Home » Eclipse Projects » Eclipse Platform » [Juno][XML Editor] last edit location does not work
[Juno][XML Editor] last edit location does not work [message #948257] Wed, 17 October 2012 18:37 Go to next message
I have a problem with "last edit location" feature in XML editor.
Since Juno release (Eclipse 4), "last edit location" button or shortcut (CRTL+Q) doesn't work on XML files. If I modify a text file or a java file, it's possible to return at the last typed text. But if I modify an XML file, it's not possible. This is not reproducible with Indigo release.
To reproduce it :
- open XML file in an existing project
- modify something
- switch on an other file
- try to go on "last edit location" with button or shortcut
There is no bug for this on bugzilla so I would like to know if someone else has the same problem.
PS : Sorry for my poor english
[Updated on: Thu, 18 October 2012 10:31] by Moderator
Re: [Juno][XML Editor] last edit location does not work [message #949048 is a reply to message #948257] Thu, 18 October 2012 12:25 Go to previous messageGo to next message
Régis,
I'd suggest opening a bugzilla for the Web Tools project; they have a
specific (eclipse.webtools) forum as well.
On 18/10/2012 2:11 PM, Régis wrote:
> Hello,
> or a java file, it's possible to return on the last typed text. But if
> Indigo release.
> To reproduce it : - open XML file in an existing project
> - modify something
> There is no bug for this on bugzilla so I would to know if someone
> have the same problem.
> Regards
Re: [Juno][XML Editor] last edit location does not work [message #949714 is a reply to message #949048] Fri, 19 October 2012 04:06 Go to previous message
Hi Ed,
Thanks for your reply. I will open a bugzilla.
Previous Topic:Eclipse Juno is unusably slow
Next Topic:Open file at line from command line
Current Time: Sat Jul 19 23:41:01 EDT 2025
Powered by FUDForum. Page generated in 0.03761 seconds
