Home » Eclipse Projects » Remote Application Platform (RAP) » About the exception of upload widget
About the exception of upload widget [message #93603] |
Mon, 16 June 2008 06:07  |
The org.eclipse.rwt.widgets.Upload component has been used in my project.
I have deployed my project in jetty-6.1.9.
When I visited this project, the following exception will be throw out:
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Nativ e
Method)
at
sun.reflect.NativeConstructorAccessorImpl.newInstance(Native ConstructorAccessorImpl.java:39)
at
sun.reflect.DelegatingConstructorAccessorImpl.newInstance(De legatingConstructorAccessorImpl.java:27)
at java.lang.reflect.Constructor.newInstance(Constructor.java:4 94)
at
net.heartsome.srp.component.ContentPageComposite$1$1.widgetS elected(ContentPageComposite.java:318)
at
org.eclipse.swt.events.SelectionEvent.dispatchToObserver(Sel ectionEvent.java:174)
at org.eclipse.rwt.internal.events.Event.processEvent(Event.jav a:44)
at
org.eclipse.swt.events.TypedEvent.processEvent(TypedEvent.ja va:114)
at
org.eclipse.swt.events.TypedEvent.executeNext(TypedEvent.jav a:154)
at
org.eclipse.rwt.internal.lifecycle.RWTLifeCycle.readAndDispa tch(RWTLifeCycle.java:243)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :682)
at
org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2393)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2352)
at org.eclipse.ui.internal.Workbench.access$5(Workbench.java:22 05)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:425)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:408)
at
org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:157)
at
net.heartsome.srp.ssisrap.Application.createUI(Application.j ava:34)
at
org.eclipse.rwt.internal.lifecycle.EntryPointManager.createU I(EntryPointManager.java:92)
at
org.eclipse.rwt.internal.lifecycle.RWTLifeCycle.createUI(RWT LifeCycle.java:230)
at
org.eclipse.rwt.internal.lifecycle.RWTLifeCycle$UIThreadCont roller.run(RWTLifeCycle.java:116)
at java.lang.Thread.run(Thread.java:595)
Caused by: java.lang.Error: Unresolved compilation problem:
at
org.eclipse.rwt.widgets.upload.servlet.FileUploadServiceHand ler.register(FileUploadServiceHandler.java:155)
at org.eclipse.rwt.Upload.<clinit>(Upload.java:55)
But it working properly in Eclipse.
What the cause of this exception? How can i resolve it?
Terry
Re: About the exception of upload widget [message #93756 is a reply to message #93711] |
Tue, 17 June 2008 05:55   |
Originally posted by: fappel.innoopract.com
so it seems that org.apache.commons.fileupload is not on your build path.
Have you added it to your feature.xml? Is it available in your workspace
from where you build the deployment version?
Ciao
Frank
-----Ursprüngliche Nachricht-----
Von: Terry Zhang [mailto:terry_zhang@i-len.com]
Bereitgestellt: Dienstag, 17. Juni 2008 10:27
Bereitgestellt in: eclipse.technology.rap
Unterhaltung: About the exception of upload widget
Betreff: Re: About the exception of upload widget
Hi Frank,
Thank you for your advice.
I used the feature export, but the following error information appeared in
log file:
39. ERROR
in
/data/terry/Studio/rap_studio/workspace/org.eclipse.rwt.widg ets.upload/src/org/eclipse/rwt/widgets/upload/servlet/FileUp loadServlet.java
(at line 18)
import org.apache.commons.fileupload.*;
The import org.apache.commons cannot be resolved
40. ERROR
in
(at line 19)
import org.apache.commons.fileupload.disk.DiskFileItemFactory;
41. ERROR
in
(at line 20)
import org.apache.commons.fileupload.servlet.ServletFileUpload;
42. ERROR
in
(at line 109)
FileItemFactory factory = new DiskFileItemFactory();
FileItemFactory cannot be resolved to a type
43. ERROR
in
(at line 109)
DiskFileItemFactory cannot be resolved to a type
And then the feature export failed. I don't know what happen about it, and
how to resolve it.
Terry
Frank Appel wrote:
> the root cause of your exception is a 'Unresolved compilation problem'.
> So
> it seems that your export doesn't work properly. Maybe some dependencies
> used by the fileupload projects are available. To get a better picture
> of
> the problem it often helps to use the feature export which provides more
> detailed information.
> Ciao
> Frank
> Bereitgestellt: Montag, 16. Juni 2008 12:07
> Betreff: About the exception of upload widget
> Hi
> project.
