discriminator type [message #92698] |
Tue, 07 August 2007 18:52  |
Hi All,
I've looked around, but not been able to find this answer: Can I turn off
the discriminator type in the database? I'm working against a pre-existing
schema so I'm not able to have the dtype column. If I remove it, what
problems would I be causing?
Jason
Re: discriminator type [message #92715 is a reply to message #92698] |
Wed, 08 August 2007 05:21  |
Hi Jason,
The discriminator column is required in case of single table inheritance mapping strategy. This
because Hibernate needs to know type of object is stored in a specific record in the db.
In case of inheritance strategy joined then no discriminator column is added.
You can either set the inheritance mapping strategy globally (see the options) or use an Inheritance
annotation.
gr. Martin
Jason Henriksen wrote:
> Hi All,
> Jason
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: discriminator type [message #609431 is a reply to message #92698] |
Hi Jason,
annotation.
gr. Martin
> Hi All,
> Jason
The Netherlands
FUDForum. Page generated in 0.28270 seconds
