Home » Eclipse Projects » EGit / JGit » rebase fails: "cannot delete file"
rebase fails: "cannot delete file" [message #912561] Thu, 13 September 2012 15:18 Go to next message
I have a large (more than 100 modified files) commit I am trying to rebase to a more current parent commit. If the new parent commit consists of only small, non-conflicting changes, the rebase has no problem. But if the new parent commit is larger and conflicts with my commit (on the order of 20 conflicting files), the rebase always fails. The error dialog usually says something like this:
Checkout conflict with file: Cannot delete file: C:\Users\Brian\dev\Workspaces\dali-master-3\webtools.dali\common\plugins\org.eclipse.jpt.common.utility\src\org\eclipse\jpt\common\utility\internal\ArrayTools.java
I am also unable to merge the commits using EGit.
I can use TortoiseGit to perform the rebase and resolve the conflicts outside the Eclipse workspace without a problem.
Is this a bug? I did not see one like it on Bugzilla. Is there a workaround?
Thanks.
Re: rebase fails: "cannot delete file" [message #925291 is a reply to message #912561] Thu, 27 September 2012 11:20 Go to previous messageGo to next message
Which EGit version are you using ? Are files reported in this conflict error message
deleted in one of the involved commits ?
Re: rebase fails: "cannot delete file" [message #925407 is a reply to message #925291] Thu, 27 September 2012 13:35 Go to previous messageGo to next message
Matthias Sohn wrote on Thu, 27 September 2012 11:20
EGit 2.0.0
Yes, the file reported in the error message (ArrayTools.java in this case) is to be deleted by the commit I am trying to rebase.
Re: rebase fails: "cannot delete file" [message #925532 is a reply to message #925407] Thu, 27 September 2012 16:29 Go to previous messageGo to next message
Could you retry the same scenario with EGit 2.1 which I released yesterday ?
Re: rebase fails: "cannot delete file" [message #930259 is a reply to message #912561] Tue, 02 October 2012 02:43 Go to previous messageGo to next message
Long Path Tool helped me in this situation. PathTooDeep.com
Re: rebase fails: "cannot delete file" [message #940480 is a reply to message #925532] Thu, 11 October 2012 13:19 Go to previous message
Matthias Sohn wrote on Thu, 27 September 2012 16:29
I have moved to EGit 2.1 (on Eclipse 3.8.1) and this large commit no longer has problems with rebasing. The commits from origin on top of which I am rebasing are not as large and "conflicted" with my commit as the earlier, problematic, commit; but it does seem like my problem is fixed.
Previous Topic:EGit does not honor ~/.hushlogin
Next Topic:How to clone or checkout a specific branch ?
Current Time: Sun Jul 20 16:03:06 EDT 2025
Powered by FUDForum. Page generated in 0.08502 seconds
