Home » Eclipse Projects » Virgo » Autowiring services >1 deep(Having problems wiring a chain of services)
Autowiring services >1 deep [message #924232] Wed, 26 September 2012 12:33 Go to next message
Hi, all -
I have a Spring question for you.
I have three services: web, business, and data. Business and data both export services to Virgo. What I would like is for web to reference the business service and for business to reference the data service, so my chain looks like this:
(user) -> web -> business -> data -> (database)
The data and business services are properly exposed using osgi:service tags and they are referenced properly using osgi:reference tags from the business and web services, respectively.
I am using Spring Autowired to inject the services into my various classes, so the WebController class looks like this:
public class WebController {
    @Autowired
    private BusInterface bus;
and the business class looks like this:
public class BusImpl implements BusInterface {
	@Autowired
	private DataInterface data;
So, now the problem. The business service is properly autowired into the WebController class, but that business service instance has not been properly autowired with the data service - so data is null in the above BusImpl class.
I can autowire both business and data services directly into the web bundle, so I know they're both working properly, but it's like the autowiring fails when I have a chain of services > 1 deep.
[Update]
Any services I autowire in business are null when the business service is autowired into web, including org.osgi.framework.BundleContext.
But if I autowire the BundleContext in web and pass the BundleContext to the business service, the business service can then get the data service:
ServiceReference<DataInterface> ref = context.getServiceReference(DataInterface.class);
DataInterface data = context.getService(ref);
// Now data is not null
This makes me think that there are no classloader issues here, but a Spring autowiring problem ...
Any ideas about how I can address this?
Thanks so much for the help -
Justin
P.S. I have a running example, if needed.
[Updated on: Wed, 26 September 2012 16:11] by Moderator
Re: Autowiring services >1 deep [message #926091 is a reply to message #924232] Fri, 28 September 2012 05:45 Go to previous messageGo to next message
Did you configure annotations in the middle tier bundle? See: http://static.springsource.org/spring/docs/3.0.x/spring-framework-reference/html/beans.html#beans-annotation-config
Re: Autowiring services >1 deep [message #926381 is a reply to message #926091] Fri, 28 September 2012 11:59 Go to previous messageGo to next message
Thanks, Glyn - I've gotten it to work using a combination of steps, though I'm not sure all of them are necessary or desired. I've been on a project using different technologies for a few years, so I'm rusty. Anyway, I've added this to the module-context.xml:
<context:load-time-weaver aspectj-weaving="on"/>
<context:spring-configured />
<context:annotation-config />
<context:component-scan base-package="userviceproto.bus" />
And then added the @Configurable annotation to my classes that contain autowired fields.
I wonder if any of these are undesirable as it seems overkill for this issue.
Thanks.
Justin
Re: Autowiring services >1 deep [message #929084 is a reply to message #926381] Mon, 01 October 2012 03:54 Go to previous message
I was hoping that the annotation-config element would suffice, but I'm no expert.
Previous Topic:ClassNotFoundException: org.springframework.context.config.ContextNamespaceHandler
Next Topic:Spring Web Services & Virgo 3.0.x
Current Time: Sat Jul 19 13:46:40 EDT 2025
Powered by FUDForum. Page generated in 0.09153 seconds
