Home » Eclipse Projects » Nebula » Checkbox GridColumn Event Handling(How to check which column is clicked on Grid?)
Checkbox GridColumn Event Handling [message #921454] |
Mon, 24 September 2012 02:07  |
I am trying to develop a GUI which has a Grid with 10 to 15 columns.
First column is a label, then a column group of 4-5 columns and then another column group of 4 columns and last column is with Text Editor.
The two column groups contains the columns of check boxes with some text associated with checkbox.
Now I am trying to check which checkbox is clicked in the Grid, based on that i have to do some handling.
To implement this kind of GUI, I am implementing the selection listener on Grid. I can find out whether the check box is clicked or not through following code:
public void widgetSelected(SelectionEvent e) {
if(e.detail == SWT.CHECK)
System.out.println("~~~~~~~~~~ CheckBox CLICKED ~~~~~~~~~~~");
After getting this message printed on my console, i am unable to find out which check box is clicked. Also I am using column spanning in column groups.
Please help me out ASAP.
Thanks in advance.
Ashish Rawat
[Updated on: Mon, 24 September 2012 04:03] by Moderator
Re: Checkbox GridColumn Event Handling [message #929133 is a reply to message #921769] |
Mon, 01 October 2012 04:47   |
Hi Thomas,
Following is the source code for your inspection. Please guide me through the way where I can find the solution to my problem.
Please not that there are 2 column groups, and one group may contain any number of check-box columns. If in first group, in 1st row there are 5 check box columns then it may happen in 2nd row of same group there may be 2 check boxes only.
public PinTableGridView(Composite parent, int style,
DataBindingContext dbc, IComponent objComponent,
ArrayList<ModelItem> objChildrenList) {
super(parent, style);
setLayout(new FillLayout(SWT.HORIZONTAL));
this.dbContext = dbc;
this.pinSettingsComponent = objComponent;
this.list = objChildrenList;
updateMaxInputPinsCount();
updateMaxOutputPinsCount();
model = new PinSettingModel[list.size()];
for (int index = 0; index < list.size(); index++) {
ModelItem modelItem = list.get(index);
model[index] = new PinSettingModel(pinSettingsComponent,
modelItem.getSymbol(), RAppIDWizardUtility.getInputList(
pinSettingsComponent, modelItem.getSymbol()),
RAppIDWizardUtility.getOutputList(pinSettingsComponent,
modelItem.getSymbol()), modelItem.getExtraText());
gridTable = new Grid(this, SWT.BORDER | SWT.V_SCROLL | SWT.H_SCROLL);
gridTable.setHeaderVisible(true);
gridTable.setLinesVisible(true);
editor = new GridEditor(gridTable);
gridTable.addSelectionListener(this);
// Functions Column
colFunctions = new GridColumn(gridTable, SWT.NONE);
colFunctions.setText("Functions");
colFunctions.setWidth(200);
// Input Column
colGrpInput = new GridColumnGroup(gridTable, SWT.NONE);
colGrpInput.setText("Input");
if(maxInputPinsCount == 0)
colInputPins = new GridColumn[1];
colInputPins[0] = new GridColumn(colGrpInput, SWT.NONE);
colInputPins[0].setWidth(125);
else
colInputPins = new GridColumn[maxInputPinsCount];
for (int i = 0; i < maxInputPinsCount; i++) {
colInputPins[i] = new GridColumn(colGrpInput, SWT.CHECK | SWT.LEFT);
colInputPins[i].setWidth(50);
if(maxInputPinsCount == 1)
colInputPins[i].setWidth(125);
colInputPins[i].addSelectionListener(new SelectionListener() {
// TODO Auto-generated method stub
System.out.println("~~~~ Selected Column: " + e.getSource().toString());
public void widgetDefaultSelected(SelectionEvent e) {
// Output Column
colGrpOutput = new GridColumnGroup(gridTable, SWT.NONE);
colGrpOutput.setText("Output");
if(maxOutputPinsCount == 0)
colOutputPins = new GridColumn[1];
colOutputPins[0] = new GridColumn(colGrpOutput, SWT.NONE);
colOutputPins[0].setWidth(125);
else
colOutputPins = new GridColumn[maxOutputPinsCount];
for (int i = 0; i < maxOutputPinsCount; i++) {
colOutputPins[i] = new GridColumn(colGrpOutput, SWT.CHECK
| SWT.LEFT);
colOutputPins[i].setWidth(50);
// User Assigned Signal Name Column
colUserSignalName = new GridColumn(gridTable, SWT.NONE);
colUserSignalName.setText("User Signal Name");
colUserSignalName.setWidth(150);
editableColumn = colInputPins.length+colOutputPins.length+1;
private void updateMaxOutputPinsCount() {
int maxOutputPins = 0;
for (int i = 0; i < list.size(); i++) {
ModelItem modelItem = list.get(i);
maxOutputPins = RAppIDWizardUtility.getOutputList(
pinSettingsComponent, modelItem.getSymbol()).size();
