Home » Archived » Buckminster » Updating with P2 from PDE-built to Buckminster-built product
Updating with P2 from PDE-built to Buckminster-built product [message #955211] Tue, 23 October 2012 12:03 Go to next message
Hi all!
I think we have a similar problem like Mr. Scholz in http://www.eclipse.org/forums/index.php/mv/msg/354684/875978/#msg_875978 with our project.
Our RCP project uses an implementation of the P2 Operations API (UpdateOperation + ProvisioningJob) for updating.
Previous versions have been built via the PDE Export wizard but as our project kept growing, we decided to setup a buildsystem using Buckminster Headless within a Jenkins CI.
The problem now is that the PDE-built products cannot be updated from repositories built with Buckminster. The result of an update request would simply state "nothing to update".
As I was analysing the differences between PDE and Buckminster built repos/products, I noticed that the names of the profiles and root IUs differ.
The projects consists of two products therefor we chose two releng features containing the product definitions and a reference to our main plugin (where the product extension point is defined).
With the following product definition (filename: myAppA.product)
- ID: "" (blank)
- version: "1.0.0.qualifier"
- name: "myAppAProduct"
- product: "myAppA.main.product"
- application: "myAppA.main.application"
... this is what is generated:
1. by PDE export wizard:
1.1 content.xml in repo
<unit id='myAppA.main.product' version='1.0.0.201207181026'>
<update id='myAppA.main.product' range='0.0.0' severity='0'/>
<properties size='3'>
<property name='org.eclipse.equinox.p2.name' value='myAppAProduct'/>
<property name='lineUp' value='true'/>
<property name='org.eclipse.equinox.p2.type.group' value='true'/>
</properties>
<provides size='1'>
<provided namespace='org.eclipse.equinox.p2.iu' name='myAppA.main.product' version='1.0.0.201207181026'/>
</provides>
1.2 profile-file in ./p2/org.eclipse.equinox.p2.engine/profileRegistry/<profilename>/<latest>.profile.gz
Profile name is "profile.profile"
<iuProperties id='myAppA.main.product' version='1.0.0.201207181026'>
<properties size='2'>
<property name='org.eclipse.equinox.p2.internal.inclusion.rules' value='STRICT'/>
<property name='org.eclipse.equinox.p2.type.root' value='true'/>
</properties>
</iuProperties>
<iuProperties id='myAppA.main.product_root.win32.win32.x86' version='1.0.0.201207181026'>
<properties size='1'>
<property name='unzipped|@artifact|/some/path' value='/some/path/myAppA|'/>
</properties>
</iuProperties>
</iusProperties>
2. by Buckminster:
We perform the standard site.p2 action as prerequesite to a rather common create.product action which calls p2's director:
<java jar="${equinox.launcher.jar}" fork="true" failonerror="true">
<arg value="-application" />
<arg value="org.eclipse.equinox.p2.director" />
<arg value="-repository" />
<arg value="${repository}" />
<arg value="-destination" />
<arg value="${destination}" />
<arg value="-profile" />
<arg value="${profile}" />
<arg value="-profileProperties" />
<arg value="org.eclipse.update.install.features=true" />
<arg value="-installIU" />
<arg value="${iu}" />
<arg value="-p2.os" />
<arg value="${target.os}" />
<arg value="-p2.ws" />
<arg value="${target.ws}" />
<arg value="-p2.arch" />
<arg value="${target.arch}" />
<arg value="-roaming" />
<arg value="-consoleLog" />
</java>
Where the iu property is set to myAppA.product.
To stop Buckminster from complaining (about "The installable unit myAppA.product has not been found.") I had to change the ID in the product definition to "myAppA.product".
Now Buckminster builts just fine, but with following differences to the PDE-wizard...
2.1 content.xml in repo
<unit id='myAppA.product' version='3.1.1'>
<update id='myAppA.product' range='0.0.0' severity='0'/>
</properties>
<provides size='1'>
<provided namespace='org.eclipse.equinox.p2.iu' name='myAppA.product' version='3.1.1'/>
</provides>
2.2 profile-file in ./p2/org.eclipse.equinox.p2.engine/profileRegistry/<profilename>/<latest>.profile.gz
<iusProperties size='175'>
<iuProperties id='myAppA.product' version='3.1.1'>
</properties>
</iuProperties>
<iuProperties id='myAppA.product.executable.win32.win32.x86' version='3.1.1'>
<property name='unzipped|@artifact|/path/to/product_built' value='/path/to/product_built/eclipsec.exe|/path/to/product_built/myAppA.exe|'/>
</properties>
</iuProperties>
</iusProperties>
Is there any chance to make Buckminster build just like PDE does?
Any help will be greatly appreciated.
Kind regards,
M. Emmerling
Re: Updating with P2 from PDE-built to Buckminster-built product [message #957425 is a reply to message #955211] Thu, 25 October 2012 04:02 Go to previous messageGo to next message
These seems wrong. This error does not come from Buckminster but rather
from the Eclipse p2 director. There should be no reason to change the
product ID. You need to specify the exact same IU name as in the
content.xml, which should be (also for Buckminster generated sites)
"myAppA.main.product". Try running the p2 directory with that name as IU.
Thorsten
Re: Updating with P2 from PDE-built to Buckminster-built product [message #964355 is a reply to message #957425] Tue, 30 October 2012 09:05 Go to previous message
Hello Thorsten,
thanks to your help I was able to get stuff working by simply using the product ID declared in the product extension point.
Kind regards,
Max
[Updated on: Tue, 30 October 2012 09:06] by Moderator
Previous Topic:[solved] Can't install emma.headless
Next Topic:SVN readerType, headless, No component found
Current Time: Sat Jul 19 18:46:27 EDT 2025
Powered by FUDForum. Page generated in 0.03181 seconds
