Home » Archived » Visual Editor (VE) » From JBuilder to Eclipse VE
From JBuilder to Eclipse VE [message #94543] Tue, 21 June 2005 11:49 Go to next message
Originally posted by: skibler.kimoce.com
--------------090809020402020307000109
Hi all,
has anyone stumbled into trying to migrate a Java project from JBuilder
to Eclipse?
I am trying to evaluate the effort in it. If you try to rebuild a
project previously developed with JBuilder into Eclipse, the Visual
Editor simply displays the components side by side without any attempt
to 'put them where you put them before'.
I joined an example of .java file with problem (Attach File -->
KimChar.java). That will tell us if it is the coding pattern or if it
is some other problem.
If any of you has suggestions, thank you in advance!
Gui reprentation JBuilder :
Gui representation Eclipse VE :
Steff.
P.S. : Eclipse log trace is empty.
Content-Type: text/x-java;
name="KimChar.java"
Content-Disposition: inline;
filename="KimChar.java"
package kim.bean.kimchar;
import java.awt.BorderLayout;
import java.awt.Color;
import java.awt.Component;
import java.awt.Dimension;
import java.awt.FlowLayout;
import java.awt.GridLayout;
import java.awt.event.ActionEvent;
import java.util.Vector;
import javax.swing.BorderFactory;
import javax.swing.JLabel;
import javax.swing.JPanel;
import javax.swing.JScrollPane;
import javax.swing.border.Border;
import kim.bean.commonbean.BeanConf;
import kim.bean.kimbutton.KimButton;
import kim.bean.kimconf.KimConf;
import kim.bean.kimconf.KimConfEvent;
import kim.bean.kimconf.KimConfListener;
import kim.bean.kimconf.KimConfTypListener;
import kim.bean.kimlabel.KimLabel;
import kim.bean.kimpanel.KimLFPanel;
import kim.util.KimConst;
import kim.util.client.CommonFunct;
import kim.util.struct.CharHead;
import kim.util.struct.CharTag;
public class KimChar extends JPanel implements BeanConf{
private static final long serialVersionUID = 3256999973420676660L;
private transient Vector charHeadLoadedListeners;
private transient Vector histListeners;
private transient Vector paramChangedListeners;
private transient Vector kimConfListeners;
private int typTrans = -1;
private long inCde = -1;
private Object paramsStruct;
private Vector charHeads = new Vector();
private int currentHeadNum = 0;
private boolean isKimConfTestInput = true;
private boolean isLoaded = false;
private boolean isEnabled = true;
JScrollPane charScl = new JScrollPane();
BorderLayout sclBorderLayOut = new BorderLayout();
JPanel charHeadPnl = new JPanel();
BorderLayout borderLayout1 = new BorderLayout();
BorderLayout borderLayout3 = new BorderLayout();
BorderLayout titleBrdLyt = new BorderLayout();
KimButton nextBtn = new KimButton();
JPanel buttonPnl = new JPanel();
FlowLayout buttonFlwLyt = new FlowLayout();
JPanel charHeadPnl1 = new JPanel();
KimButton prevBtn = new KimButton();
KimLabel charHeadLbl = new KimLabel();
KimLFPanel titlePnl = new KimLFPanel();
GridLayout gridLayout1 = new GridLayout();
GridLayout gridLayout2 = new GridLayout();
GridLayout gridLayout3 = new GridLayout();
Border border1;
Border border2;
Border border3;
JPanel nextBtnPnl = new JPanel();
JPanel prevBtnPnl = new JPanel();
JLabel circleLbl = new JLabel();
JLabel pageLbl = new JLabel();
static {
try {
} catch(Exception e) {
public KimChar() {
try {
jbInit();
e.printStackTrace();
private void jbInit() throws Exception {
border1 = BorderFactory.createEmptyBorder(5,5,5,5);
border2 = BorderFactory.createEmptyBorder(5,5,5,5);
border3 = BorderFactory.createEmptyBorder(0,5,0,5);
this.setLayout(borderLayout3);
charHeadPnl.setLayout(borderLayout1);
titleBrdLyt.setVgap(50);
titleBrdLyt.setHgap(50);
nextBtn.setType(kim.bean.kimbutton.KimButton.CHAR);
nextBtn.setPreferredSize(new Dimension(11, 16));
nextBtnPnl.setPreferredSize(new Dimension(11, 16));
nextBtn.addActionListener(new java.awt.event.ActionListener() {
public void actionPerformed(ActionEvent e) {
currentHeadNum++;
load();
nextBtn.setIcon(CommonFunct.loadImgClass(this, KimConst.Icon.NEXT));
circleLbl.setIcon(CommonFunct.loadImgClass(this, "circle.gif"));
circleLbl.setVisible(false);
nextBtn.setVisible(false);
buttonPnl.setLayout(buttonFlwLyt);
buttonFlwLyt.setHgap(2);
buttonFlwLyt.setVgap(2);
charHeadPnl1.setLayout(gridLayout1);
prevBtn.setType(kim.bean.kimbutton.KimButton.CHAR);
prevBtn.setPreferredSize(new Dimension(11, 16));
prevBtn.setVisible(false);
prevBtn.setIcon(CommonFunct.loadImgClass(this, KimConst.Icon.PREV));
prevBtnPnl.setPreferredSize(new Dimension(11, 16));
prevBtn.addActionListener(new java.awt.event.ActionListener() {
currentHeadNum--;
load();
charHeadLbl.setForeground(Color.white);
charHeadLbl.setPreferredSize(new Dimension(110, 20));
titlePnl.setLayout(titleBrdLyt);
this.setBorder(BorderFactory.createLoweredBevelBorder());
charHeadPnl.setBorder(border1);
charHeadPnl1.setBorder(null);
titlePnl.setBorder(border3);
this.add(charScl, BorderLayout.CENTER);
charScl.setViewportView(charHeadPnl);
this.add(titlePnl, BorderLayout.NORTH);
buttonPnl.setOpaque(false);
pageLbl.setForeground(Color.white);
buttonPnl.add(pageLbl,null);
prevBtnPnl.setOpaque(false);
gridLayout3.setHgap(0);
gridLayout3.setVgap(0);
prevBtnPnl.setLayout(gridLayout3);
prevBtnPnl.add(prevBtn,null);
buttonPnl.add(prevBtnPnl, null);
buttonPnl.setAlignmentX(0);
buttonPnl.setAlignmentY(0);
buttonPnl.add(circleLbl, null);
nextBtnPnl.setOpaque(false);
gridLayout2.setHgap(0);
gridLayout2.setVgap(0);
nextBtnPnl.setLayout(gridLayout2);
nextBtnPnl.add(nextBtn, null);
buttonPnl.add(nextBtnPnl, null);
titlePnl.add(charHeadPnl1, BorderLayout.CENTER);
titlePnl.setOpaque(false);
charHeadPnl1.setOpaque(false);
charHeadPnl1.add(charHeadLbl, null);
titlePnl.add(buttonPnl, BorderLayout.EAST);
public void addHeadChar(CharHead headChar, CharTag[] tags){
if (!headChar.charHeadCnsPnt && !headChar.charHeadMdfPnt){
return;
KimCharHead beanCharHead = new KimCharHead(this);
beanCharHead.setHeadChar(headChar);
for (int i=0; i<tags.length; i++){
beanCharHead.add(tags[i]);
beanCharHead.addCharHistListener(new CharHistListener(){
public void histBtnClicked(CharHistEvent e){
fireCharHist(e);
charHeads.add(beanCharHead);
public void updateCharTag(long charHeadInCde, CharTag[] charTags){
if ((charHeads!=null) && (charHeads.size()>0)){
for (int i=0; i<charHeads.size(); i++){
if (((KimCharHead) charHeads.get(i)).getHeadChar().charHeadInCde==charHeadInCde ){
((KimCharHead) charHeads.get(i)).updateCharTag(charTags);
public void updateComp(){
((KimCharHead) charHeads.get(i)).updateComp();
this.setHeadNum(0);
public void clear(){
currentHeadNum = 0;
isLoaded = false;
this.load();
public boolean isLoaded(){
return isLoaded;
public void load(){
if (charHeads!=null){
nextBtn.setEnabled(charHeads.size()>(currentHeadNum+1));
prevBtn.setEnabled(currentHeadNum>0);
nextBtn.setVisible(charHeads.size()>(currentHeadNum+1));
prevBtn.setVisible(currentHeadNum>0);
if(nextBtn.isEnabled() == false && prevBtn.isEnabled()==false){
}else{
circleLbl.setVisible(true);
if (charHeadPnl.getComponentCount()>0){
charHeadPnl.removeAll();
if (charHeads.size()>0){
charHeadLbl.setText(((KimCharHead) charHeads.get(currentHeadNum)).getHeadChar().charHeadDsc);
pageLbl.setText((currentHeadNum + 1) + "/" + charHeads.size());
((KimCharHead) charHeads.get(currentHeadNum)).load();
isLoaded = true;
charHeadPnl.add((Component) charHeads.get(currentHeadNum), BorderLayout.NORTH);
} else{
charHeadLbl.setText("");
this.updateUI();
this.setEnabled(isEnabled);
public boolean isFldFull(){
if (!((KimCharHead) charHeads.get(i)).isFldFull()){
return false;
return true;
public Vector getFldsNotFull(){
Vector fldsNotFull = new Vector();
for (int j=0; j<((KimCharHead) charHeads.get(i)).getFldsNotFull().size(); j++){
fldsNotFull.addElement(((KimCharHead) charHeads.get(i)).getFldsNotFull().get(j));
return fldsNotFull;
public boolean isEnabled(){
return isEnabled;
public void setEnabled(boolean isEnabled){
this.isEnabled = isEnabled;
((KimCharHead) charHeads.get(i)).setEnabled(isEnabled);
public void setEnabledAt(int rubNum, boolean isEnabled){
if ((charHeads!=null) && (charHeads.size()>rubNum)){
((KimCharHead) charHeads.get(rubNum)).setEnabled(isEnabled);
public void setHeadNum(int currentHeadNum){
this.currentHeadNum = currentHeadNum;
load();
public KimCharHead[] getKimCharHeads(){
KimCharHead[] kimCharHeads = new KimCharHead[charHeads.size()];
charHeads.copyInto(kimCharHeads);
return kimCharHeads;
return null;
public CharTag[] getTags(){
int nbCharTag = 0;
for (int i =0; i<charHeads.size(); i++){
nbCharTag += ((KimCharHead) charHeads.get(i)).getTags().length;
CharTag[] charTags = new CharTag[nbCharTag];
int numChar = 0;
for (int j=0; j<((KimCharHead) charHeads.get(i)).getTags().length;j++){
charTags[numChar] = ((KimCharHead) charHeads.get(i)).getTags()[j];
numChar++;
return charTags;
public void setTypTrans(int typTrans){
this.typTrans = typTrans;
public int getTypTrans(){
return this.typTrans;
public void setInCde(long inCde){
this.inCde = inCde;
public long getInCde(){
return inCde;
public void setParams(Object paramsStruct){
this.paramsStruct = paramsStruct;
public Object getParams(){
return paramsStruct;
public void notifyScrollChange(int scrollPosition){
int sclValue = charScl.getVerticalScrollBar().getValue();
int visibleAmount = charScl.getVerticalScrollBar().getVisibleAmount();
int maximumValue = charScl.getVerticalScrollBar().getMaximum();
scrollPosition += 23;
if (scrollPosition >= (sclValue + visibleAmount)) {
if ((sclValue+visibleAmount) < maximumValue) {
charScl.getVerticalScrollBar().setValue(scrollPosition-visib leAmount);
} else{
charScl.getViewport().getComponent(0).doLayout();
public boolean isKimConfTestInput() {
return this.isKimConfTestInput;
public void setKimConfTestInput(boolean isKimConfTestInput) {
this.isKimConfTestInput = isKimConfTestInput;
public void reinit(){
((KimCharHead) charHeads.get(i)).reinit();
public synchronized void addCharHistListener(CharHistListener l){
Vector v=histListeners==null?new Vector(2):(Vector)histListeners.clone();
if (!v.contains(l)){
v.addElement(l);
histListeners = v;
public synchronized void removeCharHistListener(CharHistListener l){
if (histListeners != null && histListeners!=null){
Vector v = (Vector) histListeners.clone();
v.removeElement(l);
histListeners = v;
private void fireCharHist(CharHistEvent e){
if (histListeners!=null){
Vector listeners = histListeners;
int count = listeners.size();
for (int i = 0; i<count;i++){
CharHistListener myListener = (CharHistListener) listeners.elementAt(i);
myListener.histBtnClicked(e);
public synchronized void addParamChangedListener(ParamChangedListener l){
Vector v=paramChangedListeners==null?new Vector(2):(Vector)paramChangedListeners.clone();
v.addElement(l);
paramChangedListeners = v;
public synchronized void removeParamChangedListener(ParamChangedListener l){
if (paramChangedListeners != null && paramChangedListeners!=null){
Vector v = (Vector) paramChangedListeners.clone();
v.removeElement(l);
public void fireParamChanged(){
fireParamChanged(new ParamChangedEvent(this, this.getInCde(), this.getParams()));
public void fireParamChanged(ParamChangedEvent e){
if (paramChangedListeners!=null){
Vector listeners = paramChangedListeners;
ParamChangedListener myListener = (ParamChangedListener) listeners.elementAt(i);
myListener.paramChanged(e);
public synchronized void addCharHeadLoadedListener(CharHeadLoadedListener l){
Vector v=charHeadLoadedListeners==null?new Vector(2):(Vector)charHeadLoadedListeners.clone();
v.addElement(l);
charHeadLoadedListeners = v;
public synchronized void removeCharHeadLoadedListener(CharHeadLoadedListener l){
if (charHeadLoadedListeners != null && charHeadLoadedListeners!=null){
Vector v = (Vector) charHeadLoadedListeners.clone();
v.removeElement(l);
public void fireCharHeadLoaded(CharHeadLoadedEvent e){
if (charHeadLoadedListeners!=null){
Vector listeners = charHeadLoadedListeners;
CharHeadLoadedListener myListener = (CharHeadLoadedListener) listeners.elementAt(i);
myListener.charHeadLoaded(e);
public synchronized void addKimConfListener(KimConfListener l){
Vector v=kimConfListeners==null?new Vector(2):(Vector)kimConfListeners.clone();
v.addElement(l);
kimConfListeners = v;
public synchronized void removeKimConfListener(KimConfListener l){
if (kimConfListeners != null && kimConfListeners!=null){
Vector v = (Vector) kimConfListeners.clone();
v.removeElement(l);
public void fireKimConf(KimConfEvent e){
if (kimConfListeners!=null){
Vector listeners = kimConfListeners;
KimConfListener myListener = (KimConfListener) listeners.elementAt(i);
if (e.getType()==((KimConfTypListener) myListener).getTypList()){
switch (e.getType()){
case KimConf.TESTACTION:
myListener.testAction(e);
break;
case KimConf.TESTFOCUS:
myListener.testFocus(e);
break;
case KimConf.TESTINPUT:
myListener.testInput(e);
break;
Content-Type: image/jpeg;
name="Eclipse.jpg"
filename="Eclipse.jpg"
