Home » Language IDEs » ServerTools (WTP) » IWAB0398E Error in generating WSDL from Java ......
IWAB0398E Error in generating WSDL from Java ...... [message #94966] Tue, 26 April 2005 04:52 Go to next message
.........java.lang.ClassNotFoundException:
simple.webservicetest.WebServiceTes
Running eclipse with console i get the below outpur
Can anyomne help fix it
I'm ollwoing a tutorial from here
http://www.eclipse.org/webtools/initial-contribution/IBM/eva lGuides/WebServicesToolsEval.html?p=1
Many Thanks
Error while running
org.eclipse.jst.ws.internal.axis.consumption.core.command.Ja
va2WSDLCommand$1$Emitter
at
org.apache.axis.tools.ant.wsdl.Java2WsdlAntTask.execute(Java 2WsdlAntT
ask.java:267)
at
org.eclipse.jst.ws.internal.axis.consumption.core.command.Ja va2WSDLCo
mmand.executeAntTask(Java2WSDLCommand.java:144)
at
mmand.execute(Java2WSDLCommand.java:81)
at
org.eclipse.wst.command.env.core.fragment.CommandFragmentEng ine.runCo
mmand(CommandFragmentEngine.java:322)
at
org.eclipse.wst.command.env.core.fragment.CommandFragmentEng ine.visit
Top(CommandFragmentEngine.java:288)
at
org.eclipse.wst.command.env.core.fragment.CommandFragmentEng ine.moveF
orwardToNextStop(CommandFragmentEngine.java:208)
at
org.eclipse.wst.command.env.ui.widgets.SimpleCommandEngineMa nager$4.r
un(SimpleCommandEngineManager.java:206)
at
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalCont
ext.java:344)
at
org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:289)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 824)
at
org.eclipse.wst.command.env.ui.widgets.SimpleCommandEngineMa nager.run
ForwardToNextStop(SimpleCommandEngineManager.java:175)
at
org.eclipse.wst.command.internal.env.ui.widgets.WizardPageMa nager.run
ForwardToNextStop(WizardPageManager.java:69)
at
org.eclipse.wst.command.internal.env.ui.widgets.WizardPageMa nager.get
NextPage(WizardPageManager.java:91)
at
org.eclipse.wst.command.internal.env.ui.widgets.SimpleWizard Page.getN
extPage(SimpleWizardPage.java:123)
at
org.eclipse.jface.wizard.WizardDialog.nextPressed(WizardDial og.java:7
41)
at
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java
:338)
at
org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:543)
at
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:
89)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:842)
at
org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2908)
at
org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2541)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:718 )
at org.eclipse.jface.window.Window.open(Window.java:696)
at
org.eclipse.wst.command.internal.env.ui.widgets.popup.Dynami cPopupWiz
ard.run(DynamicPopupWizard.java:123)
at
org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:2
44)
at
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection
(ActionContributionItem.java:557)
at
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContri
butionItem.java:507)
at
org.eclipse.jface.action.ActionContributionItem$6.handleEven t(ActionC
ontributionItem.java:421)
at
at
at
org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1612)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1578)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.jav
a:293)
at
org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:144)
at
org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:10
2)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformAct
ivator.java:228)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.ja
va:333)
at
va:150)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:268 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:260)
at org.eclipse.core.launcher.Main.run(Main.java:887)
at org.eclipse.core.launcher.Main.main(Main.java:871)
Caused by: java.lang.ClassNotFoundException:
t
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(Bundl
eLoader.java:359)
at
org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. loadClass
(AbstractClassLoader.java:94)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Unknown Source)
at org.apache.axis.utils.ClassUtils$2.run(ClassUtils.java:197)
at org.apache.axis.utils.ClassUtils.loadClass(ClassUtils.java:1 71)
at org.apache.axis.utils.ClassUtils.forName(ClassUtils.java:112 )
at org.apache.axis.wsdl.fromJava.Emitter.setCls(Emitter.java:14 77)
at
ask.java:206)
... 48 more
--- Nested Exception ---
java.lang.ClassNotFoundException: simple.webservicetest.WebServiceTest
at
eLoader.java:359)
at
at
ask.java:206)
at
at
at
at
at
at
at
ext.java:344)
at
at
at
at
at
at
41)
at
:338)
at
at
89)
at
at
at
at
44)
at
at
at
at
at
at
at
a:293)
at
at
2)
at
ivator.java:228)
at
va:333)
at
va:150)
Re: IWAB0398E Error in generating WSDL from Java ...... [message #95048 is a reply to message #94966] Tue, 26 April 2005 10:01 Go to previous messageGo to next message
I'd like to help, and also try to understand this problem some more.
