Home » Modeling » GMF (Graphical Modeling Framework) » Programmatically drag and drop
Programmatically drag and drop [message #92826] Mon, 15 January 2007 12:16 Go to next message
Originally posted by: joerg.weinmann.iese.fraunhofer.de
Hi everybody,
I need some help with the various Request subclasses of GMF-runtime.
In my EMF model the class "Component" has a reference "contains" to itself,
so that a Component can contain several other "Components". I already have a
GMF-generated editor for my model.
So for example, let C_A be a Component which contains Components C_A1 and
C_A2. And let C_B be an other Component.
What I want to do is programmatically move C_A1 and C_A2 to C_B, so that C_B
contains C_A1 and C_A2 and C_A is "empty".
I already tried SetRequest&DestroyRequest and MoveRequest, but it is not
working like I exepected it. So basically all I want to do is simulate a d&d
programmtically.
My underlying gmf model loks like this:
<ecore:EPackage xmi:version="2.0"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore"
name="ConnectorComponent"
nsURI="www.iese.fraunhofer.de/ConnectorComponent" nsPrefix="cmpnt">
<eClassifiers xsi:type="ecore:EClass" name="AbstractComponent"
abstract="true" eSuperTypes="#//ArchitecturalElements">
<eStructuralFeatures xsi:type="ecore:EReference" name="contains"
upperBound="-1"
eType="#//AbstractComponent" containment="true"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="name"
eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="AbstractConnector"
<eStructuralFeatures xsi:type="ecore:EReference" name="source"
lowerBound="1"
eType="#//AbstractComponent"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="target"
lowerBound="1"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="ArchitecturalDescription">
<eStructuralFeatures xsi:type="ecore:EReference" name="has"
upperBound="-1" eType="#//ArchitecturalElements"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="ArchitecturalElements"
abstract="true"/>
<eClassifiers xsi:type="ecore:EClass" name="Connector"
eSuperTypes="#//AbstractConnector"/>
<eClassifiers xsi:type="ecore:EClass" name="Component"
eSuperTypes="#//AbstractComponent"/>
</ecore:EPackage>
Input:
Re: Programmatically drag and drop [message #92840 is a reply to message #92826] Mon, 15 January 2007 12:20 Go to previous messageGo to next message
Continuation of my post:
Input:
<cmpnt:ArchitecturalDescription xmi:version="2.0"
xmlns:cmpnt="www.iese.fraunhofer.de/ConnectorComponent">
<has xsi:type="cmpnt:Component" name="C_A">
<contains xsi:type="cmpnt:Component" name="C_A1"/>
<contains xsi:type="cmpnt:Component" name="C_A2"/>
</has>
<has xsi:type="cmpnt:Component" name="C_B"/>
</cmpnt:ArchitecturalDescription>
Expected Output:
<has xsi:type="cmpnt:Component" name="C_A"/>
<has xsi:type="cmpnt:Component" name="C_B">
</has
Thanks for your help.
J
Re: Programmatically drag and drop [message #92853 is a reply to message #92826] Mon, 15 January 2007 12:29 Go to previous messageGo to next message
Originally posted by: vcciubot.uwaterloo.ca
The easiest way would be to create your abstract transactional command
that adds one component to a different container. This is equivalent of a
move since EMF will remove it from its previous container.
Execute that command on the operation history.
-vlad
On Mon, 15 Jan 2007 18:16:51 +0100, Jörg Weinmann wrote:
> Hi everybody,
> programmtically.
> xmlns:xmi="http://www.omg.org/XMI"
> upperBound="-1"
> </eClassifiers>
> lowerBound="1"
> lowerBound="1"
> </eClassifiers>
> </eClassifiers>
> abstract="true"/>
> </ecore:EPackage>
> Input:
Re: Programmatically drag and drop [message #93117 is a reply to message #92853] Tue, 16 January 2007 06:04 Go to previous messageGo to next message
I think what you described already exitsts:
org.eclipse.gmf.runtime.emf.type.core.commands.MoveElementsC ommand
My code looks like this:
MoveRequest moveRequest = new
MoveRequest(selectedElement.getEditingDomain(), createdModelElement,
listOfContainedElements);
MoveElementsCommand moveCommand = new MoveElementsCommand(moveRequest);
selectedElement.getDiagramEditDomain().getDiagramCommandStac k().execute(new
ICommandProxy(moveCommand));
But the visuals don't get updated. I have to close and reopen the diagram to
see the changes. Is there a way to force a refresh on the whole diagram?
J
Re: Programmatically drag and drop [message #93229 is a reply to message #93117] Tue, 16 January 2007 08:16 Go to previous messageGo to next message
I modified my action like you advised, but the result is the same like
before: the underlying data model is correctly changed, but the visual
representation is not correctly updated.
IOperationHistory history = OperationHistoryFactory.getOperationHistory();
try {
history.execute(moveCommand, new NullProgressMonitor(), null);
} catch (ExecutionException e) {
e.printStackTrace();
J
Re: Programmatically drag and drop [message #93320 is a reply to message #93229] Tue, 16 January 2007 11:05 Go to previous messageGo to next message
Are the containers you are moving canonical? Meaning, do the compartments
have canonical edit policies installed? If so you can put a break point in
CanonicalEditPolicy#shouldHandleNotificationEvent to see whether it
returns true after your command gets executed.
