Home » Eclipse Projects » JFace » [Databinding] Problems with multiple actions in a checkbox(When I select a checkbox I'm modifyng another attribute, binded to a Text, that's not automatically updated)
[Databinding] Problems with multiple actions in a checkbox [message #940439] Thu, 11 October 2012 12:33 Go to next message
Hi, I'm having a problem with an SWT Dialog, where I've one Checkbox and one Text. When checkbox is changed setBooleanAttribute(boolean value) method is called through databinding, and after setting the attribute, the method changes the value of another attribute, which is binded to the Text component.
The issue I'm facing is the update of Text value, that is not being modified when the model's attribute changes through setBooleanAttribute.
I'm generating the binding with Window Builder and model elements are two separate objects. The following code is the generated binding and a simplified example version of the triggered sets explained before:
		IObservableValue btnManejaDominioObserveSelectionObserveWidget_1 = SWTObservables.observeSelection(btnManejaDominio);
		IObservableValue controladorManejaDominioObserveValue = PojoObservables.observeValue(controlador, "manejaDominio");
		bindingContext.bindValue(btnManejaDominioObserveSelectionObserveWidget_1, controladorManejaDominioObserveValue, null, null);
		IObservableValue textObserveTextObserveWidget = SWTObservables.observeText(text, SWT.Modify);
		IObservableValue controladorDominioAdapternombreObserveValue = PojoObservables.observeValue(controlador, "dominioAdapter.nombre");
		bindingContext.bindValue(textObserveTextObserveWidget, controladorDominioAdapternombreObserveValue, null, null);
		// FIRST SET (Boolean)
		public void setManejaDominio(Boolean manejaDominio) {
			this.manejaDominio = manejaDominio;
			this.dominioAdapter.setNombre("Default Nombre");
		// SECOND SET (Called from the first)
		public void setNombre(String nombre){
			this.nombre = nombre;
I'm not sure if databinding is wrongly configured or has to do with composite layout. When I debug the values are properly set in the model.
How can I react to those model changes in GUI?
Thanks in advance
Mauricio
Re: [Databinding] Problems with multiple actions in a checkbox [message #945684 is a reply to message #940439] Mon, 15 October 2012 10:33 Go to previous message
I was working over the wrong concept that binding from model to GUI was automatically done. The missing actor in my model was PropertyChangeSupport, with that point added and changing PojoObservables to BeansObservables I achieved bidirectionality.
These are useful resources:
Eclipsepedia - Pojo Bindable & JFace Databinding
JBoss Tools - Eclipse wizards with jface databinding in Deltacloud Tools (1)
https: //community.jboss.org/wiki/EclipsewizardswithjfacedatabindinginDeltacloudTools1
Previous Topic:refreshing the content of an advanced property sheet
Next Topic:JFace CellEditor- Table cell click actions
Current Time: Sat Jul 19 22:51:40 EDT 2025
Powered by FUDForum. Page generated in 0.04919 seconds
