Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » EMFStore catalog/index(EMFStore catalog/index)
EMFStore catalog/index [message #946175] Mon, 15 October 2012 21:52 Go to next message
I've been looking into EMFStore as an approach to maintaining my models and model instances. Looks very promising but I have the following questions:
Where can I find the model/schema that EMFStore uses to maintain its catalog/index of saved models and instances?
What is the type of repository the EMFStore uses? git, svn, or something else?
Jim
Re: EMFStore catalog/index [message #946705 is a reply to message #946175] Tue, 16 October 2012 08:22 Go to previous messageGo to next message
Hi Jim,
EMFStore uses EMF to define its model/schema, so they are all described
in Ecore, namely in three plugins in our git repository:
org.eclipse.emf.emfstore.common.model/model/common.ecore
org.eclipse.emf.emfstore.server.model/model/server.ecore
org.eclipse.emf.emfstore.client.model/model/client.ecore
The repository is a custom repository and stores its data into EMF
resources. By default it uses the EMF XMI resource implementation,
storing data in to a set of XML files.
Let me know if you need any more information!
Maximilian
Am 16.10.2012 03:52, schrieb Jim Foscue:
> questions:
> something else?
> Thanks
> Jim
Maximilian Kögel
Get Professional Eclipse Support: http://eclipsesource.com/munich
Re: EMFStore catalog/index [message #946970 is a reply to message #946705] Tue, 16 October 2012 13:35 Go to previous messageGo to next message
Thanks for your quick reply.
As a follow-up it looks like a ProjectSpace is the top level that references a Project. And a Project contains the list of model elements(object/model instances?). Is this accurate?
Where does EMF keep up with the resource location?
Re: EMFStore catalog/index [message #947682 is a reply to message #946970] Wed, 17 October 2012 06:05 Go to previous messageGo to next message
Hi Jim ,
yes, Project is a container for EObjects and is being maintained by
ProjectSpace, which stores accounting information such as the changes
that have been executed.
I am not sure, if I understand your question about the resource location
correctly, but I will try to answer anyway ;): EMFStore automatically
takes care of all objects that are added to the containment tree of the
project, if necessary it adds them to a resource (by default a XMI
Resource).
Maximilian
Am 16.10.2012 19:35, schrieb Jim Foscue:
> Thanks
Maximilian Kögel
Re: EMFStore catalog/index [message #948378 is a reply to message #947682] Wed, 17 October 2012 21:47 Go to previous messageGo to next message
Thanks for your replies. I have more questions...
Can the EMFStore clients run in an offline mode without the server?
We are considering building on top of EMFStore and would need to be able to provide the users the CRUD capabilities. Where can I find the documented API (maybe javadoc) for EMFStore?
How would I query the EMFStore for instances? Say I have Library models stored and I want to find one that matches a name that is part of the Library.
Thanks again for all your help.
Jim
Re: EMFStore catalog/index [message #949034 is a reply to message #948378] Thu, 18 October 2012 12:06 Go to previous messageGo to next message
Hi Jim,
sure, thanks for giving EMFStore a try, comments inline...
Yes, absolutely. Projects can remain in an unshared state. They are only
stored on the client then.
All public methods are documented as JavaDoc, if you install the source
bundles you can see the documentation. A good starter to learn about the
API (which is quite thin), are the example plugins:
http://eclipse.org/emfstore/documentation/howToUseExamples.php
You can find more information including the example plugins on this page:
http://eclipse.org/emfstore/documentation.php
> Library.
Clients check out a project from the EMFStore. So they can run queries
on the project locally. It is possible to implement a server extension
to run specific queries on the server, but currently there is no generic
server-side query support.
If you would like to discuss certain usage scenarios, maybe a Skype
telco would help to answer all your questions. I would be available on
Skype tomorrow (GMT+2). Anyway I am happy to answer your questions in
the newsgroup, of course.
Maximilian
Maximilian Kögel
Re: EMFStore catalog/index [message #949110 is a reply to message #949034] Thu, 18 October 2012 13:50 Go to previous messageGo to next message
As for the queries part, the following sounds interesting:
http://eclipse.org/proposals/modeling.emf.incquery/
Maybe, that could be integrated (somehow) into emfstore (client or server side).
Re: EMFStore catalog/index [message #949791 is a reply to message #949110] Fri, 19 October 2012 05:46 Go to previous messageGo to next message
Good idea, I guess so. I know Istvan (project lead) and hope to meet him
next week at EclipseCon.
Maximilian
Am 18.10.2012 19:50, schrieb Erdal Karaca:
> server side).
Maximilian Kögel
Re: EMFStore catalog/index [message #958921 is a reply to message #949791] Fri, 26 October 2012 06:12 Go to previous message
an update on this: I met Istvan at the EclipseCon and we agreed to build
a prototype for an integration to show feasibility. The first iteration
of the prototype will allow to run queries on the client side and the
second iteration will run queries on the server side.
Maximilian
Maximilian
Am 19.10.2012 11:46, schrieb Maximilian Koegel:
> Cheers,
> Maximilian
>> server side).
Maximilian Kögel
Previous Topic:EMFStore Team Support
Next Topic:Edit - ignore this post [Texo] Trying to get the Rest Web Service going
Current Time: Sat Jul 19 21:28:56 EDT 2025
Powered by FUDForum. Page generated in 0.03513 seconds