In my case I override it like this:
protected boolean shouldHandleNotificationEvent(Notification event) {
Object element = event.getNotifier();
if (element instanceof EObject && !(element instanceof View)
&& NotificationUtil.isSlotModified(event))
return true;
return super.shouldHandleNotificationEvent(event);
This might trigger the update in your case too. I don't remember why I
added this code, but I think I was having a similar problem.
-vlad
> try {
> Cheers,
> Jörg
> "Jörg Weinmann" <joerg.weinmann@iese.fraunhofer.de> wrote in message
> news:eoibgm$3q6$1@utils.eclipse.org...
>> Thanks,
>> to see the changes. Is there a way to force a refresh on the whole
>> diagram?
>> Cheers,
>> Jörg
>> "Vlad Ciubotariu" <vcciubot@uwaterloo.ca> wrote in message
>> news:pan.2007.01.15.17.29.52.516113@uwaterloo.ca...
>>> -vlad
>>>> Hi everybody,
>>>> itself,
>>>> have a
>>>> and
>>>> C_B
>>>> d&d
>>>> programmtically.
>>>> <?xml version="1.0" encoding="UTF-8"?>
>>>> upperBound="-1"
>>>> </eClassifiers>
>>>> lowerBound="1"
>>>> lowerBound="1"
>>>> </eClassifiers>
>>>> </eClassifiers>
>>>> abstract="true"/>
>>>> </ecore:EPackage>
>>>> Input:
Re: Programmatically drag and drop [message #93358 is a reply to message #93320] Tue, 16 January 2007 11:30 Go to previous messageGo to next message
I think all container elements are cononical, because they are generated by
GMF. I've put a break point in the shouldHandleNotificationEvent method, but
it seems that it always returns true. I also tried to refresh the diagram
elements manually, but it also doesn't work. Are you sure that the
MoveRequest is the right request? AFAIU "REQ_MOVE" means moving children in
the same parent container, but I want to "deparent" them and add them to an
other parent. On the other hand, the underlying data structure gets
correctly updated, so MoveRequest could be right.
I have to admit I am a little frustrated at the moment. I would really
appriciate more hints to a solution. Thanks.
J
Re: Programmatically drag and drop [message #93713 is a reply to message #93358] Wed, 17 January 2007 14:05 Go to previous messageGo to next message
Jörg,
This seems to work fine in the Taipan Example -- you can move small and
large items from one ship to another. I would suggest looking to see
how it is accomplished here.
Cherie
> Cheers,
> Jörg
> news:pan.2007.01.16.16.05.17.340180@uwaterloo.ca...
>> return true;
>> -vlad
>>> try {
>>> Cheers,
>>> Jörg
>>>> Thanks,
>>>> diagram
>>>> diagram?
>>>> Cheers,
>>>> Jörg
>>>>> a
>>>>> -vlad
>>>>>> Hi everybody,
>>>>>> itself,
>>>>>> have a
>>>>>> and
>>>>>> that
>>>>>> C_B
>>>>>> not
>>>>>> a
>>>>>> d&d
>>>>>> programmtically.
>>>>>> nsPrefix="cmpnt">
>>>>>> upperBound="-1"
>>>>>> </eClassifiers>
>>>>>> lowerBound="1"
>>>>>> lowerBound="1"
>>>>>> </eClassifiers>
>>>>>> </eClassifiers>
>>>>>> abstract="true"/>
>>>>>> </ecore:EPackage>
>>>>>> Input:
Re: Programmatically drag and drop [message #93743 is a reply to message #93358] Wed, 17 January 2007 14:54 Go to previous messageGo to next message
If the model gets updated, the problem lies with the canonical policies.
Try the following experiment, try first to move programmatically one child
from one parent to another.
Then try to add a child through the user interface. Will this trigger an
update for your programmatic action? If it does, the policy doesn't
refresh when you make your change programmatically.
Another check to see whether it's the CanonicalPolicy's fault is to
breakpoint
protected List getSemanticChildrenList(); in the modified containers.
vlad
> Cheers,
> Jörg
>> return true;
>> -vlad
>>> try {
>>> Cheers,
>>> Jörg
>>>> Thanks,
>>>> diagram
>>>> diagram?
>>>> Cheers,
>>>> Jörg
>>>>> a
>>>>> -vlad
>>>>>> Hi everybody,
>>>>>> itself,
>>>>>> have a
>>>>>> and
>>>>>> that
>>>>>> C_B
>>>>>> not
>>>>>> a
>>>>>> d&d
>>>>>> programmtically.
>>>>>> nsPrefix="cmpnt">
>>>>>> upperBound="-1"
>>>>>> </eClassifiers>
>>>>>> lowerBound="1"
>>>>>> lowerBound="1"
>>>>>> </eClassifiers>
>>>>>> </eClassifiers>
>>>>>> abstract="true"/>
>>>>>> </ecore:EPackage>
>>>>>> Input:
Re: Programmatically drag and drop [message #99673 is a reply to message #93713] Wed, 31 January 2007 11:23 Go to previous message
Thanks for your help Vlad and Cherie,
as it seems my problem lies deeper. I wanted to trigger a move which was ok
in the domain model but was not specified in the gmfmap model. After the
execution of my command the view was corrupted. I think I will have to
modify my gmfmap model.
J
Previous Topic:@Override directive: Eclipse bug or reference error ?
Next Topic:programmatically add an element and links
Current Time: Sun Nov 02 16:44:46 EST 2025
Powered by FUDForum. Page generated in 0.07105 seconds