/9j/4AAQSkZJRgABAQEASABIAAD/4QAWRXhpZgAATU0AKgAAAAgAAAAAAAD/ /gAXQ3JlYXRl
ZCB3aXRoIFRoZSBHSU1Q/9sAQwAFAwQEBAMFBAQEBQUFBgcMCAcHBwcPCwsJ DBEPEhIRDxER
ExYcFxMUGhURERghGBodHR8fHxMXIiQiHiQcHh8e/9sAQwEFBQUHBgcOCAgO HhQRFB4eHh4e
Hh4eHh4eHh4eHh4eHh4eHh4eHh4eHh4eHh4eHh4eHh4eHh4eHh4eHh4eHh4e /8AAEQgBsgDZ
AwEiAAIRAQMRAf/EABwAAQACAwEBAQAAAAAAAAAAAAAGBwMFCAQCCf/EAFAQ AAEEAQMCAQUI
EAUCAwkBAAIAAQMEBQYREgcTIRQVIjEzFlFVVnSTlLMIFxgjKEFSVJGSo9HS 09TVMkJhceNi
oTREgSQlNzhDhKWxtLX/xAAaAQEBAAMBAQAAAAAAAAAAAAAAAwIEBQEG/8QA MhEAAgEBBQYF
BAEFAQAAAAAAAAECAwQRMXGxEhUhUWGRBUFS0fATFBYigQYyocHx4f/aAAwD AQACEQMRAD8A
tPqJ1AwOiKgnk5DlsyiTw1om3M3Zt/8A0b8W7+Hiyrn7o/DfFfKfOgox1DpS ZLqlcs3GGaOK
60bCQNt2xL/C7fjb1+tXbr7QvTDGZKjgPcriMe2Trzn5ymsvENbt8ff3bcuW zPu2z7LblRo0
IJzg5Nx2nxu4cl14cyKqSnJ3O7jdheVz90fhvivlPnQT7o/DfFfKfOgq31Jp GDGZ69j608du
GvMUYTBs4yMz+Ds7etv9fxr3t00vjPBHNJViGx5K0BuMh945wjkYAEAcyIQl Fy2F2bwbd3IG
PrU/D7DUhGor7mr1x8jUlaa8ZOLxROfuj8N8V8p86CfdH4b4r5T50FXRdP8A PjXCyWAyTQnX
K0Ej1D4lCLM5SM+2zgzELuXqbk3vrK2gxjxvlV/K46hOUXehpTjM88oO24O3 CMhHl/lYyHdn
YvASEnz3XYuvcx+7rFgfdH4b4r5T50E+6Pw3xXynzoKDaq6Z5jA6jlxEmNvS MVuStSlKmYeW
8T4sUbePLfcX2Z3/AMTeta+fQuZgnngnw16KWtt3wOsbFFuBSNyZ29H0AIvH /KLv6mdF4ZYp
K9ah2usncyyfuj8N8V8p86CfdH4b4r5T50FWVPR1q1QvXo4D8npABSyNCZCz kbCIuQi7C77u
7cnFn4uzPvsz5MhoXM46U4shhr1SSOJpzGesYOMbkwMbs7eAuTsO/q3fb1r3 dVjvu/2PvKxZ
P3R+G+K+U+dBPuj8N8V8p86CraDQuZnisSwYa9LHWiGewQVjdooyHmJk7N6I uPpM7+Dt4+pe
D3P/APQ36EXhVjeCfc8+9qltRfZGYU5QAtN5KMSJmcylHYW999t32/2Z1NdK dSsVqXgGNnxT
Tmzu0E1045GZn28WeL39tv8AdlUulejeQ1Zp+pf01fo3r3lT18lQkdoTx4uT 9uUnJ37kZCzu
7i27PuLMbsXGOah0rSxOpLdTC5gMvUqys0GRhieIZnZmdyFuT+DFyZiZ3YuL Ez7Oy03YLJWl
sUm1L5iX+5qwW1NcDqnvZr4Px/00/wCUnezXwfj/AKaf8pVZ0r1/dgMcTqaw UwGX3m2frF3/
AMpf6f6q4hdiZiF2dn8Wdvxri2izzs89iaN2lVjVjtRPB3s18H4/6af8pO9m vg/H/TT/AJS2
CKBU1/ezXwfj/pp/yk72a+D8f9NP+UtgiA1/ezXwfj/pp/yk72a+D8f9NP8A lLYIgNf3s18H
4/6af8pO9mvg/H/TT/lLYIgNf3s18H4/6af8pO9mvg/H/TT/AJS2CIDX97Nf B+P+mn/KTvZr
4Px/00/5S2CICltSYopsxlbYRuReUzkLM27u7GX7lI+o2qWnzZ34MjbnolC7 Qyx0ZYioOOzv
u5MLGJ7lybfZ2Fmd2dhJpTgNPWMuNySrB3XC3Pz9IW23mPb1u3vLZ+4bJ/mP 7QP3rr2qy0rX
RjCc9ngvc51ntNSzVnOML+L9ijKOLnvnLcKnHFBNsYSRvuExO25GH4+D+i7e DeLkz+LOzTvy
upPm8FkLley74UKIVzAR5PHCwdyN23225NIQl6/F2fdnbhOPcNk/zH9oH709 w2T/ADH9oH71
uWVUqFCNJ1L9lXX3/MiFpqVa9aVVQuv8riD0rdSC/UsFXsuMNzETuzCO7tUg eM9vH1u7+H+n
r2Wnv4vG5SEbVw7le/FWjrtHFXGSKTtRjGD8nMXDcRFnbYvFndvXxa0PcNk/ zH9oH709w2T/
ADH9oH71sKtRi71Jd0Qcar4OL7EDOXHTZPNWLFGWWHI5dr0bHGJcGYbDCRC7 7E4lMBcH9EuL
i77OsmpLcN3Tr4ikVhmIK4SkNSOpHIMclmR2eOInFm3njfb8bi7v47Kce4bJ /mP7QP3p7hsn
+Y/tA/evPqUL09pd15Ht1a67ZfYrjBYvFUQychVznqTVK0J15pGA5zaaCSQG cfFhftSbF+Ju
O/i7b7K3ZoHDj6fGSeoMlkbrBjIKbHDMMQuwxxE4kYvHzEi9RCD+PFlNfcNk /wAx/aB+9PcN
k/zH9oH7166tFu9yXdcrjxRqpXKL7EK05dp1syOWyFUYbI3hsE8OPisM8Q8e EMfdJngEGF2F
wffYmb/IKhnuf/6P+yuj3DZP8x/aB+9PcNk/zH9oH71lGvRi21Jd0eOFVq5x fYrfSeY1FpjE
jSwVXH42y9sp7d7j35L4sRdqIxIW7cYg/FxB93d3JiB3Jy0d7EDdy167Dh62 IrTzc4KNeZ5Y
4B4juLE4j4OfMmFmZhZ2FvBmZXJ7hsn+Y/tA/enuGyf5j+0D96nTlZ6ctuMu OZnL60o7Ljwy
KX9z/wD0f9lMtHZqziYho5HuS028AkYXIov9Nm8XH/8AX+3qm3uGyf5j+0D9 6e4bJ/mP7QP3
ry0Ss9ohszku6FL61KV8YvsZ680ViEJoZBkjNuQkL7s7L7Xij0Jl4DeSnFYq G78neGwDM7++
4u7iT/6uzr1DpzWoDxYqZs3qKSEXJ2/14ys2/wDszf7LhVLI4v8AWSf8o6kL SmuMWv4Z9ovn
3P6197H/ADH/ADJ7n9a+9j/mP+ZT+2n07r3M/rx69n7H0i+fc/rX3sf8x/zJ 7n9a+9j/AJj/
AJk+2n07r3H149ez9j6RfPuf1r72P+Y/5k9z+tfex/zH/Mn20+nde4+vHr2f sfSL59z+tfex
/wAx/wAye5/WvvY/5j/mT7afTuvcfXj17P2PpF8+5/WvvY/5j/mT3P6197H/ ADH/ADJ9tPp3
XuPrx69n7Gz6R+wy3yuT66ZTpQXpH7DLfK5Prplp/sqwik6HZaOxEEsJXsYM gGLEJC+Rrbs7
P4Ozt+JbEo7U4x5qOiJwezBvq9WWki5R0h0/6b18BTuai0jgJrmTmEasM1J2 257tBHsHFxKX
jIXMncWFo38OXjD9Z6N0ngs/NTi05h5KZs01OYqET9yEvEX34Mzu3iJbNsxC TfiV7LZaVqtV
Sy06i2oY8O92T4MwrVp0aMa04frL5xz8jt5FwR5m0p8WsL9Ai/hTzNpT4tYX 6BF/Cup+O1fW
jS3rD0s73RcEeZtKfFrC/QIv4U8zaU+LWF+gRfwp+O1fWhvWHpZ3ui4I8zaU +LWF+gRfwp5m
0p8WsL9Ai/hT8dq+tDesPSzvdFwR5m0p8WsL9Ai/hTzNpT4tYX6BF/Cn47V9 aG9Yelne6Lgj
zNpT4tYX6BF/CnmbSnxawv0CL+FPx2r60N6w9LO90XBHmbSnxawv0CL+Faut idMvqzIRlp/E
PCNGqQg9KPiJPJY5OzbbM7sw7v8Aj2b3ljL+n6qaW2uJ6vFINP8AU/QtFwR5 m0p8WsL9Ai/h
TzNpT4tYX6BF/Csvx2r60eb1h6Wd7ouCPM2lPi1hfoEX8KeZtKfFrC/QIv4U /HavrQ3rD0s7
3RcEeZtKfFrC/QIv4Vq9T4nTMeNhKHT+IjJ71MXcKUbO4vZjYm8G9Ts7s7fj Z3ZYz/p+rGLl
trgex8UhJpbJ+haLiXpt0y0lrbOZyGzTelDj4KHYhxtGkLmc5WmJyeWvI7+E AMzNt+P1r0dV
+lWh9EhgbeM8pv8AlmUkpzR38fjjgkAa85E4FFABs4yRg277bs/qXKqUKdO0 qzSn+zdy4efc
3oVJzpOso8ErztJFyPoToRobM6IwGcydjKjPfxNG5P5PTxbC81iGMuEYlT8P SPZmIvUzu7+C
ln2KGEx+mernVrTuJOU6OP8AM8UTzV4IpfSisGTG0ACDuxGTcmbxZmWpKdLa 2FL9sbrvLuWU
amztNcDoxERAQXpH7DLfK5Prplo/stT7fQXNn+Tbxr//AJCut50j9hlvlcn1 0yjX2ZcowfY4
ammIiAY5aBOQjydma9Xfdm3bf/bdv92WxtKNWMn5bOiIxV8Gl11ZGY9UaSzV Chco5jE0q45E
boRT2aQkMQ7iMPammAoSEWAGcW2bhuDkJM71t111Vgr2QpVMZNBYsV5J5JpY ZQlEQkaNxj7o
O4k7G0smwu4j3dt+XJhr+Do51YnNwg09kJSZt3YI6ZPt7/hcXwfSDqoBkB4K 8JC+zs4Umdn9
7/xi2fDLB4R4dbXbKdSbfHg1z/i9mFstNutVn+hKMUuH+DB51H8pv0p51H8p v0rN9qPql8B3
P1aX9Yn2o+qXwHc/Vpf1i+p39Yub7HE3ZaOhh86j+U36U86j+U36Vm+1H1S+ A7n6tL+sT7Uf
VL4Dufq0v6xN/WLm+w3ZaOhh86j+U36U86j+U36Vm+1H1S+A7n6tL+sT7UfV L4Dufq0v6xN/
WLm+w3ZaOhh86j+U36U86j+U36Vm+1H1S+A7n6tL+sT7UfVL4Dufq0v6xN/W Lm+w3ZaOhh86
j+U36U86j+U36Vm+1H1S+A7n6tL+sT7UfVL4Dufq0v6xN/WLm+w3ZaOhh86j +U36Vr4Mkzaj
unu3jUrt6/eOb96232o+qXwHc/Vpf1ixj0d6njZOdsJd5mAg/o0tthcnb/zn /U6wn45Y24tN
8Hy6Mzj4bXSeB8+dR/Kb9KedR/Kb9Kzfaj6pfAdz9Wl/WJ9qPql8B3P1aX9Y s9/WLm+xhuy0
dDD51H8pv0p51H8pv0rN9qPql8B3P1aX9Yn2o+qXwHc/Vpf1ib+sXN9huy0d DD51H8pv0rX5
/JMdGNt2/wDF1n9fvTg6232o+qXwHc/Vpf1ix2OjvU+eNgPCXdmMT8BpesSY m/8AOe+ywq+O
WOUJRTfFcjOHhtdSTdxbn2MFxz939qKTtyx1sSwSM3Lt7ndEpNm8fQEiP/Th v6mXg+yDCnSG
O5VOJ47GcpMBhfjmaUY8dbDwAfSDjvxdy3333bZVxV6UdXKllrNGnnKUzHGf OparwPyjcnAv
QvN6QuRbP625Pt617cv0+65ZmKGHNWdWZaGGXvRRX8nFZjA+JDzYZL7ty4kT b7b7O/vr4+1U
KVfxaFuVW6MWndc+d53aNSdOwys2xxaav4HQmn2gl6MaSpTSgEcuiqbgBTjD 5RMdIY3BjL0W
cQ2Zmffbvu7+C8/2LYBF1g6qQRuzjDU07EzNMMvHjRMePMfRJ2223bw8FQOH 6edccMDhh7er
8cDxxxuNXLRxM4RjxAfRyDeAt4M34m8GVy/YP18xFqnqHPn8jcyGUnDHtalu T92dpIZb1dxk
J5ZHd2eHZvS/wsO3htvzYeHKlaZ2j6m1tcLuPT+PI25WrbpRpbN13nwOoERF tkCC9I/YZb5X
J9dMon9m1/8ALFq7/wCy/wD7YFLOkfsMt8rk+umXi+yY0pldb9FM5pfC1pbN 29JUYY4njY+A
W4Tkce4YA7sAk7M5jvttu26pVxWS0ROlg83qzSaxyN3GYCyWOr0ZpqzRTSDe JhgMzJmAD5Ow
uwxm5/4m9KSP8bbPtHIpIiGRi7tUhhNyd3cw2+9G7uzbu4i4vs3+KMvfVQ5O p9krfGWObQuL
7Mwg00JVaMscjgzMJOMmQJt2YQbw2b0Wf1+KzwfdOAMvd0Rj55JSFzkkiqM7 sLPxHYckzMzc
jfwbd3J99/Dbh0bPa422VWTWw7+3l8zOpUq0HZ1BYrXz/wB/4LURVb+Ev8Qc X81W/uafhL/E
HF/NVv7muwc8tJFVv4S/xBxfzVb+5p+Ev8QcX81W/uaAtJFVv4S/xBxfzVb+ 5p+Ev8QcX81W
/uaAtJFVv4S/xBxfzVb+5p+Ev8QcX81W/uaAtJFVv4S/xBxfzVb+5p+Ev8Qc X81W/uaAtJFV
v4S/xBxfzVb+5p+Ev8QcX81W/uaAtJFVv4S/xBxfzVb+5p+Ev8QcX81W/uaA tJFVv4S/xBxf
zVb+5p+Ev8QcX81W/uaAtJFVv4S/xBxfzVb+5p+Ev8QcX81W/uaAtJFVv4S/ xBxfzVb+5p+E
v8QcX81W/uaAtJQH7ET/AOI3VX5eP/8AoZRav8Jf4g4v5qt/c1K/sV9Ga30z ntZ5TWeDPFyZ
gq8sbvLA4ySPYuzS8Riml4iPlAM3It3/ANfFAXwiIgIL0j9hlvlcn10ynSgv SP2GW+VyfXTK
dKlXFZLRE6WDzerCIimUCLm/7InUGdxmvnGR5q9eGsMlMYi4FLBsznNF/lll CRzYopGMePbd
hYi2mjuqmyGrIdJZarbw0OTs12evSeyFU2cpOD2oWd+40couL8wJ5YmGN4+f KQT0p2y6UoqN
9xX6XBNvgzrJFotAxWoNJUYbtmO1ajYxmmjhaIZTYyYiYGd2Bnfd+LO+2+y3 q3IvaSZIIiL0
BERAEREAREQBERAEREAREQBERAEREAREQEF6R+wy3yuT66ZTpQXpH7DLfK5P rplOlSrisloi
dLB5vVhEWmy+pKGNwFLNzQ3XrXLNKtED1yjlErU8UEfOOTiQbFMLkxMxCzP4 btsplDTa4xNX
KZJo8hiGyNZoYyEZKbzgxiUnjtxdmdt/+65s6pQ5jAagyhZiGwEFyxJIMdyN xq5eAyfjG+7M
PejYmhF3ZnZhAS9F45B64wWUoZzB0M3i5/KKGQrR2qsvAh7kUgsQFsTM7bi7 Ps7M/vr2rTr2
ONb+59StKs6Ur0Qzog2UbpZhHzEdoLTxyFtacnmeN5TeIpOTMXN4+Dvy8d3f fd93UzReLI5S
hj7mNqXJ+1Nk7L1aY8CfuStDJM47s2zfe4ZC3fZvR29bsz7cVspIkz2oo/S1 lp25qIsDBcmK
33ZIQkKnMNaaaPfuQxWHBoZZR4ScowMiHtybs3bPjIF6AiIgCIiAIiIAiIgC IiAIiIAiIgCI
iAIiICC9I/YZb5XJ9dMvd1erSWun1/iUPk9eWvbvRzTBFHPThsRy2oSI3aPj JAEsbtI4xux7
G4i5O3h6R+wy3yuT66ZTpUq4rJaInSweb1Zzz0Z0xiNQ9QZNV4jSMOL0hBev zUIIZKzVWmev
hWjMRqyHBMPdq2TZxcxCWLd+MoNthwPTjUFLB6Zo5jQPnTOVbOm5a2Z7lKTz NWqDQazW7kkr
Sjsde2fGETAu/uzu5mzdGIplCk6OH1be6FYHRGS0Jk6zYujj6WVgmbFWpbgR Q7O9QZZZa7kM
8cJP5QIt23NwbuMO2swOjsvHQwOk753aVnUFbI0MzRuNAcr4KC+csPIoC7Mf GGz5I0ddx4tk
GMfCsIjf6IChtUdN9RZsc3i6mAhpZq9Lm/K9UTSwtHkaduC4FWoUgEVkxiex T3CSNoxap6Ll
wi5ZtV6ZzWsdd+6jNdMrtjD0vN3cwuTPHTS3+1Floy7Yd84X4Fern98MPADc dyZme80QFf3a
GdyvU/DX5NPXaMeJszPPelyIT0LNV4LARtBDz5R2nKaJykeGMmEZo2lMHZpL AREAREQBERAE
REAREQBERAEREAREQBERAEREBBekfsMt8rk+umU6UF6R+wy3yuT66ZTpUq4r JaInSweb1YRE
UygVDa16x5TF64tUqjE2OhsnWjhaKN5JzichlFpC8I5PQIgjIXaQeL9wNzaO +VT/AFF6d6c1
Rq2/dyAWojOSJrQVpu2NpgCNx7jM2/Jtm2MXE9hH0vQHjq2tzUFsO7j8+f8A SlLZv/dXojGq
OpmuKetsYOHltX8XfhiKhWjrw/8AvATFjcxIoxdi25A7cm7LMMxscZE0d+4e WSxiac8pcpJI
AM3223dxZ3dcgjrPUFO0N5rslEmIYWYZDetSsA/B6ktfk0bQ894xIRA9nYSJ pGAz6w0NdHJa
JwWRGMohtY2vOwEzs4sUYls+7M+7b/jZlGxVfqSlxfDn8+cueVWm4KN/mbhE RdAiEREAREQB
ERAEREAREQBERAEREAREQBERAQXpH7DLfK5PrplNLturShGa5ZhrRFLHCJyy MAuchsAAzv8A
5iMhFm9buTM3i6hfSP2GW+VyfXTLD9kDLDB01eaxlPNEMebwxSX+UY+SC2Uq u8u8jODcW9Lc
2cfDxZ23ZUq4rJaInSweb1ZYCKjItb25Lg0b/UzzbpEbNsaes96AecCjholH F3zieoW52Lw7
RxiT+R7b7xyuTA6w6g3tJ5/UeayXmo6tnEU56IY4IvNI2quMlvWDKViduwNi xIPcbjHtI8vd
FhGOZQu2vbq2ZrMNezDNLVlaGwEcjEUJuAmwGzf4S4GBbP47EL+p2WOfG46x KUs9CrLIXrM4
RJ3/ABet2XNQauy1DK54dN9RsZPhbuoJ5J9VX8vRpxzzR43FDFA1lqc1Zydj n+9jCJE1d3Y2
4SMcgymoNSX9MZjN6z1BSrUMTqTTMclUKb1K9YiPDWbEpnOzSiAnJI4jIwED HJ3OXoNF40ni
CztQ9LtA5/KecsrpqrNZfj3HAziCbYeLdwAJhk9HYfTZ/Bhb1C20wjAI4xjj AQAWZhEW2Zmb
1MzKjeuHVU8Xi4s1ozVmFirVMbNkoZp8xWipZohI2avA715itGBQEMkcUkBD 3o257mzhutRa
k6g0LmosTi4fL7+nq2QzQH5OEnnKvJDK+OqdkNjbeZ5o+QFzfzbuTN5SKJJY C8tlFSdHX09D
UtN6/UGHUWia96s+S1JYOm8ETy1cjzryWIIwgARlhx7t4MbFYFnJ2kAVrNC5 6HP68zOfzGsL
o0MljbVXHxY0o289162SzI8a7xA88pwV3gNnqkx+mBFy5Nv6C/0VWdFBwEeq tVBpGbT9jTzx
VDrS6biCHGCbnZ5ROEZGBWxBoXllYmcwKu3bBhZztNAEREAREQBERAEREARE QBERAEREAREQ
EF6R+wy3yuT66ZTpQXpH7DLfK5PrplOlSrisloidLB5vVhERTKBFA9ddTsVp XUEeGkrHcneH
uy9qRt4m8N247cpCZiB3CNjNmMHcWYwctDq7rTVwNzGxw4eHJV7kIWCngv8A o9uR3aF4yePg
byEzszuQgz8eRi5xscJWmlBtOWBmoSd1yxLaXix2LoY+5krdODtTZOy1q4XM n7krQxwsWzvs
33uGMdm2b0d/W7u+LS+Yq6gwFPNUjjkq3A7kJxk5CYO78SZ3Zn2dtn8Wb1rZ Kyd6vRgERF6A
iIgCIiAIiIAiIgCIiAIiIAiIgCIiAIiICC9I/YZb5XJ9dMp0oL0j9hlvlcn1 0ynSpVxWS0RO
lg83qwiIplCjOuvTizqLUsl3C24K89iGKWxHYImEZh5AFiIhZ3CRgFhdtnE2 ZmfZubSVtlMl
Qqvj9NXMdjsrHjZp4IZb0MkfllhpSexEUgn94CQgLaEglA4uBO5sJiPVOTw0 F+35SdmzEfba
N2jcdnZnd29Yv+U6rLXfQuhn7lm1i8/PjHvbPeimrNYjlJnZ+4DMQPGfg3iL /wCIRNmYmJy5
tey1JNuncm2bFOpHgqnFInvTPKQZvROPytaOaKKz3TaOYWY437p7iTM7tuz7 s+zu27eDu3ip
GtLobTdPSWlaOnqEks0NUS3ll25ymZOckhbMzbkZET7Nt4rdLoQV0UmQeIRE WR4EREAREQBE
RAEREAREQBERAEREAREQBERAQXpH7DLfK5PrplIdaZ33O4AsiNXyuY7NanWh eTtic9ieOCJj
PZ3EO5KHImEnYd3YSdmF490j9hlvlcn10yk+qsRHndO3cVI0LFPF95OUDIYZ m9KKVuBgbEBs
Js4GBM4s4kJMxNSrisloidLB5vVkGwfUfUl3XbaLt6NpR5KOzYjtTVcy8teC KGLHTFLyOGMy
3DIMLCwb8wFn2AikjjAdQ9Sam0Jp+9iKfZpBktMw5XIWMq8d3u2ZcfOYDHDA McoFHajAy5Qs
/KVmjYWZinXTXpzS0lNLlLl6bK52eWc5bsk1ghFpgrAYA0800nFxpV/aSSOz iXFxF2Bs0XS/
RUPmwa+Ou14cb5G8FaDK2oq5lU7fk5yxDIwTmDQxMxyiRO0YM7uwszTKGswu t8jV6FaV1Vd7
OTzuTxFCUYZGlArtiWEJJGAK0Esjlx7snGOItmAndhFnIfFS6wR2MEV59PTQ 27FGR8XUllOM
r9+K89CWq3ONihFrB1BaSYQd2ss5AHbkYZBjemOkMdgxwtSHNBSi7Xkoln7x nS7QkAeTSFM5
1/QMgftOHICcX3HwWfHaExmMvafbHyzR4vCS3bkNSaWSeSS7Zct7JTyG8hEw zW2cScmJ7G77
OA7ARjU3Vm1g8Tks/JpqGbCxS5WpQkHIu1me1j4rUkoyxdrjFEXkNhhkGSQv GN3BuRMGfqFr
bUlHqNhNJaZx9KayVmrJM1y48EVqKerlSeIjaGQo+BUANiFncndh9Ft3eTFo LScmUs358T5T
5T3nkqWLEstJimEhmMapk8AHIxyMZiDEXdl3d+4fLxQ9MdIR+VG8Oams2ezy uT5+9Lbi7Pd7
fasHM8sOzTzM/bIdxlMX3YnZwM+FyWZk6s6nwty7DNi62IxluhBHX4FC80l0 JeZ7u8hE8Avv
6LMzCzDuxEUsWmqaYxFXV97VkIXWy16tHVsGV+c4iijfcBaFzeIeLuTs4izs 5yP6zLfcoAiI
gCIiAIiIAiIgCIiAIiIAiIgCIiAIiICC9I/YZb5XJ9dMp0oL0j9hlvlcn10y nSpVxWS0ROlg
83qwvmaQIYTlkd2ABcidmd/Bv9G9a+lG+p+Mt5jQOYx9KeCGc6/JmnF3hlYH YyikZmfeORhc
C8H9Ey8H9Tyk7k2ihmxustNZOuVjG5QLsIm4PJXjOQWJvW24s7b+LeCw6S11 pXVYi+BynlfJ
mdmevLG7iTE4nsYs/AmA3Ev8JcS4u+zrmfTlfMYfK5Gxqyjk4dO+QyVMg2Rd ykniIDbyXlyd
pmB3cxm5OMcbTcjFuRyTXoDQwNXXJTR5LIzZeZ5JQguOAk8Jh98l+9GUU0hG I9yQH2Z2F+Iv
IRS8+nbJylFSSV/l5lpUkr7nf18jodERdEiEREAREQBERAEREAREQBERAERE AREQBERAEREB
BekfsMt8rk+umU6UF6R+wy3yuT66ZbrqDqaPSGmvPk1Oa5EN6lVOKETOTaxa igchABIjIe7y
YBF3Jx4t4vuqVcVktETpYPN6skC8+UgO1jLVaNxY5oTjFy9TO4uzbqDwdUMd JrunplsfdkC5
3Rjmhp2zlgMYsfII2IewzwbjfZyIn4RsA8yYicAaC6m4jM6b0xLlrHZy2Vxt Ge09elO9KvZs
wxyDAU/EoojJ5A4RySMb9yLZneQOUmryh4eoegM5qTBBBSsY+rkKk7WqcpzG 4dxhIeJOwbsx
CZi5N4ty32JmcXg/RfplrPC9RKmUyeNHDYTHd2WOArMUvOQ4ijcImBy4xPzY tn48Xj2HcHYR
k+guumGzWGizWoC0/i8dJRr25bOOzXnCPHPNJDEEN5+zH5LKRziws/JnaOd3 cWjd33+sOpeO
xwY+tiAu2L9vJYqrIMuIt9qsFuzABBPJwYK8zQzc2jlITZyj3F+TMWurJS21 O7iiiqyUXHyZ
YCKM6V1jQzGk9H5u4Hm+bVVaCSnV3KXaWSqVl4ubCzejHHI/J2Fn4++7MvFh uomIy3UC1pOl
Bdm7VZpAuRU5zieUbNyvNFITR8IeB0jZiMmaRy2Dfbx2SZM0REAREQBERAER EAREQBERAERE
AREQBERAEREBBekfsMt8rk+umUh1pgvdFgCxw2vJJgs1rlaZ4+4IT15454nM N2cg7kQchYhd
x3ZiF3Ymj3SP2GW+VyfXTKdKlXFZLRE6WDzerK/xmgcrR1mWsA1DSPLWbLlc Z8aXk5wS1qEV
gIw73IDIsdGQG5mwMZC4SPsS0Gleh2OwORw1lptP3ipRY957tvTsUuReanXg gDyewZu0ERNW
jdw4GQucrjIJEJBb6KZQqbD9JMrHiNN4/NarpXPczWo08YdTElX3ggt0rBtM xTyczPyCEWIe
DDyN3E92YdzqHQOVv5y3Nj9Q0qmJyObx+byNafGlNYOeoVV2GKZpgGMCGnCz sUZuzub77Owj
YCICrA0Pq7GdI4dFnlsZmpaEWMp4exVxxU5KL15YmC5K0liQZyh4BP224Mbw uDs7Hs0nwmi4
9Paio3NO2YaeLixFXD2KE0JzE9er3vJmhleRnjIXnPm5tLzZhZuDs5PLEQBE RAEREAREQBER
