Operational QVT Interpreter [message #946881] |
Tue, 16 October 2012 11:43  |
when I define a debug/launch config for the Operation QVT Interpreter,
which meta model registry does it use? When I select my .qvto script, it
correctly lists input and output models, but whatever input file I
specify, it's always rejected.
Previously I loaded all relevant models into the global EMF registry and
attached a file suffix to it. How is this supposed to work with the
per-project metamodel map?
Marius
Re: Operational QVT Interpreter [message #947717 is a reply to message #946906] |
Wed, 17 October 2012 07:01   |
Hello Ed,
actually my question was this: how does the Operational QVT Interpreter
determine the i/o models - does it use the metamodel map of the project
hosting the qvto file?
Marius
On 16.10.2012 18:12, Ed Willink wrote:
> Hi
> As a general rule only Eclipse plugins (and standalone code emulating
> Eclipse plugins) should modify the global EMF registries.
> If the input file is rejected, I suspect that in some sense it is
> incompatible with what you have specified. But you provide no real
> details to go on.
> I'm afraid that I will not be able to give you any further help without
> a zipped project including a launch configuration that can just be
> installed and run to demonstrate your problem.
> Regards
> Ed Willink
> On 16/10/2012 16:43, Marius Gröger wrote:
>> Hello,
>> Thanks
>> Marius
Re: Operational QVT Interpreter [message #947751 is a reply to message #947717] |
Wed, 17 October 2012 07:49  |
I don't know. It works for me which is why I need to see an example of
what doesn;t work to be able to comment further.
Ed Willink
On 17/10/2012 12:01, Marius Gröger wrote:
> Hello Ed,
> Thanks
> Marius
>> Hi
>> details to go on.
>> Regards
>> Ed Willink
>>> Hello,
>>> Thanks
>>> Marius
FUDForum. Page generated in 0.03569 seconds