> Method)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Cheers,
> Terry
Re: About the exception of upload widget [message #93891 is a reply to message #93756] |
Tue, 17 June 2008 22:14   |
I have added org.apache.commons.fileupload to my feature.xml, but errors
still exist after deployment. I am sure that it is available in my
workspace. Now I have found a way to solve this problem. I add
commons-fileupload-1.2.jar & commons-io-1.3.2.jar to classpath of
org.eclipse.rwt.widgets.upload, modify build.properties of
org.eclipse.rwt.widgets.upload as below:
output.. = targetclasses
bin.includes = META-INF/,\
plugin.xml,\
qx-upload.js,\
commons-fileupload-1.2.jar,\
source.. = src/
Thereafter, I don't have to add it to feature.xml. However, the
build.properties is modified. Do you have any better solution?
Terry
Frank Appel wrote:
> Ciao
> Frank
> Hi Frank,
> log file:
> 39. ERROR
> in
> (at line 18)
> 40. ERROR
> in
> (at line 19)
> 41. ERROR
> in
> (at line 20)
> 42. ERROR
> in
> (at line 109)
> 43. ERROR
> in
> (at line 109)
> how to resolve it.
> Cheers,
> Terry
> Frank Appel wrote:
>> Hi,
>> So
>> of
>> Ciao
>> Frank
>> Hi
>> project.
>> Method)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Cheers,
>> Terry
Re: About the exception of upload widget [message #93920 is a reply to message #93891] |
Wed, 18 June 2008 05:36   |
Hi again,
at least we can see that it's realy a build path problem. Somehow the
dependencies seem not to be resolved in your build process, but from my
point of view I can't see what is going wrong.
Ciao
Frank
Bereitgestellt: Mittwoch, 18. Juni 2008 04:14
plugin.xml,\
qx-upload.js,\
source.. = src/
Terry
Frank Appel wrote:
> path.
> Ciao
> Frank
> Hi Frank,
> in
> log file:
> 39. ERROR
> in
> (at line 18)
> 40. ERROR
> in
> (at line 19)
> 41. ERROR
> in
> (at line 20)
> 42. ERROR
> in
> (at line 109)
> 43. ERROR
> in
> (at line 109)
> and
> how to resolve it.
> Cheers,
> Terry
> Frank Appel wrote:
>> Hi,
>> So
>> dependencies
>> of
>> more
>> Ciao
>> Frank
>> Hi
>> project.
>> at
>> Method)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Cheers,
>> Terry
Re: About the exception of upload widget [message #96051 is a reply to message #96039] |
Wed, 02 July 2008 18:26   |
sorry , I just forgot to post it
osgi> Jul 3, 2008 1:11:36 AM org.mortbay.http.HttpServer doStart
INFO: Version Jetty/5.1.x
Jul 3, 2008 1:11:36 AM org.mortbay.util.Container start
INFO: Started
org.eclipse.equinox.http.jetty.internal.Servlet25Handler@15a0305
INFO: Started HttpContext[/,/]
Jul 3, 2008 1:11:36 AM org.mortbay.http.SocketListener start
INFO: Started SocketListener on 0.0.0.0:7070
INFO: Started org.mortbay.http.HttpServer@1f3aa07
Jul 3, 2008 1:11:48 AM org.mortbay.jetty.servlet.ServletHandler handle
SEVERE: /rap?startup=default:
org.eclipse.rwt.internal.resources.ResourceRegistrationExcep tion: Failed
to register resource 'qx-upload.js'.