AEREAREQBERAEREAREQBERAQXpH7DLfK5PrplOlBekfsMt8rk+umU6VKuKyW iJ0sHm9WERFM
oc3/AGROoM7jNfOMjzV68NYZKYxFwKWDZnOaL/LLKEjmxRSMY8e27CxFtNHd VNkNWQ6Sy1W3
hocnZrs9ek9kKps5ScHtQs79xo5RcX5gTyxMMbx8+Ugn0BrjE1cpkmjyGIbI 1mhjIRkpvODG
JSeO3F2Z23/7rmzqlDmMBqDKFmIbAQXLEkgx3I3Grl4DJ+Mb7sw96NiaEXdm dmEBL0XjkHjW
qMoyk7m732+P/wB6bVG6bS4K7z5nVGgYrUGkqMN2zHatRsYzTRwtEMpsZMRM DO7Azvu/Fnfb
fZb1Qzog2UbpZhHzEdoLTxyFtacnmeN5TeIpOTMXN4+Dvy8d3ffd93UzXWp/ 2I1WERFmAiIg
CIiAIiIAiIgCIiAIiIAiIgCIiAIiICC9I/YZb5XJ9dMp0oL0j9hlvlcn10y9 3V6tJa6fX+JQ
+T15a9u9HNMEUc9OGxHLahIjdo+MkASxu0jjG7HsbiLk7Uq4rJaInSweb1ZL FpsvqShjcBSz
c0N161yzSrRA9co5RK1PFBHzjk4kGxTC5MTMQsz+G7bKkujOmMRqHqDJqvEa RhxekIL1+ahB
DJWaq0z18K0ZiNWQ4Jh7tWybOLmISxbvxlBtsOB6cagpYPTNHMaB86ZyrZ03 LWzPcpSeZq1Q
aDWa3cklaUdjr2z4wiYF392d3M2aZQv/AAWUoZzB0M3i5/KKGQrR2qsvAh7k UgsQFsTM7bi7
Ps7M/vr2qk6OH1be6FYHRGS0Jk6zYujj6WVgmbFWpbgRQ7O9QZZZa7kM8cJP 5QIt23NwbuMO
2swOjsvHQwOk753aVnUFbI0MzRuNAcr4KC+csPIoC7MfGGz5I0ddx4tkGMfC sIiBf68WRylD
H3MbUuT9qbJ2Xq0x4E/claGSZx3Ztm+9wyFu+zejt63ZnpPVHTfUWbHN4upg IaWavS5vyvVE
0sLR5GnbguBVqFIBFZMYnsU9wkjaMWqei5cIuWbVemc1rHXfuozXTK7Yw9Lz d3MLkzx00t/t
RZaMu2HfOF+BXq5/fDDwA3HcmZnAtOlrLTtzURYGC5MVvuyQhIVOYa000e/c hisODQyyjwk5
RgZEPbk3Zu2fGQKv8NLqDJdQ5LOpNGZqKGpZnixFnyikdCpEzGLWdmsPMU0w +HJ4meMZO2LC
zzSS2AgCIiAIiIAiIgCIiAIiIAiIgCIiAIiIAiIgIL0j9hlvlcn10ynSgvSP 2GW+VyfXTKdK
lXFZLRE6WDzerCIimUCKIdXNUz6T0k92lHzvWZmr1eTiwsfEjfdy8PEYyZmd 2YicRcgZ3Mat
w/VnUWc01lxxtixLma1cpYHipByMGNglLyd2c2mhd3d4HJ+b8BY2ciaPXqWm FOew8TNQk47X
kdAoqk+x+1nqfVcM4555Z4YAIYrrtFwsEJCJMzgI83F93c2AG9NgcWOORW2q UqiqR2kYyWy7
giIqHgREQBERAEREAREQBERAEREAREQBERAEREBBekfsMt8rk+umU6UF6R+w y3yuT66ZTS7b
q0oRmuWYa0RSxwicsjALnIbAAM7/AOYjIRZvW7kzN4uqVcVktETpYPN6szIi KZQ0HUPG0cvp
C5jcjXGxVsFEEgO7t/8AVDZ2dvESZ9nYmdnF2Z2dnZnXPOusBDoMYWwVi0Nj NEcc9+1ZMTkO
NgeKs8kXEowIGkdyjdpN4o/8Yg4LqKeGGxEUU8QSxl6wMWJn/H6nWryumNO5 XGz47IYShPVn
FhkjeAW32dnZ2dm3Z2dmdnbxZ2Z2dnZnWraLPKq74u7gUhPZ6rkU19jjq2/l tYXMNemsydqh
JM0Vrc5qkjSQscRSbvzB+YGDu7u7OTsRhx434oto/SWi9GX5KeAo1aN/IRlK QnYKWxNFGTcn
Z5Cc3jApR8G9EXkb1bspSqWek6VNRbvPKklKTaVyCIisYBERAEREAREQBERA EREAREQBERAE
REAREQEF6R+wy3yuT66ZYfsgZYYOmrzWMp5ohjzeGKS/yjHyQWylV3l3kZwb i3pbmzj4eLO2
7LN0j9hlvlcn10ynSpVxWS0ROlg83qymdM9RDoanjPO62pWdEB5fWqaivSVo q+SlYMbJDvYA
QhIxKXIRs0bCztAbOxFERKv8DdyOa0PlMpmdZXaeWylnTGcnqiFSPjXaLClY y4gUTkwRlHMx
G7vXHtGxDuLrqZFMoUzJrLIhqeOtT1v5dZDJYupicTtULz9jZwqPPkuIRtLJ xaa2fcgIIR8m
8R2CRihmoL+psz010Vjs3qH3Qe7PG4nKWRzGOrSV687ZTDjwGKAIecJeWHzA yJ3YAZiH0nLp
lEBQGoMZf6bahwtmiOmceFPG5DI3zwGBHHVwoBkMI9wyheSXmbVgm3IX5OzC wjyYd8GsdUaw
aOrV1o0OIqYy9jMpl2mnrvHXCxmsbLU5SCzMwwsGRrOTPsTVO6e3cjXQyICs 9Wary9mxTPRW
apZPG6rrebMNfpyQTRUL4SG8s4v4tPtA88zgTsLPjnj35zsyzdEWGu2qKE2f ms3otQZKabDy
vAxYwJchakiNgEGlYZwIZWeUiYmdnDYXU5mxdCbOVc3JByv1K01WCXmXoRTF EUg7b7PuUET7
u27cfDbd9/agCIiAIiIAiIgCIiAIiIAiIgCIiAIiIAiIgIL0j9hlvlcn10yn SgvSP2GW+Vyf
XTKdKlXFZLRE6WDzerCIimUCrnUnVvB4XU9rCyxgYVOLWLb2BGOHfdncm25O AkxCUgsQA4Gx
ELgbDYy556o9LL2V1tbt4HJVqcJW++72BIjqSSMJzFFt/jCR33KInZuW7sTe h29a1TqQinTx
v+fP+FKag3+74Eq1L1tpaf1Z5nyGIjjqRCzWbpXHFojcWkduLx7EIxv3Hfk2 4sbRtIQGI2rj
7HldCva4cO9EMnHffbdmfbf/ANVyZFqvEvmMTaLAVbseNqQvj45gIbVmrEzO LvM5sEs0bkx9
mSMWjlbwL0glfqjSs8VrTGKswHzimpQyRls7bi4M7P4/6KdlrurKSvvu+fPl 3tSm4JXq682S
Ii3SQREQBERAEREAREQBERAEREAREQBERAEREBBekfsMt8rk+umU6UF6R+wy 3yuT66ZZ+s13
K4/RMVnCHxv+e8PHEL2SgGTnkqwPGcgiTiBiTgTsJeiT+iXqelXFZLRE6WDz erJmirmv1Az9
zMnpWlpjGFqqtLYa5BNmDCiAQx05CKOw1cpDJxv1theEG3aXx9AXk8WG6uyZ rE381jdLTNi4
pcbWpT2roRlZsZCKkdaMgFjeMRe6zSl6XBhFwaZyIY5lC01qbuBgtXJbT27U RSuzkIOG27Cw
/jF39TMqih6m6n0/qPUeJyOn/OOcs5uQoaVa1eu1KlaHHYxzYJIKckrbnaAt uwIcjk3Jn49z
dXOpOdytO1LjNO3cFWpZvBUpbF8wawXls2NM4HruLuBtFblCTk7cHYODm5F2 sZRUlcwa3U/2
P1DI5ByxWprWLx8lhrJ1iqjMcMnju8EnIe14u7sziTMxGO3AmBrgwmNqYbDU cRj4+1To1461
cPyYwFhFv/RmZQrqz1IDQfblHF+doa9Y7uUjrtZOxVrD6pGGGvKDcmCbi88k AO8ZensxuGHM
9VKuIHIBdw8xW8RLlJcrVhmYpK9KlA07WBd2YJCkCeg7RsTOL29nf71JtjCl Cnfsq68yc5SS
TeBYyKv6mvsrX1njtH6g09SqZa5ZhEno5IrNeOCWtfljNjOGMnPlj5RcODMz GBMZPuLePQ+t
tSal6oZehBj6QYClW7cwy3HaWCWLIZSq8sYtC/d7vkcbuJGDRs3hzffehiWY iifSXJZnK6PO
xqC7DeyMWXylSWeGv2IyaDIWIQ4huXEWCMWZnIn2bxIn3d5YgCIiAIiIAiIg CIiAIiIAiIgC
IiAIiICC9I/YZb5XJ9dMpPqjA4zUuGkxGXimkqSSxTO0NmSvIJxSDLGYyREJ iQmAkzi7Puyj
HSP2GW+VyfXTKdKlXFZLRE6WDzerImfTrSpUYqw18nFLHKcvl0OYuR35HNhY mktjK08gu0cT
OJm7bQxNttGHH2R6L0vFichia+HhrUchLFNNDARRCBxRQxRHFxduyUYV4eDx 8XB4xIdibdSB
FMoQyLpjpCGvJHFDmo5pLJWZLo5+810zKOKMme13u84OMELPHz4P2o323Fnb 22NBaTmwd7CB
ifJKF6zWtSxUrEtbhLXGAYCjeIheLgNWBhaNxZu23vvvJl58leq42hNfvTDB WgHnLITPsA/j
d9vxf6oCKZfpjpDLYtsdkIc1NC9Y6kxef7wy2oCIyeKxK0zHYBnkk4jKRMLG bCzMTs+zr6Xq
nmdR5HLPDlBzcUNMoJoG7YUo43ZqxC7uMgvJLakcnbd2n4vuICvgtcaVbCS5 tsuB4yKE5zth
EZRNGDO5FyYXbZtn3/2Xp0xqrBalh7uGulYZt+YnBJEcbswu4mJixAWxg/Em Z9jF9tnZ1gqk
W7rz253XmtDp1pUaMtYq+TllklCXy6bMXJL8bgxMLR2yleeMWaSVmEDZtppW 22kPlmwGg9M4
GxSsYmrdrzVO9tJ5ysmU/dkklPyhykd7P3yaYx73PgUhuPF3d1JkWZ4abR+m MRpPFy43CBdC
tLZltG1q/PbJ5ZC5SFzmMybkTuTsz7OREXrJ3fcoiAIiIAiIgCIiAIiIAiIg CIiAIiIAiIgI
L0j9hlvlcn10ynSgvSP2GW+VyfXTKdKlXFZLRE6WDzerCIimUCgfXfDZHNaA lixu0stexHMV
RzcGtt4j22LduJs5DIBbttJHG/INuYzxeHO1JruMkrwODSOQE3N3ZvRNi9bM /vKdWO1Bx5o9
i7mmcpafbI43H5ttYDl4cdd4BBJI4QXLNsDjeGx99cY45InYReY+IGT123d+ MY2Z9jVj8Fjr
l6DG3Z5r4wkNqCUOy1ePuMUIxxMRCMb8jdiF3Fyc2Z2YGjj2HVXpvn9R0a9z HtjTu0glDyaW
R3C3BLx7sLu4szO/AXbluLuPEmZn5Drvseun+rtN6mu5bUNcsfSjpnSpVZbI TzOJSAe5GDlu
I9t+LuXJ2kfkzuPIubRo1IVYrZ/Vefz29jYnKM4OTf7cvL586l4IiLrGsERE AREQBERAEREA
REQBERAEREAREQBERAQXpH7DLfK5PrplLc3lKGFxc2SyU/ZrRcWd2AjIiImE AABZyMyJxEQF
nIiJhFnd2ZRLpH7DLfK5PrplIdbYT3RaYt4bs4Wbyjh6GXxvl9R+JiXpwcw5 /wCHw9Jti2fx
22elXFZLRE6WDzerPFDrrT81jH1oxzRWb+zx1/Md1pYBKQoxOwHa5VgIgPic zAJMBuzuwu7V
z0+632s/ZxFG9jdP+V2YsYM9armH85Snbp1rBTQ0Xjd3rxvZfkby7jHDKfjw 2eWaX0Hm9NZC
nexurPLJpK0NXLnlq0107EUdiecRgkKwxxbPamBnlKd2AYmfdwJz02kOkmVw OPrYGTVdK1gA
s4m5PCOJKO2c+Pr0443GbvuAgR0YjIXiJ+JGLEz7G0yhJpOqWhIac923nfIq UPbJrdupPXrz
xyTBCM0MsgME0POWJnmjcoxaQCImEhd/FrDqXjscGPrYgLti/byWKqyDLiLf arBbswAQTycG
CvM0M3No5SE2co9xfkzFrK3Sa01bBUrmpYZammoqdTCjFjnjkGrBcpWXGwTy k00pNQgDuAMQ
s5SFwfcRHZ6h0Dlb+ctzY/UNKpicjm8fm8jWnxpTWDnqFVdhimaYBjAhpws7 FGbs7m++zsIg
e2TqloSGnPdt53yKlD2ya3bqT1688ckwQjNDLIDBNDzliZ5o3KMWkAiJhIXf Z6P1NHqSznAh
pzVosZeiqgUwnHJK0lOtaYijMRKIm8p4uBNuzh47O+zQDTfQ7HYOtXqUptP1 IqMtBqs9HTsV
e3PDVuV7P/tc/NynlLyUBcw7Q8jMyjJ+DBJpNGZ987qoq+qoaeF1LKU1iKtQ OPI1jejFVY4L
bT8QJuyEjO8JOz7t7zsBs8TrzTOSuVaUNq7Xu2rLVoal7G2algjeGWYXeKaM TYCCvO7SOzAT
xGLO5M7LxWNbTZXIS4rQ2PpZy/V5le8uuSUa9YQsTVtnNoZDI3mrTizCDjtC ZOQ7x9yGB0mv
4TEaiPFw6ZG/mPNUNWLAYMcVXoS1rZyBfKMp5GnOIpmmcHdmkauMb78lMz0T NhvIpdBZClgp
q2Nr4ko71OS/Xkp1+fYBx70ZscbySbG0ni0h82N+DgBnx/UTS9rDZXJy2pqY 4Wid3LQzQE8l
II5LEUjFwYhMhkqWQftubO8e4uQkLlm0FrCtqwMqMVC7UmxmSt0ZWlrTNEfZ szQMccxAIS8m
h5OwOXBy4k+/riWouk1qXDZnGaZ1LDjx1BiJMXmJsljnuSTtJJalOePtywjH KUl2yZeBBu4M
IAI7PM9HYC1p0snVbIQ2cXYvT3akT1nCeA7E8s87SSc3GQXklfhsAOIszO5v 6SAkCIiAIiIA
iIgCIiAIiIAiIgCIiAIiICC9I/YZb5XJ9dMp0oL0j9hlvlcn10ynSpVxWS0R Olg83qwiIplA
iIgCIiAIiIAiIgCIiAIiIAiIgCIiAIiIAiIgCIiAIiICC9I/YZb5XJ9dMp0i KlXFZLRE6WDz
erCIimUCIiAIiIAiIgCIiAIiIAiIgCIiAIiIAiIgCIiAIiIAiIgP/9k=
name="JBuilder.jpg"
filename="JBuilder.jpg"
/9j/4AAQSkZJRgABAQEAYABgAAD/4QAWRXhpZgAATU0AKgAAAAgAAAAAAAD/ 2wBDAAUDBAQE
AwUEBAQFBQUGBwwIBwcHBw8LCwkMEQ8SEhEPERETFhwXExQaFRERGCEYGh0d Hx8fExciJCIe
JBweHx7/2wBDAQUFBQcGBw4ICA4eFBEUHh4eHh4eHh4eHh4eHh4eHh4eHh4e Hh4eHh4eHh4e
Hh4eHh4eHh4eHh4eHh4eHh4eHh7/wAARCAFjAcADASIAAhEBAxEB/8QAHAAB AAMBAQEBAQAA
AAAAAAAAAAUGBwgEAgMB/8QARhAAAQAGAwsMAQIEBQUBAAAAAAECAwQFBlWU 0QcRFRY2VnWT
s7XUCBIUFxg3UVd0laHkIRMxIkFlcSMyYYOFgZGktMHw/8QAGgEBAAMBAQEA AAAAAAAAAAAA
AAECBAMFBv/EADIRAQABAQENCQEBAQEBAAAAAAABAhMDBBEUFTFRUoGRwdHw BRIWMlNhcaGx
QSFiIvH/2gAMAwEAAhEDEQA/AOj3/LiG6OfNo7HhmR2jDtMsNmOFQ7CXRnR5 cmzqo2Zs2iUN
V2C/PUS0ShRN5LG9eSlH7nuf8uIbo582jsZDL02XRYxhJ5RF3GGweGMmSXqM xV4d3R0Qu0Qo
shnzujrX1v40J/e8i+i+lCVlUJ53tcqq6sNP8Uu10pp/yWkP8YjcQYIYv9zO JPbJCeehRs3h
zRCE+N5Lz+/5SeSAN4nAHJu6Qa5pGHdV4brvLZdL+4NF2rVf91110vaV0p/C Efm/eQhCEfhC
EI9bCVbqKWKiW02OCjVKqOeqoozWVQte/KEJS7ovo/1vI/sgPEq3UVWDRLCa 3Bo2QqlLNVdV
mqqste/CEpQ7pShF/wDneT/ZJ2wT7faP99/p75VYvEtSmleKs11nlLV6e2zF zUS8JUXeG7Rr
+mhCiL6b36qEX/2/F/8Ab8nkxtZqNFl2MHmpilf9+ZCmib//AHQkhky5dz5t 9EXlvneHT/x/
6J84u3d6Vln3FPAHOu41VThwxvWpriIwYPpNrTao0vfrQiamyqE3+YmELoRf /wCiiD9ccWFA
TN7S1sIPFu7jTEuV76Ixbu40xLle+iVxWdMby3/5+k5jiwoCZvaWtgxxYUBM 3tLWwg8W7uNM
S5XvojFu7jTEuV76IxWdMb02/tO5OY4sKAmb2lrYMcWFATN7S1sIPFu7jTEu V76Ixbu40xLl
e+iMVnTG8t/adycxxYUBM3tLWwY4sKAmb2lrYQeLd3GmJcr30Ri3dxpiXK99 EYrOmN5b+07k
5jiwoCZvaWtgxxYUBM3tLWwg8W7uNMS5XvojFu7jTEuV76IxWdMby39p3JzH FhQEze0tbBji
woCZvaWthB4t3caYlyvfRGLd3GmJcr30Ris6Y3lv7TuTmOLCgJm9pa2DHFhQ Eze0tbCDxbu4
0xLle+iMW7uNMS5XvojFZ0xvLf2ncnMcWFATN7S1sGOLCgJm9pa2EHi3dxpi XK99EYt3caYl
yvfRGKzpjeW/tO5OY4sKAmb2lrYMcWFATN7S1sIPFu7jTEuV76Ixbu40xLle +iMVnTG8t/ad
ycxxYUBM3tLWwY4sKAmb2lrYQeLd3GmJcr30Ri3dxpiXK99EYrOmN5b+07k5 jiwoCZvaWtgx
xYUBM3tLWwg8W7uNMS5XvojFu7jTEuV76IxWdMby39p3JzHFhQEze0tbBjiw oCZvaWthB4t3
caYlyvfRGLd3GmJcr30Ris6Y3lv7TuTmOLCgJm9pa2DHFhQEze0tbCDxbu40 xLle+iMW7uNM
S5XvojFZ0xvLf2ncnMcWFATN7S1sGOLCgJm9pa2EHi3dxpiXK99EYt3caYly vfRGKzpjeW/t
O5OY4sKAmb2lrYfaJ4VQhCEQWakIR/S2pAYt3caYlyvfRGLd3GmJcr30Ris6 Y3ot/wDn6T+P
H9Hmr2xqMeP6PNXtjU8bvKt1FZgzS3mtwZtkqoS0VUVZrKqrXvyhCUu6EpRf /neR/ZAeJVuo
qsGiWE1uDRshVKWaq6rNVVZa9+EJSh3SlCL/APO8n+yRYTrdbk2n/PW961p1 UXRzV4JNCyP9
YW1T/wDD5xxYUBM3tLWwg8W7uNMS5XvojFu7jTEuV76IxWdMb0W/tO5OY4sK Amb2lrYMcWFA
TN7S1sIPFu7jTEuV76Ixbu40xLle+iMVnTG9Nv7TuTmOLCgJm9pa2DHFhQEz e0tbCDxbu40x
Lle+iMW7uNMS5XvojFZ0xvLf2ncn0TwqhCFUQWakIR/S2ox4/o81e2NSAxbu 40xLle+iMW7u
NMS5Xvok4tOmN6Lb/n6T+PH9Hmr2xqfxadVF0c1eCTQuj/WFtU//AAruLt3e lZZ9xTwAxdu7
0rLPuKeAIxedP2Wv/KwY4sKAmb2lrYMcWFATN7S1sIPFu7jTEuV76Ixbu40x Lle+iMVnTG9N
v7TuTmOLCgJm9pa2DHFhQEze0tbCDxbu40xLle+iMW7uNMS5XvojFZ0xvLf2 ncnMcWFATN7S
1sGOLCgJm9pa2EHi3dxpiXK99EYt3caYlyvfRGKzpjeW/tO5OY4sKAmb2lrY McWFATN7S1sI
PFu7jTEuV76Ixbu40xLle+iMVnTG8t/ady0v+XEN0c+bR2K1yVUpTK8y30/t HFb3t7kWV/y4
hujnzaOxWeSpkxM2nVN3OQvfyVbOJX5qdvBnSJoe5cumvk+uTyvFGryqlxeH d6hajk8PyjJZ
Z3VS2atErLMF+coosshmoyVW/SVvslE30I1Lrzl6gI7rXHiTEZ9grCGvyjy8 QRzhjKIw1yiC
IUq7tFUQ/pCz0su7rKtV1v4lVkXk81Vkr/D+Gal5JU+iwKh4dVWdh9Re3ZlN +xNWHBEf575o
94ePdL7m95in+z/vX+OmevOXs347rXHiR15y9m/Hda48SczdFgVDw6qs7B0W BUPDqqzsNHh+
nW+p5qZSq6wOmevOXs347rXHiR15y9m/Hda48SczdFgVDw6qs7B0WBUPDqqz sHh+nW+p5mUq
usDpnrzl7N+O61x4kdecvZvx3WuPEnM3RYFQ8OqrOwdFgVDw6qs7B4fp1vqe ZlKrrA6Z685e
zfjutceJHXnL2b8d1rjxJzN0WBUPDqqzsHRYFQ8OqrOweH6db6nmZSq6wOme vOXs347rXHiR
15y9m/Hda48SczdFgVDw6qs7B0WBUPDqqzsHh+nW+p5mUqusDpnrzl7N+O61 x4kdecvZvx3W
uPEnM3RYFQ8OqrOwdFgVDw6qs7B4fp1vqeZlKrrA6Z685ezfjutceJHXnL2b 8d1rjxJzN0WB
UPDqqzsHRYFQ8OqrOweH6db6nmZSq6wOmevOXs347rXHiR15y9m/Hda48Scz dFgVDw6qs7B0
WBUPDqqzsHh+nW+p5mUqusDpnrzl7N+O61x4kdecvZvx3WuPEnM3RYFQ8Oqr OwdFgVDw6qs7
B4fp1vqeZlKrrA6Z685ezfjutceJHXnL2b8d1rjxJzN0WBUPDqqzsHRYFQ8O qrOweH6db6nm
ZSq6wOmevOXs347rXHiR15y9m/Hda48SczdFgVDw6qs7B0WBUPDqqzsHh+nW +p5mUqusDpnr
zl7N+O61x4kdecvZvx3WuPEnM3RYFQ8OqrOwdFgVDw6qs7B4fp1vqeZlKrrA 6Z685ezfjutc
eJHXnL2b8d1rjxJzN0WBUPDqqzsHRYFQ8OqrOweH6db6nmZSq6wOmevOXs34 7rXHiR15y9m/
Hda48SczdFgVDw6qs7B0WBUPDqqzsHh+nW+p5mUqusDpnrzl7N+O61x4kdec vZvx3WuPEnM3
RYFQ8OqrOwdFgVDw6qs7B4fp1vqeZlKrrA6Z685ezfjutceJHXnL2b8d1rjx JzN0WBUPDqqz
sHRYFQ8OqrOweH6db6nmZSq6wOmevOXs347rXHiR15y9m/Hda48SczdFgVDw 6qs7B0WBUPDq
qzsHh+nW+p5mUqusDpnrzl7N+O61x4kdecvZvx3WuPEnM3RYFQ8OqrOwdFgV Dw6qs7B4fp1v
qeZlKrrA6Z685ezfjutceJHXnL2b8d1rjxJzN0WBUPDqqzsHRYFQ8OqrOweH 6db6nmZSq6wO
mevOXs347rXHiR15y9m/Hda48SczdFgVDw6qs7B0WBUPDqqzsHh+nW+p5mUq usDpnrzl7N+O
61x4kdecvZvx3WuPEnM3RYFQ8OqrOwdFgVDw6qs7B4fp1vqeZlKrrA6Z685e zfjutceJHXnL
2b8d1rjxJzN0WBUPDqqzsHRYFQ8OqrOweH6db6nmZSq6wOmevOXs347rXHiR 15y9m/Hda48S
czdFgVDw6qs7B0WBUPDqqzsHh+nW+p5mUqusDpnrzl7N+O61x4kdecvZvx3W uPEnM3RYFQ8O
qrOwdFgVDw6qs7B4fp1vqeZlKrrAvjCLxR8muT2EzPWEHJrGOcvCnVml3ZMX mINGiyXhRsq0
WX/UYrvN9RZF5KqGaOalVZKVk9Wu7szYNXhqos2Ss8NENF0Ltl10IShRVS8q hZKUKIvKo/hV
vIvpWWvX1lkp5/ueMIE6xa5nGGjuswbocIy0QlyZqIXeVmXNUVUWUR/G3Qoy S0QqozQsuhKF
UoRzUL3uhjwL+wxX3Zzxh/ZejekR3ZmM3+fkAAMTWob/AJcQ3Rz5tHYrPJUy YmbTqm7nIsz/
AJcQ3Rz5tHYrPJUyYmbTqm7nI53v5KtnFFfmjbwUTlYtksZteV+b/CrCoclC 1/8Af/Hffx/+
8TA8Ko8fk6G5QsLZTrPDrDIZE2CrKKwuGpdn1neasllVmz4sqshKPwsqlCEJ QlH7lM7Mcw54
OFVXtPsOyb/vW9rjNN1qwTt0Q8O/L2ut1umG5xh/+yyzCqPH5GFUePyan2Y5 hzwcKqvaOzHM
OeDhVV7T08tdn+r+8mXEL41WWYVR4/Iwqjx+TU+zHMOeDhVV7R2Y5hzwcKqv aMtdn+r+8jEL
41WWYVR4/Iwqjx+TU+zHMOeDhVV7R2Y5hzwcKqvaMtdn+r+8jEL41WWYVR4/ Iwqjx+TU+zHM
OeDhVV7R2Y5hzwcKqvaMtdn+r+8jEL41WWYVR4/Iwqjx+TU+zHMOeDhVV7R2 Y5hzwcKqvaMt
dn+r+8jEL41WWYVR4/Iwqjx+TU+zHMOeDhVV7R2Y5hzwcKqvaMtdn+r+8jEL 41WWYVR4/Iwq
jx+TU+zHMOeDhVV7R2Y5hzwcKqvaMtdn+r+8jEL41WWYVR4/Iwqjx+TU+zHM OeDhVV7R2Y5h
zwcKqvaMtdn+r+8jEL41WWYVR4/Iwqjx+TU+zHMOeDhVV7R2Y5hzwcKqvaMt dn+r+8jEL41W
WYVR4/Iwqjx+TU+zHMOeDhVV7R2Y5hzwcKqvaMtdn+r+8jEL41WWYVR4/Iwq jx+TU+zHMOeD
hVV7R2Y5hzwcKqvaMtdn+r+8jEL41WWYVR4/Iwqjx+TU+zHMOeDhVV7R2Y5h zwcKqvaMtdn+
r+8jEL41WWYVR4/Iwqjx+TU+zHMOeDhVV7R2Y5hzwcKqvaMtdn+r+8jEL41W WYVR4/Iwqjx+
TU+zHMOeDhVV7R2Y5hzwcKqvaMtdn+r+8jEL41WWYVR4/Iwqjx+TU+zHMOeD hVV7R2Y5hzwc
KqvaMtdn+r+8jEL41WWYVR4/Iwqjx+TU+zHMOeDhVV7R2Y5hzwcKqvaMtdn+ r+8jEL41WWYV
R4/Iwqjx+TU+zHMOeDhVV7R2Y5hzwcKqvaMtdn+r+8jEL41WWYVR4/Iwqjx+ TU+zHMOeDhVV
