Home » Eclipse Projects » Remote Application Platform (RAP) » FilteredTree not working correctly for custom TreeViewer
FilteredTree not working correctly for custom TreeViewer [message #955656] Tue, 23 October 2012 20:14 Go to next message
I have a CustomTreeViewer which extends TreeViewer.
In order to use the FilteredTree, I overrode the method doCreateTreeViewer to return my TreeViewer.
PatternFilter filter = new PatternFilter();
FilteredTree tree = new FilteredTree(parent, SWT.MULTI | SWT.H_SCROLL SWT.V_SCROLL, filter, true){
protected TreeViewer doCreateTreeViewer(Composite parent,int style) {
return new CustomTreeViewer (parent, SWT.MULTI | SWT.H_SCROLL | SWT.V_SCROLL);
return tree.getViewer();
This is not working. I know that there is a NotifyingTreeViewer which has been introduced to solve the bug 187200 within the FilteredTree but since this is an inner class, I am not able to extend it.
Appreciate any help in this regard,
Cheers !
Re: FilteredTree not working correctly for custom TreeViewer [message #956038 is a reply to message #955656] Wed, 24 October 2012 03:29 Go to previous messageGo to next message
RAP adopts the workbench as is provided by the Eclipse Platform Project.
If you think the NotifyingTreeViewer should be made public (or whatever
other measures to resolve the problem), please file an enhancement
request against Platform/UI [1].
Please let us know when you filed a bug so that we can adopt the changes
once it got resolved.
HTH
Rüdiger
[1] https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Platform
On 24.10.2012 02:14, Wishwas Mohan wrote:
> @Override
> SWT.V_SCROLL);
> Cheers !
Rüdiger Herrmann
http://codeaffine.com
Re: FilteredTree not working correctly for custom TreeViewer [message #956635 is a reply to message #956038] Wed, 24 October 2012 13:31 Go to previous messageGo to next message
I have added the bug
https://bugs.eclipse.org/bugs/show_bug.cgi?id=392775
In the meanwhile, please do let me know if you know of other reasons why my code might not be working.
Though the custom tree viewer is not extending NotifyingTreeViewer, it should atleast work though with some refresh issues I guess.
Re: FilteredTree not working correctly for custom TreeViewer [message #958028 is a reply to message #956635] Thu, 25 October 2012 13:41 Go to previous messageGo to next message
Did you try to wrap the TreeViewer that you create in doCreateTreeViewer
into a copied version of NotifyingTreeviewer?
If this doesn't help the problem lies probably somewhere else...
> should atleast work though with some refresh issues I guess.--
Rüdiger Herrmann
Re: FilteredTree not working correctly for custom TreeViewer [message #958340 is a reply to message #958028] Thu, 25 October 2012 19:40 Go to previous messageGo to next message
Rüdiger,
If you meant, copying the contents of the NotifyingTreeViewer, that is not possible since the setUseCache method has default visibility.
I am actually using it in a pagebookview. Am not sure if that could be a problem.
I have the tree shown but dont have the filtertext. The filter text is getting created but is not showing up in my view for some reason.
Thanks.
Re: FilteredTree not working correctly for custom TreeViewer [message #958922 is a reply to message #958340] Fri, 26 October 2012 06:13 Go to previous messageGo to next message
On 26.10.2012 01:40, Wishwas Mohan wrote:
> Rüdiger,
from looking at the code it seems that the pattern-filter only uses a
cache if the treeViewer is an instance of NotifyingTreeViewer (see
method createTreeControl). Hence you should be able to create your
custom tree-viewer without having to wrap it into a NotifyingTreeViewer.
> problem.
This seems a different issue altogether. Are you still using a custom
tree-viewer? Does the filter text re-appear if you use the default tree
viewer? Have you made sure that you are correctly layouting the widgets?
> Thanks.--
Rüdiger Herrmann
Re: FilteredTree not working correctly for custom TreeViewer [message #971634 is a reply to message #958922] Sun, 04 November 2012 21:25 Go to previous messageGo to next message
I am sorry I coudnt reply earlier. I was off for a bit. I will be working on it this week and let you know.
Re: FilteredTree not working correctly for custom TreeViewer [message #976967 is a reply to message #971634] Thu, 08 November 2012 19:35 Go to previous messageGo to next message
I tried using the TreeViewer. It does work.
However, the problem is when this is viewed in a PageBookView. In case of a PageBookView, the parent composite needs to be a PageBook. So, When I override the doCreateTreeViewer by creating the TreeViewer with a PageBook as parent, the tree is created. However, the filtertext is not created since the parent composite is different.
I am trying to find the issue.
Please let me know if you have any suggestions on this.
Re: FilteredTree not working correctly for custom TreeViewer [message #982047 is a reply to message #976967] Mon, 12 November 2012 17:38 Go to previous message
Hi Rüdiger,
I think I found the problem. When I create a pagebook view, the control needs to be the pagebook. However, when I create a FilteredTree and get the treeviewer from it, the tree viewer's control is the tree rather than the Pagebook. This was causing the problem. So, I just needed to make sure that I recursively get to the Pagebook which is the parent of the FilteredTree which is actually the parent of the tree to fix the problem.
Thanks a lot for your help.
[Updated on: Mon, 12 November 2012 17:53] by Moderator
Previous Topic:[RWT Standalone] Access Application object at runtime
Next Topic:Label text being cutoff when resizing browser or chaging zoom level of browser
Current Time: Sat Jul 19 11:07:19 EDT 2025
Powered by FUDForum. Page generated in 0.05293 seconds
