Home » Language IDEs » PHP Development Tools (PDT) » The easy update
The easy update [message #94714] Fri, 27 February 2009 07:47 Go to next message
Originally posted by: nomail.nomail.it
I guess I can state that Eclipse + PDT are not easily updatable with a click
like other products.
To avoid the problem of dependencies (e.g. PDT 2.1 is not working on Eclipse
used for 2.0), etc, the best is using the package All-in-one. But that
solution brings another problem that need a little know how I don't have:
how to migrate custom information? E.g. how to backup/restore templates,
indentation values, Javascript validator->error/warnings, etc.?
Re: The easy update [message #94756 is a reply to message #94714] Sat, 28 February 2009 03:32 Go to previous messageGo to next message
W dniu 2009-02-27 13:47, Rik pisze:
As far as I know. All your preferences and settings are stored in your
workspace directory. Usually it is located in your
Document and settings directory:
C:\Documents And Settings\YourUserName\workspace (Windows XP)
C:\Users\YourUserName\workspace (Vista)
This directory still exists after upgrading all-in-one package.
Regards.
Adrian Ziolkowski
Re: The easy update [message #94852 is a reply to message #94714] Sun, 01 March 2009 17:55 Go to previous messageGo to next message
Originally posted by: eclipsenews.20.epm.spamgourmet.com
Just use the same workspace as before and all your settings will be
retained.
Re: The easy update [message #94866 is a reply to message #94852] Mon, 02 March 2009 06:29 Go to previous messageGo to next message
Originally posted by: christopher.loerken.net
> retained.
Be warned though that this unfortunately left my old Eclipse Europa PDT
1 version unusable since it cannnot start anymore...
And I too would have switched back for performance reasons since a
2.5Ghz Dual Core with 4GB Ram is obviously not enough for all the new
features :(
So (Warning: noob tip) make a backup before ;)
Christopher
Re: The easy update [message #94980 is a reply to message #94714] Wed, 04 March 2009 09:45 Go to previous message
Yes I've found them. Are located under <workspace>\.metadata
@Christopher
The problem is quite surely that new versions could change the number and
usage of parameters, so upgrading and downgrading to previuos versions can
generate problems. E.g. a parameter X=(n1 to n3) can contains n4 that
previous version Europa can't handle.
Thanks everybody!
Rik
Previous Topic:Contribution Item
Next Topic:wizards
Current Time: Sat Jul 19 18:00:52 EDT 2025
Powered by FUDForum. Page generated in 0.04768 seconds
