Home » Archived » Test and Performance Tools Platform (TPTP) » TPTP and tunnel
TPTP and tunnel [message #93700] Mon, 19 March 2007 06:41 Go to next message
Originally posted by: piolaki.wp.pl
Im trying to make test from recording through tunnel, but when im finish
recording there is no action no url nothing in test file.
When im making test recording without tunnel, test file have all action
everything work fine.
I was trying change configuration Agent Controller, but nothing change.
im using tptp 4.3.1
firewall off
What i have to check or configure to make it work?
If are needed more precisely information about configuration just ask:)
Piotr
Re: TPTP and tunnel [message #94131 is a reply to message #93700] Mon, 26 March 2007 02:42 Go to previous messageGo to next message
Hi, Piotr
By default, the Agent Controller uses the following ports to establish
neywork connections: 10002, 10005, 10006 (and 10003 if security is
enabled).
If you have network problems, You can set another values in the
config/serviceconfig.xml file.
Igor
Re: TPTP and tunnel [message #94168 is a reply to message #94131] Mon, 26 March 2007 09:38 Go to previous message
Thx, I found error i give adress like http://127.0.0.1/ and doesnt work,
correct adres is http://localhost/ :p
Previous Topic:LogParserExtension example multi file import fails
Next Topic:Generate an a .adapter file
Current Time: Sat Jul 19 21:32:08 EDT 2025
Powered by FUDForum. Page generated in 0.03467 seconds
