Adding API to access ImportManager or to add imports to ITreeAppendable [message #949670] |
Fri, 19 October 2012 03:15  |
Compared to ugly code like (from http://www.eclipse.org/forums/index.php/t/262321/):
@Inject extension TypeReferenceSerializer
f.toField(name, type) [
val Procedure1<ITreeAppendable> proc = [
append('''new ''')
newTypeRef('java.util.BitSet').serialize(f,it)
append('''(«dataDef.fields.size»)''')
initializer = proc
I'd prefer to write
addImport(newTypeRef('java.util.BitSet').type)
append('''new BitSet(«dataDef.fields.size»)''')
initializer = proc
The obvious problem is breaking user-defined classes implementing ITreeAppendable, but I am not sure if people do this in practice. Of course, after I wrote it, I saw that this problem could be solved by creating my own class extending TreeAppendable, and overriding JvmModelGenerator.createAppendable to return it... So is it worth filing a bug for it?
Re: Adding API to access ImportManager or to add imports to ITreeAppendable [message #961538 is a reply to message #949670] |
Sun, 28 October 2012 07:00   |
> append('''new ''')
> initializer = proc
> I'd prefer to write
> initializer = proc
> a bug for it?
the appendable supports append of JvmType, so you could write
append('''new ''')
append(newTypeRef('java.util.BitSet').type)
initializer = proc
without using the serializer... which might be less ugly?
from what I understand about the appendable and import manager, using
initializer = proc
would still not be safe, since the "BitSet" you write in append('''new
BitSet(«dataDef.fields.size»)''') would not ensure that the string
"BitSet" is actually referred to the type ref java.util.BitSet (and
possible ambiguities would not be handled transparently by the
ImportManager).
somehow, the append of a type in the appendable should still be done NOT
as a string, but as a JvmType so that the ImportManager can deal with
that... at least that's how I understand it works
hope that helps
cheers
Lorenzo
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
http://www.myspace.com/supertrouperabba
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
FUDForum. Page generated in 0.07964 seconds