7R2Y5hzwcKqvaMtdn+r+8jEL41WWYVR4/Iwqjx+TU+zHMOeDhVV7R2Y5hzwc KqvaMtdn+r+8
jEL41WWYVR4/Iwqjx+TU+zHMOeDhVV7R2Y5hzwcKqvaMtdn+r+8jEL41WWYV R4/Iwqjx+TU+
zHMOeDhVV7R2Y5hzwcKqvaMtdn+r+8jEL41WWYVR4/Iwqjx+TU+zHMOeDhVV 7R2Y5hzwcKqv
aMtdn+r+8jEL41WWYVR4/Iwqjx+TU+zHMOeDhVV7R2Y5hzwcKqvaMtdn+r+8 jEL41WWYVR4/
Iwqjx+TU+zHMOeDhVV7R2Y5hzwcKqvaMtdn+p+8jEL41Wv8AJ2dn56lqSYuz d+c4sYTGGDZt
z0I5jVo/sFmavNv3030Mmqb6EXkc383r6L+zmHXNHV5kV6uey0s4vscbLOsa cl3hydmd5jff
WDRLZosulX9NkhCEoTeSm+slRCFVlkqoNxPir9q792qqjNMzg3y9+9YwXOI6 zAAMrQob/lxD
dHPm0dis8lTJiZtOqbucizP+XEN0c+bR2KzyVMmJm06pu5yOd7+SrZxRX5o2 8Hiuod/MG9ND
ts+mlGa3UO/mDemh22fTSi1956fjhCtwzz88QAGJoAASAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAECuy+lPWLLyL/4wVH94ORo5nEv940u 6KmDeDkaOejX
/Ga55pAAUdFDf8uIbo582jsVnkqZMTNp1TdzkWZ/y4hujnzaOxWeSpkxM2nV N3ORzvfyVbOK
K/NG3g8V1Dv5g3podtn00ozW6h38wb00O2z6aUWvvPT8cIVuGefniAAxNAAC QAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAgV2X+8aXdFTBv ByNHM4l/vGl3
RUwbwcjRz0a/4zXPNIACjoob/lxDdHPm0dis8lTJiZtOqbucizP+XEN0c+bR 2KzyVMmJm06p
u5yOd7+SrZxRX5o28Hiuod/MG9NDts+mlGa3UO/mDemh22fTSi1956fjhCtw zz88QAGJoAAS
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAEC uy/3jS7oqYN4
ORo5nEv940u6KmDeDkaOejX/ABmueaQAFHRQ3/LiG6OfNo7FZ5KmTEzadU3c 5Fmf8uIbo582
jsVnkqZMTNp1Tdzkc738lWziivzRt4PFdQ7+YN6aHbZ9NKM1uod/MG9NDts+ mlFr7z0/HCFb
hnn54gAMTQAAkAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAI
Fdl/vGl3RUwbwcjRzOJf7xpd0VMG8HI0c9Gv+M1zzSAAo6KG/wCXEN0c+bR2 KzyVMmJm06pu
5yLM/wCXEN0c+bR2KzyVMmJm06pu5yOd7+SrZxRX5o28Hiuod/MG9NDts+ml Ga3UO/mDemh2
2fTSi1956fjhCtwzz88QAGJoAASAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAECuy/3jS7oqYN4ORo5nEv8AeNLuipg3g5Gjno1/xmueaQAF HRQ3/LiG6OfN
o7FZ5KmTEzadU3c5Fmf8uIbo582jsVnkqZMTNp1Tdzkc738lWziivzRt4PFd Q7+YN6aHbZ9N
KM1uod/MG9NDts+mlFr7z0/HCFbhnn54gAMTQAAkAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAIFdl/vGl3RUwbwcjRzOJf7xpd0VMG8HI0c 9Gv+M1zzSAAo
6KG/5cQ3Rz5tHYrPJUyYmbTqm7nIsz/lxDdHPm0dis8lTJiZtOqbucjne/kq 2cUV+aNvB4rq
HfzBvTQ7bPppRmt1Dv5g3podtn00otfeen44QrcM8/PEABiaAAEgAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABArsv8AeNLuipg3g5Gjmcy+ hPWLLy15N5EL
j6Ep/wCQczRj0a/4zXPNIACjoob/AJcQ3Rz5tHYrPJUyYmbTqm7nIsz/AJcQ 3Rz5tHYrPJUy
YmbTqm7nI53v5KtnFFfmjbweK6h38wb00O2z6aUZrdQ7+YN6aHbZ9NKLX3np +OEK3DPPzxAA
YmgABIAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAACAl9ozUn
2X1V2iqqzRwjqqiEpvJWT051TeR4pvISn+yEmiHDasGuwQ/lPwOJvi8SawV8 mp9wKq3elXxi
o6peUobrKO/PWSzUQoshKfwqlCEITfVSrzkdstXd9WjLs9M4hzHFm7tmbZz/ AEUJ/VaLLM0s
2nP/AHV5iFWiOaj8Lfq30/5UHp1x/wCaZ9uLLc/8mqPd6wAcnVQ3/LiG6OfN o7FZ5KmTEzad
U3c5Fmf8uIbo582jsVnkqZMTNp1Tdzkc738lWziivzRt4PFdQ7+YN6aHbZ9N KM1uod/MG9ND
ts+mlFr7z0/HCFbhnn54gAMTQAAkAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAIFel9KesWXlb6byYXH0pR/yDmaMZxL/eNLuipg3g5Gjno1 /wAZrnmkABR0
UN/y4hujnzaOxWeSpkxM2nVN3ORZn/LiG6OfNo7FZ5KmTEzadU3c5HO9/JVs 4or80beDxXUO
/mDemh22fTSjNbqHfzBvTQ7bPppRa+89PxwhW4Z5+eIADE0AAJAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACBXZf7xpd0VMG8HI0cziX+8a XdFTBvByNHPR
r/jNc80gAKOihv8AlxDdHPm0dis8lTJiZtOqbucizP8AlxDdHPm0dis8lTJi ZtOqbucjne/k
q2cUV+aNvB4rqHfzBvTQ7bPppRmt1Dv5g3podtn00otfeen44QrcM8/PEABi aAAEgAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABArsv940u6 KmDeDkaOZxL/
AHjS7oqYN4ORo56Nf8ZrnmkABR0UN/y4hujnzaOxWeSpkxM2nVN3ORZn/LiG 6OfNo7FZ5KmT
EzadU3c5HO9/JVs4or80beDxXUO/mDemh22fTSjNbqHfzBvTQ7bPppRa+89P xwhW4Z5+eIAD
E0AAJAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAACBXZf7xpd
0VMG8HI0cziX+8aXdFTBvByNHPRr/jNc80gAKOihv+XEN0c+bR2KzyVMmJm0 6pu5yLM/5cQ3
Rz5tHYrPJUyYmbTqm7nI53v5KtnFFfmjbweK6h38wb00O2z6aUZrdQ7+YN6a HbZ9NKLX3np+
OEK3DPPzxAAYmgABIAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAQK7L/AHjS7oqYN4ORo5nEv940u6KmDeDkaOejX/Ga55pAAUdFDf8ALiG6 OfNo7FZ5KmTE
zadU3c5Fmf8ALiG6OfNo7FZ5KmTEzadU3c5HO9/JVs4or80beDxXUO/mDemh 22fTSjNbqHfz
BvTQ7bPppRa+89PxwhW4Z5+eIADE0AAJAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAACBXZf7xpd0VMG8HI0cziX+8aXdFTBvByNHPRr/AIzX PNIACjoob/lx
DdHPm0dis8lTJiZtOqbucizP+XEN0c+bR2KzyVMmJm06pu5yOd7+SrZxRX5o 28Hiuod/MG9N
Dts+mlGa3UO/mDemh22fTSi1956fjhCtwzz88QAGJoAASAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAECuy/3jS7oqYN4ORo5nEv940u6KmD eDkaOejX/Ga5
5pAAUdFDf8uIbo582jsVnkqZMTNp1TdzkWZ/y4hujnzaOxWeSpkxM2nVN3OR zvfyVbOKK/NG
3g8V1Dv5g3podtn00ozW6h38wb00O2z6aUWvvPT8cIVuGefniAAxNAACQAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAgV2X+8aXdFTBvByNH M4l9CesWXk3v
xgqP/n/kHI0c9Gv+M1zzSAAo6KG/5cQ3Rz5tHYrPJUyYmbTqm7nIsz/lxDdH Pm0dis8lTJiZ
tOqbucjne/kq2cUV+aNvB4rqHfzBvTQ7bPppRkU5xeGxS7Syirg1bruLm3dH F7eW7JqzYs27
Fu9s2qiFmiEKpQhKyqt9W+rzlk/lKb5puG4JTEOrKlp0vqiqZiPbhClwmP8A Z9+MpAEfhuCU
xDqypaMNwSmIdWVLTJZ16HfvU6UgCPw3BKYh1ZUtGG4JTEOrKlos69B3o0pA EfhuCUxDqypa
MNwSmIdWVLRZ16DvRpSAI/DcEpiHVlS0YbglMQ6sqWizr0HejSkAR+G4JTEO rKlow3BKYh1Z
UtFnXoO9GlIAj8NwSmIdWVLRhuCUxDqypaLOvQd6NKQBH4bglMQ6sqWjDcEp iHVlS0Wdeg70
aUgCPw3BKYh1ZUtGG4JTEOrKlos69B3o0pAEfhuCUxDqypaMNwSmIdWVLRZ1 6DvRpSAI/DcE
piHVlS0YbglMQ6sqWizr0HejSkAR+G4JTEOrKlow3BKYh1ZUtFnXoO9GlIAj 8NwSmIdWVLSN
YT5IzeKJhTCc5cbP6F12aXVSKMEteepfvo5nPv30Xk3/AOxHcq0GGlYgR+G4 JTEOrKlow3BK
Yh1ZUtJs69B3o0pAEfhuCUxDqypaMNwSmIdWVLRZ16DvRpSAI/DcEpiHVlS0 YbglMQ6sqWiz
r0HejSkAR+G4JTEOrKlow3BKYh1ZUtFnXoO9GlIAj8NwSmIdWVLRhuCUxDqy paLOvQd6NKQB
H4bglMQ6sqWjDcEpiHVlS0Wdeg70aUgCPw3BKYh1ZUtGG4JTEOrKlos69B3o 0pAEfhuCUxDq
ypaMNwSmIdWVLRZ16DvRpSAI/DcEpiHVlS0YbglMQ6sqWizr0HejSkAR+G4J TEOrKlow3BKY
h1ZUtFnXoO9GlIAj8NwSmIdWVLRhuCUxDqypaLOvQd6NKQBH4bglMQ6sqWjD cEpiHVlS0Wde
g70aXhl1CcfICt/JENjyP/PdDQzAYpNMsRGaILD3CY4A/wARdmj8noCsUdlW rRsrGHFsowVV
aJSj9ZdVkuhRVbm31kf5lP8AOrvx6F0j/KZ6zyz3L+9fwABydVDf8uIbo582 jsVnkqZMTNp1
TdzkWZ/y4hujnzaOxWeSpkxM2nVN3ORzvfyVbOKK/NG3gosKuWXREvLJEPir o1RCot+gtEnl
m8IfGiyHv9VL3+m8slVWvN5/PTeaNFV+YshVdZKTYmcvTexbsHd/n6KdEQxU WaxBmlyZNWjy
lKFP0lWCzmsqqyTf5yFv1Er85KFbyUfkvQNV0u9Vc4ZiHKi4U0RgwzvVZErR u93jzVqIdwgx
WjfmNNOoh3CFpBS0nqIWsqVWxWjfmNNOoh3CDFaN+Y006iHcIWkC0nqILKlV sVo35jTTqIdw
gxWjfmNNOoh3CFpAtJ6iCypVbFaN+Y006iHcIMVo35jTTqIdwhaQLSeogsqV WxWjfmNNOoh3
CDFaN+Y006iHcIWkC0nqILKlVsVo35jTTqIdwgxWjfmNNOoh3CFpAtJ6iCyp VbFaN+Y006iH
cIMVo35jTTqIdwhaQLSeogsqVWxWjfmNNOoh3CDFaN+Y006iHcIWkC0nqILK lVsVo35jTTqI
dwgxWjfmNNOoh3CFpAtJ6iCypVbFaN+Y006iHcIMVo35jTTqIdwhaQLSeogs qVWxWjfmNNOo
h3CBErRq/wB400p/2IdwhaQLSeogsqeplmqJauiu7Nm4vF0SOPz69LNEqRJ1 hEOZOjkqqqql
VDZiv/itErJ5yEJZpT+6L6FUI5ycckTk2za63VIndHYXUYWpEMJPjV3fHKGq vKWjVos2Zt/1
FFlkKM1kLLLKpVRz7yeci+qlX89WgvbVaI3QiLjTGaZ3yqyZWjV/vGmlH+xD uEGK0b8xpp1E
O4QtIKWk9RCbKnqZVbFaN+Y006iHcIMVo35jTTqIdwhaQLSeogsqVWxWjfmN NOoh3CDFaN+Y
006iHcIWkC0nqILKlVsVo35jTTqIdwgxWjfmNNOoh3CFpAtJ6iCypVbFaN+Y 006iHcIMVo35
jTTqIdwhaQLSeogsqVWxWjfmNNOoh3CDFaN+Y006iHcIWkC0nqILKlVsVo35 jTTqIdwgxWjf
mNNOoh3CFpAtJ6iCypVbFaN+Y006iHcIMVo35jTTqIdwhaQLSeogsqVWxWjf mNNOoh3CDFaN
+Y006iHcIWkC0nqILKlVsVo35jTTqIdwgxWjfmNNOoh3CFpAtJ6iCypVbFaN +Y006iHcIMVo
35jTTqIdwhaQLSeogsqVWxWjfmNNOoh3CH4vsqTIs5tlXK6ZMbF6SzWQxaNn OHtGai97+FKy
iHZVKyqE3r6ELKpSj8X0fuW8C0nqILKnqZcZwnksTFGLpj7G5pnCGPar1Emy 8WWhCqrRsyat
VEtl0NFWnMVZ85Voi9eVXShLRmn9NKiUrI7MAJul1mvBGaITRRFP+/0ABzXU N/y4hujnzaOx
WeSpkxM2nVN3ORZn/LiG6OfNo7FZ5KmTEzadU3c5HO9/JVs4or80beDYgAdE gAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAChv +XEN0c+bR2Kz
yVMmJm06pu5yAOd7+SrZxRX5o28GxAA6JAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAH/2Q==
--------------090809020402020307000109--
Re: From JBuilder to Eclipse VE [message #95382 is a reply to message #94543] Thu, 30 June 2005 13:38 Go to previous message
--------------060100070104080403040309
KIBLER Stephane wrote:
> Hi all,
> to Eclipse?
> Steff.
I took the code above, cleaned it up to use JButton/JPanel (instead of the KimXXX customization) and removed the icons
since I had no access to them. I was able to bring it up with the latest VE code base with no problem. see attachments.
Not sure what is the particular issue in your file, but the first hint would be to click on the visual components with
the warning (yellow "!") sign. They reflect exceptions that were thrown on the target VM. It will tell you (on the
status bar) what feature the problem occurred on, and what is the exception that was thrown.
name="KimChar.java.java"
filename="KimChar.java.java"
* Copyright (c) 2005 IBM Corporation and others.
* All rights reserved. This program and the accompanying materials
* are made available under the terms of the Common Public License v1.0
* which accompanies this distribution, and is available at
* http://www.eclipse.org/legal/cpl-v10.html
* Contributors:
* IBM Corporation - initial API and implementation
* Created Jun 29, 2005 by Gili Mendel
* $RCSfile: $
* $Revision: $ $Date: $
import javax.swing.*;
public class KimChar extends JPanel {
JButton nextBtn = new JButton();
JButton prevBtn = new JButton();
JLabel charHeadLbl = new JLabel();
JPanel titlePnl = new JPanel();
Border border1;
Border border2;
Border border3;
static {
try {
public KimChar() {
try {
jbInit();
// nextBtn.setType(kim.bean.kimbutton.KimButton.CHAR);
currentHeadNum++;
// load();
// nextBtn.setIcon(CommonFunct.loadImgClass(this, KimConst.Icon.NEXT));
// circleLbl.setIcon(CommonFunct.loadImgClass(this, "circle.gif"));
// prevBtn.setType(kim.bean.kimbutton.KimButton.CHAR);
// prevBtn.setIcon(CommonFunct.loadImgClass(this, KimConst.Icon.PREV));
currentHeadNum--;
load();
this.setSize(332, 164); // Generated
currentHeadNum = 0;
isLoaded = false;
this.load();
return isLoaded;
return isEnabled;
// load();
this.inCde = inCde;
return inCde;
} else{
} // @jve:decl-index=0:visual-constraint="10,10"
Content-Type: image/png;
name="Image1.png"
filename="Image1.png"
iVBORw0KGgoAAAANSUhEUgAAA10AAAJ1CAIAAACtkQ3nAAAALHRFWHRDcmVh dGlvbiBUaW1l
AFRodSAzMCBKdW4gMjAwNSAxMzozNjowNyAtMDUwMBMzm34AAAAHdElNRQfV Bh4RJCUWqQ6W
AAAACXBIWXMAAA7DAAAOwwHHb6hkAAAABGdBTUEAALGPC/xhBQAAl0hJREFU eNrsnV9oG1e+
x0+CCiNoYQQNSJAFq9yFyNxCZCisDXmILnmITBZi04VG3AtbtQupTWAdb+Am un3IKikEJxdy
4xSaqAu9yA8NdmBDlIewykMWqZCLFQh4Ci1RoAUJWpiBBjQPht4zOvZ4PP80 M/ozI+n7sTg+
c+Z3js5odDTf+Z0/c0D86SUxo/yknDqeIhY0mk1B2KKRufezZMjZuFdgkURi MhaN+l0d0C/o
V5p0OsvqF3v+3qzf9R0C1t9/yCJoOz5i/1sNAACuOGClC4n1zw27do6AItQB gTgO0G+11fll
X+z5+1CErlk/DYHoG9CFAIAeEnKbYVRFIdH4PqlApMeIK9xIQq+gzHGoO7ns i525P8v5XcNh
JLMrpovkIdoOAAAML+504Y4oPJ0h2zJLiZwr6WzEm2m/D6pblAOk6vB+kRjU AxgBjNJwRxQ+
mHV/owT2oXyGbXVI0HYAAGAI6cFlULgxp8YTSxt+H1HPoOqQSkM4PwZP/vIV m725Ty/1MNc+
9reG9XfN73DmX5Q6FzXeZB7N9sRxWPnfedP0mX9f9/sQAQBgNHGnC3echftp yHqz6mt9X9z0
mzIZQuA49IuVm3dN05fPfdSTXMxlqJ5T+sXOPtL3INOv7NyfN3UZhUeL6ySd gTTsBP08aVjo
znFodQqoXoQ0BACAfuDaX2jUdw2p/Y/bM0h/eF1v8/WC30e6Q25pkUXyN27Z J6qkT2dKkIbD
gL1q7ICxKZjdy3AcHz8yU6TSUBg7aZjlcixSkPP2iXt7H892JQ2tTwGkIQAA 9AP3/cjb+oS6
3P7xlvcMGmsLHXNRwuGwGm+1Wh3fmdpTMxZ2c8zMq0Q1RP6aogJzFxbVFNN6 UtKnMqUHkIaD
w5vC8+Zl3CFkMuFE/VLXmlL2YjH1XiI3HSEiobqkIKezP5SNWcTbfOQTSRtq 07URK6iBGneY
xaocD7kcfcLnPipsr9D/2dDyXtsJmc/YyT6ZLxBFwHlrOzanoHxnPvWxiTSM HHpH/OmlGu77
TKyXX/AGe5felgkAAD7iYXyh/hY+d7Nkb2BKOBxptUTNZli7aW0pt+M96JWm 1zMmF/aLCcuS
06fmSw+8X96AcxyNBew1nKEpyGT366ARPPzR80y11Z5PcWatJ3ZOkYM0ZHtZ 2Li5l6JGTGGW
6iYryrR6HbF/o25Qmoyh7di818LT+VVP0rDjKTDNpYpCddPzkXaUfRCFAIAR o9vrRuOGybpZ
saWyzV5/yV9boXKQXc+0V7W2+3DFPi+k4Vix55TW3ix0uiVhwk4r73RSzxWe M/aDIlkhFm1H
2WWLN2no7RRo/YV+f2YAADBkHGT/2LIdPaNZF2/P0ZC0NWLsTMF51nA4Yowb E9VQt0uXYgqT
htoUJ6KQQaWhIGw1ms1eflwgCIQMr18sbakyaf1iliVEv/CSGhImCll890VT WMheanzHwLQm
hOjN9pdg3Ku+kallRxurVzFk0nZoon0u9lqoum87HU+BGUwO2ohCKhnZS43r 0rW9z6qZdlO3
V1emzszKBgAAAohyzaGisPK0Ovd+Vvq53qtyI3M7U0964jI07WJW+5dZRNvd rOuk7i3wGo4k
4V3X+T/+T51xH2ukd599slZk/1VflazJ4rBkXco7FxRfYOMGr4uYFms0Y6Eu RZdX+0ZWb2Fl
Y4lhDK7Dz4Gy/Gx+xYHXUPzDzjywVKdT4ARVh2mVIourPkU1otoYU+wxZvRm AwAA/qL8oqeO
p1w8v2T/VSF2Qe9obFxLNb7KmhrbF7W3uW1I3DbZbP0i6tL3eQqt3zp3cVk3 QYGNNcxfdeQy
pKRPzpceQRqOLOGjM9x7cfFBOXIqJT+rt55XzKwcPRiFaqyX1zopLWfl6FJo sQ7z6izVKmkr
5rC0Odmk7ZBzH21wTtuOQ2nYw1MwGAVmnOBi7M6GpxAAEHx27vTdeAr1d+mG da2dTwqRLTaN
g4lks029WeuXhk09GbmLOfXCpp13sisN88QZ6ZOzpUd4qEOw6G6dmj2RQRUJ /8EZIok0lMga
FSXFJwLbJe9+rZQI50CXhLh3LsqKArso699LfUddxHRirzYxxL28yqkF0rhl RivL/e9labOf
udeLVm1HkYZv3iLOWK5lVkiH2f1OT0EwcCL+IBABAENBD+YrGte1rm3rf+6T IdcD8sJvxTxX
iebdrxFNUFWgOg3FLZCGgaLLWcza6bTig7KiSM4uSJ+vik9rNKX8eFNZIeWD lFUW+2InP5Wp
3qKhNlHNrotoi926vJNLm2g0M6bYW6r1MdbByXHRJlPi2ypQ03ZczX3Ovcjk baWhw1MwMNQl
b5x7HzH3BQAwjPRCF+5f15qYrmv9lf4pKVS3aZWfKuPUdF2ko87TFmhvzFwd qmuQRjz7mSAN
R4c37HauXJif2neK276qN0hndm0m/yorIu+v8l7iG3obGmFmam7FXmdsZqa1 2fqv3XexsTSr
m5OPgrWU0qEd16ASUduOk09DQ+7bDtLQ0SlwgNY511Gl6QYjWi15oxN8xoUS jTixAQAA33H/
vJNO61pTg/qXmY65KKLYMDVg6TSFRlg6ixhD1V41s3k7Ru5y3mhjmuiQ1InZ 8mNIw5Eiciql
dF9+vsqfXSD8mninmIhGW+5XzdzTZ5pNbWgfMS3Hysxhdvu62aPKwY6JDrGR hr06BaZC0Kjz
bBY7tC/BlRl8hwCA4OPBX6h/1ohhXeuuHkYyjKROpMqPy4KwlUhMQh0OKdpu UPlZXSJrSvcl
vyY3lYnthcszmt0sg5e1pn08qGCS/z6TI0Vj23F4CgaD2x5kAAAYXrq9btSv Jv0+hEBApSFR
hkAps7MhDYed1vMKmwAr3tlZG6V0qKcLfA6Eqc8CMy/DFioNaZjb7zg0noLl i8V+16Tj+jKu
dgEAwDASeH/CUAHH4RCz2xTmT653VQ7wRP6VxnH4tfe+aQAAAN3gXhe6H4E3 VqSOtx2HTxR1
SCMQiMMCFxpUrySwYOVHZd3TZVJA2wEAAL+Av7AvMHVIIBABcAlThwQCEQAA /AC6sL8YBSII
KGgKAWOlqReIwIoeP+AeADDG4GI4IFSBCAKC/lKKphBUVn52/JROAAAA3XHQ 7woAAAAAAIBA
