Home » Modeling » TMF (Xtext) » Problem after eclipse update to 4.2.1(ClassCastException)
Problem after eclipse update to 4.2.1 [message #934051] Fri, 05 October 2012 11:56
I tried to update to Eclipse 4.2.1 using the default download for DSL-developers from eclipse.org. Now my xtext projects struggle with some inner ClassCastException.
The error-indicator is being displayed in the first line of the respective XText grammar files.
Anyone else with the same problem? Known fixes?
I am switching back to 4.2 for now.
!SESSION 2012-10-04 18:53:59.066 -----------------------------------------------
eclipse.buildId=M20120914-1800
java.version=1.7.0_03
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=de_DE
Framework arguments:  -product org.eclipse.epp.package.dsl.product
Command-line arguments:  -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.dsl.product
This is a continuation of log file C..\workspace_4.2\.metadata\.bak_0.log
Created Time: 2012-10-05 17:21:47.655
!ENTRY org.apache.log4j 4 0 2012-10-05 17:21:47.656
!MESSAGE org.eclipse.xtext.xtext.XtextLinker  - org.eclipse.xtext.util.SimpleAttributeResolver$DiscardingAdapter cannot be cast to org.eclipse.xtext.xtext.ecoreInference.SourceAdapter
!STACK 0
java.lang.ClassCastException: org.eclipse.xtext.util.SimpleAttributeResolver$DiscardingAdapter cannot be cast to org.eclipse.xtext.xtext.ecoreInference.SourceAdapter
	at org.eclipse.xtext.xtext.ecoreInference.SourceAdapter.adapt(SourceAdapter.java:28)
	at org.eclipse.xtext.xtext.ecoreInference.EClassifierInfo$EClassInfo.addFeature(EClassifierInfo.java:326)
	at org.eclipse.xtext.xtext.ecoreInference.EClassifierInfo$EClassInfo.addFeature(EClassifierInfo.java:150)
	at org.eclipse.xtext.xtext.ecoreInference.Xtext2EcoreInterpretationContext.addFeature(Xtext2EcoreInterpretationContext.java:125)
	at org.eclipse.xtext.xtext.ecoreInference.Xtext2EcoreInterpretationContext.addFeature(Xtext2EcoreInterpretationContext.java:94)
	at org.eclipse.xtext.xtext.ecoreInference.Xtext2EcoreTransformer$3.caseAssignment(Xtext2EcoreTransformer.java:403)
	at org.eclipse.xtext.xtext.ecoreInference.Xtext2EcoreTransformer$3.caseAssignment(Xtext2EcoreTransformer.java:1)
	at org.eclipse.xtext.util.XtextSwitch.doSwitch(XtextSwitch.java:164)
	at org.eclipse.xtext.util.XtextSwitch.doSwitch(XtextSwitch.java:70)
	at org.eclipse.xtext.util.XtextSwitch.doSwitch(XtextSwitch.java:58)
	at org.eclipse.xtext.xtext.ecoreInference.Xtext2EcoreTransformer.deriveFeatures(Xtext2EcoreTransformer.java:461)
	at org.eclipse.xtext.xtext.ecoreInference.Xtext2EcoreTransformer.deriveFeatures(Xtext2EcoreTransformer.java:468)
	at org.eclipse.xtext.xtext.ecoreInference.Xtext2EcoreTransformer.access$2(Xtext2EcoreTransformer.java:464)
	at org.eclipse.xtext.xtext.ecoreInference.Xtext2EcoreTransformer$3.caseGroup(Xtext2EcoreTransformer.java:412)
	at org.eclipse.xtext.xtext.ecoreInference.Xtext2EcoreTransformer$3.caseGroup(Xtext2EcoreTransformer.java:1)
	at org.eclipse.xtext.util.XtextSwitch.doSwitch(XtextSwitch.java:245)
	at org.eclipse.xtext.xtext.ecoreInference.Xtext2EcoreTransformer.deriveFeatures(Xtext2EcoreTransformer.java:480)
	at org.eclipse.xtext.xtext.ecoreInference.Xtext2EcoreTransformer.deriveFeatures(Xtext2EcoreTransformer.java:314)
	at org.eclipse.xtext.xtext.ecoreInference.Xtext2EcoreTransformer.transform(Xtext2EcoreTransformer.java:140)
	at org.eclipse.xtext.xtext.XtextLinker.linkModel(XtextLinker.java:223)
	at org.eclipse.xtext.resource.XtextResource.doLinking(XtextResource.java:279)
	at org.eclipse.xtext.linking.lazy.LazyLinkingResource.doLinking(LazyLinkingResource.java:82)
	at org.eclipse.xtext.xtext.GrammarResource.superDoLinking(GrammarResource.java:42)
	at org.eclipse.xtext.xtext.GrammarResource$LinkingTrigger.installDerivedState(GrammarResource.java:75)
	at org.eclipse.xtext.resource.DerivedStateAwareResource.installDerivedState(DerivedStateAwareResource.java:125)
	at org.eclipse.xtext.resource.DerivedStateAwareResource.getContents(DerivedStateAwareResource.java:48)
	at org.eclipse.emf.ecore.util.EcoreUtil.getAllContents(EcoreUtil.java:1121)
	at org.eclipse.xtext.xtext.ui.editor.syntaxcoloring.SemanticHighlightingCalculator.provideHighlightingFor(SemanticHighlightingCalculator.java:49)
	at org.eclipse.xtext.ui.editor.syntaxcoloring.MergingHighlightedPositionAcceptor.provideHighlightingFor(MergingHighlightedPositionAcceptor.java:51)
	at org.eclipse.xtext.ui.editor.syntaxcoloring.HighlightingReconciler.reconcilePositions(HighlightingReconciler.java:88)
	at org.eclipse.xtext.ui.editor.syntaxcoloring.HighlightingReconciler.modelChanged(HighlightingReconciler.java:281)
	at org.eclipse.xtext.ui.editor.syntaxcoloring.HighlightingReconciler$1.process(HighlightingReconciler.java:252)
	at org.eclipse.xtext.ui.editor.syntaxcoloring.HighlightingReconciler$1.process(HighlightingReconciler.java:1)
	at org.eclipse.xtext.util.concurrent.IUnitOfWork$Void.exec(IUnitOfWork.java:36)
	at org.eclipse.xtext.util.concurrent.AbstractReadWriteAcces.readOnly(AbstractReadWriteAcces.java:32)
	at org.eclipse.xtext.ui.editor.model.XtextDocument.readOnly(XtextDocument.java:78)
	at org.eclipse.xtext.ui.editor.syntaxcoloring.HighlightingReconciler.refresh(HighlightingReconciler.java:249)
	at org.eclipse.xtext.ui.editor.syntaxcoloring.HighlightingReconciler.install(HighlightingReconciler.java:204)
	at org.eclipse.xtext.ui.editor.syntaxcoloring.HighlightingHelper.enable(HighlightingHelper.java:91)
	at org.eclipse.xtext.ui.editor.syntaxcoloring.HighlightingHelper.install(HighlightingHelper.java:79)
	at org.eclipse.xtext.ui.editor.syntaxcoloring.HighlightingHelper.install(HighlightingHelper.java:61)
	at org.eclipse.xtext.ui.editor.XtextEditor.installHighlightingHelper(XtextEditor.java:496)
	at org.eclipse.xtext.ui.editor.XtextEditor.createPartControl(XtextEditor.java:458)
