Home » Eclipse Projects » Equinox » Starting Eclipse workbench
Starting Eclipse workbench [message #94380] Tue, 07 August 2007 10:48 Go to next message
Originally posted by: thomas.forster.iese.fhg.de
is it possible to start an Eclipse workbench instance from
an Equinox-OSGi launch configuration?
If yes, how would I do it?
Regards Thomas
Re: Starting Eclipse workbench [message #94431 is a reply to message #94380] Tue, 07 August 2007 11:00 Go to previous messageGo to next message
By coincidence I was just trying to do this and found a few bugs with
PDE->UI. Once I figure out what is going on I will open a bug and post
the link here.
Tom.
Re: Starting Eclipse workbench [message #94522 is a reply to message #94380] Tue, 07 August 2007 17:48 Go to previous messageGo to next message
Here are the steps I use to get this to work:
1) Create a new OSGi Framework launch configuration
2) On the bundles tab set "Default Auto-Start:" to false and "Default
Start level:" is 4
3) Make sure the following bundles have these settings for Start Level
and Auto-Start
org.eclipse.core.runtime default true
org.eclipse.equinox.common 2 true
4) On the Arguments tab remove the following options from the VM
arguments "-Declipse.ignoreApp=true -Dosgi.noShutdown=true"
5) Add -product org.eclipse.sdk.ide to the end of the Program arguments
Assuming you are using the Eclipse SDK as your target this will launch
the sdk product which should start the workbench.
HTH
Tom.
Re: Starting Eclipse workbench [message #94552 is a reply to message #94522] Wed, 08 August 2007 04:18 Go to previous message
> Start level:" is 4
> and Auto-Start
> HTH
> Tom.
Thanks a lot, it worked!
Regards Thomas
Previous Topic:Start Equinox using Reflection
Next Topic:PDE MANIFEST.MF editor import-package error
Current Time: Sat Jul 19 21:42:29 EDT 2025
Powered by FUDForum. Page generated in 0.26295 seconds