ACdJ3+m+i2fu/aybB1gD71TOOrXcuFeg58Xv+gIAAAC9JCTcUBYPSyz1fW2w cQadyEMEJDgA
AICx5eD0p/mxez6JT/Bvxz2EAAAAAACD4eDqh4vCt02/qzH6UJEn/Vz3EPpS 28r3zeyNKn1t
fj/W343IiSt+VwEAAAAYHKGFL2+Vlpb9rsbo400UmvZpRn5zfeF2Jn+qjyu6 Ff5eX/i9IkkX
v9isXEv7+LnNXCjd+tPU1L90Ptj8p3YaLnf5krcKUGkoPvaYFwAAABguQhuf LPpdh7HASvat
PK0Wvi1Qg0k+Mh2NLR8jHaWh+MN5Kg0JUaRh5Ue51iCiJFM4jovwXDJGZg53 ++gOoSkSEqdq
zF9R6Aqq/Kg0XLl9V5e+/MlHnkUhA9IQAADAmHAwde0hffldjdFHK/Vm/7us xgvfbmWPTAof
Z7cksdpsOPEXkrY0XP2kmHvQlOQIF4nE47GZZIKGhIuUBbn4Qu6ytpkT8dW/ 12culCpD1Y9M
9R9VgdqU7kUhAx3KAAAAxoGDwo0Mm5IM+opW6nFEVuON/8wvH5tWxxE6H1+4 Vc9RaVgR6sko
P3OET0Q5GqaTfCweE5ry5s+dpWHkN9epsjTdtXAiUViavvWnqeUvNp0fY/7Z WuTO4sy9HI24
+nBsauIWrTTslSikwF8IAABgHAhNf5ovX875XY3RZ7/UE9RO5GpzY0sSJ/kI M3PoL6QUq431
Wn4+mSO3ya0/TtMUqgQ5QlZbhOf5siBNHevQm6ztj9btYqP6aCQRjTg8wMzj 6zzHPTw915Dk
cqNON4snzjvMa1MTxub3zQjPxd/mnZSmSkOIQgAAAMAVodUPF4ksT/ldj5FH J/VYnIlC4eMs
jcc+yxGL6SmmBdYluV4XV6r55WklY3I6kauKEY7wHJnkw62mI/ebKsiSZKvZ bEaj0ankZPxw
NHMivvjFJhWF2d87mhCde7bGEW4+npBlEuGUSFEQaGL+vTMOPx+rmtA6LO76 LJ0PduyVIiQQ
hQAAAMYJzEceEKb+QraLxnP319S4Q38hkYkgh9eqjXVhZT6xvHA70/jjdPhv dVmi2iyccDzC
cLOamZou0uzZk1P1er1S3STTUwsnEvTl/OhWn1fyv5sRxD0xOhWN5L6pONeF VjUpLE0P5gSZ
0o0ovPLZFS7EydsyC2mKdtNJqGbR5fVQFEKECHsenv+L0y4RAIYIzEceEKb+ wulojMaZp3CS
j2xJ4r99fv0fZ887kYaS0mvc4jiOyoRfW7cOhJXzmE3Ei4KSLjmu2GZta30t NX+mSG5n5iaU
jtpKbTN+2N005CjH1SWR13RcS7KS6KqQntQkONDLhiAIftcCANAXsh/iMZhg NAlhMvJgMPUX
5k+f8bB+ISMR5RqEhPkwG3O3UMqtpvMLtzPLycRWvRGLOtVktRfN1LHIw430 7JwiyFK8JLyQ
yCl3R5eaSGxJ9fmJSTWl8qpOE10V0pOaBAfm2EskEvAXIhz5MBKN+F4HY9ho NvpUcvZstvrP
qt+/MQD0hZDfFRgX9s1HliVTCVj4Q0mX63x5wUoaphNcoSolJsJy2zkXj3C3 qvnF6RyVhlMT
0WTMacVihwj99YxFY6qvLnbItZdr9Vh2/sGV8qt6eiIhyWKl2QxzSqKrQnpS k+BALx4snDk+
43ddAOgjlacVev/jdy3Mif+294+MosdLwxbBE2TBaAJdOCC0EjD8S8nmkXfZ r9OlG7XGNw2W
y6rAqbe52gQRmo1NudWQIrJMxJb8sJafTSrSMPuu06ehpE+mCl+VIzzH87G7 t5MffaKM8PNw
gOunLuWeFha/KSc4PjURz7sUhT2sSUBgjj0WAjDCsFugAKJrffXv6vZeQCYi BUHo6C+kZmH6
B8AoAl04IJz4C2O/i6WXkqoopALRvis5+y5XiZBaXarV2IQPriaRTSE3lcjb rPmiI344mv2P
VOlRufFTM3ZoZ/KH8+xaqBbMH/P+EfWwJkFA9Rf6XREA+ktgb350rY/W08av qY4GVgWiKVRc
itui30cGQB+BLhwQTPwtLu08NiN3VZmAfOvGJa00TC8RJgqZQOwwH7nNzGHO 8NS7VsflAHVQ
Qbbw8d7EYbfZe0hwatI98BeCMSGwNz+61mdfT3WvfZtV/YUAjCoH/a7AuMBE HhWC9eYW3aSh
ThTSUPUUMlG4dnHD5nkn9qgPyvMlew/xoSYhZ69OwF8IxoTA3vwY/YVOjqKj fGSWGF8IRhX4
CweEKv4erhVnz2RoaOxKbnyjzDth3cdUFBLb8YUdoYqqmwp3mb2HBKcmroC/ EIwJgb356au/
EOMLwagCXTggtBLQVBSqErDtNSzt5prrRhoCH4G/EIwJgb356ZO/EOMLwWgD XTgg1OWsbcLs
1+oazkltLuALPK904ktS3XSzI/AXgjEhsDc/GF8IgAegC/vO3PtYFn9Y2bhf SB1PWW3aA38h
GBMCe/PTV38hxheCUQW6sO/A5zeewF8IxoTA3vxgfCEAHvCoC8tPyn7XHACP OPf5dQP8hWBM
COzND8YXAuABj7qwY9/oxr2Ch/7TWlNYeVSQZEmUROW5F1xs+WQ2GXX6hCXf PXOel5UBnpGk
Js+7WN2Q2pPtQXQAwV8IxoTA3vxgfCEAHuhXP7IHUXjl0erD5+WpiViMXuaj ypVelqXs35bn
j6YvnVzw92MCAacpEVGiP9n0O9NeWmy7nUo3yV4kOcHFo0R8TSID+VWHvxCM CYG9+cH4QgA8
0C9d6NZfSEXh+vON+aPTyfhUhOOVwRukVW/WY3ys8LhIDSANgQ1UFEbeVOSg zCm/6fy2ohEZ
SmRb2VX/UY5HOel1azC6EP5CMCYE9uYH4wsB8EAg/IW1pvDweTl9JDmdSKUm 9sZ+TU+Q8qsy
vS1bf15KJ1POO5Qjh94Rf3qpi2sTrXKpcYdZQECQ28qPtF86RUjI7n19+8su vibxtwdRJfgL
wZgQ2JsfjC8EwAO91IUb9wpWu+xl4sqjwuREJB5LMFFYflUS6gLdTB9JT/KT Va46NRFbfVK4
+8GK2ypphV1HUag1gCIcLuhvurzNEbInComqFHWWSkfzILQa/IVgTAjszQ/G FwLggR77C031
n41eZDSlBs8c84TUpfraE+URcLVXQqlWltsjxFqyYuO2Mt1oO4jC4aK1zfGa 0YSU3LUr589d
MlrKgxoUBH8hGBMCe/Nj9BfWv6szYWcaqrkEQbCywfhCMPIEYv1CUZbEn2Tp iNLMmpJU+W5v
WjH3VvviyhHZ5S+PURSyFLWzWI13lIA6M20Jxr3AH3b9hQohkrt6hf6/flOR hjr34MCuYPAX
gjEhsDc/utaXSDgaiRT/bYdlJcSfFV2I8YVgVAmELoxwfItIDalJ43E+xh/i 2dV78WSGI9x6
rdSUxHDvfnl0Ywft3YpGM+PIRYhC/9H0FzNRyKDScEGVhtt6y76i+gvLj8ss buOoMA2JptPK
NB0hwoCE9n44v8KW1Ko8rfSjZL9/7wDoI73XhQcOHNBu/vrrryzCZigbw3pq 9i6zeFyp/88s
/V+kl/OPk/Fo/MzROVmWqS7kuXAs6m5pQOYO7F6xGUvQTk8BAUH5nd7tPmYp uaVL+RtKfFUr
DQdZpfbFo/ai5vdnA0DfEQTB7yoMjoVzWBwDjDKWurD8pOztsRCqENTBhh4a Q0r46Az3Xlx8
UI6cSsnP6q3nlVsf5Gl6U5aKVaoS5dp3W7nT593WpFfSUItupnMPSwZdQlVY XhWFF5SRheeX
Ll3fLw0JGdyYILVzLXUiBX8hQoSjEZYfl5NHkwTjC8HoErJ6ot1gnhXGoKKQ /+AMkUQaSmSN
6sIrT663ZLkpNURZrjcbZ05knC9So8WzNMR85CGjPfWYykEqDZkoVAjRO/tL TBQOrPtYRdYM
Y+84YgkAEHzq39VVZyHGF4JRJTRI/WeF+KCsiMKzC9Lnq+JTpd9t81W7V0Im wg/1uWNz+S4W
tXYoDbVTUoj1kEGdGQgIyvqF9Jd6W+k+3reDSsOlS2zxmgH3I3POlr0AAAwL tC2v3ly9++Vd
vysCQB/p8fjCjkvSOESSFBd9lI8Vz93y4CnUqTrt7BDjcoY2CxxqU6zM4FYM ClQahtrPyVHX
td5NJ7rIQJCdLZMLABgW0JbBONBLXejhmciMyKmU0oP8+Sp/doHwa+Kd4j/+ XPT7kwFDhryt
eARNhvzsyMEdlTawvh/4CwEYMbRtGeMLwagSiHVq5Gd1iawpPcj8mtzEI4aA a5ITnPCjpfzi
2tIwcbgdf2tAVYK/EIARQ9uWMb4QjCqB0IWt5xX6ohHxDtyEwDXVb5vTR6Lx w53l18Y3zdS/
Rsj2IG704S8EYMRAWwbjgP+6MF5+aG/Aljl0UhT/tt2sT/lJtZZSykmWC9zx aZY4+eFqIhqh
EaEpbn2JVamGksRhfuOfzYbYkl8Tmcj7Hou8+wUPhwj/Jpc5HiPbksNiN+4X bDY7An8hACMG
2jIYB/zXhR3xPGxRBxWF079u0Uj1wCSLUKgoXL96xu9DBF3BETl9lFP+hwib dsyFdvcwNF9z
yaks1C/V5HbmPvyFAIwYGF8IxoGDflegM72a46yiikIA+gf8hQCMGBhfCMaB IdCFvfIXJsuF
6oFJ+pKfVNVEoSnOX1yb/HC1+/J1DwDUpht3WRm7Lbyjpbqpjaj0/N2BCvyF AIwYaMtgHBiC
fmTn4wvt4Y5P97Uf2eoBgAEsXC2NCr6+Vns0iESUlcxF8SWN0NBhLvgLARgx 0JbBODBG/kIq
B/06BKq9tC634KgxXcWAEa0WZNLQYUb4CwEYMTC+EIwDI+4vrKdmWSRefhi/ kWPSkEZUA8HB
colMOWl9bCzCUtS9qtrTGTgp3FiaMW5aOEvX1bBLbGSrk3fXCs3ByF/uTX4A 7+IW+AsBGDEw
vhCMA0OgC7v0F4aPzkRvXGouXWk9r/w/e28DZMdx2Hf2SivqrUzabx3KWUTk GcuczgQsKgTP
kgK6fA6XYe4IWJcTUL5YwNkpcWnnSDA8C6DpQMDRKRkgKggB3SGgfBVzSZcd rsqhsayKSos6
67RwUjpAZ1sgIvkAuqToQRF1uzFgv+eI8htRS+7129lt9PbX9PT0vJnu+f/q cdivp6c/5s3b
98e/v+QZJ5lr0/CCjBd//ClB/dj30hpyE8o1pFemLIJBFGaWLqQpXhlLlnqk 2xtseZIka2qs
z21/N4hfXft6coImYLOVywV+IQCRge8yaAIB9COn85FtjkqoKGRHB5R+mHnS hjIBy0dQb7rc
7F3Aaruka9IhTkXh+M2kTV/tVvra1G6N37z6Wg20W63O6oYonev5en9Y3zE9 YnwhAE0G32XQ
BILxC22OSpb2Hx34hZ9yn3Es2GC5LECbzC3LBQY615MkWV2/cJnc+Bf9qmXY X906mawvZnj5
W8mWiXx/3O21IA/8QgAiA+MLQRMIxi90pn/pfGdqZ/+z826X88MHlafsMes8 5foyZc8LiUl3
Dv5gL2+MGt3wDx83dSZMNLGfdwK/EIDIwPhC0ASC8QvdyNxkLxOhP5cXakpF lUvJGXJT9iNn
li5XQJnMnIlOLDqUPjRahBs1uMwduQR5YRKQ14L23iH8QgAiA99l0AQC0IW+ 1i90RjetRHir
62gWhJ195sqwTXqdqjOcNVTJufTQV8Bx6z5mwC8EIDLwXQZNIIB+5GpFIcgF v5lKHD3Uzv3I
8AsBiAyMLwRNAH4h8EkcWjClYD8y/EIAIgPjC0ETCEAXQhSCSijYjwy/EIDI wHcZNIEA+pEL
zkc2k5y7cGFkK33RQNUNBTUlXbmQ5OlEJvALAYgOfJdBEwhAF5bqF74yNb19 5TJ90UDVDQV1
BPsjAwBSML4QNIEAdGGpfiFD3iKPJ3Nqbehzb4F34BcCEBkYXwiaQAC6sFS/ cNvCTGY/ss3U
2qrW7QMpNxa1ZssWjkoJhgv8QgAiA99l0AQC0IWl+oWt+7ajHxkYwP7IAIAU fJdBE2j6fOQL
I1vNPcgAYH9kAADB+ELQDALQhc7rF74yda8cuW3hPP928uRhKg3TQNUNBTXC ML/EUibCLwQg
MjC+EDSBAHRhEb9wy8/u5t9eeemMkGDi43voy5CD/b4d6RDDmBZ2bjIFFy8k 8AsBiA58l0ET
CGZ8oc1RJLX5v9Vde7GYPNhPKIEojJV0ZCF7WV4FvxCAyMB3GTSBYPxCm6NI kpCvJeTVzvrb
sUEMAHlI55qwGSdYvxCAxoLxhaAJBOMXupCQ5N2kNzGWvmi4gtVKQFOBXwhA ZGB8IWgCwfiF
LvSSpN0iH9iSvktWY4rUhPUUywEABOAXAhAZ+C6DJhCALnSej0xZ/KSHtQ/Z hBImAeUABGKs
pN3HbBVDrF8IQGPBdxk0gQB0obMo3LbobWFCm/1OhnlPwPDJO0MZfiEAkYHx haAJRD2+EIAC
5J2ALAC/EIDIwPhC0ARi9gsBcIbf8i7X9ncM+IUARAa+y6AJwC8EoBTgFwIQ GfgugyYQgC6E
XwhCBH4hAJGB8YWgCQSgC+EXAhsGf7CXN0aNbhgoMWR1Br8QgMjA+ELQBDC+ MAPnBWgsL7RP
xsJ564M1dNzgZ5zwYcuxhvALAYgMfJdBEwhAFxZZv7DOWG67zMBaicPEYaKJ APxCACID32XQ
BALoRy4uCu94dLbqRijgF8oG8QG/EIDIwPhC0AQC0IUFxxfuPDa/7fYJenTO YWQdXYwctkxs
KNGtbt5rApyBXwhAZGB8IWgCAejCIn7h/KVO51py5uAUPdKwWyYr66Qqiu2J x2LIeicvfyqN
NyQ2lyhHMlVnk7mvmgBn4BcCEBn4LoMmEIAuTP1Cm6PM9KkLl0/uogF6pOFK 6i/7dm7Iqq6q
mjSEdnuSvnRvM4FfCEBk4LsMmkAAujD1C22OAvOXOuPt1v3752iYHmnY2TIs wgpHhbexVjUJ
hbmXZwxvzcAvBCAyML4QNIEAdKHz+MK9xxcWl7oXl7rje2bokYZpTIUNqY9R V5+a+KI10GEb
FyxcXn+xBMOtEvxCACID4wtBEwhgnRrn8YXdWT+r2wij8Qzj8+ROXrfBfMqV aOR8hlAT4Az8
QgAiA99l0ARi9gu9oOx7FWKUp/izusREI9HkSF0XsMeaAL/ALwQgMvBdBk0g AF0Y5aLWIHrg
FwIQGRhfCJpAALoQ+yODEIFfCEBkYHwhaAIB6EL4hSBE4BcCEBn4LoMmEIAu hF8IQgR+IQCR
ge8yaAIB6EL4hSCTgQRLl6RZX5hGmGo//H/mwy8EIDIwvhA0gQB0IfxCECLw CwGIDIwvBE0g
AF1YrV9YZNM5mzSWG9ONcAytCaAI8AsBiAx8l0ETCEAXxuoXpotX2295XHx/ ZDBM4BcCEBn4
LoMmEPN+J4w7Hp39xqf3VN0OESwrXQaTm8WYi1+vpibwCwGIDIwvBE0gAF04 99JMEWm489j8
ttsn6PFzB3e45SBvHyfEpG/5sOFyPrGhREvVWHZNgqNzlSx8TYzccnsFNYFf CEBkYHwhaAIB
6MIionD+UqdzLbl8csfW/XM0vOPuSYdMeDmYduMKMYRTWoJ2NCRmyCpQqdWU 8tRvTSJgcjOZ
3rwh5uLXqUSroCbwCwGIDHyXQRMIZnyhzVFm+tSFyyd30QA90nAl9TfPF7G3 BouPL3SeuRIQ
natk5vMbXq90qqkJ/EIAIgPfZdAEgvELbY4C85c64+3W/fvnvnByFz3SsLNl WASD7LMXhWXX
JAKoCmstm/zCIf9LH34hAJGB8YWgCQSgC53HF+49vkCPi4SM75lhMd3Zyla9 EVTgkEWhoSYx
gfGFAICSwPhC0AQC0IXO4wt9SUBhYB/fkyuPCxR6aQ2JycapIZmSUc7HY02i YRLjCwEA5YDv
MmgCAejCgvORC6KUUIZpInJ6XWKDOMvMxG9NYsKjXzj38ozhbSbwCwGIDHyX QRMIQBdif2SQ
i3vfu+Ftf9nRL5y6b8rwNhP4hQBEBsYXgiYQzHxkAMICfiEAkYHxhaAJBKAL 4ReCEIFfCEBk
4LsMmkAAuhB+IRgqy3avLOAXAhAZ+C6DJoDxhSAGWoM/2etvlrkjl2DYVYJf CEBcYHwhaALw
CwEoBfiFAEQGxheCJhCALqzWLyyy6ZxNGsuN6UY4htYEUAT4hQBEBr7LoAkE oAtj9QvTxavt
tzwuvj8yGCbwCwGIDHyXQRMIQBcW9wvveHS26kYoiHJZacCAXwhAZGB8IWgC AejCgn7hzmPz
226foEfnHOQOXCFGDlsmNpToVjfvNQHOwC8EIDIwvhA0gQB0YRG/cP5Sp3Mt OXNwih5p2C0T
oQNX2f+bmn/8qTTekJglkHdDVlqJTNXZZO5QE+AX+IUARAa+y6AJBKALU7/Q 5igzferC5ZO7
aIAeabiS+pvniwxzfKHzzJX6M/hrLSxPMyolGHKV4BcCEBf4LoMmEIAuTP1C m6PA/KXOeLt1
//45GqZHGna2DIuwwlHhbaxVTZoA/EIAIgPjC0ETCEAXOo8v3Ht8YXGpe3Gp O75nhh5pmMZU
2BDBqKvQt4vSMqwb8AsBiAyMLwRNIOb9TrqzfhY+FEbjGcbnyZ28lomFU/KI Q7kaHmsCygB+
IQCRge8yaAIx+4VeUPa9CjHKU/zZzMRyoTbV8FgT4B34hQBEBr7LoAkEoAux PzIIEfiFAEQG
xheCJhCALox1vxMQN/ALAYgMjC8ETSAAXQi/EIQI/EIAIgPfZdAEAtCF8AuB DTeWMGSMbphY
NeS/6PALAYgMfJdBEwhAF8IvBCECvxCAyMD4QtAEAtCF8AtBiMAvBCAyML4Q NIEAdGG1fmGR
TedKyrmM+o9wBNrSugG/EIDIwHcZNIEAdCH8wlwwEZZX5BXff7mqltYT+IUA RAa+y6AJBKAL
i/uFdzw6W3UjKgD7IFcL/EIAIgPjC0ETCEAXFvQLdx6b33b7BD065yB3sAox ctgycWZZyoAy
gTKxoRS3tgfX0gqBXwhAZGB8IWgCAejCIn7h/KVO51py5uAUPdKwWyZCB2u6 ebHQ5Zo6c/yp
NN6Q2KYsAWVuykwyW6TMPMWm8qG0tELgFwIQGfgugyYQgC5M/UKbo8z0qQuX T+6iAXqk4Urq
n2s+h/Pkj+IUH19YYUtbAx22ccHC5fUXS1Du/ROBXwhAZOC7DJpAALow9Qtt jgLzlzrj7db9
++domB5p2NkyLMIKhzmlbMKFRXNaagP8QgAiA+MLQRMIQBc6jy/ce3xhcal7 cak7vmeGHmmY
xlTYEAdvLHXv+L5dj5mjpaUCvxCAyMD4QtAERotnUTbO4wu7s34WPhRGyxnG z8mdsObBdnxi
Qx8uu1DOjcUIAbO6UiaQ6xlES7vdRedPtlTgFwIQGfgugyYQs1/oBWXfqBCj PMWfVSZe2Yih
OGV9hBghZ/6sMhObZobV0roBvxCAyMB3GTSBmP3C0GGuWNUVQUtdgF8IQGRg fCFoAvAL60vc
0zKibyn8QgAiA+MLQRMIQBc21i8E9gwkWLokzfrCNIIVPnzLDn4hAJGB7zJo AgHowsb6hSBo
4BcCEBn4LoMmEIAuhF8IQgR+IQCRgfGFoAkEoAvhF4IQgV8IQGRgfCFoAgHo wmr9wiKbwpWU
c646WO41N8IRYktrCPxCACID32XQBALQhfALc8FEGL/XnI0yK74/clUtrSfw CwGIDHyXQRMI
QBcW9wvveHS26kZUQHwrv4QF/EIAIgPjC0ETCEAXFvQLdx6b33b7BD065yB3 sAoxctgycWZZ
yoAygTKxoRS3tgfX0gqBXwhAZGB8IWgCAejCIn7h/KVO51py5uAUPdKwWyZC B6uyfzY15/hT
abwhsU1ZApZdw3z+qbSSd7dTZi4kDqulN5YwZIxuWMVwyK4d/EIAIgPfZdAE AtCFqV9oc5SZ
PnXh8sldNECPNFxJ/XPN53Ce/KFjmOMLK2xpa6DDNgrB5fUXS+ClJGvgFwIQ GfgugyYQgC5M
/UKbo8D8pc54u3X//jkapkcadrYMi7DCYU4pm3BhUWFLJydai9eTbm/w6r++ +krWXhSyepyc
GKTcND6kuwG/EIDIwPhC0ARGi2dRNnMvzbh1Je89vkCPi4SM75lhMd3Zyla9 kftzM2HunY3S
Kl5coC2dOduZfnBy8rbsf8rPfXFp6n3jZHkYf9DhFwIQGRhfCJpAALrQeXyh LwkojJYzjJ+T
O2HNg+34xIY+XHahnBsvp/iAeZyfUrfJiYNoabe7uPunNj37cqc3cAc1H+Eo GRsl7Ztbe+/b
RJZ7OT9/R+AXAhAZ+C6DJhCALnT2C72gtK8M0zjk9LrENjnbJJAzNBdhU8mA WtrrLbVIMv3A
avfw4HEeqLHW2nO9/o977jHvDUkWwi8EIDbwXQZNIABd2Nj9kS37VSMgypbC LwQgMjC+EDSB
AOadNHa/k3AnoKClBH4hANGB8YWgCQSgCxvrF4KggV8IQGTguwyaQAC6sLF+ IQga+IUARAa+
y6AJBKAL4ReCEIFfCEBkYHwhaAIB6EL4hSBE4BcCEBkYXwiaAOYjZ1De6tDK 9f8MZXmpSd5C
h3lDIgN+IQCRge8yaALwCz3AxFbe3X7tN47LVY1hFuoLj1tC1wT4hQBEBr7L oAkEoAuL+4V3
PDpbdSNA44BfCEBkYHwhaAIB6MKCfuHOY/Pbbp+gR+ccRtZhb/lThoB8FR9j KE4XyJsylwmn
a6aNG2pzrf09jAP4hQBEBsYXgiYQgC4s4hfOX+p0riVnDk7RIw27ZcJ6XQ3C Rdiije1QzF8l
b1ssqKXiGLatYygLVVbY1y2yzLxW/drFgV8IQGTguwyaQAC6MPULbY4y06cu XD65iwbokYar
bYhyw1/dOL9US5VhoeUaXGhZDe8CNwLgFwIQGfgugyYQgC5M/UKbo8D8pc54 u3X//jkapkca
drYMgQHeDqy6LjUCfiEAkYHxhaAJBKALnccX7j2+sLjUvbjUHd8zQ480TGM8 Vqwke4xfO8a8
jkx6tqSFY+yrUaRiEVuM8AsBiAyMLwRNIOb1C7uzfhY+ZNqFF0lygI2fEwbS eRRtvIoSRjQS
lXqzF3O5KixUQ9fRLFTM8h76uleVA78QgMjAdxk0gZj9Qi8oV/tjb5XiTLhQ iCecNpLL0iUW
amJwEA1vMwuVm2lZDZuK2d/DOIBfCEBk4LsMmkDMfmHcMJut6ooEU7EhA78Q gMjA+ELQBOAX
hkpt53nUtmJDBn4hAJGB8YWgCQSgC+EXghCBXwhAZOC7DJpAALoQfiEIEfiF AEQGvsugCWB8
IQClwPuFna910gCNtD+yS4RrHbLCEUccvRzZFxzjC0GsBKAL516agTQEwcF+ QrZs2fLsqWer
rg4AwCcYXwhiJQBdWK0oLG9RPWHNP10plhVgySyzrbbtTSA19vY9vm/b3due e/65qqsDAAAA
ZIPxhR5gUizv7h38sn8ed/4oKVuQi9QvpKKw6ooAAAAAtjTCL7zj0dlvfHpP 1e0AzaI12pp+
aPrCFy/0ST/tcmIBFjbH8JcIZ+ULEUYY4SGHCQAxEoAuLDi+cOex+W23T9Dj 5w7ucMtB2MON
713le2/lgHxV5prPmcmc+3Zt6lPG3n2N5cCvHKi6CgAAAEA+AuhHLiIK5y91 OteSMwen6JGG
3TKx6ZMVNnNjuyTzV8lbJ49wCFozc9NhA8psM+ujrDMAAAAAmkMAujAdX2hz lJk+deHyyV00
QI80XG1DlHsTm3cldi5IzpYpRUNBchoAAAAANIcAdGHqF9ocBeYvdcbbrfv3 z9EwPdKws2VY
Wyw1HO8FGpIpBSUAAAAAGkIAutB5PvLe4wuLS92LS93xPTP0SMM0xmPFIvbV Im4aAAAAAHQE
MO/EeXxhd9bPwofCbAx+ugYfYCPzhCF6fr03Yd6JzVwWPpllGviFAAAAQAOJ 2S/0gm4IINOI
LEYO8FfJIwiV2iszmW6QoiGBsiHKSwx1BgAAAED0BKALsQkeAAAAAMAQCEAX 1n+/EwAAAACA
CAhAF8IvBAAAAAAYAgHoQviFAAAAAABDIABdCL8QAAAAAGAIBKAL4RcCAAAA AAyBAHRh3fzC
XGs+C4md14tmWxhnVsZ+BxT79L7SAAAAAKDOBKAL4RcCAAAAAAyBAHRhcb/w jkdnq24EAAAA
AEDdCUAXFvQLdx6b33b7BD065zCyjhypSyOnt8nWJsayevxZL012qxsAAAAA AiIAXVjEL5y/
1OlcS84cnKJHGnbIge13zG8frNwEWbct8giHOVshhk9jqKGcj3DWodW56gZp CAAAAMRBALow
9QttjjLTpy5cPrmLBuiRhgvWxLBxsME8U+6wTOrtwBX3KQEAAAAQHAHowtQv tDkKzF/qjLdb
9++fo2F6pGE3yzATS2NPQNCLbpk4VNVXc3R6FwAAAACBEoAudB5fuPf4wuJS 9+JSd3zPDD3S
MI0pUpOSvLHQLbfQ6w8AAACAlNGqK5CN8/jC7qyHhQ+VQwYNaZyzlTNRZsvH MKPRUL3U/JPz
5COFPM3lyrWFXwgAAADEQcx+oS+E3lJBZglpmGySE8vXCp2wcs+snK0hJrNE Pk9loTbl2twW