At what point in the tutorial did you see this error? Or at what page
in the Web service wizards?
In the tutorial, I didn't see any references to a WebServiceTest class,
so I assume its a Java bean that you fashioned? Is the bean in the same
service project specified on the 3rd page?
> Many Thanks
> Error while running
> at
> ask.java:267)
> at
> at
> at
> at
> at
> at
> at
> ext.java:344)
> at
> at
> at
> at
> at
> at
> 41)
> at
> :338)
> at
> at
> 89)
> at
> at
> at
> at
> 44)
> at
> at
> at
> at
> at
> at
> at
> a:293)
> at
> at
> 2)
> at
> ivator.java:228)
> at
> va:333)
> at
> va:150)
> t
> at
> eLoader.java:359)
> at
> at java.lang.ClassLoader.loadClass(Unknown Source)
> at java.security.AccessController.doPrivileged(Native Method)
> at
> ask.java:206)
> ... 48 more
> at
> eLoader.java:359)
> at
> at
> ask.java:206)
> at
> at
> at
> at
> at
> at
> at
> ext.java:344)
> at
> at
> at
> at
> at
> at
> 41)
> at
> :338)
> at
> at
> 89)
> at
> at
> at
> at
> 44)
> at
> at
> at
> at
> at
> at
> at
> a:293)
> at
> at
> 2)
> at
> ivator.java:228)
> at
> va:333)
> at
> va:150)
Re: IWAB0398E Error in generating WSDL from Java ...... [message #95096 is a reply to message #95048] Tue, 26 April 2005 10:51 Go to previous messageGo to next message
Section 3.2.4
I called my java file WebServiceTest in the tutorial it's Converter.java
"Seng Phung-Lu" <sengpl@ca.ibm.com> wrote in message
news:d4lhq3$nvu$1@news.eclipse.org...
> At what point in the tutorial did you see this error? Or at what page in
> In the tutorial, I didn't see any references to a WebServiceTest class, so
>> Many Thanks
>> Error while running
>> at
>> ask.java:267)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ext.java:344)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> 41)
>> at
>> :338)
>> at
>> at
>> 89)
>> at
>> at
>> at
>> at
>> at
>> 44)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> a:293)
>> at
>> at
>> 2)
>> at
>> ivator.java:228)
>> at
>> va:333)
>> at
>> va:150)
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> Source)
>> t
>> at
>> eLoader.java:359)
>> at
>> at
>> at
>> at
>> ask.java:206)
>> ... 48 more
>> at
>> eLoader.java:359)
>> at
>> at
>> at
>> at
>> ask.java:206)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ext.java:344)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> 41)
>> at
>> :338)
>> at
>> at
>> 89)
>> at
>> at
>> at
>> at
>> at
>> 44)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> a:293)
>> at
>> at
>> 2)
>> at
>> ivator.java:228)
>> at
>> va:333)
>> at
>> va:150)
>> Source)
Re: IWAB0398E Error in generating WSDL from Java ...... [message #95186 is a reply to message #95096] Tue, 26 April 2005 18:22 Go to previous messageGo to next message
Is the bean in the service project which you specified on the deployment
page(page 3)? From the exception, it appears the Axis AntTask is unable
to load your service bean.
If the service project specified was not where your WebServiceTest.java
file lives, the class loader will not be able to see it. While this
isn't explicit in the wizards, I agree the error message could be more
informative.
On the other hand, if everything was set correctly and it still blows
up, thats bad. Could you zip and attach your workspace to the bug?
https://bugs.eclipse.org/bugs/show_bug.cgi?id=92760
Thanks!