at
org.eclipse.rwt.internal.resources.ResourceManagerImpl.doReg ister(ResourceManagerImpl.java:411)
at
org.eclipse.rwt.internal.resources.ResourceManagerImpl.regis ter(ResourceManagerImpl.java:224)
at
org.eclipse.ui.internal.servlet.ResourceManagerFactory$Resou rceManagerWrapper.register(ResourceManagerFactory.java:134)
at
org.eclipse.swt.internal.widgets.displaykit.QooxdooResources Util.registerContributions(QooxdooResourcesUtil.java:211)
at
org.eclipse.swt.internal.widgets.displaykit.QooxdooResources Util.registerResources(QooxdooResourcesUtil.java:189)
at
org.eclipse.swt.internal.widgets.displaykit.DisplayLCA.write Libraries(DisplayLCA.java:217)
at
org.eclipse.swt.internal.widgets.displaykit.DisplayLCAFacade Impl.writeLibrariesInternal(DisplayLCAFacadeImpl.java:31)
at
org.eclipse.swt.internal.widgets.displaykit.DisplayLCAFacade .writeLibraries(DisplayLCAFacade.java:36)
at
org.eclipse.rwt.internal.lifecycle.DisplayUtil.writeLibrarie s(DisplayUtil.java:66)
at
org.eclipse.rwt.internal.service.LifeCycleServiceHandlerConf igurer.getLibraries(LifeCycleServiceHandlerConfigurer.java:2 02)
at
org.eclipse.rwt.internal.service.LifeCycleServiceHandlerConf igurer.getTemplateOfStartupPage(LifeCycleServiceHandlerConfi gurer.java:60)
at
org.eclipse.rwt.internal.service.BrowserSurvey.load(BrowserS urvey.java:123)
at
org.eclipse.rwt.internal.service.BrowserSurvey.renderScript( BrowserSurvey.java:90)
at
org.eclipse.rwt.internal.service.BrowserSurvey.sendBrowserSu rvey(BrowserSurvey.java:51)
at
org.eclipse.rwt.internal.service.LifeCycleServiceHandler.int ernalService(LifeCycleServiceHandler.java:180)
at
org.eclipse.rwt.internal.service.LifeCycleServiceHandler.acc ess$1(LifeCycleServiceHandler.java:168)
at
org.eclipse.rwt.internal.service.LifeCycleServiceHandler$Lif eCycleServiceHandlerSync.doService(LifeCycleServiceHandler.j ava:133)
at
org.eclipse.rwt.internal.lifecycle.RWTLifeCycleServiceHandle rSync.serviceInternal(RWTLifeCycleServiceHandlerSync.java:47 )
at
org.eclipse.rwt.internal.lifecycle.RWTLifeCycleServiceHandle rSync.service(RWTLifeCycleServiceHandlerSync.java:35)
at
org.eclipse.rwt.internal.service.LifeCycleServiceHandler.ser vice(LifeCycleServiceHandler.java:140)
at
org.eclipse.rwt.internal.service.ServiceManager$HandlerDispa tcher.service(ServiceManager.java:100)
at
org.eclipse.rwt.internal.engine.RWTDelegate.doPost(RWTDelega te.java:61)
at
org.eclipse.ui.internal.servlet.RequestHandler.service(Reque stHandler.java:51)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
at
org.eclipse.equinox.http.servlet.internal.ServletRegistratio n.handleRequest(ServletRegistration.java:90)
at
org.eclipse.equinox.http.servlet.internal.ProxyServlet.proce ssAlias(ProxyServlet.java:111)
at
org.eclipse.equinox.http.servlet.internal.ProxyServlet.servi ce(ProxyServlet.java:59)
at
org.eclipse.equinox.http.jetty.internal.HttpServerManager$In ternalHttpServiceServlet.service(HttpServerManager.java:269)
at
org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder .java:428)
at
org.mortbay.jetty.servlet.ServletHandler.dispatch(ServletHan dler.java:677)
at
org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandl er.java:568)
at org.mortbay.http.HttpContext.handle(HttpContext.java:1530)
at org.mortbay.http.HttpContext.handle(HttpContext.java:1482)
at org.mortbay.http.HttpServer.service(HttpServer.java:909)
at org.mortbay.http.HttpConnection.service(HttpConnection.java: 820)
at
org.mortbay.http.HttpConnection.handleNext(HttpConnection.ja va:986)
at org.mortbay.http.HttpConnection.handle(HttpConnection.java:8 37)
at
org.mortbay.http.SocketListener.handleConnection(SocketListe ner.java:245)
at org.mortbay.util.ThreadedServer.handle(ThreadedServer.java:3 57)
at org.mortbay.util.ThreadPool$PoolThread.run(ThreadPool.java:5 34)
Caused by: java.io.IOException: Resource to read not found: qx-upload.js
at
org.eclipse.rwt.internal.resources.ResourceUtil.openStream(R esourceUtil.java:228)
at
org.eclipse.rwt.internal.resources.ResourceUtil.readText(Res ourceUtil.java:113)
at
org.eclipse.rwt.internal.resources.ResourceUtil.read(Resourc eUtil.java:44)
at
org.eclipse.rwt.internal.resources.ResourceManagerImpl.doReg ister(ResourceManagerImpl.java:406)
... 40 more
Salwa
Re: About the exception of upload widget [message #96150 is a reply to message #96051] |
Thu, 03 July 2008 02:24   |
Originally posted by: rherrmann.innoopract.com
Hi Salwa,
still, the stack trace tells that the resource was not found. Please
double check that it is where it is expected. Maybe unpack the
deployed bundle and see it it is really there.
Rüdiger
Salwa wrote:
> INFO: Started
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 40 more
> Regards Salwa
Re: About the exception of upload widget [message #96261 is a reply to message #96150] |
Thu, 03 July 2008 05:29   |
I unpack the upload bundle , and the qx-upload.js is there ,,, The
strange thing is, the load.js is registered , but qx-upload.js No...