AAAAAIRIALqwbvudAAAAAABESQC6sHK/EAAAAACgCQSgC+EXAgAAAAAMgQB0 IfxCAAAAAIAh
EIAuhF8IAAAAADAEAtCF8AsBAAAAAIZAALqwbn5hrqUKhcTOS0CzXYmVuy27 1ZDf7tkmW+83
BwAAAAC1IgBdCL+Qh19K0KMIKylbAAAAAAREALqwuF94x6OzVTcCAAAAAKDu BKALC/qFO4/N
b7t9gh6dc1B2sAoxQhqbDlk5W5sYZT7mEot0XguNymw4AAAAAMIlAF1YxC+c v9TpXEvOHJyi
Rxp2yCHdX1joYGWR/B7BcgxLrBR8ykv4GD4NfyGDL8LQBWyzQ50y28yGK1sB AAAAgEAJQBem
fqHNUWb61IXLJ3fRAD3ScMGaGPYCNthmys2Fias7qNuquHjTDBrUUBD8QgAA ACAaAtCFqV9o
cxSYv9QZb7fu3z9Hw/RIw26WYSZKYy8TQYq5ZeJWW4+N0qleAAAAAARHALrQ eXzh3uMLi0vd
i0vd8T0z9EjDNKZITUpyxeIw2+JoBQAAANBkRquuQDbO4wu7sx4WPlQOGTSk cc5WzsTXoD1+
yCCfbaYRmFm6zc0BAAAAQCjE7Bf6QugnVQ7sE7pTdSMRhWvlYYJyWcpsDXma C+WzNSTILF2u
oTkrAAAAANSfAHRh3fY7AQAAAACIkgB0YeV+IQAAAABAEwhAF8IvBAAAAAAY AgHoQviFAAAA
AABDIABdCL8QAAAAAGAIBKAL4RcCAAAAAAyBAHRh3fzCXGsKComd1yNk+xEr d1s2FOpWW8uC
vN8uAAAAAFRIALoQfiEPv6agWXIVlHT2BQEAAAAgDgLQhcX9wjsena26ERWA PYsBAAAAkIsA
dGFBv3Dnsfltt0/Qo3MOyu5UIUZIY+PVydnaxCjzsSxRuKT4rVAW7aX3GQAA AADDJwBdWMQv
nL/U6VxLzhycokcadsgh3VxY6E5lkfzuwHIMS6wUfMpL+Bg+DX8hgy8iV4ev jY+oLCjzVijb
BQAAAIAgCEAXpn6hzVFm+tSFyyd30QA90nDBmhh2ATaYZPKux7pLbJw2ZW5l 9BcrC5JrmOtW
AAAAAKDOBKALU7/Q5igwf6kz3m7dv3+OhumRht0sw0yUxl4mgvByy8RX/T02 U6eDAQAAAFBz
AtCFzuML9x5fWFzqXlzqju+ZoUcapjFFalKSBxartRZruwAAAIBYGa26Atk4 jy/sznpY+FA5
ZNCQxjlbOZPyhujxQwb5gjKNwMz62NwuAAAAANSTmP1CXwi9osqBfULnqW4k onCtPExQLkuZ
rSFPXQ11l/AFma8y10euszkrAAAAANSNAHRh3fY7AQAAAACIkgB0YeV+IQAA AABAEwhAF8Iv
BAAAAAAYAgHoQviFAAAAAABDIABdCL8QAAAAAGAIBKAL4RcCAAAAAAyBAHRh 3fzCvGsK2uwL
Z7/jSK5sM7NiR+UmzgAAAABoFAHowqD9Qn7vOI+Sy3u2/MKEkIYAAABAMwlA Fxb3C+94dLbq
RgwoaYVnLBwNAAAAAC8EsA/e3EszRaThzmPz226foMfPHdzhloNyYzdh4zgh Tea2cubN4oR9
6pyrylfDYXs6OTd5x7wm73rX6y1VXQUAAADAJwHowiKicP5Sp3MtuXxyx9b9 czS84+7JvDnw
Eo2F5YCcRt71WE5DNBIwU2PZZyvUU1ci33csb2Gna3hmtnHTbk/kSk91ZN5L AAAAgGESgC5M
/UKbo3zt9KkLi8/voYHLJ3dtemh28fncupDHsOevYUxeQQk4nGx1tmVmsoYP RlzqkW6PJMsk
SRL6tr+8foLGcIFtm1uTE6T7OpWSa5d0rg/Ot6quv4Gk6gqAksBTFyX4WKOk ko81AF2YCj6b
o8D8pc54u3X//rkvnNxFjzTsZhlmIthmpeY/NCwb1TSPUIAqvPGbB3IwaQ2+ v+3lgUZkDMLL
g7Od15LJiVbv9T67JEla9G9lq87fv+XiWTSUmv8K4qlzAx+rOzX+WEm9P9lK PtY6P0prOI8v
3Ht8gR4XCRnfM8NiurPuvdIO+izzEjfNV1K2RWhgPzJZVX79VfFHOEV4+Omj h588lP4p7KdR
q9+z7uvcJaOkVe+/lSH8bagpdf9k60yNnzp8rO7U+GMl+GQl6v1xreI8vrCI BGQoR/IZ0thc
npmnoLHk2R55s7VphX2jimQbGclykiy3CNkgCunxyPGjBx4/JCZe7Wumx4G5 WP+/RPWvIYiP
mj11k5tJ56riCPJRs48VmAlAFxacj1wcWWPJYZs0lnkqL7EcQWhfDWFyjK+G N43+cqvNDSU8
fPxoGpRFISXpc+H1SwAYNnjq8rDwNTK9WTze+96qqyWDjzVKqvhYG7F+IQBl MfAL1766sigU
hq3UeRQLAAAAQOAXAlCIjd3Hg8D+gSjsrscn6YSy5RuJ+8uD6SnC5XUkgL8N wAk8dVGCjzVK
qvhYA/i4IApBbRlYgKvf2yNPHkr9wiMnjx7Yf0hII6w1sGYx1vzLV+efmZpT 80+2zuCpi5Ka
f6z4wm4kgH7koPdHBpGzOg05WRV/gznIq5w4ebTV2phm9f/9/NkDAAAAwyQA nQy/ENSWwaIz
hIyl/xoeHUjDI6uu4YnjR/etuobpPOUNfiFbv6bm/4YGzuCTjYWLX1cf+/iI YwKf5kYC0IUY
XwhqDZWGo2Rs/afiwP5DJ06uiUKiGke4ujnKhuWvAQC1Zcvtg2+rfAQgVgLQ hXUThc5rSsvx
NjHmImzS+0oDlNBfiNbGPuIDjx9KuIkmbCLy2PobZjZg6yowfPDURQk+1ijB Pnhq6uYXQj8B
xrbNrSuvmf7opSvpb7ltNXzL2iWd15JW7f9W1vlnpubU/JOtM3V+6vCxOlPn j5Xgk5UIQBcW
F4V3PDr7jU/vqbodIDYuvLq0/c6Jydus/ujNfWlp6n3jNDA5QV81/zsJAACg oQSgCwv6hTuP
zW+7fYIeP3dwh1sOwlZvaZcrvzGdbi84mz3icm2I51ZhyxiQly23tee+uLTY 7Sev039xJv3l
jeOX179bY6OkfXNr732byHKv11tKEtK53r/8LfwbFQAAQO0IQBcWEYXzlzqd a8nlkzu27p+j
4R13T+bNgVdm8rbFhgSGC3nMadxEm5ynEGNZN2Dm2U+d4N+O6VP2aOJLVVcX AAAAyCIAXZj6
hTZH+drpUxcWnx/0IF8+uWvTQ7OLz+fWhTyZ+knnFw4Zm3KrqltM7HsEgxMA AABERQC6MBV8
NkeB+Uud8Xbr/v1zXzi5ix5p2M0ydMa7D5d3ZrFB/MEjBACAmvPEJxbo8Zmn p8wJZAyXAGAm
5v1O9h5fWFzqXlzqju+ZoUcapjFFapLpsekS1Nmcq3PdAACgsTDNpxN/RKP/ IApBEYLxCx3o
znpY3YZNMSEaj02XQBnPizDznBWWXpknHynkyZcrp2HDDTHvBAAAaougBelb ndqj8XxiiEJQ
kJj9Ql+srMPeEkkCygmU8TxCjHCt8i27RC5aV5CyFEOdAQAAVIvSILRxDSEK QXFi9gsBAACA
4HCQd1CEwBcB6MK67XcCQMqzvzFbdRUAAAAAnwSgCyEKQT2xWaemfavt/Pfe 9Y59YgAAAKAM
ML4QAAAAAAAMCEAXwi8EAAAAABgCAehC+IUAAAAAAEMgAF0YvV8oLDfovNB0 eqGv3GyqCgAA
AICYCEAXxuoXlqexystZt8wh9CIAAAAQAQHowuj9QgAAAACAOhDAOjVF1i/s TO3k304ufM4h
E2HLOH5vujTM9qbjN6lTXiXsYidsc5dZtDmGkRYk5KyrNtFsr6esHrvQoS0A AAAAqDnx+4Vj
d99L5SA9ul2eyh3dvsMMYUM55VUsUqntGOaihRg+jUPrWFbKBhryNLQFAAAA AIESgC5Mxxfa
HJVMnDzEjgXJJX1knWe4XLmFsTITOUaXYalj/qACAQAAgPgIQBemfqHNUcnS /qOD46eeHXK1
dVKvSCa53MGypSEAAAAAIiMAXVhwPnL/0vnO1M7+Z+eL18RtCRgv4syjwoNY BAAAAICSAOad
FBlf6DbRhEceQidPNLG5SpfG3LmsK1qZJjOHzGoL2E8lyWwLAAAAAOpP/H5h ceSuW/aWP5KN
ElC4SjjFBwQ5ZciEqLqnhZjM3AzVNlyrq7DuWgAAAAAERwC6EOsXAgAAAAAM gQB0YeV+IQAA
AABAEwhAF8IvBAAAAAAYAgHoQviFAAAAAABDIABdCL8QAAAAAGAIBKAL4RcC AAAAAAyByNcv
LBV5xb40Zjgr+dmXYt6Lr9pWBM3UU0uZaS5+erLqagIAAAC2wC90Z8iyick7 m/2R+av4BQ7l
C6tqRQQsfHIi8wgAAAAERAC6sLhfeMejs1U3widF9lyGBeiRqaeWqPgzH6uu IwAAAJCDAHRh
Qb9w57H5bbdP0KNzDiMchLPrBAPP7IQJaZQBZQJlYkMpuRpVz1aEQqYoVHY0 93rJ0lLvwqUr
8+deoUcapjFVNwUAAAAYEIAuLOIXzl/qdK4lZw5O0SMNO+TA98OySD6sTCBj 6MkVMjHvd2yu
rSGBLPtq24pQcPALqQTsLC12k2Ry8+TUfdvokYZpDKQhAACAOhCALkz9Qpuj zPSpC5dP7qIB
eqThClth48aVSpHe5/q0olY4+IVUBRIytmliotVq0SA90jCN6SY952ocHtmd vgynDGfLuDPm
cstD9vWFZzXXoyt0FJCcQ3uHg9+b7OVT0923sv96OGRet08TgDoQgC5M/UKb o8D8pc54u3X/
/jkapkcadrMMi2PpxtWcOFrhEQe/8MrVxVa7RbUh/2q121eudp2rcWTljOGU 89kilJezmfTJ
lI9CAhsyOwqixMunxm4au13sbWZnQsFyc6XHkgsAKAlgnZq5l2bcupL3Hl+g x0VCxvfMsJju
bC1WvWF/HDP/MHn8G+r9z3ElragPNn6hsE5Nr9tLNk+++MIcHzn1kR00npA1 EcncGvojnYbT
X2s5nkg/5Hx6A7whpMxBd9acVZGidfnkzZ8h/OqzJ5BFskeXpZQDwiVCbsr8 dUXossq8P8Jn
rXwM5M/dkI/h/su31/n+239Mmfct8z4DADwSgC50Hl/oRQJm/utWmUD446XL hP/3tPDLwf9N
lH/AdMgJhJx1balVK0LBwS9sj7dJkuz66I50OGErtQx7ySB+HfZ7T49pOA0I clD+mRfSG2qu
EwqCOMjsT8ybXkjM6qmUv4b4TJRfBCI90mnPY96HM1NHsrd8ETbVFtorf+7C bRT+5WCZjxDP
pxcKcr7/bh+T7r5l3mcAgEcC0IXOfqEv5H/FCvE2fVUOU0bMBdmXoryqJq0I Gge/cHJivJd0
CdnUWo+hARpD4wnpC/nn9WYq6brNi0FemC2rXE6hfX0cHkvlQ+5xopVSBfLD /ixvhYOS0/17
w7JQs1CTTVOH++ar5wGaEgAdAejCakVhGd0Wln2vNSeOVhTBwS8cb7V6vf7S 0mK7PT7ebnV7
Sa/XJQlptVuyLqwc78JU5z/xMXwaXbwZpbdUKro+azd86fvi+bjdfx2Zmy3Z 3Ddfn2lMHRcA
+CWAeSfV7nfCbxbiN88KG4VWeMFhPvLERHtyMxWEY4tXF89fuEKPNExjJifa cv55/R7vPX1D
qwDf12kTb0OR+Q3CtXlnMbsVqrwtfIDdB919zhufmbLI/c9LlEOQAQiRke61 b9inXji3MHXf
FA20b8Wur6AW9HpLrdH1XtmB/T0It9Z8cD7+RnqyPHDm2MOchp+5PrClzz9C etetJq3TS46c
25opDe2/KbRcllgY72WYn8Gjm6eiSyZEyvnbqAGb+Q3ms3J9nCedCD2VvKUt yA7luFvBQ9JN
VSGqobS63IRCi9xP5VtljEM+8hBDw+di/xEYInW3VDckWvc5CvnY32r4hQAo CUAXVj6+ENSZ
CnUhvdxifOF224aodGHVdxeAmIE0BEAmgH5kiEJQT0raH5nvPRzyutAANAqI QgBkAph3Ar8Q
1BOH+cg2wCYEAABQFfAL3dEt+DeEAdS5dpQy70BVYStCpyS/EAAAAKiKAHRh tfORDQy5D4Lf
bNR+Ryk+sTJ9Va2IAIf5yAAAAECdCUAXFvcL73h0tupG+KSIksN4Go/ALwQA ABAZAejCgn7h
zmPz226foEfnHIR+WD4gJLDJhL2VA8oEysSGUnI1qp6tCAX4hQAAACIjAF1Y xC+cv9TpXEvO
HJyiRxp2yIHvh2WR8h6dmYs8m3t+LbuGhSJ0m8DqGiLIvpq0IlzgFwIAAIiM AHRh6hfaHGWm
T124fHIXDdAjDVfYilwzRSwzzCWwvGxP4r0VQQO/EABfjIxU+fc5vnoC4EwA 69SkfqHNUWD+
Ume83bp//9wXTu6iRxqmMTvurmCnFuUmCr4yDLcVoRO6X+hl9eyyl+DOm78h va+q6raEKZ5/
8c1mwmVlxXYFeKbM2CU2McOvZ2bllWGhLCHee3N0W9FkxlteZeihKh5vmEZp 2GKHnbXZkkdX
H+VVmdM6ne+2+X6aG+tAALrQef3CvccX6HGRkPE9MyymO1uLVW/4TZ/MKZXr yLh9/N7FXJFW
REBJ6xcOjdCVRCXtNYi/4vmbNxIsnj4OUm3EC6ZUP/GaSY6pCXzFhHCawNwQ v40S/qmfGV6v
0kpmbsoY9tZXPNFoO3P90xhh7LtN281vDfUxpM8Vr6uAsIFncQLQhc7jC71I wMy1YJQJBFGv
y4R/uAXJL+8Wyn/25mGCuuoZ2lJJK0KnJn6hvKGtcudc3dbJhsQka99kfmsW krU/r2Ur+Evy
5q9Lb6iM/RbAfErdXsNEv7lzwfuTF5t9q5Vmp3K3ZSWCMlOe4uPTSOaB2Xh7 hiIy6yYXnbc+
yvTmegqZyJmXSt5lyHRnHf4+V/JX3aH+mWKuSHvzlusQ74Cld8MTzPjCChEm ZCgDfJqVjSjT
ZJbCYuQSlfkLVdLlXJ9WREBNxhfyQkRQAPIpFi//6ptj0kt0+QsZMpFhaWgJ 6eUKKE/Z10fZ
XqHcTBnEpxEuMd9P5X1Q1t8XyvtvqI+bKKRaJ30ZTskaS3a8lJnwp/KKKlkU 2tfH0C5dTZT5
85nruom9syJhd7tGcqkT3SjzakefK921vOoqV3pze3X1sb9vFd7PmP1CL5iH FxTJM3R5FEcr
ilATv5Bh+C1PT/ka+lbSJbnG54XeeVrP+vPSMBPmhMmmmlIG8QrMRurl0lK6 jmOH+ijbZaik
IZlONOuutYkxVsZl2wJlXy2xsMSEBHL3q6GLyUt83nbJS7Nl9gtn5m9/oS59 3ni3+5CLAHRh
tfsjl6F74tBScbSiCKGPL5TROUa6PujM3HKlTHO2UYdu9fFY4YKUVP9hIneY yqfsMeuhXGpJ
6Ud6aRfJo9LKGBSYmY/Hv8m++jF14+18xeeqbd7BgpXfvapKD6Afubb7I4OG Uze/0JfCcM5H
d6FNP3La020jB8trSKASzSOWd8B+2N+QV3XJVE7m+jgPZ7QsvW7Y9IEq9yZw K8vLADsb0ZO3
nnEvteHQGT3SvfYN+9QL5xam7puigfatw3NBqvULQc3p9ZZao621NwP7exBu rfngfPyN9GS5
T7iHOQ0/c33wjJ1/hPSuW61/nl5u4Rfa/k7Qcp2/VsL4MN3UB5spEboRZnkv yTWvwjz5IzP/
zPrYJM6sp1IzGaZ06Oam+LJddTnopsLY1Ed+hJSYF09RjuETcjDH60qxSW8z ecWyPsqZKIZ6
KmfS5FpVx9zeMkSncokTw2I0hoFVQ16kRig6szKGs77aa6iPIX2ueLf1evLa hwHoQgAMVKgL
j5zbmukX2n9TvOjCYd11EC14lgCIBrc+5QD6kSufjwyAkprMR+ZnlaInFLiR PjwQhQDEhNtA
wwDmndS2E9mwYGbZY05zrW+euWJ7Va3wRevmdiXl1mR8IX7FQXHwFAEAUgLQ hbUdXzhk2aRc
/D1TvWXOuqqqFX5Z6pFujyTLJEkS+ra/vBpL35IbgW2bW5MTpPs6GW+5F8QT 33xkAAAADSeA
fuTiovCOR2erboRPhryUURBQUTh+M2nTV7tFX5varfGbW+MscHOr3Wp1Xhuo xN7rfV+F1sQv
BAAAAHwRgC4sOL5w57H5bbdP0KNzDiMchJv1zS+PmTkVXEijDCgTKBMbSsnV qHq2woFkedUj
XH0lyeBtGjlwD+mpNNGqOd593VuhNRlfCAAAAPgiAF1YxC+cv9TpXEvOHJyi Rxp2yCHt95T3
djMnkGFplKqIz8Qgm4Ryc3UKy7KvDq3wRbKcJKudxakiHLCqFPtML7KUSeKr UPiFAAAAIiMA
XZj6hTZHmelTFy6f3EUD9EjDFbbC+16HmfJLmb5urfBFf7k1cArXhxUSFpBI vHUjwy8EAAAQ
GwHowtQvtDkKzF/qjLdb9++fo2F6pGE3y7A4lm5czal1K1b9QioEDz99dNBf PEq667bgiVNH
+YTe3EL4hQAAAKIjAF3oPL5w7/GFxaXuxaXu+J4ZeqRhGlN1a9ZIrT63LX2c 7TrvPl+RVnhm
1RociMLVY5KQsdGBBExF4Zo01JuIbsAvBAAAEBkBrFPjPL6wO+thdZvMvlpl AmEYny4TJqf4
BGkkixECQm7KpQd11TO0ZfitKP7R8AxcwGVy5MlDh48PJOCRk0cP7z/07LpT uO/xQ8mNzU+8
Ab8QAABAZMTsF/pC6DxVBvg0KxtRpskshXAjAg0lypmYc65VK/ySrL4OP3ko fUulYRqgopAl
oPgbXgi/EAAAQGwEoAurXdSaX6TGl6Dxm1u1d6YureAmHTNpSDhR6LH7mAG/ EAAAQGQEoAur
9QszHTLnPCtsVHytSNJFCtfVYSoND9Dj6hyUxOt0Ewb8QgAAAJERgC6s5yZ4 oHasr1+drll4
YP+hRJho4tsyhF8IAAAgMgLQhZWPLwRBkK5Tw3Y9EV/rjuGYvxLhFwIAAIiM mOcjg+awbXPr
ymvavuLWqlO45bbV8C3eCoVfCAAAIDIC0IVzL81AGgIDF15d2n7nxORt2QvR zH1paep942TZ
z6RkG7/w4qcnq749AAAAgC0B6MLK5yPrZlfo9hrOvNChLGBgy23tuS8uLXb7 yeskIcmGDZHX
H/CxUdK+ubX3vk1kueerXPiFAAAAIsNRF/Z6TRk41e0u6hpLTxluiOFCh7KA luU+fU3dyd4b
XcNkMTM/e+AXAgAAiAxHXdhu5zNCqNzJewmIjJmznd0/tallXDGmdXM7V57V ymj4hQAAACLD
vR95qUe6vcEk0CQZ/NL3udVAEi6wbXNrcoJ0X6dScu2SzvXBeftNycpYec6G CmtY/6JzlUvz
nJxoTT84+ezLnekHxs2J8z5X4963t7MGfiEAAIDIcNeF9Md7/ObBz3bSGvwy t5dJwq0PxxYN
6byWUE3Qe73PLkmS1mCzWvuSfS87Z6lpvNfQXksFULT1h5J+1lfoY3Bbq5dk VyTvc1WhLoRf
CAAAIDLc1y9MuLXi6M99+uN9+Omjq07PjUWGU+XZfZ27ZDSHH7aWg9dXi1i9 vNfQstwwis5z
t8m63OwnWelVzxV9qMgyMTxXVYH1CwEAAERGEV2YJKs9eszOGfx+E3Lk+NE+ +2lniVeNInpM
lvP7f8u+X97RlzV5G3fcPEibHodQdFVNzio6Q5cKz1X6UB1ef6iUz1VVwC8E AAAQGe79yP3l
Vpsb8kV/udPggccPyYkTbsE4dknd8VTDha+R6c3i8d73DqPoClvtnKfwXB15 8lD6aJ04eVR+
tBI/CxE6gvGFAAAAIqPAPnjLN8w/WRQKNk6Vrg6oE61R02sA91ylncvsoTpx 6mitniv4hQAA
ACKjiC5c+3/a0zcI7D80NrraA7j6doMvuHrc0AlYYbevfQPD66UdVtF583RN nCSDJanpo5W+
fZZJw+X8OfsG4wsBAABERoHxhWRNIhx5cu03+8jJo305jRDTsPGFpVPDJhcc X7j6kLBXahnS
Ryu9eN+qd8j+7VFpNzL8QgAAALFRyC9cmx9AyOF1aXji5NFWa2Oa1f9X+/sN QkJSk0eObxCF
a2lqAPxCAAAAkeE+7yRZXTFkbH0cGJWG6e/3ieNH9632+qXzSTcsfZL2JpOq f9eHWPrFr6uP
/SHfgaonstgPBBSeKyYKDzx5KH2iFM9VRcAvBAAAEBnuunAA/QkfJWPrKufA /kMnTq6Jwg3j
CNdJuJUOm8OW2wdNlo/NgptHYpOYPVfpQ0WPiTCgsAY3EPORAQAAREYhXUh/ qlsb+4gPPC78
fq/5RGPrb5hPhn3wgi467z54afoxu8dNeK4G85FFObjhuaoK+IUAAAAiw10X btvcuvKaSR60
Vn/Ct9y2Gr5l7ZLOa0krv6rwSxBaquZF51Wu6WPQvjn7OofnqirgFwIAAIgM R1144dWl7XdO
TN5mJQ/mvrQ09b5xGpicoK86DAwDFTD3xaW9920yp3F5rpYrm9QEvxAAAEBk OOrCLbe16c/8
YrefvE4Skgi7k7Fcx0YHFtFADSz3er2lJCGd6/3L38Iq141j0zhZ1XD0MTAl c3iuKmwU/EIA
AACR4dqPnCxO3cneZLk7yeJaulGyZYK+YBk2Ehtjb7nv8FxVBfxCAAAAkVFg /UIAmg3WLwQA
ABAZuf3ChXMLVdcZgFoAvxAAAEBk5NOFU/dNVV1hAOoCxhcCAACIDPQjA+AI /EIAAACRAV0I
gCMYXwgAACAyCu13sri0dOXK5aqbAIAVW7Zs3TTh08CDXwgAACAyHHUhU4S7 fna66ibUgrmX
ZtKAd/FRKxbOLYQ7xpRWnj60Hj+g0McXHh7ZTY9HVs5UnolDVh7LtWdk5IIc ubKyfZh1KLmB
IysrK1XXAgBQJS66MBWFUIQ87G5QgZgq5rgFYoikijadUO/lowndLxyyqKq2 PlTSeRFwaSYs
N6VSDBGqCKuuAgCgFuTWhRCFZgSBCHVYN6g69CUNa+IXps4ZWdVVgoumO8Xi zYmVZ5WRsnun
TJ/ZBF2J9uUqSdUb03BMIPIxcpgPCBcyeHUoZCIUIUfK+RNJaJq1rCzmnN2+ 9EKlOkwj4SMC
0BBGute+YZ96TRR+ZG/V1Q6GuZdfjEkaBt2PLDSE/1zo22euDwT9+UdI73rH Mocj57ZmSsP2
rba6kJZrn1jAXhrK0k0ZY9BbyvyFlLIGtfECDfWxLNeAzi/k44UwkdxBQ26y wpOTZeZvSD8c
lP3I0IUANIpC804oz7409crVK9vuntz3wPmq21JHqIam0hDGYS6OfPKo4ezh pw55vKoINfEL
b9wBvUhKTxXpqJXduzIuqRV5NZnSTTR0NGemz6xAXr/QzV+EIgSgUeTThYJZ +Oxnp658demZ
X5q6coXsfXzyxVNWRkvTSO8YVYfE07C2JvDMqeeU8U88/rCXq9Le5IIfR+jj C2WUPchE5dtZ
5lZ1g7JJpRg7+s1c9v9s6qO7XJU4n2KDwgMAZJLbL0y48CuvXnnm8SeeOHV6 1wd277xr69Hf
nDrwi43YJe/w/sfSwJGTp82RjB0f2TsPaVgyZtXonbr5hUI3cZF8/FbAV8V8 NXz4/bPEThRW
UjGLWqEfGYAGkb8feflGcNvdk/Of+dwzT+7e+9CL2z6w5ZVrVw4s58tsbGys 3+8XbwbNh4W9
ZJhJak1RIXLk+EAFHn7yMRZDNDdhx4f3zn82tzQcf/cd/BhQ9laIL4jf3Irj pvDcXEZn6uYX
GgYX6uKJ3UC9NGfhKtY3zU6xTIT0ueadCGMc5ZSGcg0oJ4Xwp2RBpkvPZrEI gwXl9PJ0FuZN
shyE3HL1I3uEdTELKhCiEICm4TC+8IZjOH3fwu6XJhdfSPZ9eMuzn72yaXMr PTvz8o500CFN
kCvDIvT73TSwqjW75d+6AVSIpJpjoyLRtmjHh3fPf3bwG1bcNayVjPNLGWMB y6BufiGRFJJO
MGWORCx+SS4DzyYHOU1eD7L4eEFdvCFn/pRyXrMuPGQMyg+iEIBGUXQfvDOf 7rTuJHNLV1rt
3umnr9CYmbM7BoMOPzp1D5mc3r+l6gaWwpHjzzALiipCJgpX7cNnzNdSaXjl yuXFJeyQFjw1
8Qt5UzD0qR7DJ/Xw5EgS0dqERYAoBKBpeNgfefq+hfN/dPjFT69ZdK+8euXI 49NP/Mvz3WTT
zru2nnhhh2U+Y2Pj6Yu95U8p0+TNU1eKMo05Z14aptiIwhQv0nD83XewQPri 3+Y9pUwgBIBA
TfZHPrJyhn9VfVcCY2Vle/rKjAQAgCZQdJ2alISQrXvWNoI78IvSoEO7TLiO 4HFdR7AhDVNy
yjQsLMcIATm+DHJ1KBuUGT8ukIVZjO6U8qqSRi5GTE38QgAAAMAXhead3CBJ Lv/rfetvpsVB
h8tWGY7dMs5H9r+zKtHo8ZbBMU0mpOEZpEnzWb2KhYX0cg4sc6HcDfEShz/x hDDLIR1reORp
K8uQsuPB3fNnraShMO9EOGtWjZnVkEUksKSG4wsBAACAIhSad8LoJ10+fscD W165eqU1MTkY
dPjJRfmSsVs29b+zyGfIx9Awd0likUau2FqYK2UQqclBvJCmWRWji0TD4U8c 5scUkvV5J+vS
8Ijlrdzx4M75s58jxaah6PScYAo65x8QQ16nBn4hAACAyPDUj9y/Ia1mPr+L LXZ9vrVYINdU
