Home » Modeling » TMF (Xtext) » re-generate captured text
re-generate captured text [message #953437] Mon, 22 October 2012 04:40 Go to next message
Hi, is there a way to generate back from an object of the parse tree the text that was consumed by the parser to instantiate such object?
Example:
Grammar:
Func: "f" "("arg=ArgSpec")";
ArgSpec : ...
Document
f( 5*PI )
Given the ArgSpec instance (which is possibly a complex type with properties etc) I would like to simply generate the string "5*PI", without manual processing all the fields of the ArgSpec instance
I hope it's clear
Thank you
B
Re: re-generate captured text [message #953446 is a reply to message #953437] Mon, 22 October 2012 04:52 Go to previous messageGo to next message
if i get you write you have a parsed eobject in your hand and want to access the text that was parsed.
you get access to the node model through the NodeModelUtil class.
~Christian
Re: re-generate captured text [message #953519 is a reply to message #953446] Mon, 22 October 2012 06:07 Go to previous message
Thank you!
So far, I found these
NodeModelUtils::getTokenText(NodeModelUtils::findActualNodeFor( <my eobject> ))
NodeModelUtils::findActualNodeFor(<my eobject>).getText()
which seem to work
thanks again
B
Previous Topic:formatter that keeps original line breaks
Next Topic:Autoindent code
Current Time: Sat Jul 19 16:24:20 EDT 2025
Powered by FUDForum. Page generated in 0.03778 seconds