plork123 wrote:
> Section 3.2.4
>>Hi,
>>>Many Thanks
>>>Error while running
>>> at
>>>ask.java:267)
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>>ext.java:344)
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>>41)
>>> at
>>>:338)
>>> at
>>> at
>>>89)
>>> at
>>> at
>>> at
>>> at
>>> at
>>>44)
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>>a:293)
>>> at
>>> at
>>>2)
>>> at
>>>ivator.java:228)
>>> at
>>>va:333)
>>> at
>>>va:150)
>>>Source)
>>>t
>>> at
>>>eLoader.java:359)
>>> at
>>> at
>>> at
>>> at
>>>ask.java:206)
>>> ... 48 more
>>> at
>>>eLoader.java:359)
>>> at
>>> at
>>> at
>>> at
>>>ask.java:206)
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>>ext.java:344)
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>>41)
>>> at
>>>:338)
>>> at
>>> at
>>>89)
>>> at
>>> at
>>> at
>>> at
>>> at
>>>44)
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>>a:293)
>>> at
>>> at
>>>2)
>>> at
>>>ivator.java:228)
>>> at
>>>va:333)
>>> at
>>>va:150)
>>>Source)
Re: IWAB0398E Error in generating WSDL from Java ...... [message #95323 is a reply to message #95186] Wed, 27 April 2005 03:55 Go to previous messageGo to next message
What do ou mean by this - there isn't a page 3 do you mean section3?
> page(page 3)?
<Could you zip and attach your workspace to the bug >
Do you mean the.metadata folder?
news:d4mf54$1ll$1@news.eclipse.org...
> file lives, the class loader will not be able to see it. While this isn't
> informative.
> On the other hand, if everything was set correctly and it still blows up,
> Thanks!
> plork123 wrote:
>> Section 3.2.4
>>>Hi,
>>>>Many Thanks
>>>>Error while running
>>>> at
>>>>ask.java:267)
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>>ext.java:344)
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>>41)
>>>> at
>>>>:338)
>>>> at
>>>> at
>>>>89)
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>>44)
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>>a:293)
>>>> at
>>>> at
>>>>2)
>>>> at
>>>>ivator.java:228)
>>>> at
>>>>va:333)
>>>> at
>>>>va:150)
>>>> Source)
>>>>t
>>>> at
>>>>eLoader.java:359)
>>>> at
>>>> at
>>>> at
>>>> at
>>>>ask.java:206)
>>>> ... 48 more
>>>> at
>>>>eLoader.java:359)
>>>> at
>>>> at
>>>> at
>>>> at
>>>>ask.java:206)
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>>ext.java:344)
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>>41)
>>>> at
>>>>:338)
>>>> at
>>>> at
>>>>89)
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>>44)
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>>a:293)
>>>> at
>>>> at
>>>>2)
>>>> at
>>>>ivator.java:228)
>>>> at
>>>>va:333)
>>>> at
>>>>va:150)
>>>> Source)
Re: IWAB0398E Error in generating WSDL from Java ...... [message #95353 is a reply to message #95323] Wed, 27 April 2005 05:38 Go to previous messageGo to next message
Ok, i've deleted everything from my workspace and tried it again, and it
works - for now anyway
"plork123" <plork123@hotmail.com> wrote in message
news:d4ngnf$2a6$1@news.eclipse.org...
>> page(page 3)?
>> informative.
>> Thanks!
>> plork123 wrote:
>>> Section 3.2.4
>>>>Hi,
>>>>>Many Thanks
>>>>>Error while running
>>>>> at
>>>>>ask.java:267)
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>>ext.java:344)
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>>41)
>>>>> at
>>>>>:338)
>>>>> at
>>>>> at
>>>>>89)
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>>44)
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>>a:293)
>>>>> at
>>>>> at
>>>>>2)
>>>>> at
>>>>>ivator.java:228)
>>>>> at
>>>>>va:333)
>>>>> at
>>>>>va:150)
>>>>> Source)
>>>>> at
>>>>>t
>>>>> at
>>>>>eLoader.java:359)
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>>ask.java:206)
>>>>> ... 48 more
>>>>> at
>>>>>eLoader.java:359)
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>>ask.java:206)
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>>ext.java:344)
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>>41)
>>>>> at
>>>>>:338)
>>>>> at
>>>>> at
>>>>>89)
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>>44)
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>>a:293)
>>>>> at
>>>>> at
>>>>>2)
>>>>> at
>>>>>ivator.java:228)
>>>>> at
>>>>>va:333)
>>>>> at
>>>>>va:150)
>>>>> Source)
>>>>> at
Re: IWAB0398E Error in generating WSDL from Java ...... [message #95523 is a reply to message #95353] Wed, 27 April 2005 12:10 Go to previous messageGo to next message
Good stuff. (I think...) =)
Just to clarify. I meant page 3 of the wizards(aka "Service Deployment
Configuration" page), where you can choose your serivce and client
projects, server, and runtime.
If this problem pops up again, could you include detailed instructions
on how to reproduce it and perhaps attach your workspace to the bug
report? The workspace is the folder which contains all your projects
and includes the .metadata folder. Its location is displayed when you
first start eclipse, and by default, I think it goes to "C:\Document and
Settings\user\workspace".