The export bundle hold the following files:
1) plugin.xml:it contain this info:
<?eclipse version="3.2"?>
<plugin>
<extension point="org.eclipse.rap.ui.themeableWidgets">
<widget
class="org.eclipse.rwt.widgets.Upload"
id="org.eclipse.rwt.widgets.upload"
name="upload">
</widget>
</extension>
<extension point="org.eclipse.rap.ui.resources">
<resource
class="org.eclipse.rwt.widgets.internal.uploadkit.QxUploadResource "/>
<resource
class="org.eclipse.rwt.widgets.internal.uploadkit.UploadResource "/>
</extension>
<extension point="org.eclipse.equinox.http.registry.servlets">
<servlet
alias="/upload"
class="org.eclipse.rwt.widgets.upload.servlet.FileUploadServlet "
httpcontextId="org.eclipse.rap.httpcontext"
load-on-startup="false">
</servlet>
</extension>
</plugin>
2) qx-upload.js
3) upload.jar
4) META-INF : contain this info:
Bundle-ManifestVersion: 2
Bundle-Name: %Bundle-Name
Bundle-Vendor: %Bundle-Vendor
Bundle-SymbolicName: org.eclipse.rwt.widgets.upload;singleton:=true
Bundle-Version: 1.0.0
Require-Bundle: org.eclipse.core.runtime;bundle-version="3.4.0",
org.eclipse.rap.rwt,
org.apache.commons.fileupload;bundle-version="1.2.0",
org.apache.commons.io;bundle-version="1.3.2"
Export-Package: org.eclipse.rwt.widgets
Import-Package: javax.servlet;version="[2.3.0,2.5.0]",
javax.servlet.http;version="[2.3.0,2.5.0]"
Bundle-ClassPath: upload.jar
Bundle-ActivationPolicy: lazy
Bundle-Activator: org.eclipse.rwt.widgets.Activator
Salwa
Re: About the exception of upload widget [message #96289 is a reply to message #96261] |
Thu, 03 July 2008 06:06   |
Salwa,
looking at the source code in CVS, the qx-upload.js is registered in
QxUploadResource.
If I export the plug-in, there is no embedded upload.jar either. Are
you maybe working with an outdated or modified version?
Rüdiger
Salwa wrote:
> Hi
> <plugin>
> <widget
> name="upload">
> </widget>
> </extension>
> <resource
> <resource
> </extension>
> <servlet
> alias="/upload"
> </servlet>
> </extension>
> </plugin>
> 2) qx-upload.js
> 3) upload.jar
> Regards Salwa
Re: About the exception of upload widget [message #96414 is a reply to message #96051] |
Thu, 03 July 2008 09:08   |
Originally posted by: tavoaqp.gmail.com
I have the same problem here, do you have any progress on this issue?
Gustavo
Salwa escreveu:
> INFO: Started
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 40 more
> Regards Salwa
Re: About the exception of upload widget [message #96772 is a reply to message #96414] |
Fri, 04 July 2008 05:01   |
maybe the problem is, that the qx-upload.js is in the root folder of the
project. Can someone who can reproduce this issue try to move it to a
subfolder (i.e. /src).
I think that the registration mechanism starts searching there - the
location for Upload.js is "org/eclipse/rwt/widgets/Upload.js" in the
UpdateResource.java.
Stefan.
Gustavo schrieb:
> Hi
> Thanks
> Gustavo
> Salwa escreveu:
>> Hi,
>> INFO: Started
>> Failed to register resource 'qx-upload.js'.
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 40 more
>> Regards Salwa
Re: About the exception of upload widget [message #96907 is a reply to message #96772] |
Fri, 04 July 2008 12:18   |
I guess I solved this issue, is pretty simple in fact and a known solution:
- Export the org.apache.commons.upload and org.apache.commons.io bundles
as deployable plugins
- Delete the projects from your workspace (with content)
- Import the deployable plugins (File->Import->Plugin
development->Plugin and fragments)
- Ccompile your .war again
At least that worked for me, hope it helps :)
Gustavo
Stefan Roeck escreveu:
> Regards,
> Stefan.
> Gustavo schrieb:
>> Hi
>> Thanks
>> Gustavo
>> Salwa escreveu:
>>> Hi,
>>> INFO: Started
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 40 more
>>> Regards Salwa
Re: About the exception of upload widget [message #97074 is a reply to message #96907] |
Sat, 05 July 2008 07:52  |
Thankx for you help guys.
I have solved the prob :).
Actually, I was exporting the upload plug-in as a jar File, but when i
export it as a folder, it works with me.
So in your export window , there is "Option" tab , you just need to check
out "Package plugins as individual JAR archive".
Salwa
Current Time: Sat Jul 19 19:34:20 EDT 2025
Powered by FUDForum. Page generated in 0.07851 seconds
