Home » Eclipse Projects » Equinox » Equinox and Declarative Services Annotations
Equinox and Declarative Services Annotations [message #956159] Wed, 24 October 2012 05:34 Go to next message
In the OSGi compendium specification (Release 4, Version 4.3) on page 275 annotations are defined as an alternative for the DS XML files. I noticed that the package org.osgi.service.component.annotations which contains those annotations is exported in org.osgi.services (3.3.100) which comes with the latest Equinox SDK.
I was not able to use the annotations with Equinox. Also, there are not dependencies from equinox.ds to org.osgi.service.component.annotations. I think this indicates that it's simply not implemented, right?
Are there any plans to support this or is there a known workaround e.g. using Apache SCR?
Thanks in advance.
Cheers Holger
Re: Equinox and Declarative Services Annotations [message #956195 is a reply to message #956159] Wed, 24 October 2012 06:02 Go to previous messageGo to next message
Hi Holger,
Am 24.10.2012 11:34, schrieb Holger Staudacher:
AFAIK the annotations are not interpret at runtime. They are only useful
for at build time when the XML file is actually generated. DS still
relies on the XML file currently.
There is a contribution in Bugzilla to add such a build processing step
to PDE. But the activity on the bug is not very promising. Do you know
if there is a Tycho/Maven plug-in which can generate the XML?
-Gunnar
Gunnar Wagenknecht
gunnar@xxxxxxxx
http://wagenknecht.org/
Re: Equinox and Declarative Services Annotations [message #956381 is a reply to message #956195] Wed, 24 October 2012 09:11 Go to previous messageGo to next message
Gunnar Wagenknecht wrote on Wed, 24 October 2012 06:02
This is correct. These annotations have only class retention and are not runtime visible annotations. They are for tools to use (like bnd or PDE) to generate the xml when packaging the bundle. DS implementation cannot use the annotations at runtime; they must only use the xml.
Re: Equinox and Declarative Services Annotations [message #956450 is a reply to message #956381] Wed, 24 October 2012 10:11 Go to previous messageGo to next message
Thanks BJ for clarifying.
I know there is some improvement work happening for DS.
Has it been discussed to allow those annotations at runtime and add a
"Service-ComponentClass" header to the manifest? DS could do byte code
scanning to scan those classes for annotations and generate the
component at runtime (without loading the class).
-Gunnar
Gunnar Wagenknecht
gunnar@xxxxxxxx
Re: Equinox and Declarative Services Annotations [message #956499 is a reply to message #956450] Wed, 24 October 2012 11:09 Go to previous messageGo to next message
Thanks for clarifying this. I simply missed the policy.
@Gunnar: I have openend a bug against tycho, see https://bugs.eclipse.org/bugs/show_bug.cgi?id=392764
Re: Equinox and Declarative Services Annotations [message #956764 is a reply to message #956450] Wed, 24 October 2012 15:44 Go to previous message
Gunnar Wagenknecht wrote on Wed, 24 October 2012 10:11
Yes, the idea to support the annotations at runtime has been mentioned for a future spec. Such support would be necessary to allow "inheritance" of annotations so that, for example, @Reference could be used in a super class of the component implementation class.
No actual work has started on this though. The current proposals for the next DS spec update do not include this.
Previous Topic:[SOLVED] ClassLoader problem : How to specify it ?
Next Topic:Redirect std out inside console
Current Time: Sat Jul 19 09:47:06 EDT 2025
Powered by FUDForum. Page generated in 0.04406 seconds
