Home » Archived » M2M (model-to-model transformation) » [ATL] Attribute not being populated in target model
[ATL] Attribute not being populated in target model [message #94754] Fri, 07 November 2008 13:35 Go to next message
Hi all,
I am having a bit of difficulty with my transformation. When I try to
populate a target model attribute with an element from a set, only the
last target model element is populated with the attribute.
For example, the transformation below creates 4 TargetElements. Only the
fourth (last) element will have a value for the attribute 'att1'. Why is
att1 not populated the first three times TARGET!TargetElement is generated?
rule xx{
from
s:SOURCE!SourceElement
to
t:TARGET!TargetElement(
att1 <-SOURCE!AnotherSourceElement.allInstances()->first()
Any help would be much appriciated!
Mark
Re: [ATL] Attribute not being populated in target model [message #94783 is a reply to message #94754] Mon, 10 November 2008 04:28 Go to previous messageGo to next message
Originally posted by: mddfabro.ilog.fr
The same model element cannot be referred by more than 1 attribute or 1
containment reference.
So, only the last 'att1' that is set up will refer to
'SOURCE!AnotherSourceElement.allInstances()->first()'.
Marcos.
Mark Melia wrote:
> Hi all,
> rule xx{
> from
> to
> Mark
Re: [ATL] Attribute not being populated in target model [message #94808 is a reply to message #94783] Mon, 10 November 2008 05:24 Go to previous messageGo to next message
Hi Marcos,
Thanks for your reply, appriciate it!
Just to confirm..
what i expect in the target model is (roughly):
targetElement1.att1 = anotherSourceElement1
targetElement2.att1 = anotherSourceElement1
targetElement3.att1 = anotherSourceElement1
targetElement4.att1 = anotherSourceElement1
This is perfectly acceptable to do in an ecore model, but can't be done in
ATL?
Mark
Marcos Didonet Del Fabro wrote:
> Hi
> Marcos.
> Mark Melia wrote:
>> Hi all,
>> rule xx{
>> from
>> to
>> Mark
Re: [ATL] Attribute not being populated in target model [message #95013 is a reply to message #94808] Mon, 10 November 2008 18:42 Go to previous messageGo to next message
"Mark Melia" <mark.melia@gmail.com> schreef in bericht
news:b720a04b0d8317f6710f63732b8ae316$1@www.eclipse.org...
> Hi Marcos,
> Just to confirm..
> what i expect in the target model is (roughly): targetElement1.att1 =
> ATL?
I think the point of Marcos is that it is not acceptable in an ecore model.
Probably att1 is a containment attribute. If targetElement1 contains a
certain model elemnet, than targetElement2 cannot contain it. You wil need
to create a new anotherSourceElement1 for each assignment, this should be
done once you create a rule for AnotherSourceElement. Do you have one?
Alfons
> Mark
>> Hi
>> Marcos.
>> Mark Melia wrote:
>>> Hi all,
>>> generated?
>>> rule xx{
>>> from s:SOURCE!SourceElement
>>> to
>>> Mark
Re: [ATL] Attribute not being populated in target model [message #95056 is a reply to message #95013] Tue, 11 November 2008 05:01 Go to previous messageGo to next message
Hi Alfons,
Thanks for you reply and feedback, much appreciated!
I have investigated this and att1 is not containment attribute. Also in my
ecore model after the transformation I can edit the Ecore model to reflect:
Any other ideas?
thanks,
Mark
>> Hi Marcos,
>> Just to confirm..
>> ATL?
> Regards,
> Alfons
>> Mark
>>> Hi
>>> Marcos.
>>> Mark Melia wrote:
>>>> Hi all,
>>>> generated?
>>>> rule xx{
>>>> to
>>>> Mark
Re: [ATL] Attribute not being populated in target model [message #95134 is a reply to message #95056] Wed, 12 November 2008 11:46 Go to previous messageGo to next message
Hi all,
Just to add a bit more details to this problem. I have defined two global
variables - the first one was an instance of a SourceElementA from the
source metamodel (MMa), 'c', the second a simple String attribute, 'str'
(see below).
helper def : c : MMa!SourceElementA =
MMa!SourceElementA.allInstances()->first();
helper def : str : String = 'test';
I have then defined a rule that converts from instances of SourceElementB
to instances of TargetElement. The instances of TargetElement are
populated with the attribute values defined in the global variables where
EReference (containment = false) attribute 'sourceEleA' is assigned c and
EAttribute 'stringAtt' is assigned str.
