Home » Language IDEs » C / C++ IDE (CDT) » Building CDT: ILaunchFilter?
Building CDT: ILaunchFilter? [message #95546] Wed, 25 February 2004 17:18 Go to next message
Originally posted by: berg.enea.se
I tried to build CDT as described in the FAQ (i e download HEAD
from CVS) using Eclipse 3.0 M6 (which I managed to build) but I
get a compilation error: The class
org.eclipse.cdt.launch.internal.CApplicationLaunchShortcut does
not compile because "The import org.eclipse.debug.u.ILaunchFilter
cannot be resolved". I did not find any such class in the Eclipse
source. How do I solve this? (Upgrade to Eclipse 3.0 M7? Check out
a particular version of CDT? Something else?)
Thanks in advance
Mårten Berggren
Re: Building CDT: ILaunchFilter? [message #95562 is a reply to message #95546] Wed, 25 February 2004 18:18 Go to previous message
Originally posted by: ddaoust.ca.ibm.com
The code on HEAD has been modified in a way this is no longer compatible
with Eclipse M6. You will need to upgrade to Eclipse M7.
In general the latest version of CDT should be used with the latest version
of eclipse -- sometimes it may work to mix, but it is not recommended.
- Dave
"M
Previous Topic:Make doesn't run automatically anymore
Next Topic:I am a rookie
Current Time: Sat Jul 19 12:42:44 EDT 2025
Powered by FUDForum. Page generated in 0.03230 seconds
