Modifying the default grammar [message #947013] |
Tue, 16 October 2012 14:29  |
I use xbase and want to support using a tick (') behind a variable
reference to refer to the variable's previous value. The idea (at the
semantic level) is to have a hidden set of variables suffixed by
__PREVIOUS__ that remember the previous state and translate a reference
with the tick to refer to the hidden one. E.g. the identifier "a" refers
to "a" and "a'" refers to "a__PREVIOUS__".
The translation works, but I have problems redefining the grammar to
support this, without also redefining the ID terminal.
What I tried was the following:
// remove the use of tick in the String terminal
terminal STRING: '"' ( '\\' ('b'|'t'|'n'|'f'|'r'|'u'|'"'|"'"|'\\') |
// support trailing tick, as 'previous' value
PreviousValueID: ValidID "'"?;
// use PreviousValueID in XMemberFeatureCall
XMemberFeatureCall returns xbase::XExpression: ...
The idea is to limit the use of the tick-suffixed references to variable
references. However, I still got syntax errors when I use the tick. I
also need to redefine the ID terminal to allow a trailing tick, but this
will allow it almost everywhere, including in class names. I couldn't
find other usages of tick in the grammar than in the STRING terminal, so
shouldn't it be enough to redefine only STRING and not ID?
Hallvard
Re: Modifying the default grammar [message #947056 is a reply to message #947013] |
Tue, 16 October 2012 15:22   |
Hi Hallvard,
what kind of syntax error do you get?
Did you override XFeatureCall, too?
Overriding the ID rule should not be necessary.
Sebastian
Looking for professional support for Xtext, Xtend or Eclipse Modeling?
Am 16.10.12 20:29, schrieb Hallvard Trætteberg:
> Hallvard
Re: Modifying the default grammar [message #947084 is a reply to message #947056] |
Tue, 16 October 2012 16:00  |
Sebastian,
You are right, I discovered a bit after posting. The problem was I
didn't override XFeatureCall (the rule used when there is no dot, which
is the case for ordinary variables).
I ended up redefining only the STRING terminal and the IdOrSuper rule,
which is used by XFeatureCall. XFeatureCall itself needn't be redefined.
Here's the overrides:
// remove apostrophe variant
// support trailing apostrophe, as 'previous' value
IdOrSuper: (ValidID "'"?) | "'" | "super";
I also needed to inject a new value converter for the IdOrSuper rule, so
the apostrophe suffix is converted to __PREVIOUS__.
I get a warning stating that "Decision can match input such as "'\''"
using multiple alternatives: 1, 2", but it seems to work...
Grammar overrides are very powerful, but you really need to understand
the grammar you're overriding.
Hallvard
On 16.10.12 12.22, Sebastian Zarnekow wrote:
> Hi Hallvard,
> Regards,
> Sebastian
FUDForum. Page generated in 0.03110 seconds
