Home » Archived » Test and Performance Tools Platform (TPTP) » Concering bug 144950
Concering bug 144950 [message #87809] Fri, 17 November 2006 12:05 Go to next message
I even saw bug 144950, were you are discussing the scalability of the log framework.
In my opinion, the scalability problem exists also for the trace model and the test model.
Arguments for the trace model might be obvious. For the test model, consider a test suite
for replay of larger log files. According to the TPTP ASQ method, you start with
an import of a record (i.e. the log) into a representation of the test model:
This will need a similar amount of memory like the representation in the log model.
Hope, this is helpfully.
Greetings
Holger
BTW: Didn't you solve the problem for the log model by the usage of the EMF database feature CDO?
Re: Concering bug 144950 [message #96125 is a reply to message #87809] Tue, 17 April 2007 07:37 Go to previous messageGo to next message
Hi Holger,
Great news. We are starting to integrate the new service oriented data
management infrastructure
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=169353) with the Test Project
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=177041) to attempt to resolve
these scalability issues.
Paul
"Holger Machens" <machens@informatik.fh-wiesbaden.de> wrote in message
news:ejkq71$qg1$1@utils.eclipse.org...
> Hello,
> framework.
> the test model.
> start with
> model:
> log model.
> Greetings
> Holger
Re: Concering bug 144950 [message #96182 is a reply to message #96125] Tue, 17 April 2007 23:18 Go to previous messageGo to next message
Hi Holger,
In the log case we used our own EMF to RDB mapping framework (which was
build before CDO and Teneo).
That framework is generic and we already enabled it for Test (for execution
results, this function will probably surface in a post 4.4 tech preview)
model and I also did tests with the Trace and Statistical models (although
this will not be part of TPTP 4.4 GA).
The idea of service oriented data management infrastructure (TPTP DMS) is to
provide canned services to cover most TPTP UI/reporting/analysis uses cases
and also allow extensions and customizations for different data domains or
persistence mechanism.
An important feature of the new TPTP DMS is to provide a more flexible in
memory model that would be easy to page in/out and protect the client code
from memory problems (which we hit by using EMF).
Another idea is to use specialized data structures instead of just modeled
POJOs to optimize the data query and retrieval from the underlying data
store.
This DMS framework is inteded to be shared/reused within COSMOS project.
Bug 144950 and it's dependant bugs are intended to make the Test
UI/reporting components scalable by using queries instead of direct
navigation of the model and by using SWT virtual tree/table support combined
with other navigation helpers (we already did this for the Log UI and
partially in some Trace views).
Just having better scalability in the model is not enough we always need to
make sure that the UI/reporting/analysis components will leverage the model
scalability in the right way.
Marius
"Paul Slauenwhite" <paules@ca.ibm.com> wrote in message
news:f02bie$1mi$1@build.eclipse.org...
> Hi Holger,
> Project (https://bugs.eclipse.org/bugs/show_bug.cgi?id=177041) to attempt
> to resolve these scalability issues.
> Paul
>> Hello,
>> framework.
>> and the test model.
>> start with
>> model:
>> log model.
>> Greetings
>> Holger
Re: Concering bug 144950 [message #96514 is a reply to message #96182] Fri, 20 April 2007 10:15 Go to previous message
Hi Paul and Marius,
thanks for your information and clarification!
Very interesting!
Holger
Marius Slavescu schrieb:
> Hi Holger,
> store.
> Regards,
> Marius
>> Hi Holger,
>> Paul
>>> Hello,
>>> framework.
>>> and the test model.
>>> start with
>>> model:
>>> log model.
>>> Greetings
>>> Holger
Previous Topic:assertions http recording / integration with other test system / GEF
Next Topic:Application controlled start/stop profiling within eclipse
Current Time: Sun Jul 20 05:35:00 EDT 2025
Powered by FUDForum. Page generated in 0.05356 seconds