	at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.createPartControl(CompatibilityPart.java:129)
	at org.eclipse.ui.internal.e4.compatibility.CompatibilityEditor.createPartControl(CompatibilityEditor.java:95)
	at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:300)
	at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
	at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:859)
	at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:839)
	at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:111)
	at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:319)
	at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:240)
	at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:161)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:102)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:71)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:53)
	at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:141)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:896)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:630)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:732)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$2(PartRenderingEngine.java:703)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$7.run(PartRenderingEngine.java:697)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:682)
	at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.showTab(StackRenderer.java:1114)
	at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer$1.handleEvent(LazyStackRenderer.java:67)
	at org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:41)
	at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:180)
	at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:150)
	at org.eclipse.swt.widgets.Display.syncExec(Display.java:4687)
	at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:187)
	at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:38)
	at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:197)
	at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
	at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
	at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
	at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
	at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
	at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
	at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:81)
	at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:58)
	at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
	at org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.setSelectedElement(ElementContainerImpl.java:171)
	at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.showElementInWindow(ModelServiceImpl.java:418)
	at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.bringToTop(ModelServiceImpl.java:385)
	at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.delegateBringToTop(PartServiceImpl.java:579)
	at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.bringToTop(PartServiceImpl.java:315)
	at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.showPart(PartServiceImpl.java:985)
	at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:3079)
	at org.eclipse.ui.internal.WorkbenchPage.access$22(WorkbenchPage.java:3003)
	at org.eclipse.ui.internal.WorkbenchPage$8.run(WorkbenchPage.java:2985)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2981)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2940)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2931)
	at org.eclipse.ui.ide.IDE.openEditor(IDE.java:655)
	at org.eclipse.ui.ide.IDE.openEditor(IDE.java:614)
	at org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInEditor(EditorUtility.java:360)
	at org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInEditor(EditorUtility.java:167)
	at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:249)
	at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:228)
	at org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchRun(SelectionDispatchAction.java:275)
	at org.eclipse.jdt.ui.actions.SelectionDispatchAction.run(SelectionDispatchAction.java:251)
	at org.eclipse.jdt.internal.ui.packageview.PackageExplorerActionGroup.handleOpen(PackageExplorerActionGroup.java:376)
	at org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart$4.open(PackageExplorerPart.java:538)
	at org.eclipse.ui.OpenAndLinkWithEditorHelper$InternalListener.open(OpenAndLinkWithEditorHelper.java:48)
	at org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredViewer.java:866)
	at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:49)
	at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
	at org.eclipse.jface.viewers.StructuredViewer.fireOpen(StructuredViewer.java:864)
	at org.eclipse.jface.viewers.StructuredViewer.handleOpen(StructuredViewer.java:1152)
	at org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(StructuredViewer.java:1256)
	at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrategy.java:275)
	at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.java:269)
	at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:309)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
	at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4169)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3758)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1029)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:923)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
	at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:588)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:543)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
Previous Topic:scoping: both uri and classpath based
Next Topic:Suggest feature only if another feature exists
Current Time: Sun Jul 20 16:06:00 EDT 2025
Powered by FUDForum. Page generated in 0.03598 seconds