n20y6DN77PNJU1oWzVQgDegWSTHjRRqmuPX/6q6ikamaDMVHHP4sZviFAAAA IsOTLkxu6EJh
sesTv7PrwM/PCelT1UU4P4/FGDCnYaeUeaaRuUoxi8LUmmLWIA04m1VFpCFT b0QScPwp+6vk
lG6NagLwCwEAAERG/v1O1OML+2MfONBaDT5zUpx3sk91Sbe7KOSWxgil0MjM NDbxfIZ8Sj5/
FpbrJnD4k0fkspSRlkw9sHPh82ppKKs9XUB+6+UU0AG/EAAAQGQ4+IWK3UQW L2wYUbf3pXs2
LnY9jA1IQmfqgamFzy9cuXJ5y5atle+VF1YPclWE7hfabxYynExSKllqJ9cG dOYtSdKzNVnj
ZmRkBAsQAgBy4acfWeDFkxdfvLB77tJgsetnnoK2sIVKQ3qk6pBUvY0yFKEN ofuF9VnsMK1J
hYty5xKFwvZ3clZ1WBCb7WsHAAC5KEUXUvZuP7O3Fv9gDo9aGYfAQE38Qn4b Yt0+yMIppT8n
JyaaLZUz918m/ixAOR9ZPsrlKpugRLkJMvP8BPNPsBXlS4hmM2XlKVVlRDHn 7PalFyrVIbY8
BgAYyL/fyTJepb+m7puiLyoNF84t0Bc2zasn9dnvJA1QJSQoJ/kUi7fZbli+ RJe/kCETZwWN
QGU+cqGyPLUUhWR9axM5kqyrQBv/j6UUEvPxNvmsSLjdNwAAcKYsvxAUh0rD NEClIdWINAAH
sVbUxC9kGDRQesqXb1feJR5vRfHS3cYIytLQ/tq8fqGbvwi5CQAwAF0YALJA rBBah6rvR10I
fXyhjM5p0/VBZ+ZWdYOqJ5e4zKvYoPAAAN6BLgwJJhBBcYoL3Lr5hUJncZF8 /FbAV8WG0AQz
qReoG27IIofZUgcwvhAAYGAk18xT+lMKaQLigH+YafiZ69M0cP4R0rvesb/c wi+0tYtoue1b
Hc1FYVydcrKIIZ5oZp/IRdhfYj/vRKfhdFNkhOKUb+VboUOQcWxkIXsrTygx TFUh0mwVZf5D
QOhiZioQohAAYAa6EDSU4rrwyLmtmX6hvdTzogurvqk1AvdECVY0BACYQT8y AI7UZHyhYbGY
BlL5Etk1B6IQAGAGuhAAR2oyvhDqhwd3AwAAigBdCGrKxa8uXPjS0uWv3ph/ vfWurft+cU/V
9bpBTfxCAAAAwBfQhaB2UEVIj5OTkzO/uTD9i9MXvnRh+98ejNaf+c0Zw1VH njpqOHv4k4e8
17MmfiEAAADgC+hCUIj5P8rY0mPHB3JoI6YIWUyqBXnXUAdVflQaPvPp54T4 Jx59uAxRSOAX
AgAAiA7oQlCUbfdpl9545ZztWm6yIkx5cXbq6LGlQwepuHx4756MTmSq/6gK 5KVheaKQwC8E
AAAQHdCFwAPzL8zpTs1cXaTH6Z/dpkugU4TrPEzIkcHxqtXCb7w0LFUUEviF AAAAogO6EPhh
x8d26U4ZVCMVhXpFOJhosuoRXk6dQvrWpiapNCTljCnkgV8IAAAgMqALgTc2 tXJf0rlKX9p1
pPd8dDv56A2bsNOxWnGalK8IU0L3C72sd+hx0US2RUe6xp7NzhxYpVnYZ2Vo +6kAAGIFuhBU
zO4PDzYdOfPZhTTAoDH8WyoK77mrXnvthO4X1mqpP17hpWGKsJmbTHFRGLSy FDZr1p0qu2gA
QExAFwJv5LcLBzD9JwjB+lMTv5DfIFi3P7JwSrkpiJyYaLZUliNl1zDXviOC OEsVobClL9mo
AnnJmCuezzyNVOavqefaxsf8Dsj8qfV8tivTE9Umy2TjTsq87WeQfbImkyuj K1Suj7yhs3Iz
aL5iRLNPNMEWzAAEzlB14cj3vjfyn/5s5PXvVt1q4I125/o7b/2Bd3/7m+/8 6lc+tO+0nOAP
n3uMnn375THl5T/8rdf+7t/5IA1c+dq3t7z3Pfyp/+sP/vCmV9d+Wr797W9/ 4L0fJJdfNdRk
5a/98Er7h1be+c6htb0mfiGTcfSYhtOA8hS7hGyUbmSjHOSTCWFl/oLyEzQo S++A7COmYVk1
Eklf8vpPmV4QoJmk2kjWbYJ5xt4K6eUE/Fs+saAR5fR8ffjq8fFK7aisj6AU WVgnTNFnDUDE
DEMXvm1xafT//n/e/uVX3v6nX3tb55srP/iDKzf/QNUNB374wOvfv/mHbrn/ z/78hxfOvHIT
+d5bYoK3/udH6dmxz6s/8Xu7f/nWS79HAz9GUwqnvpf80GfXLMibk2TsXZ81 VONtf9Ely8tv
3f6e5Xv+1psf/Inl7R9cueXmstteE7+QYdBeTMY5Zy5IxpIukclrOw2h61mn t7yk57WdLr1w
imu7lVZz03P2V8EpBCBoytSFKytv/9Ovv+P3Xn7H75+j7958/48PfrP/0UNv 3n3Xyg9AF0bC
H1z8T+//qQ/+/r/6N3/vf/rvf6xFlK7g3HP/5hc+8reUl/+fZ//t33/wp2ng 0v979e4f3yyc
+un/5kdp4OrVb9794z9tNplHrl1/+7//6tv/5PLbv/naTS9/7q1Nf/37f3/H 93/mv3trU4mO
XU38Qo8oe5CJ5P/Z5zb8JlQiSnR+nq/0xEn/AQCAA2Xpwrd98z++87nffsfv L7z17lvf+Pl/
UPYvNKiK74+968t//CdvtMbeuuUW3QBDelbnEH+/1fpy588GoXe9ay3AnXrr B95FA2++q5Vp
MNMEb03+6Pf/h59h/xq56Xd+96bZ33vj53a98Q92r7R/qIy2180vLNJdK+Tj twKZFZMHFCrD
vtDl6aUsG5GXN71OCMrDHHNdnrc+hmpslK0YXwhAwPjXhSP9/jvmP//O0/9y 5Yd+sP/rh4fT
oweqIt3mLl282o177hoop4tf7aQBRrp+Te5pyCMjb9753jcPP/nGL31s9Ozn 3/n8vxo998Xv
Pf6Plj/0E+Ttb/fb9rr5hYZ5J7p4YrfQDBu2yF/FDzEUMhHS26hVfvaxsE6N /bwQeQpzeokQ
L89xscw/RZ5vIY/P44cJWqZnmevGLHJ1VncxZ8Yb5osIgxr5IY+5yoUoBCB0 POvCkde/2/r1
fzb6hxdL9WlADZl/YW7e6UKqCIWAF976kXe/8Q/3LP+9qZtmfnvsyafemP6F 7/3Cz/mVhnXz
C4mkwHSCLHMkYvFLHJxLQUzIU0wcMsmMz5s/0fhzyjF/BpdON0ZQmYMuH5uz mTU3V9uyCUXu
JwCgVvjUhW/75n8c+/V/PvKXf/nd5/7FW3+zvsv5Au8YtrnLxLCudfE1C9/a NJEc+pXln/rJ
sX96bOTb3/7eL+/zOOepJn6hYbGYWNGZf+WXu+a3YXifDohCAELHmy6kovBd TxymP8P9X/sn
b93+nuIZgiYgrGVdCiMjyz/9k3/1zJGxo/985Nf/WfK//qovaVgTv7AJQlCg KvEBOQgAiJ63
ecllpPeXY//knw5E4dO/BlEIasib//Xdf/WpY2//6uV3zvwOefNNL3nWxC8E AAAAfOFBF470
+61jJ0b+8j8nv/K/YGFCUFve+tH/Ijn0xE2feemmf/2ylwxt/MKqGw0AAADk oHA/8srKTS++
9I7fX/ir08/AKQQ1Z/neD33v4X/Y+t8+/eZ/9V8Wzw1+IQAAgMhw1IUL59a2 sv3Bb/1/P/nM
qSv/7X1/+r3vknOB7W8LGsg7/sZfe3DTROv/eP5t/+PPFMyqJuMLAQAAAF84 6sJdPzs9+N/K
CjlwgExs+vHj//uPv2dgFs69NLN2KifOF4KG0+sttds5bDma/ntvrLzrV3/t h+/eQh4oVDT8
QgAAAJFRrB/5P/wHcuYM+eVfJu9Z60F21naWF86+8Jhlhns+dtrXPQL1Z6lH uj2SLJMkSejb
/vJqLH1LbgS2bW5NTpDu6+SH7/87b275sTt+/w/ILz5MbnqHc6HwCwEAAERG MV347/7dYGrn
hz/MIobgF2578HBmmlfOHvF7m0DNoaJw/OaBHExag8342ssDjZgyCCwPTnVe SyYnWr3X++O3
3vzGL3z03U8efuPVP33z/e9zLjR0v9DLeoceF03MlVWUizUKm6CwcPE85Qx9 5V+4ydUsRQkA
0FFAF9Lv8MIC+eAHyebNLK5svzBlvFXo51bYBdWwWerG5q7Y5AYqIVlVfmT1 JShCSj99v/qw
d18nk7eS5Z/80FtjY6Nf/vdFdGHofmHdRFXd6lMqysWxU/XGdjHxsoC2sMGd sqzqboLVn2IA
wDApoAuXlsgf/RH51V8lozcyyeUX0sS6U2WMNWR/dNjuqzbbrcqXgxqSLCfJ couQG6KQMKUo
pBx0NLfe+pF3/8XWH3vPv/3i937+58io4+Z4NfEL+W2IdfsgC6f4nY4NiYlm S+XM/Zd16TOb
oCvRvlwdghXHe2aGsNJjM2w9rIzklRkfn8ux0+1TnBkvZK6Ug4a2C7fLXFXh 39KkmAWIrZYB
qIQC6xdeu0beeIN86EN8XF49R9PLL0P6/up4Mfr732qtvvhwaz08SNaq7paC CuhTUcicwlU5
ePj4UVkUUpLUPBwZ+Ysf+5tv63xzJEmcC63J+oW8WhJkn3yKxctayhyTXqLL X8iQyTVZhuqa
YCjdvlwdqaBJXzohJYf5q8zxfIxSTSrjhUz42qYvZf35fGzi+Xx0GDZ3TrNK 65OZ24pEZtEA
gLpRbHzhLbeQdpuPKHtacUJWBR9TfYL8a60ddT/1qefHnD+5FyMNGP6csRwI /iFbK9b9wgGj
5PDTR+n/T5w6euDxQ8nGx4Q9G//5tr9BP8KR737XeTH2mviFDINCSk8V6ajN 1HZeLhkC9j2n
upTKeINgyttXq/QglfnbyD45Ta4eZEEmmvHrF+IPLACVUEwX/vmfD17vubGc delrzVgagRph
KPyh0XUT88JRTqyTlaBKOGswFYUpVBruY9JweUPKN2+6aaTbG/nzvyB//Ufc ygx9fKGMsgeZ
bOyutVd7jRovWPZAPZ0Y1fUpV3QT8PcQgODxsz8ywzBkUMfIRoSs+CPR6j2R hLj0I8t1UHaI
4G9fDRk8GGn38booPLz/UBp49tRRYv3k5KJufqEvf845H92FZRuHefNX6qcK RZWXonWZ5DUa
KxeXXE1GZAMSAFA2nnWhg1+oG4+SZsUfyWDSwBgh68MK9S+3MWMYFhM09DMf jClc5fCTh8go
OaCShn1/JdZkfCHDMO+EBnjxxL8VTulylq+ST/HD/likMLRRibI+ylqZy9XB RsixcXLyKX7W
BTvK4/yU8UL+/Dg/5VG4RDkfhT/q8pczkdOzeKECulukS1+GXkzH5DDkUT34 UwzA8Cm8P/JG
yh5faPmj3idjRUpBB3F4pGbhk4eOHD86EIUpo2Tf44eeXe1KVs5BKUjd/EIi dd3qBFPmSMTi
l+TqRLbJwWaijAFDP688hC7XyELDKd28FpsYeR5xZrk2YZvSc50qiOEvLf4I A1AJ1fuFftDN
ROFg80UMb+V/toIgGKxfSFal4bpHuAaVhvsH4wvL6EeuiV+Yy/kDIAjwRxiA qqjYL8w7HjH5
zsb5yDycNFxLJsGvX6h7KyRW5qC8HFQMlYajA6O4z9a1Xo8nQsATNfELGzW9 AwAAQKl41oW5
RKGzuYjFCYFMsry6dKV8Yk0OrqnEQiMMNhLffGQAAAANJ7DxhclgDsGL5d4S ECDbNreuvKbt
K26tSsMtt62Gb/FWaE38QgAAAMAXVfqFDpx++kCp+YMQufDq0vY7JyZvy/aR 5760NPW+cbLs
Z1Iy/EIAAACREZhfWIcSQd3Yclt77otLi91+8jpJSLJhW+T1B3xslLRvbu29 bxNZ7vkqF34h
AACAyAjML3QucfaFxywz3POx00NuAihIiyQ77l5duXKUpKNPW6PrZ1K4x7zn TRbCLwQAABAb
DfILtz14ODPNK2ePDLPyIGjgFwIAAIiMpviFKeMtP7/TudY4lNfxd1vaJr1Q 2BhKl5Vyu2fg
l9D9QmFzlKoyUe7IXDArL7k5IGymYkiWBvj96ISdju1XkBZ2XilYfz4f3R56 fu9YeZkPAS9f
IgBqRZB+oWHVwyaMNbRXmdhdtFRC9wtr8mPGtu/z1aIKF/e2lDWpHEwT8+G8 +ZCNCrLgVnVK
McoEokEpOmcu5++d8nIGIFZC9QuVBRn0Yn91DZMWWR9yli5pwiawJum2yjRZ VGsjppIR6rAk
auIX8n6bbn9k4ZTSV5MTK88Szf7LZKPQdLPu7PPJm799PrKstMlfafsRCz9M EC5yPvyWx7JK
0+13pzQR+azkeLl0w4Z4OpNS2V55b2ibm6mrpyFeGc5Trvin0tzTonv+ld87 h+8XXyv0+YCh
4XkfvLz7lwyNhGzcKKW1cXXs1tpRtwIe2yJPjtSlkdPbZGsTo8zHskTgkZr4 hfxPi6Bs5FMs
3ma7YfkSXf5Chuy3MJeBJ9dfl0/e/A3p5XbJjbKpP9UcOs3HXvJVSqdQ6R2m KemRBQyVEcqV
e4fleCYEdVW1yV/X3lyZm+tpiNeF85QrYk6ve/6V3ztlApaM5P++AFASofqF ubE0AlXCUDlW
Tw7IafgYy2yFGCGNnJuhYqBsauIXMgy2VnrKyyjA8i4pu19bWZ9Sf4MFAWe2 EjOzUmbiVqvi
TdMNPfQ42FF3eXn9wnn9wkxyfe90jyL+noMhE+T4whTdDIy0DvyREK0RKJBk 7bGn20yZGLtr
hRGBhktsDL/MjZvBcKiJX+gRZQ8X2Wik2QupmoxfNNTHrV25MMwmKXtoXanY iLbgmlbtX9G6
fV9AY/HcjzxMv1Bn+Kd14I+UJBnsi9vKeiWW+lEidelsuh50TXDOBFSFjV84 zPr4UjbO+egu
tO9HLufGVFaQjSOY2Slsf23BeSfDaW/Z9TRkXvb9KekLiAFCYMiMdK99wz71 wrmFqfumaKB9
6yT5ylfIgw+Ss2fJ+9/PEgxtPrJu3omu9MPHju792PRkO8O/OfKpo0cOHhLv kdThmytGt05N
wWzz1rDsD6Uqer2l1ii/fnXmutZL6T54X/6t377vxG9893dfeHPrnfTBfub6 4Mk5/wjpXe/Y
lEsvOXJua6Y0HHxTLBtyvWOfWEAY264czG6IJ5oh83IR9pfYzwsxzJshxeaL 6M7q8jFfaG6F
Yb6FEMnH66ZK8JfIi9oIU5h1K92Yy1WG5Uts8s9sr3M+ysGF5vwNs2pKMi/N k0hI1vNmfj4x
6QQMn8aML9TR4uYma8xCftVA3fdTXlkwEzlb5fKE+Jdibanb+EIiaRedlMkc iVj8EvtOMcN4
/Fz1MZfo0K5cDTEswpIZr5s2YThrvsQmMjOHgvn7ysd8Q5Txzov+uJHrUXR4 DiEKwZAJdXxh
3onPyXc2zkfm4SYpryWTEL6Z/FvdiMPMeKL6wmfGZA4uFOavEPxZKY2ajC80 LBYDQEywdWfC
GrZYBPz1BsMnSL/QuZSoFicEVVMTvxBCEDSE5shBACokVL8wb4kJIc+eenGY FQPRUxO/EAAA
APBFkH6hQ4mnnz4w5IqB6KmJXwgAAAD4Ivj9TpxLrO3WLCAU4BcCAACIjIDX LyxYYnhTp0HN
qNv6hQAAAEBB4BeauHJ1dueOrQ8/dM+JTz025HaB+gO/EAAAQGTALzRx4pOn T588fOipJ658
9aKX2uZajFBI7LyQYXqhzZ57WCsxF/ALAQAAREZT5iO7Xfjc8+c7V2cfe/TI 1ANTw2wUCILQ
/UIv6x0Wz8RyQ5FcWXnJzQHLpfXK2IFD2OTDe3p7HLa6yUwJABgaTZmP7HZh 5+pcKgqnPrJ3
/tgd4+22Yn+U1UCfqoRH/HiKIBRCn49ck19itv2drxYNbftjGUuZJWxk56vo XPv/FtmX2UCu
fydU/nkBAGTgF5qY/cwCFYV7P7r3/PFdkw/sbq1uvatMufilOWW8cgM9YctL IY3NhphytoaY
XPkAe2riFxr2F9adUvo0cmKi2fJVjrTf19imLW77I1vepcx8DDtBG9BZgOYt gw35CIkz4w3l
2qTXVEb8G2L4Q8HfN8vnx4DN1t5CPthKGAAvYHyhic7XLh74+OlnHpra9MAU abUWLy0svjqf
vnqX1o69V+db45vId/ry5fTv1Mo67C8si+Q1mRzDEjPM2QoxfBpDA+V8gD01 GV/I/2QKykY+
xeJtNnWVL9HlL2TI5F0uQ0iuvy6fvPkb0svtkhtlU38qs2SllZqC7JWZiZCe aTibeF4I5k2v
b5SIITH/DPB3VXef7T8vm88RAOCLpvuF5uOWu7Y+/NC92+5uEzLWHt+UkGTL g4fam28U17s6
c+Xs0U0TW17JKk63XTIxGnuyy6i7BMJu+NTEL2QYbJj0lJdRgOVdUna/trI+ pWoLQX45dxzb
yDhZGhbPM5dfaMb5+ZGfCl1WcAoB8ELTxxeajwc+/tyFT91x7/4lcmzmG6+c 7iZ9XhRS6Ntu
73Av6SWJY/1TY4+FLa8S/gK6ZQIKEvr4QhllDzLZ+Att/wNfk/GLhvq4tSsX Qh+uUhpmjjUU
EthZfR4GL/pSWnnvM59SVod1e64AiIzmrl9oSZ/0Tx+cuHzhUELF37Wkd3VD cfRt8h3SXeqQ
LGFYklyDCqyQuvmFvpSNcz66C+37kcu5MZUVVMbEDl2eecsqo26+oB9QOqjA fjozWR91U3Xd
AQieke61b9inXji3MHXfYMWW9q2T5CtfIQ8+SM6eJe9/f9WtKJdnHxrb8UsH ev3exYEGVcw7
2frhvZdfenH6+a58Sp5Twht7/EQTloyPF/qRLWeZ6LLlKybEKEsMgl5vqTW6 /qEM7O/VyUFr
PjgffyM9WR4MBv3yb/32fSd+47u/+8KbW++kD/Yz1wdO8PlHSO96x6bc9Ltg 4Rfa2ja03MHX
ygnmqejmnaTo4olm9olchP0lDouVyPUnxeaL6M7q8jFfaG6Fcn6JbtKJrMmU p3TzRfglZjLj
dfkL6YujvJOGR85w23XPLdF/jph0AoAvPOvCgMYX5mL+E+ObPrC7m3R1Ca58 fmHf8908WQI/
VKgLj5zbmukX2ks9L7pwmHcegPoQ4r9pAagnzR1fmIsdT3effWiMJIT1FrPl C9fCLbeMQcDU
ZHyhYbEYABoCRCEAvmjufOS87Hu+XzwTEBM1GV8IIQgAAMAXzV2/EICC1GT9 QgAAAMAXmI8M
gCM18QsBAAAAXzRlfOHsC49ZZrjnY6eH3AQQKDUZXwgAAAD4okHjC7c9eDgz zStnjwyz8iBo
4BcCAACIjKb4hSnjLZff6fJWQJDXFBxyBUAR4BcCAACIjCD9QsOYwqqmoegW o85Et3I1qD/w
CwEAAERGqH6hsiCDXuyvLjbYIutLHadrD7JFB5O1BQn7WIcQWBO6X+hlvcPi mVhuKJIrKy+5
OZC50zFLJsQ4bDqSuVuJ23YmfjdBYWBxTQBCIfj5yJYkqQZkqq+1cUO71tpR t8nxyDrsLX/K
EJCvytzE0zIZqJzQ/cLM/WeHVo1oWmQpp9Jk9Ji+SirLLWfvihAAEBah+oW5 sTQCNcJQ3tTY
kMa8FbIcMJSCnmUbWje3Kym3Jn6hYX9h3SmlryYnJpr9beVI+32Nbdritj+y 5V3KzMewE7QB
ft9hZbzuLC8NmVcnm3a6fZMNRZvrSfT7L1tkIv6T1fxnSvecKJ9Ph+eQrxX+ YAJQkID9wpGN
CHXgj0Sr90QSUm4/svw3a4XDkAyYWeqRK1fJK18nF/4kSV8Ll9Zff5zMfymZ +1LSWV1kOrF8
FCyoiV/I/2QKykY+xeJlrWOOSS/R5S9kyH7jdUpLiVx/XT558zekl9slN8qm /krnj8k+3Vk5
E/4qlkDIh7+QPyVnaK6PMv/MTMjGv1rC3y4luudE+XwqE7h97gAABwL2C3V/ jNI68EcyUANj
hGSLPo+iAQyTbo+M30z6yyRprX3IbRpeXjtLP1Z6qvNaMjnR6lzvb/Gk1mri FzIMtlZ6ysso
wPIuKbsLWFmfUrWFILMEaagTYbKCNMg1t+GD9nXWZJLPL8wk1/Op+8jwz2kA vBDkfGQHLPc2
7pOxXNliCGBN6FxPkqQ1eJyXOW94VRfSjz4ViKlgvPytZMuEH1e4Jn6hR5Q9 d2SjkWYvpOow
eNFcH7d25ULoq5WloU0mwoU2lp5NfQpkUqUCq9tzBUBkBL8/clFaUkAF661O /yDSI/+WxcgB
IRkoj4EcXN4YNbrhHz7eveC67Y/sS9k456O70L4fuZwbU1lBlgIul84TEhfR iMUr40ZJDyrm
6gHghZHutW/Yp144tzB13xQNtG+dJF/5CnnwQXL2LHn/+1mC2q5f+MQnTkw/ vndyIsO/OfyJ
E888faDs+gOP9HpL7fbEwh8n4+01ab/WfbyuEVO/cHBuOZn6idbM2Su7PzB4 9+Xf+u37TvzG
d3/3hTe33kkf7GeuD56c84+Q3vWOTbn0kiPntmZKw8E3xbIh1zv2iQWEMfvK QfqGeKKZCiAX
YX+J/bwQw7wZUmy+iO6sLh/zheZWKOeX6CadGEYWsrfCRBDlKWVKQ31s4pWz XrxgnkSS+bmY
P0dMOgHAF0GOL3QuBYsTAo/UbXwhkbSLTspkjkQsfol9Z59hnkGu+phLdGhX roYoVZROWtnE
G3qcbTqjPRbti1wfmcPnBVEIgBeaMr4wIeTZUy9WXQsQFTUZX2hYLAaAhgBR CIAvgvQLHTiN
3mHgm5r4hRCCAAAAfBHw+oXNqSqoJzXxCwEAAABfNHc+ckBVBfWkbvORAQAA gILALzRx5ers
zh1bH37onhOfeqzq+oLaAb8QAABAZMAvNHHik6dPnzx86Kknrnz1YoVVlRfl sokBZQO/EAAA
QGTALzTx3PPnSYs89uiRLXfdU3V9Qe2AXwgAACAymjIf2a2qnatzVBROPTA1 9ZG988fuGG+3
B0sgpvtmbAz0qUp4pEpPEQyfmsxHBgAAAHzRlPUL3ao6+5kFKgr3fnTv+eO7 Jh/Y3Rqsi61e
G3vxS3NyJN+3y5bXYpFyDIuU0xgyx8JdVQG/EAAAQGTALzTR+drF554//8SO sd3/eBdptRYv
zTNZOJaQfmtwpDET26fJd/rKHHjxx/ZW5mP43ZNTqSfE6GSfTRpQKvALAQAA REbTxxeaj1vu
2vrwQ/dO3t2mOrA9vmmMJPc8eGDqkcv0tf3jg+OWjxwgJNk0scW+3JF1CqYB lQO/EAAAQGQ0
fT6y+Xjg489N37X02LGle3dQmdjqJv325g0NpG+7vX4v6SWJVaGpt5diSLbC UfV9AlowHxkA
AEBkNN0vzKRP+qcPTly+cCih4u9a0ru64Sr6NvkO6S51iKUwzAkswzoDvxAA AEBkYHxhBlMf
X7zy0FiLSsD+YjdJzhx/gpAnhDS97mJfIwuF2SHpgEI+gTmm4NwUUCoYXwgA ACAyMB85m33P
9+c/Mb7pA7snf2qHMkG/t6hzC2XRZojRSb1cmYChAb8QAABAZMAvtGLH091n HxojCWH6jy1f
uBZu2We2AeVaNiAI4BcCAACIDPiFtux7vm+fOMVG50ELhgv8QgAAAJHR9PnI ADiD+cgAAAAi
A/ORQQwM+vSXV0PL61GjUgLfwC8EAAAQGRhfmMHsC49ZZrjnY6erbhMYKhhf CAAAIDIwvjCb
bQ8ezkzzytkjVTcIDBv4hQAAACIDfqEV460KfuDzTlWW10HUJcNkFy/ALwQA ABAZzfILDWMK
61ltfmlDtpy1QdXxp6D/ygZ+IQAAgMhonF+orKFBL6YbmbTW/lufv8BWK0zW VjLsOy9gCIIF
fiEAAIDIaO58ZEuSVAMy1dfiwiy+pZ7uOsLBxwhn2Vv+QkOV0rPsaJkYWy17 B34hAACAyGju
+oW2WBqBmnVQVtYR9rhLO3mFUzJMO/I9wkLnMp8Dr0QNyYAX6rZ+ofzvELLx nx8lPQC6f3XI
8SMbGebN0dT8An15zCrNzTJPj6VXAp43oSzDWwACool+oe6PRVp5/kis171L SO5+ZKECTLfx
ks6sHZW7JDMMyYAX6uYXss9d/idBqf8q0D1gul28h1Al65pv95IPlXc0q/Rl L/V8lV4VeN4A
iJLGjS8k+j8raeX5IyVJxgjJFn1J/nWTIddCJ6zxhcLzJvyDhNnYhPsnCtn4 k6/LygvK/IX6
CNOqctWHybVUugmaLD3LR/LyjsWzZHxu0n3ebl+uw83JbPLhkd1CzJGVM8qz NN781qGquhrG
/bzJk/z4ZiqLxt9/UFua6BfmwnJT5D4Zcy5C+RcT1J+6+YUy6ROl7OxTmijy IAc5fRm+iy5/
oT78eIlc9TH7eewsO8Wnl1Ugf5bFs35kPn83H1H5OQoYEjM9RwNpmKm9NMDH 84mFt271xPMG
QOg00S/0Q4ubm6w3C+V/B7O3ulPmy6Ed60N9/ELDI5G5dJFNjPfaCgWZf2sN posDmQ4f2egI
2uRAJK/RphSHO2a+J5bIhqJDffC8OYO/3qDmNGv9QpLf0Uy+s3E+Mg83SXkt mYQsB3WnLBOw
eDmlZYb4q+SL+vuF9SSzG87mN7jUx1gQdpXPDvHbWMELTJ3C1CxkhmK17fVL /Z83AGpFs/xC
5+phcUIgUx+/UIflSKZaOdBD6KTLNc7PRhTKwxOLlzsE+I5jL+B5sy+xPncA AIHG+YV5q5oQ