Since the bug is no longer reproducible, but we haven't really resolved
it, would you agree that we should keep the bug around but lower the
"severity" on it? This pretty standard.
-seng
>>>page(page 3)?
>>>informative.
>>>Thanks!
>>>plork123 wrote:
>>>>Section 3.2.4
>>>>>Hi,
>>>>>>Many Thanks
>>>>>>Error while running
>>>>>> at
>>>>>>ask.java:267)
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>>ext.java:344)
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>>41)
>>>>>> at
>>>>>>:338)
>>>>>> at
>>>>>> at
>>>>>>89)
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>>44)
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>>a:293)
>>>>>> at
>>>>>> at
>>>>>>2)
>>>>>> at
>>>>>>ivator.java:228)
>>>>>> at
>>>>>>va:333)
>>>>>> at
>>>>>>va:150)
>>>>>>Source)
>>>>>> at
>>>>>>t
>>>>>> at
>>>>>>eLoader.java:359)
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>>ask.java:206)
>>>>>> ... 48 more
>>>>>> at
>>>>>>eLoader.java:359)
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>>ask.java:206)
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>>ext.java:344)
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>>41)
>>>>>> at
>>>>>>:338)
>>>>>> at
>>>>>> at
>>>>>>89)
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>>44)
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>>a:293)
>>>>>> at
>>>>>> at
>>>>>>2)
>>>>>> at
>>>>>>ivator.java:228)
>>>>>> at
>>>>>>va:333)
>>>>>> at
>>>>>>va:150)
>>>>>>Source)
>>>>>> at
Re: IWAB0398E Error in generating WSDL from Java ...... [message #95812 is a reply to message #95523] Thu, 28 April 2005 06:32 Go to previous messageGo to next message
I sent my workspace to reproduce
Dynamic web projects - Hello project
Javasouuce - simple,webservice - right-click helloserver.java
Click Web Services - Create Web Service
Go through wizard without changing anything
On page 3 of wizrd (Service Deployment Config) click next
Methods show to expose - click next - get error !
news:d4odnq$d3k$1@news.eclipse.org...
> If this problem pops up again, could you include detailed instructions on
> how to reproduce it and perhaps attach your workspace to the bug report?
> The workspace is the folder which contains all your projects and includes
> the .metadata folder. Its location is displayed when you first start
> -seng
>>>>page(page 3)?
>>>>informative.
>>>>Thanks!
>>>>plork123 wrote:
>>>>>Section 3.2.4
>>>>>Converter.java
>>>>>>Hi,
>>>>>>class, so I assume its a Java bean that you fashioned? Is the bean in
>>>>>>the same service project specified on the 3rd page?
>>>>>>>Many Thanks
>>>>>>>Error while running
>>>>>>> at
>>>>>>>ask.java:267)
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>>ext.java:344)
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>>41)
>>>>>>> at
>>>>>>>:338)
>>>>>>> at
>>>>>>> at
>>>>>>>89)
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>>44)
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>>a:293)
>>>>>>> at
>>>>>>> at
>>>>>>>2)
>>>>>>> at
>>>>>>>ivator.java:228)
>>>>>>> at
>>>>>>>va:333)
>>>>>>> at
>>>>>>>va:150)
>>>>>>> Source)
>>>>>>> at
>>>>>>>t
>>>>>>> at
>>>>>>>eLoader.java:359)
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>>ask.java:206)
>>>>>>> ... 48 more
>>>>>>> at
>>>>>>>eLoader.java:359)
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>>ask.java:206)
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>>ext.java:344)
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>>41)
>>>>>>> at
>>>>>>>:338)
>>>>>>> at
>>>>>>> at
>>>>>>>89)
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>>44)
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>>a:293)
>>>>>>> at
>>>>>>> at
>>>>>>>2)
>>>>>>> at
>>>>>>>ivator.java:228)
>>>>>>> at
>>>>>>>va:333)
>>>>>>> at
>>>>>>>va:150)
>>>>>>> Source)
>>>>>>> at
Re: IWAB0398E Error in generating WSDL from Java ...... [message #95901 is a reply to message #95812] Thu, 28 April 2005 10:39 Go to previous messageGo to next message
Thanks for the quick reply!
Did you attach the workspace(zipped hopefully), to the bug? I don't see
it yet.
Here's the link to your bug report:
-seng
>>Thanks,
>>-seng
>>>>>page(page 3)?