By debugging this transformation I have established that both global
variables are set once, and that each of the attributes in the
transformation rule gets called correctly for the number of SourceElementB
instances in the source model. When I check the target model produced, I
find that only one instance of SourceElementB is populated with c, while
all instances of SourceElementB are populated with str.
rule entryLearnersBasedOnGoal{
from
competency:MMa!SourceElementB()
to
entryLearner:MMb!TargetElement(
sourceEleA <- thisModule.c,
strAtt<-thisModule.name
Is this a bug or design feature does anyone know?
Mark Melia wrote:
> Hi Alfons,
> Any other ideas?
> thanks,
> Mark
>>> Hi Marcos,
>>> Just to confirm..
>>> ATL?
>> Regards,
>> Alfons
>>> Mark
>>>> Hi
>>>> Marcos.
>>>> Mark Melia wrote:
>>>>> Hi all,
>>>>> generated?
>>>>> rule xx{
>>>>> to
>>>>> Mark
Re: [ATL] Attribute not being populated in target model [message #95239 is a reply to message #95134] Thu, 13 November 2008 11:07 Go to previous messageGo to next message
Hi Mark et al.
I have expereinced the same problem. To distill the issue using your
terminology...
I have a global property...
I can debug this value using .debug() and it shows the correct value as
the ATL transformation is run.
However if I then use property "c" multiple times later on its value is
different. It only evaluates to the correct value one time. After this the
value is empty. Why is this? I had assumed that the value would be stored
once in "c" and not re-evaluated again during the transformation.
Any insights are much appreciated.
Kind Regards,
Ronan
Re: [ATL] Attribute not being populated in target model [message #95253 is a reply to message #94754] Thu, 13 November 2008 11:26 Go to previous messageGo to next message
i have faced the same problem with the non containment references, here
you can find the discussion that lead to the resolution of the problem:
http://www.eclipse.org/newsportal/article.php?id=3516&gr oup=eclipse.modeling.m2m#3516
Re: [ATL] Attribute not being populated in target model [message #95349 is a reply to message #95253] Sat, 15 November 2008 13:34 Go to previous messageGo to next message
Hi Skander,
Thanks for your help, your suggestion of using a lazy rule worked.
rule xx{
from
to
att1
< -thisModule.att1Rule(SOURCE!AnotherSourceElement.allInstance s()- >first())
lazy rule att1Rule{
from
s2: SOURCE!SourceElement2
to
t2: TARGET!TargetElement2
I think that this should also work the original way - I wonder is this a
design decision or is it a bug. If you look through my other bugs you will
see more details of this problem.
Mark
Re: [ATL] Attribute not being populated in target model [message #95495 is a reply to message #95349] Mon, 17 November 2008 07:25 Go to previous messageGo to next message
Hi Skander,
One problem I noted with the lazy rule approach is that a new
TargetElement2 is created everytime rule xx calls it. Therefore a series
of duplicate TargetElemnent2 instances are created. Were you able to solve
this?
Mark
Mark Melia wrote:
> Hi Skander,
> rule xx{
> from
> to
> att1
> lazy rule att1Rule{
> from
> to
> Mark
Re: [ATL] Attribute not being populated in target model [message #95510 is a reply to message #95495] Mon, 17 November 2008 07:42 Go to previous messageGo to next message
yes you have to make your lazy rule execute only once with the keyword
"unique":
unique lazy rule RULE1 ....
Re: [ATL] Attribute not being populated in target model [message #95525 is a reply to message #95510] Mon, 17 November 2008 08:11 Go to previous messageGo to next message
Hi Skander,
Adding the unique keyword does succeed in eliminating duplicates, but the
original problem is back in that only the last element created contains
the reference. It is as if it thinks the reference is of type containment.
Mark
Re: [ATL] Attribute not being populated in target model [message #95616 is a reply to message #95525] Mon, 17 November 2008 10:43 Go to previous message
I use the unique keyword and it generates references to other objects. I
did not experiment the problem you're facing. Here is my code maybe it can
help:
myReferencesOnClasses <- s->collect(e | thisModule.myLazyRule(e)),
and the rule:
unique lazy rule myLazyRule {
from s : UML2!Class
to t : MM!Class (
name <- s.name,
implementations <- s.ownedPort
->collect(c | thisModule.myOtherLazyRule(c))
My Other Lazy Rule:
unique lazy rule myOtherLazyRule {
from s : UML2!Port
to t : MM!Port (
name <- s.name
This works fine for me, but you are using model elements that you collect
yourself, sometimes you can have a strange behaviour if you don't respect
the metamodel, i faced that problem.
Previous Topic:[ATL] Bug in ATL Editor?
Next Topic:[ATL] Setting enumeration value to enumeration tagged value
Current Time: Sat Jul 19 23:47:42 EDT 2025
Powered by FUDForum. Page generated in 0.05868 seconds
