Home » Eclipse Projects » Virgo » change virgo to use aries instead of gemini
change virgo to use aries instead of gemini [message #917908] Thu, 20 September 2012 10:56 Go to next message
Is is possible to change virgo to use aries instead of gemini blueprint ?
The problem is that I am trying to run apache camel on the new virgo 3.5.0 and this fails because the move from spring-dm to gemini blueprint.
Camel has support for blueprint but only for aries, not gemini.
Re: change virgo to use aries instead of gemini [message #926104 is a reply to message #917908] Fri, 28 September 2012 05:56 Go to previous message
I once spent a long coffee break at JAX London with some Aries committers trying to get Aries running under Virgo and we didn't manage to crack it, so I suspect it would take quite a bit of work.
Note that Gemini Blueprint is a superset of Spring DM 2.0 function, so if Camel used to work with Spring DM, then it might be possible to get it working with Gemini Blueprint via the Spring DM support in Gemini Blueprint. It doesn't sound hopeful though.
I wonder what Camel does to tie itself to the Aries implementation of Blueprint?
Previous Topic:Virgo Tools 3.5.0 Released
Next Topic:Eclipse Virgo's auto deploy takes long time when many files
Current Time: Sun Jul 20 14:15:03 EDT 2025
Powered by FUDForum. Page generated in 0.03005 seconds