if (maxOutputPinsCount < maxOutputPins) {
maxOutputPinsCount = maxOutputPins;
private void updateMaxInputPinsCount() {
int maxInputPins = 0;
maxInputPins = RAppIDWizardUtility.getInputList(
if (maxInputPinsCount < maxInputPins) {
maxInputPinsCount = maxInputPins;
protected void checkSubclass() {
// Disable the check that prevents subclassing of SWT components
private PinSettingModel[] model;
public void setComponent(IComponent objComponent,
// model = new PinSettingModel[list.size()];
for (int index = 0; index < this.list.size(); index++) {
ModelItem modelItem = this.list.get(index);
GridItem gridItem = new GridItem(gridTable, SWT.NONE);
gridItem.setHeight(18);
gridItem.setText(0, model[index].getSignalName());
ArrayList<String> lstInputPins = model[index].getInputPins();
int lastCheckBoxIndex = 0;
for (int i = 0; i < colGrpInput.getColumns().length; i++) {
if (lstInputPins.size() > 0 && i < lstInputPins.size()) {
ModelItem modelItemPin = pinSettingsComponent
.findBySymbol(lstInputPins.get(i));
PinDetails objPinDetails = model[index].getInputPinName(modelItemPin.getSymbol());
gridItem.setText(i + 1, objPinDetails.getPinName());
if(objPinDetails.isDefault())
gridItem.setFont(i + 1, JFaceResources.getFontRegistry().getBold(
gridItem.getFont().toString()));
lastCheckBoxIndex = i + 1;
if (modelItemPin.getItemName().contains(modelItem.getText())) {
gridItem.setChecked(i + 1, true);
} else {
gridItem.setChecked(i + 1, false);
} else {
if(lastCheckBoxIndex == 0)
lastCheckBoxIndex += 1;
gridItem.setColumnSpan(lastCheckBoxIndex, colInputPins.length - lastCheckBoxIndex);
ArrayList<String> lstOutputPins = model[index].getOutputPins();
lastCheckBoxIndex = colInputPins.length;
for (int i = 0; i < colGrpOutput.getColumns().length; i++) {
if (lstOutputPins.size() > 0 && i < lstOutputPins.size()) {
.findBySymbol(lstOutputPins.get(i));
.getOutputPinName(modelItemPin.getSymbol());
gridItem.setText(i + maxInputPinsCount + 1,
if (objPinDetails.isDefault()) {
gridItem.setFont(
lastCheckBoxIndex = i + maxInputPinsCount + 1;
gridItem.setChecked(i + maxInputPinsCount + 1, true);
} else {
gridItem.setChecked(i + maxInputPinsCount + 1, false);
} else {
if(lastCheckBoxIndex == colInputPins.length)
colInputPins.length + colOutputPins.length
String extraText = modelItem.getExtraText();
gridItem.setText(gridTable.getColumnCount() - 1,
extraText);
public void dispose() {
if (!gridTable.isDisposed()) {
gridTable.removeSelectionListener(this);
gridTable.dispose();
gridTable = null;
protected void refreshUI() {
if (e.detail == SWT.CHECK) {
GridItem item = (GridItem) e.item;
System.out.println("Widget:::::::: " + e.widget);
System.out.println("Source::::::::: " + e.getSource());
System.out.println("Event::::::::: "
+ this.gridTable.getFocusItem());
} else {
// Clean up any previous editor control
Control oldEditor = editor.getEditor();
if (oldEditor != null)
oldEditor.dispose();
// Identify the selected row
if (item == null)
return;
// The control that will be the editor must be a child of the
// Table
Text newEditor = new Text(gridTable, SWT.NONE);
final int selectedIndex = gridTable.getSelectionIndex();
final ModelItem modelItem = list.get(selectedIndex);
// TODO: Write the logic to check for extra text for Automatic
// selection. Avoid hard coding.
if (extraText.equalsIgnoreCase("No pin routed")) {
extraText = "";
if (modelItem.getText().equalsIgnoreCase("<Automatic>")) {
newEditor.setEditable(false);
newEditor.setEnabled(false);
} else {
newEditor.setEditable(true);
newEditor.setEnabled(true);
newEditor.setText(extraText);
item.setText(editableColumn, extraText);
newEditor.addModifyListener(new ModifyListener() {
public void modifyText(ModifyEvent me) {
Text text = (Text) editor.getEditor();
modelItem.setExtraText(text.getText());
editor.getItem().setText(editableColumn, text.getText());
newEditor.selectAll();
newEditor.setFocus();
editor.setEditor(newEditor, item, editableColumn);
Ashish Rawat
Re: Checkbox GridColumn Event Handling [message #982997 is a reply to message #943804] |
Tue, 13 November 2012 10:41  |
Would it be possible for you to post the snippet of code relating to the checkbox event handling? I have been trying to get this to work out on my own project and can't get it working.
Is there any website that clearly explains/shows how to do this with the Nebula components?
Current Time: Sat Jul 19 20:04:57 EDT 2025
Powered by FUDForum. Page generated in 0.04339 seconds
