Home » Archived » Test and Performance Tools Platform (TPTP) » Users and different session id
Users and different session id [message #94157] Mon, 26 March 2007 09:35 Go to next message
Originally posted by: piolaki.wp.pl
I record test on application with session. I want to run this test for few
users, but all users have got the same session id. How can I change
session id for each user? I want to run test for each user with different
session id.
Piotr
Re: Users and different session id [message #95332 is a reply to message #94157] Wed, 11 April 2007 08:39 Go to previous messageGo to next message
Hi Piotr,
What type of TPTP test are you recording/running?
-URL
-AGR
-API
For each of the test types, you can uncheck the Synchronous checkbox in
the Behavior tab of the test suite editor and each invocation in a loop will
be executed simultaneously on separate threads.
Paul
"Piotr Konko" <piolaki@wp.pl> wrote in message
news:31fa14b0a17c59d241835136088cbb95$1@www.eclipse.org...
>users, but all users have got the same session id. How can I change session
>id for each user? I want to run test for each user with different session
>id.
> Piotr
Re: Users and different session id [message #95415 is a reply to message #95332] Wed, 11 April 2007 12:07 Go to previous messageGo to next message
Piotr,
If you question is specific to the URL test type (which I believe it
is), we expose session IDs to the test author in the URL test editor or
generates JUnit test code (see
https://bugs.eclipse.org/bugs/show_bug.cgi?id=139699#c1). Preserving user
session IDs to emulate unique user sessions when asynchronously looping
through a set of iterations will be covered under enhancement
https://bugs.eclipse.org/bugs/show_bug.cgi?id=128613.
Paul
"Paul Slauenwhite" <paules@ca.ibm.com> wrote in message
news:eviktl$3mq$1@build.eclipse.org...
> Hi Piotr,
> -URL
> -AGR
> -API
> will be executed simultaneously on separate threads.
> Paul
>>session id.
>> Piotr
Re: Users and different session id [message #95729 is a reply to message #95415] Fri, 13 April 2007 07:41 Go to previous message
Correction:
"we do not expose session IDs to the test author in the URL test editor or
generated JUnit test code (see
https://bugs.eclipse.org/bugs/show_bug.cgi?=139699#c1)"
PS
news:evj13u$rhv$1@build.eclipse.org...
> Piotr,
> Paul
>> Hi Piotr,
>> -URL
>> -AGR
>> -API
>> in the Behavior tab of the test suite editor and each invocation in a
>> loop will be executed simultaneously on separate threads.
>> Paul
>>>few users, but all users have got the same session id. How can I change
>>>session id.
>>> Piotr
Previous Topic:IAC with 4.4i2 on Linux-32
Next Topic:URL recorder - session handeling
Current Time: Sun Jul 20 13:21:15 EDT 2025
Powered by FUDForum. Page generated in 0.24805 seconds