>>>>>informative.
>>>>>Thanks!
>>>>>plork123 wrote:
>>>>>>Section 3.2.4
>>>>>>Converter.java
>>>>>>>Hi,
>>>>>>>>Many Thanks
>>>>>>>>Error while running
>>>>>>>> at
>>>>>>>>ask.java:267)
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>>ext.java:344)
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>>41)
>>>>>>>> at
>>>>>>>>:338)
>>>>>>>> at
>>>>>>>> at
>>>>>>>>89)
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>>44)
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>>a:293)
>>>>>>>> at
>>>>>>>> at
>>>>>>>>2)
>>>>>>>> at
>>>>>>>>ivator.java:228)
>>>>>>>> at
>>>>>>>>va:333)
>>>>>>>> at
>>>>>>>>va:150)
>>>>>>>>Source)
>>>>>>>> at
>>>>>>>>t
>>>>>>>> at
>>>>>>>>eLoader.java:359)
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>>ask.java:206)
>>>>>>>> ... 48 more
>>>>>>>> at
>>>>>>>>eLoader.java:359)
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>>ask.java:206)
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>>ext.java:344)
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>>41)
>>>>>>>> at
>>>>>>>>:338)
>>>>>>>> at
>>>>>>>> at
>>>>>>>>89)
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>>44)
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>>a:293)
>>>>>>>> at
>>>>>>>> at
>>>>>>>>2)
>>>>>>>> at
>>>>>>>>ivator.java:228)
>>>>>>>> at
>>>>>>>>va:333)
>>>>>>>> at
>>>>>>>>va:150)
>>>>>>>>Source)
>>>>>>>> at
Re: IWAB0398E Error in generating WSDL from Java ...... [message #99095 is a reply to message #95901] Thu, 05 May 2005 05:53 Go to previous message
hi,
I thought i fixed this by reinstalling eclipse and creating a new workspace
but the problem's come back
I've tried sending a zipped workspace, but the file is too large - you only
accept 2000kb and my .metadata folder is 36.1 mbs on it's own
Any suggestions?
news:d4qsqn$drq$1@news.eclipse.org...
> it yet.
> -seng
>>>Thanks,
>>>-seng
>>>>>deployment
>>>>>>page(page 3)?
>>>>>>deployment page(page 3)? From the exception, it appears the Axis
>>>>>>AntTask is unable to load your service bean.
>>>>>>WebServiceTest.java file lives, the class loader will not be able to
>>>>>>see it. While this isn't explicit in the wizards, I agree the error
>>>>>>message could be more informative.
>>>>>>Thanks!
>>>>>>plork123 wrote:
>>>>>>>Section 3.2.4
>>>>>>>Converter.java
>>>>>>>>Hi,
>>>>>>>>page in the Web service wizards?
>>>>>>>>in the same service project specified on the 3rd page?
>>>>>>>>>Many Thanks
>>>>>>>>>Error while running
>>>>>>>>> at
>>>>>>>>>ask.java:267)
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>>ext.java:344)
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>>41)
>>>>>>>>> at
>>>>>>>>>:338)
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>>89)
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>>44)
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>>a:293)
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>>2)
>>>>>>>>> at
>>>>>>>>>ivator.java:228)
>>>>>>>>> at
>>>>>>>>>va:333)
>>>>>>>>> at
>>>>>>>>>va:150)
>>>>>>>>> Method)
>>>>>>>>> Source)
>>>>>>>>> Source)
>>>>>>>>> at
>>>>>>>>>t
>>>>>>>>> at
>>>>>>>>>eLoader.java:359)
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>>ask.java:206)
>>>>>>>>> ... 48 more
>>>>>>>>> at
>>>>>>>>>eLoader.java:359)
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>>ask.java:206)
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>>ext.java:344)
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>>41)
>>>>>>>>> at
>>>>>>>>>:338)
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>>89)
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>>44)
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>>a:293)
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>>2)
>>>>>>>>> at
>>>>>>>>>ivator.java:228)
>>>>>>>>> at
>>>>>>>>>va:333)
>>>>>>>>> at
>>>>>>>>>va:150)
>>>>>>>>> Method)
>>>>>>>>> Source)
>>>>>>>>> Source)
>>>>>>>>> at
Previous Topic:Can't see it installed
Next Topic:add soap header
Current Time: Sat Jul 19 12:36:10 EDT 2025
Powered by FUDForum. Page generated in 0.05481 seconds
