"Form Too Large" with Custom Widget [message #93935] |
Wed, 18 June 2008 15:14  |
I have a custom widget that generates quite a big amount of data that I
want to send back to the java part I'm using the following snippet:
var wm = org.eclipse.swt.WidgetManager.getInstance();
var id = wm.findIdByWidget(this);
var req = org.eclipse.swt.Request.getInstance();
req.addParameter(id + ".customparameter", this._bigstring);
But I'm getting a blank screen with a message saying "Form Too Large".
Any ideias of how can I overcome this?
Thanks in advance.
Tiago
Re: "Form Too Large" with Custom Widget [message #94006 is a reply to message #93978] |
Thu, 19 June 2008 08:26   |
Originally posted by: rherrmann.innoopract.com
Tiago,
this looks like you hit the default limit for form requests of Jetty.
See this link on how this limit can be changed:
http://www.nabble.com/Tap4-and-Jetty-%22Form-Too-Large%22-to 11029080.html
However, I would rather work on reducing the size of the request.
HTH
Rüdiger
Tiago wrote:
> Hi Rudige,
> This is what I got in the server side:
> 19 Jun 2008 12:01:51,884 ERROR org.mortbay.jetty.context./ -
> /chums?nocache=1213873311852:
> java.lang.IllegalStateException: Form too large
> at org.mortbay.http.HttpRequest.extractParameters(HttpRequest.j ava:877)
> at org.mortbay.http.HttpRequest.getParameter(HttpRequest.java:9 44)
> at
> org.mortbay.jetty.servlet.ServletHttpRequest.getParameter(Se rvletHttpRequest.java:650)
> at
> javax.servlet.ServletRequestWrapper.getParameter(ServletRequ estWrapper.java:138)
> at
> org.eclipse.rwt.internal.service.ServiceManager.getCustomHan dlerId(ServiceManager.java:128)
> at
> org.eclipse.rwt.internal.service.ServiceManager.isCustomHand ler(ServiceManager.java:116)
> at
> org.eclipse.rwt.internal.service.ServiceManager$HandlerDispa tcher.service(ServiceManager.java:96)
> at
> org.eclipse.rwt.internal.engine.RWTDelegate.doPost(RWTDelega te.java:61)
> at
> org.eclipse.ui.internal.servlet.RequestHandler.service(Reque stHandler.java:52)
> at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
> at
> org.eclipse.equinox.http.servlet.internal.ServletRegistratio n.handleRequest(ServletRegistration.java:90)
> at
> org.eclipse.equinox.http.servlet.internal.ProxyServlet.proce ssAlias(ProxyServlet.java:111)
> at
> org.eclipse.equinox.http.servlet.internal.ProxyServlet.servi ce(ProxyServlet.java:59)
> at
> org.eclipse.equinox.http.jetty.internal.HttpServerManager$In ternalHttpServiceServlet.service(HttpServerManager.java:270)
> at
> org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder .java:428)
> at
> org.mortbay.jetty.servlet.ServletHandler.dispatch(ServletHan dler.java:677)
> at
> org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandl er.java:568)
> at org.mortbay.http.HttpContext.handle(HttpContext.java:1530)
> at org.mortbay.http.HttpContext.handle(HttpContext.java:1482)
> at org.mortbay.http.HttpServer.service(HttpServer.java:909)
> at org.mortbay.http.HttpConnection.service(HttpConnection.java: 820)
> at org.mortbay.http.HttpConnection.handleNext(HttpConnection.ja va:986)
> at org.mortbay.http.HttpConnection.handle(HttpConnection.java:8 37)
> at
> org.mortbay.http.SocketListener.handleConnection(SocketListe ner.java:245)
> at org.mortbay.util.ThreadedServer.handle(ThreadedServer.java:3 57)
> at org.mortbay.util.ThreadPool$PoolThread.run(ThreadPool.java:5 34)
> It doesn't say me much, maybe will do for you.
> Thanks.
> Tiago
> Rüdiger Herrmann wrote:
>> Tiago,
>> Jetty seems to limit the maximum form content by default.
>> Is there a server-side exception you are getting? If so, please send
>> the stack trace (start with -consolelog to have it printed to std out).
>> Cheers,
>> Rüdiger
>> Tiago wrote:
>>> Hi
>>> I want to send back to the java part I'm using the following snippet:
>>> Large". Any ideias of how can I overcome this?
>>> Thanks in advance.
>>> Tiago
Re: "Form Too Large" with Custom Widget [message #94097 is a reply to message #94006] |
Fri, 20 June 2008 09:04  |
Hi Rüdiger,
That will do it. Thanks.
Tiago
> Tiago,
> HTH
> Rüdiger
> Tiago wrote:
>> Hi Rudige,
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Thanks.
>> Tiago
>>> Tiago,
>>> Cheers,
>>> Rüdiger
>>> Tiago wrote:
>>>> Hi
>>>> that I want to send back to the java part I'm using the following
>>>> snippet:
>>>> Thanks in advance.
>>>> Tiago
FUDForum. Page generated in 0.04187 seconds
