OCL editor [message #954982] |
Tue, 23 October 2012 08:05  |
I am in need of OCL editor. I wrote one editor earlier in java swing and i used following code to get syntax help to provide intellisense.
OCL<?, EClassifier, ?, EStructuralFeature, ?, ?, ?, ?, ?, Constraint, EClass, EObject> ocl;
ocl = OCL.newInstance(EcoreEnvironmentFactory.INSTANCE);
OCLHelper<EClassifier, ?, EStructuralFeature, Constraint> helperC = ocl.createOCLHelper();
helperC.setAttributeContext(eClass, eAttribute);
List<Choice> syntaxHelp = helperC.getSyntaxHelp(ConstraintKind.DERIVATION, text);
Now i am looking for some thing already available in Eclipse. Actually i want user to write OCL statements for derivation of attributes. I want to provide some sort of editor to user containing intellisense.
Any idea?
Re: OCL editor [message #955186 is a reply to message #954982] |
Tue, 23 October 2012 11:33   |
You really aren't trying very hard.
There are four Xtext-based OCL editors described in the OCL
documentation. The Completion Assist is now (Juno) quite good.
Ed Willink
On 23/10/2012 14:05, ModelGeek Mising name wrote:
> Any idea?
> Cheers,
Re: OCL editor [message #965931 is a reply to message #964728] |
Wed, 31 October 2012 12:17   |
Here comes some code again. This is Plugin Project(Indigo updated OCL exmples and editors plugin to rectify the operation overriding bug).
Open it in indigo
org.eclipse.ui,
org.eclipse.core.runtime,
org.eclipse.ocl.examples.xtext.base;bundle-version="3.3.0",
org.eclipse.ocl.examples.xtext.completeocl;bundle-version="3.3.0",
org.eclipse.ocl.examples.xtext.completeocl.ui;bundle-version="3.3.0",
org.eclipse.ocl.examples.xtext.essentialocl;bundle-version="3.3.0",
org.eclipse.ocl.examples.xtext.essentialocl.ui;bundle-version="3.3.0",
org.eclipse.ocl.examples.xtext.oclstdlib;bundle-version="3.3.0",
org.eclipse.ocl.examples.xtext.oclstdlib.ui;bundle-version="3.3.0",
org.eclipse.ocl.examples.xtext.console;bundle-version="3.3.0",
org.apache.log4j;bundle-version="1.2.15"
Above mentioned are dependencies.
open ocltest.product file. Click on "Launch an eclipse application". A new application instance will appear. Use File->open model menu. There will be a dialog after clicking on specified menu. Dialog contains an text editor. Try to type "test.", normally it throws exception.
Thanks alot for such an active support.
Re: OCL editor [message #966154 is a reply to message #965931] |
Wed, 31 October 2012 16:02   |
Cyclic resolution problems were apparent in the Juno QVT editors and
were fixed in M2.
Your configuration is unclear.
3.3.0 implies that you are probably using either M2 or GIT or some
N-build. Your editor seems to work fine using M2 or my current working
configuration (both on Juno 3.8.1).
You don't identify which Indigo service release or how you overcome the
missing Juno dependencies.
So I cannot reproduce your problem.
Ed Willink
On 31/10/2012 16:17, ModelGeek Mising name wrote:
> Open it in indigo
> org.eclipse.ui,
FUDForum. Page generated in 0.07301 seconds
