Home » Archived » Buckminster » version range substitution in MANIFEST.MF
version range substitution in MANIFEST.MF [message #956921] Wed, 24 October 2012 18:28 Go to next message
I noted that when I create a p2.site with buckminster action, if a
bundle in its MANIFEST.MF has a lowerbound then in the MANIFEST.MF of
the generated jar that version range is kept, but if there is no version
range in the original MANIFEST.MF, then in the generated MANIFEST.MF a
brand new version range is automatically created:
- lowerbound: the version of the required bundle as in the current
target platform, say 1.x.y
- upperbound: the next major version, thus 2.0.0 in this example
is this the normal behavior coming from p2 or somewhere else?
thanks in advance
Lorenzo
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
http://www.myspace.com/supertrouperabba
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
Re: version range substitution in MANIFEST.MF [message #957674 is a reply to message #956921] Thu, 25 October 2012 08:00 Go to previous messageGo to next message
This is the default behaviour. The behaviour can be controlled using
properties. You can find more info on the documentation issue here:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=309147#c2
We have a long backlog on documentation issues currently.
- thomas
On 2012-10-25 00:28, Lorenzo Bettini wrote:
> Hi
> thanks in advance
> Lorenzo
Re: version range substitution in MANIFEST.MF [message #960465 is a reply to message #957674] Sat, 27 October 2012 10:03 Go to previous message
Thanks Thomas
This concerns only required bundles where I haven't made no version
range explicitly, right?
Please, let me check whether I understand:
*pde.match.rule.bundle*
Defines the match rule used for the "Require-Bundle" header.
Default: compatible
*pde.match.rule.bundle.lower*
Defines an additional rule for the lower bound of the ranges generated
Default: equivalent
"The lower match rule enables fine grained control of the lower bound.
This only makes sense if it is set to a rule that is more stringent then
the setting for the main match rule."
since the "lower" rule is more stringent by default, then the generated
ranges will be
1.2.3.abc -> [1.2.0,2.0.0)
right?
However, 1.2.3.abc refers to the version in the target platform.
do you mean that the bucky book is becoming obsolete? Can I help in
some way?
cheers
Lorenzo
> - thomas
>> Hi
>> thanks in advance
>> Lorenzo
Previous Topic:Building product for Eclipse 3.7+
Next Topic:[solved] Can't install emma.headless
Current Time: Sat Jul 19 20:14:32 EDT 2025
Powered by FUDForum. Page generated in 0.04112 seconds
