Problem with deployment using plans [message #941247] |
Fri, 12 October 2012 06:32  |
I'm having problems getting plans to work, as a deployment mechanism in Virgo.
As per the documentation, I have carefully placed my bundles (including correctly generated MANIFEST.MF) in the $VIRGO_HOME/repository/usr directory. I then restarted the Virgo server, using the -clean flag. However, when I try and hot deploy my .plan file in the pickup directory, the server is telling me that it can't find the bundles that exist within the usr directory. This is not consistent for all of my bundles - some work, some don't, and I really can't see why!
Maybe I've missed something? Can someone please help point me in the correct direction?
Many thanks in advance,
Seth
Re: Problem with deployment using plans [message #968241 is a reply to message #941532] |
Fri, 02 November 2012 06:02  |
The most obvious cause of this failure would be that Bundle-Version of the com.myCompany.service.definition.service-definition bundle is less than 0.0.2. Please could you post the manifest here if you think the version is correct.
FUDForum. Page generated in 0.07812 seconds
