Home » Eclipse Projects » Remote Application Platform (RAP) » Label text being cutoff when resizing browser or chaging zoom level of browser
Label text being cutoff when resizing browser or chaging zoom level of browser [message #956765] Wed, 24 October 2012 15:47 Go to next message
I have a constant problem of labels being cut off. The final letter is either partly showing, or sometimes the whole label is showing only half. This happens sometimes on normal workflow, switching views, perspectives, but it happens consistently when zooming in and out with the browser, or also when resizing the browser. I have played with calling pack() on labels, or layout'ing composites.
I wonder if this is the only way to handle this, and if there is a way to handle this for the whole application. Or do I have to add a listener to re-layout the whole application on workbench resize, or zoom?
Any advice would be greatly appreciated.
Re: Label text being cutoff when resizing browser or chaging zoom level of browser [message #959404 is a reply to message #956765] Fri, 26 October 2012 13:36 Go to previous message
Hi.
Your problems should not be directly related to SWT layouting. This
glitch is a result of rounding errors by the browser. It is known to
happen when zooming on runtime[1]. However, if the zoom level is 100%
from the start and isn't changed, this should NOT happen. If a simple
resize of the browser results in this, it's likely a bug that should be
reported.
If you can give a snippet or example project to reproduce it, i will
have a look at it.
Greetings,
Tim
[1] https://bugs.eclipse.org/bugs/show_bug.cgi?id=351218
Am 24.10.2012 21:47, schrieb George R Malary:
Tim Buschtöns
Twitter: @EclipseRAP
Previous Topic:FilteredTree not working correctly for custom TreeViewer
Next Topic:New RWT session on browser refresh
Current Time: Sat Jul 19 11:21:00 EDT 2025
Powered by FUDForum. Page generated in 0.25096 seconds
