reply to message #96263] Thu, 30 August 2007 07:24 Go to previous message
Hi Danail
Thank you very much for your answer. The full path does the trick. :)
Strangely enough I've done the same for the unit tests in the CVS and
they've run successfully with the relative path.
Thanks again. Arthur.
Danail Nachev wrote:
> Hi, Arthur
> any difference.
> Danail
> Arthur wrote:
>> Hi all
>> and
>> run dialog.
>> says:
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Yours, Arthur
Previous Topic:when bundles are extracted?
Next Topic:Maven Repository
Current Time: Sat Jul 19 11:38:26 EDT 2025
Powered by FUDForum. Page generated in 0.24016 seconds
