Home » Modeling » GMF (Graphical Modeling Framework) » how can I set the location of the view in the editor without opening it?
how can I set the location of the view in the editor without opening it? [message #93132] Tue, 16 January 2007 06:16 Go to next message
I use copyToImageUtil to add a view to diagram file without opening the
file, and it works, but I can not set the location of the view in the editor
without opening the editor, how can I set the location of the view in the
((Diagram)objs[0]).insertChild(view); //add the view to the diagram file
without opening it
==============the completed code I used:
final Resource modelResource = resourceSet.getResource(
URI.createPlatformResourceURI(resourcePath
.toString()), true);
if(modelResource instanceof XMIResourceImpl){
Object[] objs = getElements(modelResource);
EObjectAdapter objAdapter = new EObjectAdapter(data);
CopyToImageUtil copyToImageUtil = new CopyToImageUtil();
diagramEditPart = copyToImageUtil.createDiagramEditPart((Diagram)
objs[0],shell,NewpmbeDiagramEditorPlugin.DIAGRAM_PREFERENCES _HINT);
CreateViewRequest.ViewDescriptor viewDescriptor = new
CreateViewRequest.ViewDescriptor(
objAdapter, Node.class, null,
NewpmbeDiagramEditorPlugin.DIAGRAM_PREFERENCES_HINT);
if(subDiagramEditPart != null){ //
Re: how can I set the location of the view in the editor without opening it? [message #93258 is a reply to message #93132] Tue, 16 January 2007 09:36 Go to previous message
HI ;
Check the SetBoundsCommand; it should give you an idea on how to do it
> without opening it
> if(subDiagramEditPart != null){ //ÊÇsubDiagramµÄcmd¾ÍÔÚsubDiagramÖд´½¨£¬Õ
Previous Topic:Question about disallowing certain changes based on gmfmap file
Next Topic:Problem with RCP when opening corresponding diagram from node
Current Time: Sat Jul 19 06:59:31 EDT 2025
Powered by FUDForum. Page generated in 0.26644 seconds
