Home » Archived » Test and Performance Tools Platform (TPTP) » Get exact CPU time of a Java Application
Get exact CPU time of a Java Application [message #93364] Mon, 12 March 2007 11:38 Go to next message
Originally posted by: schlossh.fh-trier.de
Hello everyone,
I would like to measureexact execution time of a Java application. The
textbook approach calling "System.currentTimeMillis" before and after the
code to be measured may include much more than just code's execution time.
Now my question: Is there a simply way to import and use a tptp-library
which implements the "GetCurrentThreadCPUTime"-method declared in jvmti.h in
order to get the exact execution time?
Thanks a lot
Hermann
Re: Get exact CPU time of a Java Application [message #93378 is a reply to message #93364] Tue, 13 March 2007 07:13 Go to previous messageGo to next message
Hermann,
The main problem with the JVMTI GetCurrentThreadCPUTime is that it uses
inaccurate CPU counters. These counters seem to be updated at a
millisecond resolution, so it it actually not very useful for most
practical purposes. For most functions, you are likely to get a CPU time
of 0.
The new JVMTI CPU Profiler can collect this information for you. To
enable this feature, double click the "Execution time analysis" analysis
type in the Monitor tab of the Profiling Launch Configuration dialog,
and select the "Collect method CPU time information" option.
I am not aware of any way of obtaining this information from a Java
application. If you wish to write your own native JVMTI-based data
collector for doing this, take a look at the source code of the JVMTI
CPU Data Collector
(org.eclipse.tptp.platform.jvmti.runtime/src-native/src/CGPr of) and let
me know if you have any specific questions.
HTH,
Asaf
Asaf Yaffe
Eclipse TPTP Committer, JVMTI Profiler
Re: Get exact CPU time of a Java Application [message #93450 is a reply to message #93378] Wed, 14 March 2007 05:34 Go to previous message
Hi Asaf,
thank you for your fast replay.
>inaccurate CPU counters. These counters seem to be updated at a millisecond
>resolution, so it it actually not very useful for most practical purposes.
>For most functions, you are likely to get a CPU time of 0.
For my purpose is the resolution of JVMTI's GetCurrentThreadCPUTime
suficient. So I just like to access this method within my Java-Application.
Do you have any idea how it could work?
> collector for doing this, take a look at the source code of the JVMTI CPU
> Data Collector
> (org.eclipse.tptp.platform.jvmti.runtime/src-native/src/CGPr of) and let me
I have actually checked out the
org.eclipse.tptp.platform.jvmti.runtime/src-native/src/CGPro f-project from
eclips's cvs repository and going to take a clooser look at it. So thank you
for your advice!
Best regards
Hermann
"Asaf Yaffe" <asaf.yaffe@intel.com> schrieb im Newsbeitrag
news:et6117$375$1@utils.eclipse.org...
> Hermann,
>> in order to get the exact execution time?
> of 0.
> The new JVMTI CPU Profiler can collect this information for you. To enable
> this feature, double click the "Execution time analysis" analysis type in
> the Monitor tab of the Profiling Launch Configuration dialog, and select
> Data Collector
> HTH,
> Asaf
> Asaf Yaffe
Previous Topic:What is a live instance?
Next Topic:GetCurrentThreadCpuTime
Current Time: Sun Jul 20 09:35:32 EDT 2025
Powered by FUDForum. Page generated in 0.26681 seconds
