Home » Archived » BIRT » Single meter chart from multiple data sets (charts meeters)
icon4.gif  Single meter chart from multiple data sets [message #949497] Thu, 18 October 2012 23:01 Go to next message
Simple, I am using BIRT designer and not using any API, I have three data sets each retrieve a particular variable say temperature, The temp-south, temp-north and temp-west.
How do I show all them on a single meter chart. Basically how do I access three different data sets and assign dia1, dial2 and dial 3 to three different data sets respectively?
Using basic report designer in eclipse. Any help??? Rolling Eyes
Re: Single meter chart from multiple data sets [message #950556 is a reply to message #949497] Fri, 19 October 2012 20:57 Go to previous messageGo to next message
Have you tried using joint dataSets to merge your data into a single dataSet? Then, using this final dataSet in your chart?
Re: Single meter chart from multiple data sets [message #953656 is a reply to message #950556] Mon, 22 October 2012 08:27 Go to previous messageGo to next message
I see. Is this the only way to achieve this?
Re: Single meter chart from multiple data sets [message #954214 is a reply to message #953656] Mon, 22 October 2012 17:46 Go to previous messageGo to next message
You'll have to create a single dataSet, somehow. You could use a joint dataSet, rewrite your query to only have a single dataSet, use a scripted dataSet to take the values from your other 3 dataSets to make a single dataSet, or you could take the values from the 3 dataSets, create a chart dataSet, in your chart script and set the chart to use this data, in the beforeGeneration script.
http://help.eclipse.org/juno/index.jsp?topic=%2Forg.eclipse.birt.chart.doc.isv%2Fchart%2Fapi%2Forg%2Feclipse%2Fbirt%2Fchart%2Fmodel%2Fdata%2Fimpl%2FDataSetImpl.html
Re: Single meter chart from multiple data sets [message #959348 is a reply to message #954214] Fri, 26 October 2012 12:50 Go to previous message
Created a single dataset from multiple datasets(BIG Join)and resolved the issue. Thanks for the tips
Previous Topic:Alternative to BIRT
Next Topic:PPT format report can't be opened with PPT Viewer 2007
Current Time: Sat Jul 19 14:59:58 EDT 2025
Powered by FUDForum. Page generated in 0.04391 seconds