8uypF92KwDc/burjFxqGJShPKYd5kY1LY9qk5xMLv3bKeHnGvbKSbKElPj0f lvsBzd81oV9Y
mEeSyjU+LIwpTEcN8mmEfIQihHGHcrl8Jpaa0h5lN3EqAZk1mEY6i0I8b85/ 2yEKQf1pll/o
UNXTTx+ouqagptTKLzSMIsgcYGCONJ/KFW+ZP68PdNfm/WXNHBQoJFCe0qm3 ND6zCJv44sjd
xIa3QqS9UsTzJpyV+6bzNgGAmtDc+cjOVQ2ojaBU6uMXAgCCAKIQ1J/m7nfi XNWA2ghKpW77
nQAAqqKgnw1AfYBfGHMbQanALwQAABAZGF9YyoXP/sYC6b1ilV17275Hpvw2 reytAkCKjV84
s73HX7Lt57dVXWsAAABAC+Yj2ybWnVJmknzrlekn97XbpvVtlnq9hXMXF/+I ykfPupBIO5aS
mq0NEQc2fmHnbK94QQAAAMBwgF9YKL1OL3aTFhWFM58xr3zWT3o9mrLqOwEc sfML8fkCAAAI
BowvLIXeqtobb7WMr3GWUkDeY1QOC+t1yWFltvwRu3wWBOMLAQAARAb8wlLo ru6Y3N6U4RUt
Lq2llJE7guXuYEPXsHLVWXQu+wV+IQAADJN7n9p7/pMv2sfbZ5sGimQSDfAL czCyESEr/thL
xuhxU3vc/GIp3aqRvhWW5meRymX62dmqb38M1Mcv1D2ZxfMsWJ/hNH/IpNuf yDHsVVIpea/1
W5PKN4keAvge5aqb4W1YpJoyfTGBKCQYQh0KluKQgy491i/MwcpGhKz4Yzpq cLzdMr9YSudq
VH0XG0191i9kjrLhHwNueRasz3CazzOE3yd5qxK234mwh57fUvJe62VLFbYx oGW7gpaP+B4x
6qnzSjILMxmCiVi8CIccdJdgPnIpJAmZfXnh8qtXzMkWPn8+abn/E4HvYkaP 8PAJYj6yYV9a
5Va2un1v8+bjUB9lVuZyiWY/XMvKEEnHCFsnk/U9jp01lmFfZuWWysrNlx3y caiPnJXQcBbD
7+ksh/NURhQfho9M3veZ37WPP5tuA214a/3pqauK75Fuy2lltQPaElr2z/iY VEUJPc66t0RS
XekpZaQhXjjFpy+ihpXlshpifGEpTH+4feRfJIRk7o07ue/Dar8w17b0NpdD O3qnbuMLlT9O
yj1b04dBfh6E0avKeJt8DDU05COHzelZY4Ww/UMu6B4maPh4ewNMKfKE/JmT l/bMyuJPWW7e
fOzby+cjh3XI8pEP22voXH+OmLxLhR0N0xcLy/EsUnhrcZfwParjj0XZZmGa jyANWc46Qca/
FWqSWTE+AV+uLh9degdkFcvaQl/wC3Okt0+875GpfY8Uqp5hV6XMHeLN+7Xb pAQ21M0vtJmQ
pEyvO2s51d3+KfLVN+cLoW9UKWjyqBy1HMxMb1M3gzzNVcNa9fPm8gszkQ1F N/A98kt8vzJm
LWi4KjNPm3xsctNlYnMV/MII2wWGRt38wlIp8sfd4Fvw+adnh2xUKP2zGlKk YqxdOn+UbOwj
HtpN8PtBC15g6hHmNQvr3OQ6f4/KZggjC3WTTvJm4qsyFWaC+ch1JKbvc8TU Zz5yGZRtSHic
7+lchKV5VonHVnahNvnLnqUsGQ35VOVN+jIOvdCE71FmzqG4m+mUZMuUaZer vfYyzxd2kKTl
zZKGXwiAI/XxC3XjxIX+JmHMkzk9P+ZJ7rcyj08X4vmrlPnzMcI4B91m3+yU kE+uwftEMw/D
0L/Mj0Fkp3TzLXT52KTnxw7K/b/mcoV4/ipl/nyMoPx0k1r42Sd8PrkmweRC qfZSO5BZg2mk
sy+I75Hz98h8Sws6HcOchlwkT8PwxMz0vNDU5SPEK/uvlbNblM2U06dhjC8c alUDujnAhvqM
LzT82c0cjWo4lWtUa8H8izTNMBg3K/PteU/lHYNYJL0u7FZJyzwdSpGlpE22 eZG7iQ1vhUhL
pYjvkf0lurksuYquCYI+s7/KMtIyvS5sk39eLWuuDPzCmEsEpVIfvzACQulp ipVazUcBztTt
e+RFFPoSQ3mLMCw6EzfwC2MuEZRKffzCCKi/qRA3tZ1wA3IxtO+Rs0kfEI3S gjzY76R2Jc69
Or/zhb1bj91PjzTMn7rnmM9xpvb/snTYHqqkf7bW6l/D9dnvBAAAAPAC/MJ6 lUiF4MyFFz/3
sbV/plBpSI+77tzBElBpePFgoX/E8COL7a+yHEpimSAObPzC9q2Za5sDAAAA dQF+Yb1KTEUh
VYdbj91PjzS8++Wdc5cWqBxMzcLDD97j1zUEzsAvBAAAEBlYv7BeJXaWBkri 8Msnjjy4gx5p
ePtXt7fbY5vuXHvNdK7Q4/ij9+tykHt7lTGE65MVErCzFsu/iRcKmRjS8PE2 Fa7hIlhxr18I
AACggcAvrFeJkxMDJXHkIwcOn52nxzRyaal7/vOd9LWl3afH7qe/oMthZR0m uYQYouoUFhLI
q23x4wv5Nfd1OVumYesdGCrMxwz5IzMDvxAAAEBkwC8cdonm4/T2vTtf2Lvr zh2XD36BHmn4
iacO7/nbO6gQTLXgzEtLBlFIjNZarv035RhZnJVk49XTHZSBXwgAACAysH7h sEvMOK5OMdm0
//6lXneiPf7sLx3gJ51QMkWhsFZ+qZRk4LllmxDSWt4YlT7dyzcS+MXGL7z4 6eHNO5G3NFBu
rlBSucU2Rbixd0ixmmzYzIOFi+fJ7y/CsMzZV+uqop7Plf26ygCAXMAvrB1U CC6e/MLK8xfp
MZcozKQ8pdiEVWlk6uYXMjdX6M2Xu/K9l1s4Bz+aiW3FJhx91Y3lqdybruzW VUW4zxUAwAH4
hVGh3H9TGNgnbGHkvA+mzYUOmesqXPWtVVA3vzAXhv1e+S1Tzemdyt1g6Qma SbbWDPsL5zIF
M/c71sXbqDqhPs5CULkTri6xvF8wv9sbfzbdPtjw1q22mU0o77mS3UF5Zzah CKhMACyBXxgb
8kBAeVyg/K9/Ib0upa4s4UIhB3MaZUCucA2nntTNL7SHn8ojC3HlrCNl+vzl XjCYbewsO8Wn
l1Ugf1bIJ30py7XJ31xPGaE+znvKrUgYEvOb/6ZhpvbSAB/PJxbeulVV8/lW 81wBADwCvxAA
R+rjF5oHVylnght+gw2mi0dkU00ZY9BYOltOsBXlsGX+ujQ6K9HH+MgcfmEm sqHoUJ/gnivL
cgEAOrDfCQCOhOIXyr+L8ph9h0yGgNDR7OzDEY1oc8u/vPGCfm+y4AWmTmFq FjJD0W9tQ3mu
AAAGsH4hAI7EsX5hhZ13uXReEVFYJP+yyx0CxY1DB+rTKRzEolcA1AeMLwTA kfr4hWn/Hb/q
eIqwsY0hPZ9SPvLplVvRELtf37RPlr2EDl/5yKfnV4phR3kcYWY+/CW6/DPL FdqlK5dVkg/4
Qqn2eCMwdQf50YR5CeW5MoBJJwDkBeMLAXCkPuMLieaXz/BzKM8u0kWas8r7 i6vshJXXgjGf
yhxZSKwH/+kuKbvc4sjdxIa3QqS9UqzncyXPPjYMhYQoBCAX8AtNXLk6u3PH 1ocfuufEpx6r
ur6gdtTHLwQAKIEoBCAvGF9o4sQnT58+efjQU09c+epFL4VmdojoEsjxNjGg VOIYXwhAiFj6
jgCAvMAvNPHc8+dJizz26JEtd93jpVD88YoJ+IUAAAAiA+MLTXSuzlFROPXA 1NRH9s4fu2O8
3aYycW2f3Y2BPlUJj/jxFEEo2PiFM9t7/CXbfn5b1bUGAAAAtGD9QhOzn1mg onDvR/eeP75r
8oHdLSoBBzJQweKX5pTxyhX/+Slyum3ibLaPc9u/DvjCxi/snO0VLwgAAAAY DvALTXS+dvG5
588/sWNs9z/eRVqtxUvzTBaOJaTfGhxpzMT2afKdvnw5P0VOmC7Hy0RzYpt5 duZtCUBJ2PmF
reIFAQAAAMOh6eMLzcctd219+KF7J+9uUx3YHt80RpJ7Hjww9chl+tr+8cFx y0cOEJJsmtiS
WVymbpP9QizHWnMwvhAAAEBkNH0+svl44OPPTd+19NixpXt3UJnY6ib99uYN DaRvu71+L+kl
iefq8dvJV32rgBrMRwYAgCLc+9TeXPH22aavqtsXJE33CzPpk/7pgxOXLxxK qPi7lvSubriK
vk2+Q7pLHZIlDD2uUANqQn38Qt2mEcXzLFif4TTftZKeNyApnq28g0tNqGGV 7KqN70WOuhne
hgWVg+c/+WL6UkrDIejF4qrUIQeHEpWljHSvfcM+i4VzC1P3TdFA+9ZJ8pWv kAcfJGfPkve/
//9v73yA26juPP6cOK4UYipdEk4+J03Uado4QKgDJDiFY+KS61iZTCdkWnp4 2rnU15RghuNi
yEFs7uZmlNAJcTr8MXBcHVMOw6SQZDqZyDPnQz7mbhLu0jiQC5Y5cihXQq0e YaTBLlpASe6t
nvzytP+00q6slfT9YDZPb3/79u2+t9qvfu+flYt3Pn0/dge2diWSiVFZSmp0 F1uxsX3s1cGO
/XH1Lr1xJ2LXQLWBZryYLB+8onlsVZFIxDweX+g3kneei5WNQqEnU0RKpUMp KXCTq38osvlm
2fDkCy+u6332DwcGLq5YTiv23guyJ/jYNpK4EDVzXv4s2Emtu8R3EwAAQHWD 8ci56dyfDO30
Nty82X9bQNMgmZjQ8xZqTr5qZlWonLO2mokB5QUVuHnZM01c6lwDAACoHDAe 2RSB3fG+H7uJ
dMUX5SLZYYw6LSn09rt4XU4JW8GgLIglSDwhOzildM+EJL+K1HR9Sweal7r8 PhKfolIyc0j0
guS0y7S7zy0oCqgzzgdlVBZUTDHBX2iWzv1J88YAFAZVeN556bbvdKu4hzeC p5HDKXlv9Lzk
97kSU0l+iCS5JFEcO4GU9SQqE0e9WVFnNEEZ6eKYMiIoJgMsFBP8hQA4CCkt +0j6jyvCnt27
enZ0s+c88+sk/eDGp4RDaonLSd/XPJNAjeNKyjk4ps6gjHRxTBkRFJMBFooJ 45EBcBBSSpLS
LcWiKKTb4J5dSS4ZuXG6rZlupZSzfsRnSOFP5w/oUdJy8S8Stkvl7LAtyKLk jw8eJTNYuKvw
F+bg5YH7TCZ495anS31NoOxJplweoSthz55dLNh1f7faWBK6NvBDAMgP1BmB 8HukY6lyu3ZZ
qbOFMioLKqWY0L8wN81tPTltTg0FS31BoCKQ/YWZ7stqUShld212VN8aAAAA FQD8habwumZ6
NhD19ITm7Q0Oqc45DsuJ7OZjObBdFoXx6fiMNBTGXCdT8vAUxeGOwEn9kIAu qDPOB2VUFlRK
MVWXv9CgT6FDsi3qNnHuazMzV4u7oP/KFNkFmP5yCe7oZv7C4L5dXdu7FTaK CREy/Qud9n3t
qG9JR+G0knIOqDPOx1FlhEdJD4xHtphDA72YTLfVucj0q5g13fHXspSZyTCJ CQyBLbBhyOnn
smdHdzAtDXupNNzRfWWpxekOiJg5CQAAgL1Ul7+wACSmAbnqU8g/V2ar2dOL r3pHsp1/LKBe
+M6MU1BcSU+RsskMACcjTzpDiJv91KsVpOGeXZ1pryEbp5xVDfn8NY76HQ8M QEk5ktGz2tsk
ysuxoGiKQNX5C/PGpCNQZwiAQu0pVkbW1Gp6ClK9V29JZZJ/GzRwEFQa1hL3 9Nuoa3t3776M
KCRa/QjTi6NkTX8NACiMpsXyo6TeAlA9VKO/UG+IBsu8uCWmh3xKOkvgqKWY +ux6/jxjBWly
fWRowbKDvoRc2W3EXfd3S8JAE14r3dMfuD/DUb0ZMFy6LECdcT4oo7KgYoqp Gv2FelKJZV7c
EnnSYPnlm7O8JdOFAKEGDGhe6oqcN6pMbH7/pkXpcH3mkOh5yeW872tHfUs6 CqeVlHNwTp1B
GenhnDIiKCZ9rBRTNfoL88Jk1/5kxneTB4qWZbTzguPjsZblPv8iU0/0oTdj rdd5acDvo3+O
+q4GAABQrlSjv9AeXMLY5HychZq9BhUGiv6C4sw1kI9FpbSrIzYt8hz699hE PClN0TolKVa9
4w+ru5Z45rna1zWQVCKRiEkSiV5Ijn2AX84AAACsUnX+wnxf/NJk9nhkEWGQ csYsG83xIgpV
p45nAT3xp95rYG/SDHD2Xsij9u59tRhZMDeDeoIM/pNpYwAAAMAc1eUvLDh7 aKUDAAAAQMVT
df7CfJEI6XtysNS5AEXnwQWlbEEGAAAAnEB1+QsL4OndXaXOAig6retaS50F AAAAoPTMsje5
0nbbnxmq4RoBAAAAUIXYrAsrz19YndcIAAAAgCoE/QtxjZWAPEdLKl2d+cQu tdmLxeUzeGgi
FotExkp9TQAAAMBMg/6FRbnGvmfDJHHKVHKe5s5tdnZu01wlGZiEK0Kn9Tjk GauGR4zD+2w0
Na1o8GFSHg3CI+ES1tXSnh0AUAzgLzR7XXq7NK9X+uBUx45Oj8fIRRVLJMIj oxMnqHy04YtV
nO9avbAyZsM2A9NeDnzPsYxV5JNlDL9k+gAyWQyBCAAARQX+QkuXpqcX45KL isL+V44bJpmU
Eom4hLkRHQFEoZNRCESoQwAAKBLwFxaFRFrteV3Gms81QRIJLV3Il04m2c4/ FlC4AE06BcXl
mBUpA6eLwk3tJIVl7mTkW0G/Zw7LU4pCGgIAgO3AX1gU4umXuKchhy9wIpax VKNQe6Lm09N/
egpSvReNy6CsoeqQSkM4DgEAwHbgL8wDcUgHEZQWu2pxm5DcNL7B4zVOMCJ7 Ft2au9SKTX12
PbefsYKEFlTjdGehQPv9fXTrzvzicGVc0vXsXzf/p/sngVJnv7jAcQgAAMUA /sI80FNU7KrF
Les16PXk7jtovn8h9Fx1onAor72taVVzUzpWmphIeLweKSmlP0ncOHpuohxb nXu238cCwX1P
G0dyApvaQ5CGAABgH/AXFgX6jn75cHhsPGJsFh4+JrnazSV5BUXLMpqDbce7
Re: From JBuilder to Eclipse VE [message #608125 is a reply to message #94543] Thu, 30 June 2005 13:38 Go to previous message
> Hi all,
> has anyone stumbled into trying to migrate a Java project from JBuilder
> to Eclipse?
> I am trying to evaluate the effort in it. If you try to rebuild a
> project previously developed with JBuilder into Eclipse, the Visual
> Editor simply displays the components side by side without any attempt
> to 'put them where you put them before'.
> I joined an example of .java file with problem (Attach File -->
> KimChar.java). That will tell us if it is the coding pattern or if it
> is some other problem.
> If any of you has suggestions, thank you in advance!
> Gui reprentation JBuilder :
> Gui representation Eclipse VE :
> Steff.
> P.S. : Eclipse log trace is empty.
Content-Disposition: inline;
* Contributors:
* $RCSfile: $
import java.awt.BorderLayout;
import java.awt.Color;
import java.awt.Component;
import java.awt.Dimension;
import java.awt.FlowLayout;
import java.awt.GridLayout;
import java.awt.event.ActionEvent;
import java.util.Vector;
import javax.swing.border.Border;
private static final long serialVersionUID = 3256999973420676660L;
private int typTrans = -1;
private long inCde = -1;
private Object paramsStruct;
private int currentHeadNum = 0;
private boolean isKimConfTestInput = true;
private boolean isLoaded = false;
private boolean isEnabled = true;
JScrollPane charScl = new JScrollPane();
BorderLayout sclBorderLayOut = new BorderLayout();
JPanel charHeadPnl = new JPanel();
BorderLayout borderLayout1 = new BorderLayout();
BorderLayout borderLayout3 = new BorderLayout();
BorderLayout titleBrdLyt = new BorderLayout();
JPanel buttonPnl = new JPanel();
FlowLayout buttonFlwLyt = new FlowLayout();
JPanel charHeadPnl1 = new JPanel();
GridLayout gridLayout1 = new GridLayout();
GridLayout gridLayout2 = new GridLayout();
GridLayout gridLayout3 = new GridLayout();
Border border1;
Border border2;
Border border3;
JPanel nextBtnPnl = new JPanel();
JPanel prevBtnPnl = new JPanel();
JLabel circleLbl = new JLabel();
JLabel pageLbl = new JLabel();
static {
try {
} catch(Exception e) {
public KimChar() {
try {
jbInit();
e.printStackTrace();
private void jbInit() throws Exception {
border1 = BorderFactory.createEmptyBorder(5,5,5,5);
border2 = BorderFactory.createEmptyBorder(5,5,5,5);
border3 = BorderFactory.createEmptyBorder(0,5,0,5);
this.setLayout(borderLayout3);
charHeadPnl.setLayout(borderLayout1);
titleBrdLyt.setVgap(50);
titleBrdLyt.setHgap(50);
nextBtn.setPreferredSize(new Dimension(11, 16));
nextBtnPnl.setPreferredSize(new Dimension(11, 16));
nextBtn.addActionListener(new java.awt.event.ActionListener() {
public void actionPerformed(ActionEvent e) {
currentHeadNum++;
// load();
circleLbl.setVisible(false);
nextBtn.setVisible(false);
buttonPnl.setLayout(buttonFlwLyt);
buttonFlwLyt.setHgap(2);
buttonFlwLyt.setVgap(2);
charHeadPnl1.setLayout(gridLayout1);
prevBtn.setPreferredSize(new Dimension(11, 16));
prevBtn.setVisible(false);
prevBtnPnl.setPreferredSize(new Dimension(11, 16));
prevBtn.addActionListener(new java.awt.event.ActionListener() {
currentHeadNum--;
load();
charHeadLbl.setForeground(Color.white);
charHeadLbl.setPreferredSize(new Dimension(110, 20));
titlePnl.setLayout(titleBrdLyt);
this.setBorder(BorderFactory.createLoweredBevelBorder());
charHeadPnl.setBorder(border1);
charHeadPnl1.setBorder(null);
titlePnl.setBorder(border3);
this.add(charScl, BorderLayout.CENTER);
charScl.setViewportView(charHeadPnl);
this.add(titlePnl, BorderLayout.NORTH);
buttonPnl.setOpaque(false);
pageLbl.setForeground(Color.white);
buttonPnl.add(pageLbl,null);
prevBtnPnl.setOpaque(false);
gridLayout3.setHgap(0);
gridLayout3.setVgap(0);
prevBtnPnl.setLayout(gridLayout3);
prevBtnPnl.add(prevBtn,null);
buttonPnl.add(prevBtnPnl, null);
buttonPnl.setAlignmentX(0);
buttonPnl.setAlignmentY(0);
buttonPnl.add(circleLbl, null);
nextBtnPnl.setOpaque(false);
gridLayout2.setHgap(0);
gridLayout2.setVgap(0);
nextBtnPnl.setLayout(gridLayout2);
nextBtnPnl.add(nextBtn, null);
buttonPnl.add(nextBtnPnl, null);
titlePnl.add(charHeadPnl1, BorderLayout.CENTER);
titlePnl.setOpaque(false);
charHeadPnl1.setOpaque(false);
charHeadPnl1.add(charHeadLbl, null);
titlePnl.add(buttonPnl, BorderLayout.EAST);
public void clear(){
charHeads = new Vector();
currentHeadNum = 0;
isLoaded = false;
this.load();
public boolean isLoaded(){
return isLoaded;
public boolean isEnabled(){
return isEnabled;
public void setHeadNum(int currentHeadNum){
this.currentHeadNum = currentHeadNum;
// load();
public void setTypTrans(int typTrans){
this.typTrans = typTrans;
public int getTypTrans(){
return this.typTrans;
public void setInCde(long inCde){
this.inCde = inCde;
public long getInCde(){
return inCde;
public void setParams(Object paramsStruct){
this.paramsStruct = paramsStruct;
public Object getParams(){
return paramsStruct;
public void notifyScrollChange(int scrollPosition){
int sclValue = charScl.getVerticalScrollBar().getValue();
int visibleAmount = charScl.getVerticalScrollBar().getVisibleAmount();
int maximumValue = charScl.getVerticalScrollBar().getMaximum();
scrollPosition += 23;
if (scrollPosition >= (sclValue + visibleAmount)) {
if ((sclValue+visibleAmount) < maximumValue) {
charScl.getVerticalScrollBar().setValue(scrollPosition-visib leAmount);
} else{
charScl.getViewport().getComponent(0).doLayout();
public boolean isKimConfTestInput() {
return this.isKimConfTestInput;
public void setKimConfTestInput(boolean isKimConfTestInput) {
this.isKimConfTestInput = isKimConfTestInput;
name="Image1.png"
Previous Topic:FormLayout question
Next Topic:What is nedded för VE to display a visual class?
Current Time: Sun Jul 20 17:48:07 EDT 2025
Powered by FUDForum. Page generated in 0.05120 seconds
